Genalex
Theodoros R.
Remi B.
Bouchons
Walter V.
TINYSINE TOSLINKBEE Interface Module SPDIF Optical to I2S DIR9001 CS8421 24bit 96kHz This Tinysine ToslinkBee interface module converts an SPDIF signal via an optical Toslink input into an I2S signal. A DIR9001PW Burr-Brown chip converts the SPDIF signal to I2S,...
Great product!
Male Jack DC 5.5/2.1mm Connector Gold Plated Ø6mm This DC 5.5/2.1mm male jack connector will allow you to design your own power supply cables. It offers a nice design quality, with a metal body and gold-plated contacts ensuring...
Joli mais non..
Le pôle positif accepte 1mm2 malgres l' insertion en tube. La pâte de la masse est trop fragile . Joli, transmet le signal mais fragile et cher pour ce que c' est. Je préfère elecaudio en alliage ou en cuivre tellurium.
NAEL C.
Marvelous !
the difference is night and day ! i was using a dac that had no galvanically isolated USB input, adding the HS02 in the chain made an impressive change, i know electrical interferences can cause clocks to missbehave and add what is commonly referred to as "digital glare" but i was not axpecting such a change. anyway the device works and does wonders if you have a dac that is not properly isolated. Even my girlfriend was shocked at how much difference it made !
Jean-Marc S.
AUDIOPHONICS DIGIPI+I2S Digital Interface WM8804G for Raspberry Pi SPDIF I2S TCXO This Audiophonics DigiPi+I2S interface expands the output connectivity of a Raspberry Pi, giving it an additional panel of digital audio outputs. It includes a Toslink optical...
rpi5
fonctionne très bien avec avec rpi5 et picoplayer (en tant que player uniquement) ! Merci des conseils Audiophonics
jean-michel g.
Câble opéra Triangle
Après un d’utilisation, je valide que c’est un super câble avec beaucoup de finesse et de fluidité. Très agréable à l’écoute.
De plus, couleur de la gaine très discrète.
Hector T.
TRUTHEAR NOVA In-Ear Monitors IEM Dynamic Balanced Armature 14.8 Ohm 123dB 8Hz-40kHz Truthear's Nova are high-performance in-ear earphones featuring a total of 5 drivers and a waveguide structure made using DLP 3D printing, to deliver sound with a wide frequency...
Qualité prix incroyable
Ces IEM possèdent un rapport qualité-prix vraiment intéressant.
Au niveau des + :
- Voix très détaillées (on entends les "twisting" de la langue et des lèvres)
- Séparation des instruments intéressante
- Basses propres et pas trop étouffées
Les - :
- Un dac me semble obligatoire, surtout pour les passages percutants (Les refrains semblent "plats")
- Les morceaux Classiques sont plus agréable sans Dolby Atmos, avec une préférence au Lossless (les enregistrements de Lang Lang - Pianiste - sont plus détaillés sans Atmos; la pression sur les notes et la tuile qui frappe le bois se remarque plus facilement sans DA)
- Manque de spatialisation
MUNDORF ACW120BK Wiring Cable Copper / Silver / Or PTFE 3.1mm² The Mundorf ACW120BK is a high quality wire with a high conductivity. Thus, its conductors are made of high purity mix copper / silver / gold and insulated by a PTFE sheath in...
pareil
un beau son
Sandy G.
EXCELLENTE REVELATION.
Je l'utilise avec ROSE RS 150 B en mode drive , ou avec mon 3D NANO LAB PLAYER SIGNATURE' en mode drive lui aussi.
Le résultat est très intéressant. Le niveau de sortie ANALOGIQUE de ce DAC est réglable, ou fixe, ce qui permet de l'utiliser en préampli, ou d'adapter le gain avec l'ampli qui lui fait suite. L' horloge externe 10 MHZ LHY AUDIO que j'ai rajoutée, vient jouer le chef d'orchestre, et c'est fabuleux..! Je suis enchantée du résultat. Je ne conseille pas sa partie streamer par contre, qui n'est pas grandissime. (ROSE RS 150 ou 3D NANOLAB signature font bien mieux en "streamer" )
Denis K.
SMSL PS200 DAC ES9039Q2M USB SPDIF Bluetooth 5.0 32bit 768kHz DSD512 MQA-CD The PS200 from SMSL is a small, compact DAC featuring quality components. It features an ES9039Q2M DAC chip, an XMOS XU316 USB interface and no fewer than 4 OPAs. It supports...
Très bon!
Un son de très bon niveau dans un tout petit boitier!
La clarté de la reproduction sonore est épatante pour le prix de cet appareil, en USB comme en bluetooth.
Bravo en passant au SAV d'AUDIOPHONICS pour leur efficacité lors d'un problème avec un autre produit, merci pour la réactivité!
Gerrit G.
TOPPING D50 III DAC 2x ES9039Q2M XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 Black Topping's new D50 III desktop DAC has been updated to deliver even better performance than its predecessors. It now features two ES9039Q2M DAC chips and an XMOS XU-316 USB...
Very good DAC , BUT .....!
The USB A to C cable that comes with it is only good for powering the davice , not for data transfer . If used for data , Windows 10 will not recognize the device ! Use another USB cable for both data and power and then it will work . Also , the default setting for the output terminals is TRS , not RCA . If you use RCA cables to connect to your amplifier , change this setting . This information is not provided in the manual and I think that is a big shortcoming . It took me quite some time and pain to figure this all out . Sound is perfect (once you get it running...)
Antonio C.
SPARKOS GEMINI Hybrid Headphone amplifier / Preamplifier Tube 6922 and AOP SS2590 This Gemini headphone amplifier/preamplifier from Sparkos is a jewel of hybrid technology, whose main feature is the possibility of customizing it to suit your listening...
It’s a no brainer.
The Sparkos Labs Gemini really surprised me. As a tube headphone amp, it adds a smooth, rich character to the music that just makes everything more enjoyable to listen to. I love how easy it is to swap tubes and change the sound — it’s fun experimenting with different flavors. It’s super quiet, detailed, and has great punch too. I’ve also used it as a preamp, and it sounds fantastic — very clean, natural, and dynamic. For this price, I think it’s a total bargain and honestly a no-brainer if you want something musical, versatile, and fun to use!
Tibor H.
ATAUDIO AT-5G Jack 3.5mm TRS Connector Gold Plated Ø6mm Red This ATAudio AT-5G Jack 3.5mm TRS connector features a high quality design, ensuring both performance and durability. It features a rugged metal body and 24k gold-plated...
Everything OK!
Didier T.
En un mot... Majestueux !
Et pour peu que l'on évacue tout préjugé tarifaire, la divine surprise est à portée de main...
Ainsi, les Nemoi 3220 (tjrs soudés à la Mundorf Supreme sur des Switchcraft dont il a fallu réaléser à 10,5 mm les orifices des bouchons en alu) ont donc remplacés les FA-aS22 (ayant eux-mêmes plus de 50 heures au garrot) entre mes Nuprime DAC 9SE et STA 9X.
Si les vraiment "très bons premiers" m'avaient laissé sur un je ne sais quoi de frustration par un manque d'ampleur, je les ai donc troqués pour ces Nemoi 3220, juste "pour voir" (ou plutôt entendre) : à ce tarif-là, il est des tests qui ne se refusent pas...
...et alors là...
...je ne m'attendais absolument pas à cette musique-là !
Une matière retrouvée, des basses électriques, contrebasses et violes de gambe sensiblement plus étoffées dans leurs premières octaves avec une complexité harmonique sensiblement plus riche...
...des voix plus palpables matures et charnelles...
...des instruments à vent et à cordes (acoustiques et électriques) plus concrets...
Comme si, en fin de compte, ce gain en fréquences inférieures redonnait aux instruments cette fameuse complexité harmonique nous rapprochant de la vérité.
Le tout avec (et par compensation), il est vrai, un sentiment de léger recul du niveau des cymbales, mais, dans mon cas, en totale conformité avec la configuration mise en œuvre.
Bref, ce Nemoi 3220 contribue à une musique délicatement détaillée, envoûtante et "matérielle"...
Tout prend une place naturellement "en ordre", sans sentiment que telle partie du spectre bouscule ou phagocyte telle autre, me laissant à penser que les Nemoi 3220 sont un peu moins "audiophiles" et un peu plus "mélomanes" que les excellents FA-aS22.
Tout comme pour le Ludic Silenos, sans trop savoir pourquoi (et sans chercher à le comprendre non plus), ce sera sans doute le dernier.
Deux détails pour conclure :
- concernant son montage, bien veiller à considérer que les conducteurs sont constitués de monobrins en nappe doublement isolés : une fois dénudées les gaines rouges et bleues, reste sur chacun un isolant transparent à éliminer délicatement pour assurer un soudage digne de ce nom.
- ne surtout pas le juger "from scratch", car dans ce cas, il peut verser dans un chouïa de vulgarité, ce qui disparaît intégralement une fois franchies les 20 heures...
Didier T.
Vraiment très bien tout en pouvant être un peu exigeant...
Plantons le décors...
Le guitariste que je suis (doté de son propre studio avec batterie, clavier, ...), écoute la musique avec ce qui suit :
- Node 2i alimenté via Shanti + carte PD Creativ
- Nuprime DAC 9SE (connexion Toslink QED Quartz Reference)
- Nuprime STA 9X
- Epos EPic 5 subtilement mais sensiblement remaniées (bcp + d'ampleur et de nuance)
- Liaison enceintes Ludic Silenos (exemplaire de nuance et de vérité)
- filtrage EDF via BADA 6610
...le tout dans 38m2 sous 2,80m sous plafond.
Séduit par le concert de louanges concernant ce Furutech, je l'ai inséré en symétrique entre les deux Nuprime (XLR Switchcraft + soudure Mundorf Supreme).
Ces FA-aS22 distribuent les timbres de façon très fine et aérienne avec une grande liberté, le tout avec une grande justesse tout en étant très rigoureux.
Ils ne tordent ni ne surjouent jamais, ne sont jamais durs, et restent très subtils et délicats, la scène proposée entre les enceintes est très "cinémascope".
C'est très beau, l'air circule indubitablement partout, le sentiment de lumière prédomine.
Je me suis néanmoins retrouvé confronté "à la longue" à un résultat un peu "court sur pattes" sur les jeux de batterie (j'en ai une dans mon studio), traduisant un léger manque de soutien et de matière sur les coups de pédales de grosse caisse et les jeux de basses (guitares, contrebasses, violes de gambe, ...).
Le plaisir procuré par ces FA-aS22 était au fond mâtiné d'une pointe de frustration.
Sans remettre en cause ces excellents câbles, j'ai finalement migré vers du Neotech Nemoi 3220 (mêmes XLR, même soudure) sans retour arrière possible.
En résumé, si ces Furutech sont vraiment de haute voltige, ils peuvent ne pas convenir dans toutes les situations.
Panikos K.
Extremely well made especially for the price. No internal wires, ALPS switcher, high quality aluminum enclosure. Perfect.
As always, Audiophonics offer exceptional service and fast shipping.
Niels G.
TOPPING D90 III SABRE Balanced DAC 2x ES9039SPro Bluetooth 5.1 32bit 768kHz DSD512 MQA Silver Topping's D90 III Sabre balanced DAC is an evolution of the Topping D90SE DAC. In this improved version, Topping has chosen new components and added new features for enhanced...
New DAC
This DAC is as good as all the reviews say. Incredible open throughout the frequency range, without any listenig fatique. But prefers good source material . Very much recommended for quality systems ( class A amps + electrostatic speakers)
Cyril B.
Impecable mais appli moyenne
Après une connexion direct en WiFi à l'appareil, j'ai finalement compris comment faire (regardez la vidéo sur l'iEAST Stream Pro M30) pour vous connecter à travers le WiFi de votre Box Internet.
Manque une sortie optique et surtout une application plus conviviale et plus configurable.
Cyril B.
Bien mais ....
Pas de soucis pour si connecter.
Par contre il faut quitter le WiFi de sa Box internet et se connecter directement dessus. Donc plus internet sur le téléphone, à moins d'activer la 4G mais là il ne repère plus l'Audiocast... Embêtant.
L'application n'est pas dingue mais fait le boulot.
Mais à cause des raisons ci-dessus je vais le rendre. Dommage.
Genalex Gold LION KT88
The Genalex gold lion KT88 tubes arrived very well packaged, after installing them in the amplifier, there was a noticeable difference in sound, I'm looking forward to burning the tubes and the sound will be even better. I bought them together with Tung-sol 6SN7GT and 6SL7GT for the Cayin CS 88 A amplifier. The whole combination is exceptional in sound, the sound is very dynamic, yet velvety soft, beautifully perceptible with all the details. Thanks to Audiophonics for the fast delivery of the package.
Charles K.
MOONDROP DISCDREAM 2 CD Player on Battery CS43131 32bit 384kHz DSD256 Moondrop's Discdream 2 is a portable CD player with a precise servo architecture featuring a Cirrus Logic CS43131 DAC chip to deliver the best possible sound. It has been...
un lecteur CD de qualité mais pas parfait
La qualité de fabrication et la qualité sonore sont au rendez-vous.
Un petit reproche : les pictogrammes sur les boutons d'action ne sont pas très visibles (blanc sur blanc). J'aurais bien aimé voir un contour noir autour des pictos en question.
Par ailleurs, étant donné que j'utilise le lecteur en mode fixe, une télécommande (même en option) aurait bien été utile.
Johannes R.
AUDIOPHONICS OPA1642 Dual DIP8 (Unit) Audiophonics is proud to present its OPA range with the OPA1642 based on a authentic Texas Instruments chip. This OPA offers excellent performance for audio applications. In...
Fosi V3 Monos
I just installed four of them, and the difference compared to the original OPAs is noticeable! They now sound even more contoured and simply more harmonious. You can hear them immediately. I highly recommend them. Good job, Audiophonics!
Francis B.
ISOACOUSTICS ISO-155 Speaker Stands 18kg 155x190x76mm Black (Pair) The ISO-155 model allows you to improve the placement of your monitors or loudspeakers thanks to 14 variations of position (height and inclination) available. Featuring the...
Très efficaces…
Cela apporte beaucoup au son. Pratique avec la hauteur réglable.
Absorption des vibrations incroyable … supportent bien le poids.
Francis B.
Formidable
Non seulement on achète chez audiophonics des produits au rapport qualité prix imbattable, notamment dans leur workshop, mais en plus on peut faire un upgrade d’un point de vue musicalité en maintenant la garantie. C’est une bonne chose d’un point de vue environnemental également.
Francis B.
Vraiment bien
Je ne pensais pas avoir une influence sur le son.
Pourtant elle est là. Cela ne va pas améliorer la qualité du courant reçue, en revanche, on va fortement protéger les composants câbles etc. qu’il y a autour. Un câble joue le rôle d’une antenne quasiment et propage des parasites s’il n’est pas correctement blindé. Les câbles courent en général à une distance réduite les uns des autres.
Sans dépenser des milliers d’euros, en achetant chez audiophonics des câbles blindés correctement, avec de bonnes fiches, des câbles secteurs bien isolés on limite fortement le parasitage. Aussi bien en RCA, qu’en XLR.
J’ai une meilleure écoute avec tous ces ingrédients installés je suis ravis.
Merci à Audiophonics également pour leurs conseils avisés très utiles et neutre, leur patience.
Francis B.
Audiophonics nous propose comme à son habitude, une belle finition, un blindage vraiment de bonne qualité, important pour un câble de modulation, de très bons câbles pour le prix. Rapport qualité prix toujours excellent.
Merci audiophonics pour cette mentalité toujours présente.
Dmitry K.
5 STARS PREAMP!!!!
Worth every cent!
boualem d.
j'ais oublié les étoiles
boualem d.
une tuerie
Au départ , j'étais assez sceptique comme tout le monde
mais maintenant , c'est le jour après la nuit .
Plus de ronronnement ,de bourdonnement même les sifflements ont disparus .
Faut dire que je l'associe avec trois câbles secteur digne de ce nom .
De la musique rien que de la musique ,pour tout vous dire , je suis possesseur d'un ampli ADVANCE PARIS A10 CLASSIC que je redécouvre .
Je ne pouvais pas l'utiliser en classe A , c'était trop diffus ,trop brouillon .
Aujourd'hui que du bonheur musical .
De plus si je peux me permettre , la configuration interne ressemble étrangement à une autre marque plus chère ,
le TAGA HARMONY PF-2000 ;
Je ne suis pas spécialiste en la matière mais à deux babioles prés , on n'est pas loin .
Moi , j'ai franchi le pas et pas de retour en arrière .
Igor K.
great price for OCC cable
Bought it to make custom headphone extension cable. Flexible, the PVC is exterior is durable. Price is very reasonable for OCC copper.
Igor K.
VAN DEN HUL THE MAGNUM HYBRID Speaker Cable Silver Plated OFC Copper 2x8.54mm² This  Van Den Hul The Magnum Hybrid  cable features 2x483 strands of grain-oriented, deoxygenated  OFC copper.  Each strand is then plated with  pure silver.
SUPERB, not bright
Using with PrimaLuna Evo 300 tube integrated amp, Amphion Argon 3S speakers. This cable replaced Canare 4S11 cable which I was previously using. It was easy to terminate and route. Sound is amazing. More bass, more detail, and no brightness! It also has a very old school vibe. I've spent days researching cable before landing on this one, glad I did.
You can buy 16mm nylon sleeving of whatever colour should you want to change the look. Don't let the look be the influencing factor!
Paul M.
Compact and powerful
Bought this a as a back-up supplement to the Audiophonics corresponding pre-amp that I bought earlier. Works perfectly with my ATC SCM-40 closed-box-design speakers. No need for more power. Complete control, no need for more power. Turns a little warm in temperature, but perfectly capable to put my hand on the casing. Replaces a temporary Accuphase amplifier.
Paul M.
Plain and solid speaker cable
These speaker cables serve their purpose: a straightforward presentation of what your amplifier puts out. Solid build, perfect termination and nice for the eye (not just the ears). A copper cable suitable for amplifier currents. You don't need much more.
pascal v.
Extensible Braided Sheath Nylon (PET) 15-25mm Black This black braided sleeving made of PET (Polyethylene Terephtalate) single strand can be used for many applications.  Thanks to its expandability, the unique braiding of...
Montage sur un câble secteur Oyaide tunami de 15mm, hyper facile. Belle qualité surtout à ce prix
pascal v.
la qualité à prix correct
Connecteur monté sur un câble Oyaide tunami v2, pas facile à installer car cable relativement rigide. Les vis de fixation sont moins qualitatives que sur les schuko VE512R
pascal v.
la transparence à petit prix
Câble monté avec prises Viborg rodium VE512R et VF502R et habillé avec gaine tressée noire, en remplacement d'un Norstone Arran, l'image s'élargit et la transparence passe à un stade incroyable. Les voix sont d'un naturel comme tous les instruments. Je recommande vraiment ce câble Oyaide Tunami V2
Jean-louis L.
Bon, je commence par la Mise en Service : après avoir vidé un bel emballage très "sécure" mais sans véritable Doc ~ Mode d'emploi... mais la mise en place demande 5 minutes chrono. Branché via câbles XLR depuis un Lecteur Réseau "Eversolo" faisant office de Préamplificateur (modulant ainsi le Volume) en ayant bien pris soin de Baisser à -55 dB le Niveau de Mise en Service . . . car ces Fosi V3 mono poussent fort.
Dès la mise en Écoute, cela sonne déjà correctement, pour un Rodage (-42 dB) de plusieurs Heures sur divers Types de Musiques, sans trop s’inquiéter car j'ai lu partout que ces V3 Mono chauffaient légèrement.
Au bout d'une dizaine d'heures, cela s'ouvre réellement Plus, donnant vraiment l'équivalent de mon SANSUI AU-α 607 NRA II (rendant bientôt l'âme).
Pour l'instant, je n'ai presque jamais dépassé le Niveau -30 dB qui dégage déjà beaucoup de Watts ! ! !
Seul souci rencontré, l'un des deux V3 Mono ne commutait pas en Veille * au bout des 10 minutes (sans aucun signal) avec le Commutateur de Gauche sur Auto, comme c'est prévu.
Ayant lu pas mal de Très Bonnes Analyses & Mesures de ce FOSI V3 mono, sur "audiosciencereview" & ailleurs, le mode veille ne semblerait pas vraiment efficient (économie Wh & repos des puces), donc autant les commuter manuellement sur Off.
Le SON est très Propre, avec ce qu'il faut, tout en Haut ~ en Medium & dans les Graves, ce qui n'est qu'une demi-surprise, ayant déjà acheté un V3 "stéréo" qui chante déjà bien, via de petites Eltax Monitor III sur un système "voyage".
Ces 2 petites boites ont vraiment du Coffre pour driver facilement mes Elipson Prestige 4 recapées, avec Musicalité & Rigueur !
* J'ai contacté FOSI afin de leur signaler, et... ils répondent de suite puis me font livrer une Nouvelle Carte (mère) afin de remédier à ce problème de Mise en Veille Auto ;°)
FOSI me signale aussi qu'ils attendent & analyses Toutes remarques constructives venant de ses Clients, afin de faire progresser, eux ~ leur Matériel & Produits HiFi, ce qui me semble carrément une démarche plus que remarquable.
SAV juste Impeccable & très Professionnel !
(& Je n'ai aucune action dans cette société chinoise...)
Jean Michel P.
Ne vous fiez pas à l'apparence et au poids plume de ces fiches bananes mais question transparence elles sont tout à fait incroyables. Je pense que ce résultat vient du fait que très peu de métal ne vient colorer le son. Je les utilise en mode sertissage.
Hervé R.
Pas si bien que ça !
La qualité audio est bien au rendez-vous, mais mécaniquement le câble fait des boucles des nœuds et il devient très peu pratique sur une scène avec une guitare par exemple. De plus à force d'être obligé de le dénouer régulièrement il risque de na pas durer dans le temps.
Dommage.
Hervé
Paul A.
Transcendée.
Une expérience d’écoute optimale avec une alimentation linéaire de qualité, comme l’Audiophonics 12V, améliore la stabilité du signal de DAC :
• Moins de bruit de fond (baisse du bruit de commutation haute fréquence)
• Meilleure scène sonore (plus de profondeur, de micro-détails)
• Timbres plus naturels
• Grave plus tendu.
contribuant ainsi à une meilleure restitution sonore précise et fluide de mon système hi-fi.
Dominique M.
Très déçu
J'utilisais auparavant un préampli Dual TVV47. J'ai acheté ce produit car plus récent et avec une connectique plus riche. Mais hélas le son obtenu à partir de ma platine Technics connectée au TC-4 présente une forte distorsion même à faible volume. Très déçu j'ai rebranché mon vieux Dual qui fonctionne parfaitement.
Sébastien R.
DD M130B USB-C to CIEM 0.78mm Copper OCC Cable Portable Headphone Amplifier DAC ES9603Q 1.2m The M130B cable from ddHiFi is an all-in-one headphone cable, which as well as offering signal transmission via an OCC copper core, includes an ES9603Q chip that acts as a DAC...
J'ai voulu la tenter d'avoir une solution tout-en-un sur mon smartphone qui fait exactement le même encombrement qu'un jeu d'écouteurs et pas plus, et franchement c'est incroyable.
Je m'en suis servi comme câble de remplacement de mes 7Hz Salnotes Zero, la référence qualité prix imbattable des intra (branchement en 2 pin 0.78 CIEM), en mettant à la place le M130B qui fait câble OCC (très haute qualité, mieux que l'OFC) et qui intègre le DAC et l'ampli avec une puce ESS Sabre qui fait extrêmement bien le boulot.
Couplé à USB Audio Player Pro (obligatoire pour avoir du bit perfect et bypasser le mixer Android qui rééchantillonne tout et dégrade le son), avec des fichiers haute résolution (24 bits/96 kHz) et de bons masterings, c'est du délire pour un prix super raisonnable et un encombrement ridicule.
J'ai fait du A/B test avec ma config casque à 2000+€ et ok c'est moins bien mais pas de beaucoup, ça vous donne une idée (pour ceux qui connaissent, j'ai un T1 recablé en UP-OCC avec DAC, ampli et interface USB de chez Audio-gd).
Utilisez obligatoirement UAPP et la bonne config bit perfect, on voit très clairement la différence.
Aucun problème pour driver les Zéro niveau amplification avec le M130B.
Pour une utilisation nomade si vous ne voulez pas vous encombrer qui plus est, ne vous posez pas la question !
Arnaud L.
IEAST OLIO Receiver WiFi 2.4G/5G DLNA AirPlay 2 Bluetooth 5.0 24bit 192kHz White With the Olio, iEast offers a compact and powerful wireless audio receiver that works with both WiFi and Bluetooth. Extremely versatile, it supports numerous transmission...
Mini Streamer au rapport prix/musicalité étonnant
Relié en Wifi à ma box et alimentant une paire d'enceintes amplifiées, ce streamer fait bien le job: transparent et musical, compact, appli bien conçue. S'assurer d'avoir un bon signal Wifi car le raccordement filaire à une box ou un switch via une prise RJ45 n'est pas disponible.
Tom K.
LHY AUDIO OCK-2S Master Clock OCXO 10MHz Black The LHY Audio OCK-2S is a high-precision master clock with ultra-low phase noise, designed to minimize sampling errors on high-resolution streams. This clock features six...
I used the Ock-2s in conjunction with a Singxer SU-2 to reclock a Topping D90iii via i2s. This combination clearly beats the Singxer SU-6 which does not have a clock input but also has a accurate clock built-in..
I was sceptical to try a master clock for listening purposes (as opposed to sound studios) but In my system it works very well.
This clock by LHY has converted me into an audio master clock believer. At least in my own systems I am never going to listen to digital audio again without a good clock in the chain.
It simply takes care of removing that last bit of digital edge/jitter/smear...whatever stuff of digital audio you don't want.
I do believe it requires a really revealing and neutral system to get the most out of it.
Svilen I.
LINDY CROMO LINE Interconnect Cable RCA-RCA Copper Gold Plated 2m (Pair) The Lindy Cromo Line RCA cables benefit from a beautiful design quality. Its conductors are made of Copper ensuring a very good conductivity and its connectors plated with 24k...
Excellent build quality
Excellent build quality - perfect interconnect. It is very bendy and thin.
Svilen I.
MINIDSP POCKETADC ADC Converter ES9821Q RCA to Coaxial / Optical Toslink 24bit 192kHz The MINIDSP Pocket ADC is an analog-to-digital converter featuring a stereo RCA analog input and two digital outputs, a Toslink optical output and a coaxial SPDIF output. Thanks...
Excellent box
I have a soundbar that lacks of any analogue inputs. Using this device I can connect my old AM/FM tuner to it. The build and sound quality is excellent
Zacharias L.
TANCHJIM ZERO ULTIMA In-Ear Monitors Dynamic 30 Ohm 123dB Jack 3.5mm Tanchjim Zero Ultima in-ear monitors offer exceptional performance at an affordable price. Each earphone features a DMT 4 Ultra dynamic driver with titanium-plated composite...
Good vibrant sond
The parcel has been received in around 1 week using slow delivery to Greece with no problems.
Nice box design and a earphones with a simple pouch they are not a IEM model but standard plug in earphones. The remain design ensures a IEM type of cabling and plug.
Tested in the road rthe same day with a old type DAP they delivered a quite trebly sound as with any other tested earphones so far, The original recordings have lots of treble as like Dolby cassettes in which the Dolby option is not used! Using other more linear recordings the sound is heard very close to the original I hear in my stereo. All fidelity is herd from the lowest possible level compared to the other earphones!
Replacing the buds with comply types added a few db of bass making the sound more vibrant!
István R.
excellent silver cable
The cable is a big surprise for me. I was planning to replace the legendary Siltech SQ-110 Classic MK2, which I have been listening to for 20 years. The list price of the SQ-110 1m pair was 2600EUR. This NEMOI-1220 with DIY assembly at 1/6 of the price slightly surpasses the SQ-110 cable in sound already before burn-in.
A terrible negative is the peeling of the 0.1mm thick clear Teflon insulation covering the square silver conductor.
Jean-Pascal H.
EVERSOLO BTR-12 IR / Bluetooth Remote Control for DMP-A6 / DMP-A6 Master / DMP-A6 Gen 2 / DMP-A6 Master Gen 2 This IR / Bluetooth BTR-12 remote control developed by Eversolo is designed to be paired with all their DMP series devices, i.e. the DMP-A6, DMP-A6 Master Edition, DMP-A6 Gen 2,...
Indispensable pour piloter l'Eversolo pour un prix plus que contenu à mon avis :)
Jean-Pascal H.
EVERSOLO DMP-A6 GEN 2 Streamer 2x ES9038Q2M WiFi DLNA Roon Bluetooth 32bit 768kHz DSD512 The Eversolo DMP-A6 Gen 2 is a HiFi network player that seamlessly combines outstanding sound quality with cutting-edge technology. More than just an audio device, it's a new...
Au Top
Produit au top super qualité de fabrication et surtout audiophile , il doit y avoir des défauts peut être perso je n'en ais pas trouvé et j'ai pris le temps pour donner mon avis, je recommande sans réserve , on ne peut plus dire que les chinois ne savent pas faire merci à Audiophonics également pour leur réponse rapide à tous les questions.
Johan V.
Exceptionnel
