BURSON AUDIO TIMEKEEPER GT4 Power Amplifier
The Burson Audio Timekeeper GT4 is a pair of Class AB monoblocks designed to deliver stable and controlled amplification in demanding configurations. Each module delivers 200W into 4Ω, utilizing a power section with EXICON MOSFET transistors biased at high quiescent current to reduce distortion. The integrated power supply, provided by two dedicated Fusion Core blocks, allows for pure Class A operation up to 30W, offering increased linearity at typical listening levels.
By buying this product you get 499 loyalty points
Reference : 21521
4 999,00 €tax incl.
4 165,83 € tax excl.
Shipping date: 10-06-2026.
Burson Audio Timekeeper GT4 Class AB Dual Mono Power Amplifier 2x200W 4 Ohm
Burson Audio Timekeeper GT4 : Front view
Designed for high-fidelity systems requiring significant power reserves without sacrificing signal quality, this design combines Silent Power 2 modules for reduced background noise, a Class A buffer stage to ensure compatibility with any preamplifier or direct source, and a dual-mono architecture to ensure complete physical separation of the channels.
Burson Audio Timekeeper GT4: 200W amplification
The amplification section of the Timekeeper GT4 follows Burson's traditional philosophy: power, stability, and class AB. Each device is built around EXICON MOSFET transistors, operating at a high quiescent current to minimize distortion while delivering 200W of power. In addition, the Fusion Core power supply stage allows for pure Class A operation in the first 30 watts.
Burson Audio Timekeeper GT4 : Transistor
Burson Audio Timekeeper GT4 : silent power 2 modules
Burson Audio Timekeeper GT4: Silent power supply
Power supply is a key element in the architecture of the Timekeeper GT4. It incorporates Silent Power 2 modules, discrete regulators designed to ensure a particularly clean power supply. Their role is to drastically reduce the background noise generated by the regulation, allowing the analog stages to operate under optimal conditions. The result is a quieter power supply than that obtained with conventional modules, contributing to the stability and transparency of the audio signal.
Burson Audio Timekeeper GT4: Class A Buffer
The Timekeeper GT4 includes a pure Class A input buffer stage to prevent any incompatibility issues. When activated, it adds 6dB of gain to the input signal, ensuring perfect compatibility with any upstream device.
Burson Audio Timekeeper GT4 : Buffer
Product typePower amplifier
Inputs1x XLR
1x RCA
OutputBorniers enceinte
Input impedanceXLR : 200kΩ
RCA : 100kΩ
Frequency response20Hz-20kHz
Total harmonic distortion (THD)< 0.03% @ 1kHz
Output impedance< 0.015Ω
Output power200W @ 4Ω
100W @ 8Ω
Signal-to-noise ratio (SNR)110dB
BufferXLR : 12dB
RCA : 6dB
Gain29dB
DimensionTimekeeper GT4 : 255 x 270 x 70mm
Fusion Core : 210 x 200 x 75mm
WeightTimekeeper GT4 : 5kg
Fusion Core : 5kg
ColorSilver
Package2x Burson Audio Timekeeper GT4
2x Burson Audio Fusion Core
2x Power cables
InputXLR
OutputSpeaker terminal
ColorSilver
ChannelDual Mono
ClassClass A / AB
Amplifier chipTransistors
Power (W)200.0
BURSON AUDIO TIMEKEEPER GT4 Class AB Dual Mono Power Amplifier 2x200W 4 Ohm
The Burson Audio Timekeeper GT4 is a pair of Class AB monoblocks designed to deliver stable and controlled amplification in demanding...
