Rastislav K.
Nice
Marc A.
Un bon cable...
David m.
une super prise hifi
Customers reviews - There are 19554 reviews.
Joaquin T.
Excelent petit DAC Bluetooth
Fonctionne parfaitement avec une parfaite stabilité de connexion et un son qui me plaît.
Philippe A.
amélioration effective, sensation de propreté plus marquée dans le message sonore reproduit. utilisé en tète de multiprise. m'a permis de constater que la prise avec bouton de marche arrêt était en opposition de phase et que le bouton lui même ne coupait que la terre donc c'était dangereux et maintenant corrigé.
DIMITRIOS P.
AUNE X8 XVIII BT MAGIC DAC ES9038Q2M Bluetooth aptX HD LDAC 32bit 768kHz DSD512 Black The X8 XVIII BT Magic DAC from Aune is a special edition of the DAC, on the occasion of the 18th anniversary of the brand. This one takes back the idea of the interchangeable...
A hi fi device by all means
I have it only a week now but from the first moment it gave me the confidence and pleasure that only real hi fi devices do.Always on it runs cool, every input/ output works perfectly, usb driver a breeze, sound really better than my Burson conductor 3 reff wich cost me more than 4 times more and now returned to its box as a veteran (a war casualty.)
Anders H.
Really good product
I work with professional Broadcast equipment with AES/EBU input and with this product I now have a small battery operated media player with AES/EBU output. Very practical to have for testing and repairing equipment or just listening to music when You are working :-)
julien m.
FX-AUDIO 502E-L Class D Amplifier CS8673E Bluetooth 5.0 2x65W 4 Ohm Silver The FX-Audio 502E-L offers an efficient, compact and low-cost amplification solution. Taking advantage of a high-efficiency Class D architecture, its amplifier stage uses a...
rapport qualité /prix
Difficile de lui reprocher quelque chose à ce prix , un ampli simple et efficace drive honorablement des davis mia20
merci fx audio et surtout merci audiophonics
Alain S.
Fabuleux
Tout est déjà dit dans les commentaires précédent qui sont très juste par rapport au ressentit et plaisir procuré par ces petits bijoux ...
C'est un aller sans retour tous vos précédents intras (y compris très sensiblement plus onéreux ) vont vous paraitre fade et ... limite cassés ...
otto k.
TOPPING HS01 USB Isolator 32bit 768kHz DSD512 The Topping HS01 is a small, high speed, low latency (0.29µs) USB 2.0 isolator. It is compatible with high resolution streams up to 32bit 768kHz PCM and native DSD512 for...
USB Isolation
Ein schwieriges Unterfangen mit dem Topping HS01 Isolator .
War durch Inernet Recherche etwas vor gewarnt, zusätzlich muß man richtig nach Info suchen.
Er sollte die USB Verbindung Mac Mini zum DAC galvanisch auftrennen. Wie gesagt er sollte.
Mehrfach Versuche an anderen Apple Rechner liefen sehr sperrig und es blieb beim - er sollte.
Mein schon lange benutzter „großer“ Isolator von einer anderen Firma, stellte überall die Verbindungen/Erkennung des DAC her.
Mit freundlichen Grüßen
Guillaume B.
Vraiment un très bon câble
Je l'ai sélectionné pour son architecture et les matériaux utilisés.
Le résultat est une ouverture accru, une foultitude de détails qui se révèle pour le medium/aigue, une basse profonde et charnue et une dynamique bien ressentie le tout sans déséquilibre.
Très très bien!!
Guillaume B.
Remplace très avantageusement les HDMI HighSpeed de Mon....-C...e ainsi que Cinnamon de Au......st.
Je remplace tous mes HDMI par ces câbles 2.1 en cuivre OCC plaqué argent au résultat super!!
Achat sans aucun regret!!
Acheter ce câble pour remplacer en HP mes chord epic, j'en est monté un à la place de mes nordost red pour voir (fiche nordost ET câble RAMM) et là le choc !
Tout est mieux.
Du coup je remplace tout mes câbles par du RAMM 5
C'est un super mariage avec mon système (Moon 280 et Moon 340)
Merci audiophonics
Thomas H.
AUDIO-GD DI-20HE Digital Interface Amanero Accusilicon 32Bit / 384kHz The Audio-GD DI-20HE interface is based on an Amanero Combo 384 USB module coupled to a pair of Accusilicon 90/98M clocks. The circuit is designed to offer a plethora of options...
A gamechanger
Has improved my streaming sound to a very high level. Best one piece I've ever bought
denis L.
J ai enfin pris le temps de le câbler avec des fiches elecaudio red copper. Liaison entre pre out ampli yamaha home cinema et ampli de puissance atoll. Tout simplement excellent, détaillé mais très doux j ai enfin trouvé le bon! Bien meilleur que les câbles du commerce jusqu'à 100 euros. Et encore il n est pas rodé. Une véritable affaire à ce prix!!
AUDIOPHONICS DIGIPI+I2S Digital Interface WM8804G for Raspberry Pi SPDIF I2S TCXO This Audiophonics DigiPi+I2S interface expands the output connectivity of a Raspberry Pi, giving it an additional panel of digital audio outputs. It includes a Toslink optical...
Endpoint Roon HDMI LVDS super facile à faire
Super pette carte pour fabriquer facilement un endpoint Roon. Je l'alimente depuis la carte directement avec une alimentation 5V 6A.
Paolo C.
XDUOO XD05 BAL Portable Balanced Headphone Amplifier 2x ES9038Q2M XMOS Bluetooth 5.0 32bit 768kHz DSD512 Silver The xDuoo XD05 BAL is an enhanced version of the portable headphone amplifier XD05 PLUS. Its digital/analog conversion stage has been updated, its Bluetooth wireless...
Perfetto!!!
Spedizione velocissima, prodotto imballato perfettamente, ottimo venditore consigliato!!!
Markus H.
Best so far
Tried some Gold Lions, NOS ones but these are incredibly good. I read some say to harsh in highs, dominant highs ect but this is simply not the fact. Very detailed but still natural and soft. Ordered a spare set, period. Worth the price!
FX-AUDIO D502BT Amplifier FDA TAS5342A Subwoofer Output Bluetooth 5.0 2x60W 4 Ohm Black The FX-Audio D502BT is, as its name suggests, the successor to the D502. The D502BT takes over its base and components, but this time it comes with a Bluetooth 5.0 receiver,...
Homogéne
Alimente honorablement des enceintes 3 voies de 150 watt ( bc acoustique niger) . Utiliser uniquement en fonction bluethoot , j'ai rajouté des plots anti vibratoire vibrapod 1 ( en vente sur ce site ) qui ont améliorés l'épanouissement et la transparence de la scène sonore . Mérite un rodage avant jugement . Au début l 'aigu était agressif mais je me suis rendu compte que le problème provenait du câble secteur de mon lecteur cd ; preuve de transparence de cet ampli. Le son est équilibré et le suivi mélodique agréable ; écoute non agressive . Je regrette juste un léger manque de dynamique mais ce n'est pas frustrant pour autant . A volume moyen on obtient le meilleur résultat d'écoute mais il faut reconnaitre que vu la taille de l'ampli et le prix pour mes enceintes déjà conséquentes en taille ce n'est pas mal du tout . Content de cet achat .
Giovanni G.
top notch materials but not perfect
despite of the IEC version that is perfect, the schuko neotech is not so easy to connect with the power cable (other brands like furutech are better).. however the materials (OCC copper ) are fine
Giovanni G.
NEOTECH NC-P303RH IEC Connector IEC Rhodium plated UP-OCC Ø24mm Fiche secteur IEC femelle très haute performance, idéal pour la constitution d'un câble secteur Audiophile sans compromis. Les contacts sont en Cuivre...
high quality
this is a wonderful IEC connector with top notch quality of materials OCC copper rodium plated.. it's also easy to connect with the power cable
nicolas H.
NEOTECH DG-2075 Coaxial RCA Connector 75 Ohm Ø9mm This Neotech DG-2075 RCA connector is ideal for designing a high-quality 75Ω coaxial cable. The current is distributed evenly over the entire contact area. The cable...
montage compliqué
petit retour d'expérience sur cette fiche à sertir.
Pour les experts en montage avec sertissage avant tout...
Mon niveau est plutôt bon (plein de RCA et câbles d'enceintes à mon actif..) je me suis lancé confiant dans le projet d'un cable NEVD-2001 avec ces fiches DG-2075 (même pris une pince a sertir pour l'occasion) et bien mon montage n'a donné aucun son...
1er sertissage minuscule sur l'âme, qui faut emboiter à fond dans le rca puis sertir pour que ca ne bouge plus...3eme sertissage pour les blindages
Soit mauvais contact, soit erreur dans le montage... et impossible a démonter sans casser... bref j'ai tenté, j'ai perdu...je me rabat sur le Canare deja monté... je rejouerai peut être plus tard... (à 20€ la fiche..)
un mode op' clair en rapport à cette fiche serait peut être bienvenu sur la page
thierry E.
Bien mais c'est du 2.1
Belle finition, tout petit, Bluetooth marche très bien mais ... c'est du 2.1 il faut absolument un caisson de basse séparé sinon il n'y a pas de grave dans les sorties enceintes normales. Je n'avais pas saisi cela sur la notice.
Passive Preamplifier converter RCA to XLR / XLR to RCA Silver This passive stereo 10kΩ volume controller allows you to switch from balanced XLR to unbalanced RCA inputs and vice versa, from unbalanced RCA to balanced XLR. The two...
contrôleur passif pratique et très bien fabriqué
J'avais besoin de ce type d'appareil pour régler mes enceintes de monitoring. Ce petit contrôleur offre un signal parfait musicalement, aucune interférence, bref un appareil d'un prix plus que raisonnable qui correspond exactement à ce que je cherchais et qui rempli son rôle impeccablement.
Luc V.
Un super rapport qualité/prix
J'ai beaucoup testé de DACs ses derniers temps, notamment quasiment tous ceux à base d'AKM4499, (qui va devenir collector car plus produite par AKM, l'usine ayant brûlé). Et bien ce SMSL VMV D2 est la meilleure implémentation de cette puce que j'ai pu écouter/comparer: Le son est au top, avec un medium très charmeur rappelant les DACS R2R, des basses présentes et puissantes et un registre aiguë fin et délié, même si pas particulièrement mis en avant. Une très belle réussite car ils ont respecté la philosophie du "velvet sound" d'AKM. Ce DAC est peut être le meilleur de la lignée VMV, et pour moi largement supérieur aux DACs à base d'ESS sabre !
Edern A.
Excellent streamer avec un son magnifique
Après plusieurs heures d'écoute, voici mes impressions sur le Evo Sabre.
Tout d'abord, le montage de l'appareil est extrêmement simple et ne présente aucune difficulté car il est bien documenté (c'est juste dommage que le manuel ne soit pas fourni sous forme papier). L'installation d'une image système demande un peu plus de travail mais, grâce à l'aide rapide et bienveillante du SAV, c'est faisable également.
D'un point de vue esthétique et pratique, je trouve que l'appareil est une réussite. Il est compact et pratique. Son look, un peu high tech avec ses deux écrans, est vraiment agréable à l'oeil. C'est vraiment sympa de voir s'afficher le nom de l'artiste et du morceau ainsi que le temps des morceaux qui s'écoule.
La télécommande est pratique même si j'ai parfois l'impression qu'il y a un petit décalage entre le volume sonore affiché sur l'Evo et celui de Volumio.
En ce qui concerne le son maintenant :
Avant d'acheter l'Evo Sabre, j'utilisais un Raspberry 3b+ avec un dac Topping D10 raccordé en USB. J'ai remplacé ce setup par l'Evo Sabre. Dans un cas comme dans l'autre, je lis des fichiers FLAC stockés sur un disque dur externe et la partie logicielle est confiée à Volumio (plus simple à prendre en main et configurer que Moode).
L'Evo Sabre apporte un net gain par rapport au setup que j'utilisais auparavant ! Je prends plaisir à réécouter la musique en y découvrant de nombreux détails que je ne percevais pas. Le son est très bien défini, minutieux, avec une belle distinction entre les différents éléments qui composent les morceaux, que ce soient les instruments ou les chants. Autre aspect notable : les basses sont bien meilleures qu'avant. Elles sont fermes et profondes mais équilibrées, elles ne viennent pas écraser le reste.
En gros, la musique est plus nuancée, très bien étagée, très bien articulée, ce qui est sans doute à mettre au crédit du fonctionnement en double mono.
L'entrée Bluetooth produit également un excellent son. Sachant que ce n'est pas l'entrée la plus qualitative (la faute au faible débit de données du bluetooth), c'est une très agréable surprise d'entendre un son de bonne qualité en sortie.
Je n'ai pas essayé les autres entrées (coax, optique, etc.) mais j'imagine que le résultat est de la même trempe.
Je recommande vivement ce streamer qui a de nombreuses qualités, au premier rang desquelles un son vraiment excellent !
killian D.
JANTZEN AUDIO ELECAP Electrolytic Capacitor 100V 100µF 5% Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most...
Fait le travail
Très dubitatif au début a la vu de ce dernier car l'ancien chimique fait le double de sa taille mais grosse surprise j'ai enfin retrouvé mon grave avec de l'inpact un bonne équilibre et quand même une bonne précision pour un chimique.
killian D.
Bon
Bon condo en général en remplacement de MKT de même valeur.
Comparé aux mkt ces mkp apporte plus de présence, il ne sont pas en avant mais plus présent avec plus de détail mais je sent une légère accentuation des "SSSS" et "CHHH" la gamme au dessus sera peut etre mieux pour régler ce petit souci, souci qui s'oubli facilement car il faut vraiment etre exigent. (sur une paire d'elipson mélodine 7 avec un 2.2 et un 3.3uf) restre très bon pour ce prix.
Expédition rapide et bien emballer de la par d'audiophonics.
killian D.
Bon
killian D.
TOP
En remplacement d'un vieux chimique de même valeur sur des Elipson mélodine 7 le gain est vraiment incroyable (les ancien devais etre vraiment rincés) le médium était très en avant, maintenant tout est revenus a sa place donnant une impréssion d'enceinte neuve avec encore plus de spacialité. Vraiment top. (Livraison rapide et bonne embalage de la par d'audiophonics)
ALEXANDRE R.
Condensateur occasion ?
Fonctionne parfaitement , mais esthétiquement le condensateur fait peur.
Rayer, bosselé, il doit etre à sa seconde vie.
killian D.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 47µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
En remplacement d'un vieux chimique de même valeur le gain est vraiment frappent, ne connaissant pas spécialement la différence j'était dubitatif sur le gain réelle d'un passage de chimique a mkp et bien grande et heureuse supprise. (Attention a la taille, il est énorme au moin 4 fois plus gros que le chimique)
Jean-Marc B.
ALLO BOSS2 DAC CS43198 32bit 192kHz DSD64 with Black acrylic Case Allo proposes with the Boss2 an updated and improved version of its Boss DAC. The module now integrates a CS43198 digital/analog conversion chip, offering a very good THD level...
Benné le préampli
Très satisfait sur Volumio, après quelques galères.
Je n'ai plus besoin de préampli, et ça s'entend !
(bon, reste le pb du vinyle...)
La version alu décrite sur ASR a besoin d'être mise à la masse.
Qu'en est-il pour cette version ?
alan z.
A.Z.
Very good value. Very good sound.
Rapport qualité prix très bon, et le son aussi.
Very quick -service- très rapide.
Bravo.
Qualité remarquable
La plus chère en format IEC7 de ce site mais justifiée par sa qualité de fabrication . Extérieurement un fin revêtement caoutchouté bien intégré à la prise permet une meilleure isolation vibratoire . Intérieurement un lot de bagues est à clipser en fonction du diamètre de votre câble (plus pratique que les autres marques de ce site ) . Un son très équilibré et transparent sans agressivité . Recommandable.
Cyril G.
a éviter !!!
Le vrai problème, ce n'est pas la soudure mais la qualité globale due la fiche. Il y a du jeux, le cabochon ne tient pas et pour aller jusqu'au bout de la démarche, le détrompeur, tellement mal fait, est inefficace au point de pouvoir l'insérer décalée dans une 7 broches à 270°.
Comme les autres, je n'ai qu'un seul conseil; passez votre chemin et prenez du neutrik ou équivalent.
Donato p.
GUSTARD LINE-02 Cable HDMI 2.0 I2S OFC Copper Gold Plated 1.5m This HDMI 2.0 Gustard Line-02 cable allows to make I2S connections via HDMI on devices with this connectic. It benefits from a nice design, with OFC copper conductors and pure...
Gustard LINE-02 Cable HDMI 2.0 I2S OFC Copper Gold Plated 1.5m
Wonderful product of great value in every detail has met all my expectations. Connected to my DAC it gives great performance. Excellent value for money
Donato p.
Digital Interface HDMI / MHL to I2S / Coaxial / Optical
Connecting it to the Sony Universal Player the dual HDMI outputs (HDMI Video goes to my receiver 4k HDR Ultra HD) - (HDMI Audio feeds the I2S digital interface HDMI). True DSD Stereo playback works wonderfully
BENOIT D.
OCTAVIO STREAM Streamer Bit-Perfect WiFi AirPlay 2 Bluetooth 24bit 192kHz Octavio offers with the Stream an improved version of its first streamer model. Extremely easy to use, it is designed to modernize an existing HiFi system by transforming it...
Super pour moi !
J'ai longtemps hésité ! je me demandais si cette petite boite répondrait à mes attentes qui sont très simples : lire les contenus du service Qobuz ,auquel je suis abonné, sans me ruiner. Bingo, c'est impeccable ! Connexion wifi sans problème + rj45 sur botier CPL, hyper simple. L'application Octavio Virtuose est très conviviale et claire, même si elle n'est pas aussi riche que celle de Qobuz.
Le boitier est connecté directement en RCA sur mon ampli Rega ElexR. Je fais quelques économies pour pouvoir me payer un DAC qui sera placé entre les deux. Mais la qualité est déjà très bonne sans.
Audiophonics au top pour la livraison.
Jacques S.
Fiabilité à revoir
Petit ampli par la taille mais grandes capacités musicales : puissance et clarté.
Hélas la fiabilité n'est pas parfaite, la sortie casque de mon précédent exemplaire n'a tenu qu'un peu plus de deux ans. Juste le temps de la garantie...
Geert M.
keep clear from signal wires
I have this Supra AC sensor device to measure if an AC cable or device radiates an electric field. These Viborg plugs radiate almost the same as a freeby cable. On a good isolated cable I measure nothing from end to end.
Ralph S.
Great Amp, But Unreliable
Technically this is a great amp. Unfortunately after 4 weeks mine started to emit pop sounds. Eventually after a very loud pop one channel did shut down until i turned it on off. Did send it back hoping for a refund.
Pascal C.
Confirmation
Je confirme tous les compliments et éloges des avis précédents.
On a beaucoup pour pas grand chose.
Albert H.
DD BC120A Balanced Headphone Cable Jack 2.5mm to MMCX OCC Copper 1.2m The BC120A is a high quality balanced headphone cable. It is composed of two MMCX connectors and one 2.5mm jack connector. It integrates four high purity (> 99.9999%) 6N OCC...
Très bon!
Ayant un Astell & Kern et l’excellent casque ATH-MSR7b vendu aussi par audiophonics, et ne trouvant plus sur le marché le câble avec connexion propriétaire Audio Technica j’ai trouvé cette solution avec l’adaptateur A2DC/ MMCX pour bénéficier de la sortie symétrique. Le résultat est époustouflant je recommande cette alternative à 100% ce câble est excellent, après un petit rodage la puissance, la précision instrumentale et la spatialisation est bien meilleure. Attention quand même car après on devient vite addictif!
Albert H.
MMCX Female to A2DC Male Gold Plated Adapters (Pair) These headphone and earphone adapters have a female MMCX connector on one side and a male A2DC connector on the other. Their contacts are gold plated, ensuring both good...
Excellent produit!
J’ai pris cette solution car les câbles pour relier mon Astell&Kern et casque ATH-MSR7b + le câble - DD BC120A est simplement introuvable, je ne passe évidemment pas par les sites peu recommandables .
Pas de pertes car l’adaptateur est parfaitement ajuster au casque et au câble!
Je suis très satisfait du look et du son!
Un sans faute.
Andrew T.
Wonderful clarity, energy and musicicality
Formidable!
RQP IMBATTABLE
Je fais la même analyse que le commentaire précédent.
Cette gamme 501 pur cuivre plaquée or/ argent fonctionne à merveille.
Associez les prises shuko et IEC à l’excellent câble secteur Elecaudio CS361B et vous obtiendrez un résultat incroyable.
Après 30 heures environ de mise sous tension (rodage) cet ensemble révélera tout son potentiel.
Des basses percutantes, un aigüe fin et détaillé sans agressivité. Mais le top c’est le registre des médiums. Je n’ai jamais entendu autant de présence et de définition
Bref, c’est une vraie bombe et pour un coup dérisoire.
Essayez c’est l’adopter.
Je revends tous mes câbles à 4 chiffres si ça vous intéresse ?
Christian R.
Contrepointes Audio Bastion
Jamais déçu avec Audiophonics qui a décidé de distribuer cette marque américaine il suffit d'ailleurs de se rendre sur le site de Audio Bastion pour connaitre cette marque et découvrir leurs produits. Meubles ou rack hifi très haut de gamme très beaux et une gamme d'accessoires . La marque semble très connue des audiophiles et des salons dédiés. Je voulais des contrepointes plus larges pour mon meuble mission accomplie très beau produit livré par 4 , pas ultra couteux au final et vraiment de très grande qualité à la fabrication irréprochable la bague en silicone doit avoir un vrai rôle est ce que cela est miraculeux ? non bien sûr m'étant laissé guidé par des photos de mise en application réelle de ce produit quand on voit ce qu'il y dans les meubles et à coté et vu le prix du produit y a pas à se poser de question.... Excellent
Andrew P.
KHOZMO ACOUSTIC Relay Volume Attenuator 10k 64 Steps MBB Switching Vishay Quad Channel With this product, Khozmo offers a very high-end relay ladder volume attenuator with incredible audio performance. This is based on Omron HQ relays rather than mobile contacts...
Attenuator with relays
Very attractive on the outside the red anodized casing.
It works by adding various resistors in the signal path to get the proper value for the voltage divider.
The resistors are 1% smd metal film but the color marking does not correspond to VIshay. The Omron logo is not visible on the relays.
The first section sounds worse, from step 30 there is an audible change and the response is somewhat better. Audio performance is modest when compared to an Elma A 47 smd for example.
The flat cable connectors do not fit very well and if the mounting is not vertical they can come off when moving the equipment.
The worst thing, without a doubt, is the remote with little range and with random failures, even with new batteries, sometimes you have to press the same command 2 or 3 times to get a response.
In my opinion a bit expensive for what it offers.
Audiophonics customer service as always top notch.
Marc C.
Absolument superbe !
Attendu des semaines mais Audiophonics n'y est pour rien... Il est arrivé il y a 2 jours et je ne le quitte plus.
Je suis pas d'accord avec le commentaire précédent pour lequel les basses sont trop présentes. Loin s'en faut elles sont très basses, concises et précises, jamais agressives et baveuses et pourtant mon écoute des basses sur des casques comme le H800S ou le Sony MR-Z1R est plus qu'aboutie !
Non seulement les registres sont bien là mais la dynamique et la spatialisation sont présentes et bluffantes pour un "petit" casque (qui a tout l'air d'un grand).
Les aigus peuvent déranger car très hauts au départ mais après une quinzaine d'heures de chauffe, cela disparait.
Ah oui j'écoute avec le câble symétrique en 4.4 de Meze, ce qui fait nettement la différence d'avec le câble asymétrique d'origine sur un Fiio M15.
Vraiment un très grand produit de Meze à "petit" prix pour en ce qui me concerne une utilisation nomade car vraiment confortable. Félicitations à Meze et à Audiophonics pour le sérieux.
surprenant et efficace
monté sur une boc upc et un modem wifi upc. j ai gardé les alim a découpage d origine car les remplacer aurais couté cher. Deux de ses petit purifier ont eu d excellent résultats .image plus dynamique précise et le bruit a bc reculé. Le son que je récupère sur un bloc HDMI extracteur audio a gagner en précision dynamique et clarté, grave plus propre et ample.. l autre monté sur le modem a apporté les mêmes résultats avec une bande passante plus large vus les améliorations d écoute sur mon streamer.. pour le prix sais du bon rqp. conseillé vivement avant l achet d alimentations dédiées .
Marc P.
MEAN WELL RS-100-24 Switching Power Supply SMPS 100W 24V 4.5A This switching power supply from Mean Well offers a power of 108W, a voltage of 24V DC and a current of 4.5A. With a universal connection system, it will fit easily into a...
MEAN WELL RS-100-24 Module d'Alimentation à Découpage SMPS 100W 24V 4.5A
Bonjour résidant en Martinique , commande passée le 25/04/22 reçue le 29/04/22 , rapidité éffacité , je recommande cette sociéte merci
Joel D.
Rendu sonore moyen.
L'essai de ces HP est décevant. J'espérai un rendu audio bien meilleur au vu de la bande passante annoncée.
