FANGSOUND SILENOS DAC R2R Balanced Class AB Headphone Amplifier
The FangSound Silenos is a small, versatile device that acts as a DAC, headphone amplifier, and preamplifier. Its digital-to-analog conversion stage consists of an R2R network of 192 complementary resistors to achieve clean rendering with sampling rates up to PCM 32-bit 768 kHz. Its amplification circuit is based on a balanced architecture that delivers high headphone amplification power while maintaining a pure signal.
By buying this product you get 56 loyalty points
Reference : 21342
569,00 €tax incl.
474,17 € tax excl.
Shipping date: 16-06-2026.
FangSound Silenos DAC R2R Balanced Class AB Headphone Amplifier 32bit 768 kHz
FangSound Silenos picture
The FangSound Silenos is a small, versatile device that acts as a DAC, headphone amplifier, and preamplifier. Its digital-to-analog conversion stage consists of an R2R network of 192 complementary resistors to achieve clean rendering with sampling rates up to PCM 32bit 768kHz. Its amplification circuit is based on a balanced architecture that delivers high headphone amplification power while maintaining a pure signal. It is capable of delivering up to 14W into 32Ω of output power, allowing it to drive a wide range of headphones and IEMs available on the market, including some with high impedance or planar magnetic technology. The unit is powered by a dual GaN switching power supply with up to 100W of power. In terms of connectivity, the FangSound Silenos is not to be outdone and will suit many Hi-Fi configurations, while its extremely compact form factor makes it an ideal desktop device.
FangSound Silenos: Complementary R2R DAC architecture
The FangSound Silenos incorporates a discrete complementary network of 192 resistors to improve signal processing performance and produce an analog-like sound that is appreciated by many users. It supports up to 32-bit 768kHz PCM and includes internal oversampling for more detailed and accurate sound reproduction.
FangSound Silenos DAC Architecture
The amplification power of the FangSound Silenos
FangSound Silenos: High-power balanced outputs
The Silenos' balanced headphone outputs are capable of delivering up to 14W + 14W of output power. This makes it a perfect match for high-impedance and/or low-sensitivity dynamic headphones or IEMs, as well as difficult-to-drive planar magnetic headphones.
FangSound Silenos: Dual GaN switching power supply
The GaN (gallium nitride) switching power supply delivers up to 100W of power and offers high efficiency, low EMI noise, and fast response. In other words, it provides reliable and stable power without noise interference, even under high loads.
Power supply for the FangSound Silenos
FengSound Silenos overview
1Power indicator
2Volume control potentiometer
3DAC indicator
44-pin XLR headphone output
5Balanced 4.4mm headphone jack output
6Single-ended 3.5mm headphone jack output
7Single-ended 6.35mm headphone jack output
8Balanced XLR input
9Gain adjustment (L/H)
10Power switch
11USB-C input
12100-240V AC power port
13Preamplified 4.4mm stereo jack output
Please note that when using the analog XLR input, ensure that the USB-C digital input is disconnected so that the Silenos can produce sound.
In addition, the 4.4mm preamplified output jack supports connection to XLR and RCA with active speakers or a power amplifier using a suitable adapter or cable.
Product typeDAC
Preamplifier
Headphone amplifier
DACR2R
Inputs1x USB-C
1x Balanced XLR
Outputs1x 3.5mm single-ended headphone jack output
1x 6.35mm single-ended headphone jack output
1x 4.4mm balanced headphone jack output
1x 4-pin balanced XLR headphone output
1x 4.4mm stereo preamplified jack output
Headphone amplification/preamplification specifications
Output power14W @ 32 ohms, 1W @ 600 ohms (10% THD+N, 1kHz)
11W @ 32 ohms, 0.6W @ 600 ohms (1% THD+N, 1kHz)
Output voltage25Vrms / 70Vpp (10% THD+N, 1kHz)
19Vrms / 54Vpp (1% THD+N, 1kHz)
Amplification typeClass AB
Dynamic range106dB
SNR106dB
THD+N0.002% (@ 16Vrms, 1kHz)
Gain settings2 Level : High and Low
R2R DAC section specifications
Supported sample ratesPCM up to 32bit 768kHz
ArchitectureComplementary R2R with oversampling support
Output voltage4Vrms
Dynamic range84dB
SNR84dB
THD+N< 0.1%
Power supply typeDual GaN switching, up to 100W
Power supply voltage100-240V AC
Dimensions16 x 18 x 4.5cm
Weight1.1kg
Package1x FengSound Silenos
1x USB-C cable
1x USB-A to USB-C cable
1x AC power cable
InputXLR
OutputJack 4.4mm
OutputJack 3.5mm
OutputJack 6.35mm
DAC / ADC ChipR2R LADDER DAC
Max sampling rate768kHz
ColorGray
ColorBrown
ClassClass A / AB
FANGSOUND SILENOS DAC R2R Balanced Class AB Headphone Amplifier 32bit 768 kHz
The FangSound Silenos is a small, versatile device that acts as a DAC, headphone amplifier, and preamplifier. Its digital-to-analog conversion...
