Claude T.
Bonne config
L'ensemble
- Dual Mono MKII DAC ES9038Q2M.
- Transformer I/V étage passif.
- Monitor Pro contrôleur.
Apporte un plus...
Patrick B.
Bon remplaçant pour Dynaudio D-28 AF
Très bon rapport qualité prix, installer en remplacement de Dynaudio fait bien le travail.
Claude T.
Bonne config
L'ensemble
Apporte un plus...
Linear Power supply Module DC with heat slug LT1084 1.2V / 19.5V 2.5A - reviews - There are 6 reviews.
Rudolphe D.
Moyen
Regulateur monté lt1084 au lieu du lt1083 annoncé
Rob S.
Not as described, poor quality control, works once fixed
As of today (4 October 2020), this Audiophonics web item (Ref 11645) is described incorrectly. Of the two linear power supply modules I received in September, neither had an LT1083 regulator installed. They both came with an LT1084 small plastic format. Furthermore one of the regulators was not bolted flush with its heatsink, standing in free space 1.5mm away. Easily fixed, sure. But very poor quality control. As we are dealing with voltage and current (and sensitive, costly connected devices), please check your item carefully once it arrives. Enjoy!
Alessio V.
High quality power supply!!!
Very silent and stable power supply!!! Well made with high quality components!!!
Philippe J.
Parfait permet un réglage de tension de sortie.
Alimentation pour RPI ou Écran LCD Tactile depuis un an
Vidal J.
Ronflette supprimée
Parfait, mon Dac ne ronfle plus.
Alain D.
alimentation
Qualité des composants.
Tension après réglage très stable.
The LT1084 regulated DC linear power supply module has been designed to properly power an Amplifier or other continuous audio circuit.
