NOBSOUND NS-05P PRO Symmetrizer / Desymmetrizer RCA XLR
New
The Nobsound NS-05P PRO is a bidirectional audio balancer / unbalancer designed to convert unbalanced RCA audio signals into balanced XLR signals, as well as XLR signals into RCA. Thanks to its fully bidirectional design, it provides an ideal solution for easily integrating consumer HiFi equipment with professional audio gear such as DACs, audio interfaces, mixers, power amplifiers, active speakers, or studio monitors.
Reference : 21970
49,90 €tax incl.
41,58 € tax excl.
Shipping date: 24-06-2026.
Nobsound NS-05P PRO RCA XLR Symmetrizer / Desymmetrizer
Photo of the NOBSOUND NS-05P PRO
The NS-05P PRO uses a true balanced architecture enabling conversion from an unbalanced RCA signal to a balanced XLR output in order to effectively reduce electrical noise, hum, buzzing, and ground loop issues that can degrade sound quality. This design improves signal integrity, reduces interference, and delivers cleaner, more detailed, and more stable sound reproduction, especially over long audio cable runs. The device supports two distinct operating modes: RCA IN → XLR OUT and XLR IN → RCA OUT, with 0dB gain when converting RCA to XLR and 5dB gain when converting XLR to RCA.
The NS-05P PRO also benefits from a dual independent circuit design allowing both conversion paths to operate simultaneously without mutual interference. Each section features its own independent volume control, enabling precise output level adjustment and optimal matching between connected audio equipment. With a frequency response from 20Hz to 20kHz, extremely low harmonic distortion of only 0.00007%, THD+N of 0.008%, and a signal-to-noise ratio greater than 89dB, it ensures faithful and transparent audio transmission. Its particularly precise channel balance with a deviation lower than 0.01dB also ensures excellent soundstage stability.
Powered by 5V DC via USB Type-C, the NS-05P PRO features a robust compact aluminum chassis ensuring excellent protection against electromagnetic interference while offering an elegant and durable finish. Measuring 155 x 70 x 42 mm and weighing 420g, it integrates easily into a home HiFi, studio, or desktop setup.
Overview of the NOBSOUND NS-05P PRO
1XLR to RCA Volume
2Power Switch
3RCA to XLR Volume
4RCA to XLR Input/Output
5XLR to RCA Input/Output
65V DC Power Supply (1A)
7GND Connector
Technical Specifications
Product TypeSymmetrizer / Desymmetrizer
Input1x RCA
1x XLR
Output1x RCA
1x XLR
Operating ModesRCA IN→XLR OUT / XLR IN→RCA OUT
GainXLR→RCA: 5dB
RCA→XLR: 0dB
THD+N0.008%
THD0.00007%
SNR≥ 89dB
Channel Balance≤ 0.01dB
Frequency Response20Hz-20kHz
Input Impedance20kΩ
Output Impedance100Ω
RCA Output Level2Vrms (max)
Power Supply5V DC (≥1A) via USB-C
Dimensions155x70x42mm
Weight420g
Package Contents1x NOBSOUND NS-05P PRO
1x USB-A to USB-C Cable
InputXLR
ClassN/A
The Nobsound NS-05P PRO is a bidirectional audio balancer / unbalancer designed to convert unbalanced RCA audio signals into balanced XLR signals,...
