BERRYBAK BDSP2.4U DSP Preamplifier
The BerryBak BDSP2.4U is a DSP preamplifier based on an ADAU1701 architecture, designed to handle signal processing and distribution in compact multi-way configurations. It relies on a two-input, four mono RCA output topology, enabling 2.1 or 4.0 system implementations, while its front-panel adjustment interface allows direct tuning of the bass and mid-high bands to adapt the frequency response to the system.
Reference : 22084
54,90 €tax incl.
45,75 € tax excl.
Shipping date: 25-11-2026.
BerryBak BDSP2.4U 4-Channel DSP Preamplifier
BerryBak BDSP2.4U : Front view
BerryBak BDSP2.4U: A Versatile Device
The BDSP2.4U integrates five front-panel potentiometers, enabling independent adjustment of bass bandpass filtering and mid-high highpass filtering, allowing precise frequency distribution of the signal according to the system. This approach extends to a gain balance control between the bass and mid-high sections, enabling fine relative level adjustment and ensuring consistent, coherent reproduction. In addition, its two-input, four mono RCA output architecture structures signal routing, supporting 2.1 or 4.0 configurations with independent channel distribution.
BerryBak BDSP2.4U: ADAU1701 DSP
The BDSP2.4U also integrates a high-performance ADAU1701 DSP chip for audio signal processing, including a 10-band equaliser, delay management and crossover adjustment.
BerryBak BDSP2.4U : Miumax application
Once connected to the Wondom ICP5 programmer, you can write a programme using Sigma Studio, or achieve real-time control of your audio system via the PC user interface, through which gain, volume, highpass/lowpass filters, equaliser and other parameters can be adjusted.
MIUMAX Application
BerryBak BDSP2.4U: Aluminium Chassis
Designed for direct integration into varied configurations, the BDSP2.4U adopts an aluminium chassis whose structural rigidity ensures both reliability and passive thermal dissipation, while facilitating installation in space-constrained environments. This approach is complemented by USB Type-C power delivery at 5 V, simplifying setup without requiring a dedicated power solution.
BerryBak BDSP2.4U Overview
BerryBak BDSP2.4U : numbered diagram
1Line inputs
2Mid/treble outputs
3Bass outputs
4Mute function
5Phase adjustment
6Highpass filter adjustment for mid/treble outputs
7Lowpass filter adjustment for bass outputs
8Highpass filter adjustment for bass outputs
9Channel balance adjustment
10Volume adjustment
Product typePreamplifier
DSP
Number of channels4
Inputs2x RCA
Outputs4x RCA
Maximum input level0.9Vrms
Maximum output level0.9Vrms
Input impedance10kΩ
Total harmonic distortion plus noise (THD+N)0.009%
Power supply5V DC 1A
Weight330g
Dimensions90.81 x 156 x 27.31mm
ColourBlack
Package contents1x BerryBak BDSP2.4U
Max sampling rate48kHz
ClassN/A
BERRYBAK BDSP2.4U 4-Channel DSP Preamplifier
The BerryBak BDSP2.4U is a DSP preamplifier based on an ADAU1701 architecture, designed to handle signal processing and distribution in compact...
