AUDIOPHONICS HPA-S400NC Power Amplifier Class D Stereo NCore NC400 2x400W 4 Ohm
Audiophonics PA-S400NC Stereo Class D Amplifier 2x400W 4 Ohm NCore
10%
This block constitutes an amplification solution with a formidable reserve of power (up to 400W / channel) while fully respecting the amplified signal. It is ideally suited for large listenning rooms and for studio applications requiring considerable headroom without compromising on precision at intermediate volume.
Reduced price!
Reference : 14154
Limited special offer
1 690,00 €tax incl.
-10%
1 521,00 €tax incl.
1 267,50 € tax excl.
Last items in stock !
Shipping date: 25-04-2024.
Shipping from France
Billing in France
Technical support in France
Audiophonics HPA-S400NC
Class D amplifier Stereo NCore NC400 2x400W 4 Ohm
Audiophonics HPA-S400NC Amplificateur stéréo class D NCore 2x400W 4 Ohm
We are proud to present the HPA-S400NC, a stereo amplifier based on a duo of amplification modules NC400 with their dedicated power supply SMPS600N400. This block constitutes an amplification solution with a formidable reserve of power (up to 400W / channel) while fully respecting the amplified signal. It is ideally suited for large listenning rooms and for studio applications requiring considerable headroom without compromising on precision at intermediate volume.
The modules are integrated in a sober and robust 100% aluminum housing with heat sinks. The latter has a simple design and excellent ability to block interference while effectively dissipating heat.
Two NCORE NC400 Amplification modules
Each channel is amplified by its own Hypex NC400 amplification module. This class D module provides large power while meeting high fidelity standard (power up to 400W & THD 1% with a load 4Ω)
The circuit is designed so that the signal flows only in a path of discrete component. This helps prevent the uptake of noise from the protection & control system from the onboard microprocessor.
With its current capacity of 22A and its low output impedance (Typ: 0.6 / Max 2.5 ohm), this amplification module is ideal for projects requiring high power without altering or compromising the audio precision.
Two SMPS Hypex SMPS600N400
Each amplification module has its own power supply circuit with two Hypex switched-mode power supply SMPS600N400 modules. This model has been specially designed to get the best performance of NC400 modules. These switching power supplies offer the advantage of reduced weight (300g) and a very low emission of EMI disturbances. A wide buffer stage composed of electrolytic capacitors ensures excellent responsiveness, ideal for developing the whole amplifier's dynamic.
The circuit is equipped with an advanced protection against overcharging. The latter can automatically lower the output voltage in case of overload. This will delay the arrival of hiccups - or even cancel them altogether if the overload is short-lasting.
A 3.150A fuse delay is mounted on the power connector.
Connectors
Audiophonics HPA-S400NC Amplificateur Stéréo Class 2x400W 4 Ohm
Each amplification channel in HPA-S400NC has an input on an RCA connector and an input on 3-pole XLR connector.
A bipolar selector is used to switch quickly from one input to another independently for each amplification module, this is a real source selector since each connector has its own mass, the amplifier allows two preamplifiers to be connected at the same time as well as changing from one configuration to another immediately and without "thumps" or parasitic noises.
The rear panel uses RCA connectors ELECAUDIO ER-106 gold-plated 24K and Neutrik NC3FAH2 connectors.
As a stereo output, the amplifier has two 24k gold-plated ELECAUDIO BP-209 speaker terminals. They can support conductors up to ⌀4.4mm and can operate with bare wires, banana plugs and spades.
Two Trigger connectors are also available, allowing to automate the ignition of the device upon reception of a signal from another device, or to automatically turn on another device upon ignition.
This amplifier's trigger needs to be used with a mono trigger cable (sold separately).
TechnologyNCore
Type amplificationClass D
Power / channel2Ω, 1kHz, THD = 1%: 580W
4Ω, 1kHz, THD = 1%: 400W
8Ω, 1kHz, THD = 1%: 200W
Channels2 (Double mono)
Audio inputsRCA
XLR 3-pin
Audio outputSpeaker terminals
Trigger1x Input
1x Output
Operational amplifierDiscreet
Frequency response0 / -3dB, 0-50kHz
Input sensivityXLR : 2.05V
RCA : 4.1V
Framesand-blasted aluminum
Dimensions413 x 322 x 60mm
Power supplyAC 110 / 230V (Automatic switch of internal power supply)
standby power28W
Weight5kg
Package Contents
HPA-Amplifier S400NCx1
Angled power chord (3x1.5mm² section)x1
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
Amplifier chipHypex Ncore
Power (W)400.0
4 reviews
Branché sur AUDIO-GD R-28 et Martin Logan Ascent
Reçu 24h chrono après paiement. Les fourches des câbles d'enceinte ne passent pas complètement, mieux vaut des bananes, Cet ampli a remplacé un Audiolab à transistors (8000P). Le résultat est bien meilleur, surtout au niveau de l'image stéréo, les plans sonores sont circonscrits entre les enceintes et derrière le plan des haut-parleurs (impression d'une écoute monitoring). L'image est beaucoup mieux centrée, avec une continuité entre les instruments (au lieu de points polarisés). L'impression d'avoir un écran panoramique devant soi, avec une grande profondeur d'image.
Le son est très dynamique, dès les faibles volumes. Pas besoin d'écouter fort.
Les timbres des instruments sont très riches, je redécouvre certains disques (Ragtime de Fabrice Eulry). Et les voix sont incroyables (Sicilien de Roberto Alagna). Même sur des disques de hardrock, je redécouvre des détails et des prises de sons incroyables (Roots de Sepultura).
Très naturel au niveau du rendu, dans le grave comme dans l'aigue.
Je recommande !
This review has been posted for AUDIOPHONICS HPA-S400NC Power Amplifier Class D Stereo NCore NC400 2x400W 4 Ohm
Matériel incroyable
Ce matériel est d une précision chirurgicale avec un SNR si bas qu à très faible comme à très fort niveau d écoute la qualité de restitution est incroyable sur toute la largeur du spectre, sans aucune distorsion même à 200 watts sous 8 ohms.
Il ne faiblira jamais, il donnera toujours le meilleur, même avec les enceintes les plus exigeantes.
La qualité d assemblage est magnifique dans un boitier cossu et des connectiques haut de gamme.
Cet ampli est un cadeau à ce tarif,
Il ne faudra pas oublier de consulter les mesures de ce petit bijou sur audio science review.
Merci à toute l équipe Audiophonics
 (3)
Brutal et transparent!
Livraison dans les temps et colis bien protégé. Honnêtement, la version avec nc122mp m'était largement suffisante(enceintes avec 93db de sensibilité, écoute à 2 m à 70db max) MAIS cette version avec hypex nc400 est la plus performante en terme de thd+n et de Sinad(hors module Purifi, 2 fois plus Cher et qu'à partir de 50 watts utilisés). Bref, cet ampli,conjugué avec un excellent Dac, est une Ferrari, qui pourrait pousser mes enceintes à 105 db(le bruit d'une discothèque) avec...
0, 15% de distortion(due à mes enceintes uniquement ! (0.0005% pour l'ampli).
Bref, la transparence absolue! Si ça sonne mal, c'est la source ou les enceintes qui posent problème.
Subjectivement, ce surplus de puissance se traduit sur mes enceintes par un son très dynamique, des aigus précis et des basses très propre et percutantes. On ne demande qu'à augmenter le son, signe que cet ampli est une réussite!
La version nc400 montée de manière professionelle et proposée ici par Audiophonics est TTC, Garantie 2 ans, est pour moi la moins chère en Union européenne(500 euros de moins en moyenne par rapport à Nord ou James Romeyn).
Chaudement recommandé!
 (7)
Excellent!
A remplacé très avantageusement un Atoll in200.
Très bon son, beau boitier, ne chauffe pas, prix correct. Qui dit mieux?
 (3)
This block constitutes an amplification solution with a formidable reserve of power (up to 400W / channel) while fully respecting the amplified...
