Gianfranco P.
crystalline
Alexandre G.
Thierry C.
Customers reviews - There are 19513 reviews.
Laurent F.
PANGEA PREMIER Cat7 RJ45 Ethernet Cable Silver Plated Copper Triple Shielding 0.129mm² 3m If you have high-end audio devices connected in a network, then it is essential to use quality Ethernet cables to allow your devices to deliver their full potential. With its...
Très bon et beau câble , excellente finition , je recommande
Johan Å.
AUDIOPHONICS HPA-Q250NC Power Amplifier Class D 4 Channel NCore NC252MP 4x250W 4 Ohm The Audiophonics HPA-Q250NC is a four-channel amplifier based on two Hypex Ncore NC252MP.
Insane value and perfermance
As the title says, insane value and perfermance! Compared to my much more expensive Emotiva amplifier this one sounds smoother which I didn't expect. In fact this Audiophonics amplifier sounds so good I placed an order for the 3-channel Purifi amplifier.
Regarding build quallity; one of best built amps I have held in my hands - built like a tank!!
maarten v.
Nice looking and stable for this price
Angelo B.
SABAJ A10H Headphone Amplifier Class AB 1W 32 Ohm Sabaj completes its A10 range with the A10h headphone amplifier, a high quality model based on an optimized architecture using carefully selected audio components. The amplifier...
Sabaj A10h
This neutral sounding amplifier surprised me incredibly with its open soundstage and very good separation of musical instruments. Also surprised by the sound quality with my HD650 and HD58X (incredible musical definition). The volume returned was more than enough to appreciate the perfect compatibility and goodness of the Sabaj A10h and HD650.
Comparisons made with:
-Violectric HPA V200.
-OTL MegaHertz.
-Schiit modi Multibit.
-Khadas Tone Board.
-Austrian Audio Hi-X65.
-Avantone Planar.
-Equalizer APO.
Thank you very much David Aubert who always very professional in recommending the products.
Ioannis S.
Coaxial not operate properly
Is a good DAC but the coax input operate with with continuous breaks when i connect a CD player !
Thierry A.
Très bon niveau en terme de qualité prix
Différence perceptible en utilisant ce câble par rapport au câble d'origine sur une source OPPO 203. Un peu plus de définitions.
Très bonne qualité de fabrication. Très bon rapport qualité prix. Je conseille de le tester.
Ce câble ne détériore pas la qualité du son en privilégiant un registre par rapport à un autre comme certains câbles secteurs peuvent le faire ce qui est un très bon point.
Bien pour le prix
Fait le job pour alimenter un caisson de basse équipé Dayton. A noter que le ventilateur se met en route...pour ne plus jamais s'arrêter...
Philippe K.
Excellent accessoire
Encore un excellent accessoire pratique de Dynavox. Pèse efficacement la cellule et permet un réglage fin et précis du contre-poids permettant une lecture optimisée. Excellent rapport qualité/prix.
Philippe K.
Excellent produit très bien usiné. Apporte stabilité à la lecture et réduit efficacement bruits et distorsions. Un accessoire indispensable pour tous possesseurs de platine vinyle.
parfait .
dans l esprit de rester tout cuivre j ai acheté cette fiche .
rien à redire.
bonne qualitée apparente meme si je doute que le corps de la fiche resiste à plusieurs chutes ou choques ?
accepte du câble plus gros que 2,5 mm .
montage sans difficulté et prix acceptable .
bravo .
besoin de plus ?
cette barette fait parti des premiers prix de la catégorie , comment la critiqueur ?
mon choix c est porté sur le nombres de prises bien sur , mais aussi par la presence du rail en laiton de forte epaisseur qui relie les schuko et garant d une bonne restitution du courant entre les fiches .
pour la qualité c est du très très bon .
les fiches secteurs mal s emboitent avec resistance dans la barette gage d un bon maintien.
seul hic l assemblage !
je n ai jamais rien vue de si peu pratique .
pour un meilleur contact pensez à étamé le bout de vos câbles c est toujours meilleur et ca tient mieux au serrage .
un tres bon choix .
Jean-Claude T.
Produit Ok
Superbe produit et reçu très rapidement!
Jérôme L.
au top
La carte est géniale, le rendu est vraiment bon. J'ai déjà un raspdac mini qui est équipé avec celle-ci je commande donc les yeux fermés
Juste dommage qu'il n'y ai pas les entretoises vendu avec.
MICHEL B.
Il fait le job
Ce petit appareil duplique parfaitement le signal optique. Je l'utilise pour envoyer le signal de la TV ves des enceintes actives avec entrée optique.
Il n'y a pas de décalage son image.
MICHEL B.
Super qualité
Ce câble optique a des connexions d'excellente qualité et la gaine du câble est solide ce qui est un atout pour parcourir 5 m au sol.
Denis C.
Câble HP
Merci pour la rapidité de la livraison.
Il ne reste plus qu'à le roder.
Encore merci à toute l'équipe.
Denis
Thomas V.
phase inversée
Juste pour signaler que le câble que j'ai reçu inverse la phase. Ca arrive sur des câbles bien plus chers mais s'ils sont tous montés à l'envers (?) ça vaut le coup d'être précisé.
Michael S.
Does the job
I needed to raise the height of my dac to be able to provide space for a new op-amp and these were perfect. Added stability and height to the Aune X8.
Michael S.
Recommended!
Upgraded the op-amp in my Aune X8 magic from the stock amps to the Sparkos SS3602 Dual Discrete. I found this recommendation on you tube and although I am naturally sceptical by nature, the change made a very noticeable improvement to my system. Hugely recommended purchase!
Eric F.
Top quality :-)
Avis posté avec encore peu d'usage, mais le gain pour mon usage est important.
- 1 usage classique : écoute audio de musique sur casque : meilleure spacialisation, la scène sonore s'est ouverte, et chaque instrument est plus "individualisé" et moins écrasé par les autres présents à l'enregistrement. Quand une corde est grattée ou pincée à coté d'une voix, elle se sépare mieux et vient enrichir l'écoute.
Belle qualité sonore, assez étonnante pour le prix car pour avoir une belle scène sonore, j'utilisais un ampli casque à tube seulement jusqu'ici, mais pas transportable.
- 1 usage particulier : écoute de fichiers audios pour faire de la retranscription pro. Les fichiers sources ne sont pas forcément top qualité, plusieurs interlocuteurs pouvant parler en même temps voire avec un fort bruit de fond : la séparation de chaque source est meilleure et chaque voix est donc plus facilement audible et compréhensible.
Moindre fatigue du coup :-)
Ceci est mon premier DAC, donc je n'ai pas de point de comparaison avec d'autres, mais j'en suis très satisfait.
Qualité audio franchement très supérieure à la carte audio intégrée à mon PC portable (PC entrée de gamme valant seulement +/- 800 €) dont la carte son commençait à dysfonctionner.
DAC portable = contournement du problème ;-)
Stefano G.
AUDIOPHONICS CANARE Digital Coaxial Cable Ultra Coax 75 Ohm BNC-BNC 1m This Coaxial Ultra Coax 75 Ohm cable with male BNC connectors is assembled in France by Audiophonics, with top of the range components from Canare. This includes an ultra...
Good
I am connecting a Oppo BDP 105 to a Lector Digicode s-192. Compaired with my previous 20 euro rca cable, the music is more transparent and the bass are more punchy.
I am very happy.
Giulio M.
Must have
Try with my NUC Streamer .Superior performance than linear AMP
Better bass response,detail and silence.
Ready to order another one for my Project Audio CD Trasport to work together with Ifi IPower
Arnaud P.
SMSL SU-8S Balanced DAC ES9068AS USB XMOS 32Bit 768kHz DSD512 MQA The SMSL SU-8s is a symmetrical DAC featuring the new ESS ES9068AS digital to analog conversion chip. This last one supports high sampling rates, up to PCM 32bit 768kHz and...
Tiptop.
Je cherchais un DAC avec réglage du volmue et lélécommande, pas cher, AVEC sortie XLR. J'ai vu que ses fonctionalités étaitent plus que complètes. Je l'ai pris.
Il est placé entre 2 sources, et des moiteurs actifs (d'où besoin des sorties XLR !) ; moniteurs actifs pour utilisation "à la maison".
Le SU-8S ne chauffe pas du tout, il est froid en fonctionnement, signe d'un bon design.
Il est tout pti rikiki, et c'en est rigolo car le rendu des Dynaudio Core59 au bout des câbles XLR de 5m (1er prix) est tout l'inverse :-)
La télécommande est un peu directionnelle mais à 6m ca marche nickel sans cafouiller. L''écran du SU-8S est petit, mais à 6m il indique très lisiblement le niveau du volume ; j'ai coché dans les réglages, d'éteindre l'écran au bout de 5s, comme ça il se fait complètement oublié. Simple et efficace ce SU-8S.
Merci Audiophonics de proposer ce pti DAC au RQP au plafond ; et merci pour livraison & service tjs au top.
Cdt
Thierry G.
VIBORG VH302R Stereo Jack 3.5mm Connector Rhodium Plated Ø6mm The Viborg VH302R is a beautifully designed 3.5mm stereo jack connector, using rhodium plated copper alloy contacts to ensure very good conductivity. It can accept...
Déçu
Les points de connexion pour souder les fils ne correspondent pas à la photo et ne sont pas pratiques.
Ce ne sont pas des oeillets. Il faut venir coller le fil sur la partie à souder.
Très peu de filetage pour visser le capot. Se dévisse facilement.
Les côtes sont très différentes des Elecaudio JK3-103 et ne correspondent pas à mon application,
Du coup, commande pour rien, j'ai recommandé les Elecaudio.
Cédric T.
Splendide
La photo ne fait pas justice à ce câble de diamètre plus que convenable et superbemen assemblé.
Un poil rigide mais rien de la dérangeant.
A littéralement transformé mon système stéréo en Dolby Atmos avec une représentation holographique,....
Blague à part, cet l'exemple même que c'est pas la peine de dépenser 500€ dans un câble en uranium cristallisé uni directionnel. Un bon câble, pas cher, qui fait 100% du job sans "snake oil"
Jérôme L.
Du pur bonheur
Novice dans ce genre de matériel, je redécouvre ma musique.
Mon matériel :
- un raspdac mini avec la carte isabre ES9038
- un ampli XDUOO TA-20, ampli qui emmène largement la puissance demandé par le casque.
C'est vraiment un autre monde, tout est clair et défini, l'impression d'avoir les chanteurs à coté de sois.
Le casque est confortable et semble assez costaud pour écouter sans se fatiguer pendant de bonnes heures.
Seul hic, la longueur du cable. Le son est tellement bon qu'on a envie de se lever et de se mettre à bouger mais le cable vous stop vite!
Ciaran K.
i2s dac for raspberry pi
I had an old unused raspberry pi (version 1b!) and wanted to create a squeezebox client. This needed a few small changes to the board - soldering on a header - but after that was a simple matter of following the instructions to connect the correct pins. The sound is excellent! Also very impressed with Audiophonics service - there was a small part missing in the order which was very kindly posted out to me - merci!
stoica r.
Very very nice
It is an amp in class D that is worth all the money and some. The finish from audiophonics is very very nice. But is not going to work for me with the gain on in any position. With sparkon or not is not worth the money. When you desble the gain and put xlr with 4v to 10v output in class A si wonderful. On my opinion is better than jeff rolland. 10+++ for the build -1 for output integration
Marcus K.
SMSL VMV A1 Amplifier Class A MOSFET PGA2311 2x15W 4 Ohm The SMSL A1 is a compact but very powerful Class A amplifier, offering an excellent sound reproduction, both round, musical and precise. This amplifier provides a beautiful...
Very enjoyable amplifier
Not a joke. I bought this because of good reviews and because I have efficient speakers. Sort of an experiment. I owned many amps in the past, some costing ten or even twenty times more. But this thing is a precious little amp. I am using it with an external preamp, so keep that in mind. The temperature does not exceed 43 degrees. In my system, this really is a winner.
Emmanuel v.
Volume de sortie stéréo trop faible
J'espère qu'il s'agit juste d'un problème de configuration mais j'ai une atténuation de 6dB de la sortie stéréo analogique en comparaison avec mon récepteur Bluetooth SMSL B1. La réponse du SAV de iEAST est que le signal de sortie est de 1V, comme la prise casque d'un iPhone, alors que si je me trompe, le standard de sortie de ligne audio est de 2V. Cela expliquerait les 6dB de différence mesurés sur mon ampli Yamaha. Il faut donc tourner le bouton de volume pour compenser, ce qui n'est vraiment pas très commode, outre la diminution du rapport signal bruit que cela entraîne. Je m'étonne que personne n'ai mentionné ce problème.
Christopher G.
cpg
I was always sceptical if "better" digital cables made a difference, surely bits are bits?
However this cable is definitely better than my previous ca. 30€ digital cable. Well worth a try.
Willy M.
Ravi de mon achat!
Merci à Audiophonics pour le sérieux!
Ce petit DAC correspond tout à fait à mes attentes, compact, beau son, look bien sympa, facile à installer!
En ce qui me concerne et à ce tarif rien à redire!
jb b.
WONDOM PS-BC12112 BCPB3 Battery Management System Module 5x Lithium 18650 The Wondom BCPB3 is a battery management and protection module, taking advantage of the performance and reliability of the previous models while offering more battery...
très efficace
entièrement satisfait de ce kit qui gère bien la charge des batteries . on peut recharger en branchant un courant de 5 à 24v , y compris par panneau solaire et il se débrouille donc très pratique, le seul bémol c'est qu'il n'y a pas de bouton 'off' , donc le système tourne en permanence, pour çà prévoir des interrupteurs sur les sytèmes alimentés .
ce module est livré avec tout ses cables donc inutile de commander le pack de cable en option (PS-BC12311)
jb b.
WONDOM PS-BC12311 Package Functional cables for module BCPB3 / BCPB4 / BCPB6 This cable kit contains all the necessary connectivity to use all the features of your Wondom battery managers.
vérifier l'utilité de ce kit avant de commander
les cartes de gestions de charge de batteries wondom sont livrées avec ce kit de cable donc inutile de commander ce kit si vous avez commandé un WONDOM PS-BC12112
Eric v.
qualité moyenne. Vis de serrage relativement médiocre.
Si non envoi rapide et serieux comme toujours chez AUDIOPHONICS
Arturas J.
puikus
Excellent quality, fully meets your description
Arturas J.
normal
the connection does not match the description. I had to get tired of connecting the 2.5 power cable. tired and assembled to connect the contact holds good.
Christopher G.
cpg
as one of the previous reviewers said, this is a very good transport. The only disadvantage is you cannot select the track number
Narcisse a.
DAYTON AUDIO UM10-22 Ultimax DVC Speaker Driver Subwoofer 500W 2x2 Ohm 85dB 25Hz - 1500Hz Ø25cm Dayton Audio's Ultimax series DVC subwoofers are specially designed to move energy and create clean, articulate, tense fast bass. Enjoy the best value for money available !...
parfait si ce n'était le prix
Un sub qui en jette c'est sûr! aussi bien au propre qu'au figuré. Il est lourd, sérieusement construit et même beau pour être honnête avec son HP sans cache noyau et sa membrane épaisse. Comme tout bon HP SQ il est malheureusement lourd et nécessite un ampli qui a du courant. Je l'alimente avec un vieux infinity numérique bien droit, dans un caisson clos d'environ 25L il fait des merveilles avec une belle descente et une articulation propre et détaillée agrémenté d'une belle ampleur. Il sera parfait aussi bien pour restituer les basses profondes d'un James Blake que les kicks énervés et frénétiques d'un bloc party ou d'un blink 182. Le prix est à la hauteur de la prestation mais pour le non initiés qui n'y verra que du feu, un dayton de la gamme LS fera déjà un excellent travail.
transparence et neutralité
Un excellent équilibre , une grande netteté sans ce côté dur que peut apporter l'écoute en numérique . Tout est là . Recommandable dans cette gamme de prix.
Davide C.
mod gain
Good module buffer.
Hi, i bought old version (no switch) preamp many years ago. I don't remember the modify to reduce the gain. Can you help me? Thanks.
Hi,
It's silk printed on the board.
You can change the buffer gain using the DIP switch.
Frédéric L.
MUNDORF 2.8G Insulated Female Blade Terminal Gold Plated 2.8mm 0.5-1.5mm² Red (x10) These female blade connectors allow a simple and fast connection/disconnection while ensuring excellent contact. The contacts of these connectors are gold...
Pas d’alliage cuivre
Cosse de très bonne qualité, j’ai voulu vérifier en limant la cosse
couleur laiton et apparu et non du cuivre.
Quentin T.
Un préampli vraiment ?
Un bon produit pour le prix, mais je ne pense pas qu'on puisse le qualifier de préamplificateur, car il faut pousser le volume au maximum pour retrouver un volume normal.
En tant que contrôleur de volume/sélecteur de source/récepteur BT, en revanche, il fait un très bon job.
Gregory O.
Viborg
Top class sound and better than my way more costly one from F-H
ROSE HIFI RS250 Lecteur Réseau Audio DAC ES9038Q2M 32bit 768kHz A true audiophile network player, the Rose Audio RS250 combines versatility with high performance, thanks to its high-end DAC and optimized power supply stage. A jewel of design...
Un appareil pour geek patients aux petits doigts.
Look 10/10
Son 10/10
!!! Utilisation 0/10 !!! Une horreur.
Hifirose revendu pour cause d'ergonomie "usine à gaz". Tout est ici :
https://community.roseaudio.kr/t/why-i-sold-my-hifirose-pourquoi-jai-revendu-mon-hifirose/4306
Philippe F.
NEOTECH NEI-1001 II Interconnect Cable Balanced UP-OCC Silver 2x1.17mm² Triple Shielding The Neotech NEI-1001 II is a balanced modulation cable made of 2 Silver UP-OCC conductors with a cross section of 1.17mm². Each conductor is composed of 4 strands of...
Excellent en RCA
Câbles associés aux fiches RCA WBT-0152 Ag au diamètre adapté. 2 fils soudés sur points chauds, le 3ème sur point froid + blindage à sur fiche source.
Résultat excellent. Grande transparence et dynamique, et surtout une scène sonore étendue. L’écoute n’est pas fatiguante. Hautement conseillé !
Laurent A.
DAYTON AUDIO DS90-8 Design Series Speaker Driver Full Range 20W 8 Ohm 84dB 80Hz - 13kHz Ø8cm This 80mm paper-treated membrane driver has a bandwidth from 80Hz to 13000hz. It is ideal for the design of speakers without passive filters with a linear response in two litres...
De petits montres..!
J'ai installé ces petits haut parleurs dans de petites enceintes labyrinthe Iwistao.
Raccordées à un petit ampli FX audio fx252a et un petit pré ampli FX tube-03, le tout, raccordé à mon téléphone (chambre à coucher). Le son est à peine croyable !
Pour le moment, ils sont utilisés en large bande et ça fait déjà bien le taf. Je vais ensuite rajouter un second ampli, un petit filtre actif et deux tweeters histoire d'élargir la bande.
Sinon, seuls ils sont quand même fabuleux pour le prix..
(Les labyrinthes Iwistao y sont aussi pour bcp pour la réponse dans les graves)
Yves A.
USB Black Cable USB-C Male TO USB-C Male 3.1 12cm This high-quality male / male C-type cable allows you to connect any tablet or smartphone with a USB type-C or any type of C-type input.
USB C vers USB C court
Rapide et fiable Bravo ....encore Merci
Impressionnant
Ce câble est une révélation, car il n’a pas démérité en le comparant à des ténors de la catégorie. Associé à des Viborg plaquées or/argent il a réussi à détrôner mon câble fétiche à plus de 1000€ dont je tairais le nom.
Après une bonne cinquantaine d’heures de chauffe, il est d’une cohérence et d’un équilibre à faire pâlir, voire trembler les grandes marques prestigieuses. Les timbres sont de toutes beautés avec un médium émouvant.
La dynamique frôle la perfection avec un son riche et maîtrisé. Quant aux aiguës, ils filent sans s’arrêter dans un soyeux envoûtant.
Bref c’est que du bonheur
Merci audiophonics pour ces pépites au RQP imbattable
Matos : ampli et cd Roksan K2, HP Focal Chorus V 826 re câblée athom mini
Mogami w3103 pour les HP
ET Mogami w3082( c’est une tuerie) pour la liaison cd/ampli.
Jochen R.
SMSL TABEBUIA WAVECOR Bookshelf Speakers 2 Way 100W 4Ω 88dB 56Hz-32kHz Black (Pair) The Tabebuia are the first loudspeakers offered by the acclaimed and recognized SMSL brand. These compact bookshelf models include a tweeter and a woofer from Wavecor, a company...
High quality desktop speakers
I've tried some rather different passive loudspeakers in a near-field desktop setup.,from e.g. Wharfedale, Dali, JBL, Tannoy and others. These were the only ones which did the disappearing act without sounding thin. And the quality of the parts and the finish is top notch. In the end I had to use them with a classic NAD amp because the ProJect Stereo Box S2 was simply not up to the task (annoying hiss). Highly recommended!
