TANCHJIM SPACE II Portable Headphone DAC Amplifier
The Tanchjim SPACE II is a portable USB DAC and headphone amplifier featuring dual CS43131 conversion, designed to improve audio playback from a computer or mobile device. It combines a 3.5 mm single-ended output compatible with earphones equipped with a microphone and a 4.4 mm balanced output capable of delivering up to 235 mW into 32 Ω.
Reference : 22383
79,00 €tax incl.
65,83 € tax excl.
Shipping date: 25-11-2026.
TANCHJIM SPACE II Portable Headphone DAC Amplifier 2xCS43131 32bit 384kHz
TANCHJIM SPACE II: Front view
The Tanchjim SPACE II is a portable USB DAC and headphone amplifier featuring dual CS43131 conversion, designed to improve audio playback from a computer or mobile device. It combines a 3.5mm single-ended output compatible with earphones equipped with a microphone and a 4.4mm balanced output capable of delivering up to 235mW into 32Ω.
Intended for both on-the-go use and desktop setups, it integrates the "PureBridge" USB interface, DSP management and UAC 1.0 / UAC 2.0 compatibility, allowing playback of streams up to PCM 32bit / 384kHz and DSD256. This architecture combines connection versatility, sound rendering adjustment and power for different types of headphones or earphones.
Tanchjim SPACE II: 3.5 mm and 4.4 mm outputs
The SPACE II features a 3.5mm single-ended jack output, compatible with common earphones and headphones as well as models equipped with a microphone, and a 4.4 mm balanced jack output intended for cables with matching connectors. The latter delivers up to 4 Vrms and a maximum output power of 235mW into 32Ω, allowing it to power earphones as well as more demanding headphones.
TANCHJIM SPACE II: 3.5mm and 4.4mm jack output
Tanchjim SPACE II: Tanchjim "PureBridge" USB interface
The Tanchjim "PureBridge" USB interface processes the digital signal before it is routed to the conversion stage. This architecture separates the functions of USB reception, clock management and conversion, in order to limit interactions between the different stages and ensure stable transmission from a computer or mobile device.
TANCHJIM SPACE II: PureBridge interface
TANCHJIM SPACE II: Dual CS43131 DAC chip
Tanchjim SPACE II: Dual CS43131 DAC architecture
The SPACE II relies on two Cirrus Logic CS43131 converters, assigned separately to the left and right channels in order to maintain a balanced conversion architecture. Measurements show reduced distortion, a high signal-to-noise ratio, good dynamics and a low noise level, which allows detailed rendering to be maintained with sensitive earphones as well as with higher-end headphones.
Tanchjim SPACE II: Sound profiles
The Tanchjim app allows different sound profiles to be applied, from official or community settings. These presets adapt the SPACE II's response to different earphones, headphones or listening preferences, while also allowing a selection according to music genre or the type of content played.
Tanchjim SPACE II: UAC 1.0 and UAC 2.0 compatibility
The SPACE II supports the USB Audio Class UAC 1.0 and UAC 2.0 modes, which broadens its compatibility with smartphones, tablets, computers and game consoles. UAC 2.0 mode allows playback of streams up to PCM 32bit / 384kHz and DSD256, while UAC 1.0 mode facilitates use with devices that do not support high-resolution audio.
Technical specifications
Product typePortable headphone / DAC amplifier
Inputs1x USB-C
Outputs1x Jack 3.5mm
1x Jack 4.4mm
DAC chips2x CS43131
USB interfacePureBridge
Output power235mW @ 32Ω
Output levelJack 3.5mm : 2Vrms
Jack 4.4mm : 4Vrms
Dynamic range132.2dB
THD+N0.000156%
SINAD116dB
Compatible impedance8-300Ω
UAC mode1.0
2.0
Dimensions42 x 21 x 12mm
Weight15.1g
Package1x Tanchjim SPACE II
1x USB-C cable
1x USB-C to USB-A adapter
OutputJack 4.4mm
OutputJack 3.5mm
DAC / ADC ChipCS43131
Max sampling rate384kHz
The Tanchjim SPACE II is a portable USB DAC and headphone amplifier featuring dual CS43131 conversion, designed to improve audio playback from a...
