Franck M.
Franck M.
excellentissime
Vincent B.
Bof
Customers reviews - There are 19133 reviews.
Arnaud K.
Pas des plus évident à câbler proprement mais avec de la minutie on y arrive
Christoffer P.
Terrible banana plugs
The banana plugs on these cables are terrible. I was plugging them in to my Audiophonics amp (MPA-S250NC), so far so good. Then I unplugged them and the "shell" of the banana plugs got stuck in the binding posts of the amp. I had to use tweesers to remove the small metallic parts from the amp and was scared that I would damage the amp.
Otherwise the cable itself is OK. Very thick but pretty flexible.
Christoffer P.
Excellent amp
I have been using this amp for a few weeks now and can only praise it. It has plenty of clean power to drive my system and no audible distortion. XLR connections work nicely.
Package was wrapped very good with nothing moving around.
Took more than two months after order to get, but that was more to do with the current COVID situation. Customer service answered my questions well enough when order took longer than anticipated. But a little more information without having to ask would be nice.
christophe S.
TRES BON
Se connecteur est neutre avec des timbres juste sans le coté blanc de certain connecteurs,musical et sans dureté ,le rhoduim n est pas montant ,comme beaucoup, de personnes le pense ,tous dépend de son systéme.Si vous avez un son montant ,le rhoduim étant neutre va ciblé se déséquilibre,car cette matiére est sans compromis.Par contre si vous avez un son équilibré elle vous délivrera un message musical et vocal réaliste ,avec une bonne tenue général .Convient tres bien avec un son mat aussi .
TESTER avec Cable tunami V2 OYADE ou tc31
FURUTECH iec viborg R et schuko viborg R Musicalement a tous.
Frank d.
New power supply
My old SMSL broke down which meant no music in my garden shed.
I found the right replacement at Audiophonics which was delivered to the Netherlands in about 4 working days. Excellent service.
And the product works fine with my SA-50 amplifier.
Robert P.
AUDIOPHONICS PSU S4-HP Linear Power supply Module DC Micrel29752 The Audiophonics PSU S4-HP power supply module has been designed to provide a clean DC voltage supply to an amplifier or other audio circuit. Its particularly rigorous design,...
Sound
So far this has proved be excellent, voltage once set is rock solid, although the load i have on it is well below its rating (maximum of 2amps) and at that it runs cool.
Fairly robust it has with stood a dead short on the output due to me using a faulty low voltage power socket. In dead short conditions the unit did get hot and then shut down, after removing the the short and letting it cool down it powered back up and is sound.
Pair with a good transformer and you have an excellent linear power supply, recommended.
Jean-Louis r.
une vraie amélioration
il y a incontestablement une grande différence par rapport au cordon basique d'origine.
Tout est mieux défini, plus précis avec une meilleure dynamique.
Bref: n'hésitez pas !!
Attention: le cordon secteur n'est pas fourni..
Grégory B.
Quoi de plus ?
Ayant fait récemment l’acquisition d’un casque, j’avais passé commande du couple A30/D30 de chez Topping, sur Audiophonics.
Le dac D30 avec sa puce CS ne correspondait visiblement pas à ce que je recherchais. Et cela, que ce soit au casque ou au salon sur les enceintes B&W ou d’autres matériels. L’ampli A30 était bien pour ce que je puisse en juger, connecté à un dac sabre 9023 ou la platine en 9018 du salon. Les dac sabre semble plus correspondre à ce que j’aime.
Ce petit combo 9028 et ampli class A me semblait être une bonne alternative à essayer.
Et bien comment dire, je ne remercierais jamais assez audiophonics de proposer ce type de matériels et surtout à ce prix. Je ne sais pas si d’autres boutiques comme celle-ci existe dans d’autres pays, mais je trouve que de disposer d’une enseigne comme audiophonics en France est une vrai aubaine. Surtout que les envois sont rapides, le site est clair, on dispose de détails sur les matériels …
Je suis conscient que les avis sur le son que produisent ces matériels sont subjectifs. Ce qui plaira à certains ne plaira pas à d’autres, certes. Ce qui suit doit donc être pris avec des pincettes, mais je suis vraiment resté assis lors des premières écoutes.
Des frissons dans tout le corps, je ne sais pas ce qui apporte le plus, la puce en 9028, l’ampli en class A ou la combinaison des deux, mais je suis vraiment resté scié.
Je ne suis pas un habitué des casques, j’étais avant surtout porté sur le couple ampli/enceintes dans un salon non traité (donc pas idéal), mais c’est la première fois que ça me fait ça toutes écoutes confondues.
Bref au casque, je n’ai pas testé la sortie RCA, c’est à la fois détaillé et les voix, les guitares sèches/électrique, tout prend vie, même l’électro prend de l’ampleur.
Encore une fois, cela correspondant peut-être aussi à ce que j’attendais comme « son » et mon avis est très positif, mais il est à mettre en relation avec le prix de « l’objet »
J’en viens à me demander ce que l’on peut vraiment espérer de matériels qui se vendent à des milliers d’euros … et le plus drôle, c’est qu’il y a justement quelques milliers d’euros dans le salon entre les amplis, les enceintes … et la claque … ben elle était au bout d’un ampli/dac à 130 euros et d’un casque fidelio X2HR de Philips à peu près au même prix …
Pour conclure, merci audiophonics
Gilles J.
Produit satisfaisant
Bon rapport qualité/ prix, système satisfaisant.
Marc L.
Ce câble fonctionnait mieux dans mon environnement qu'un câble qui coutait beaucoup plus cher. Par contre, ce dernier câble était meilleur dans d'autres environnements. Comme quoi tout est une question de mariage. Au niveau des qualités de l'AUDIOPHONIC, j'ai noté de la précision après un période de rodage dépassant une dizaine d'heures et une belle ouverture. C'est un câble a tendance neutre.
HIDIZS AP80 DAP HiFi DAC ES9218P 32Bit/384kHz DSD Bluetooth aptX Gray With its AP80, Hidizs offers a DAP in a really small format to accompany you throughout your day, while ensuring excellent audio performance. Indeed, the portable player...
Il a tout d'un grand ce petit !
Tout petit, il tient dans la main et peut être manipulé sans l'autre. L'objet est beau. La coque silicone (indispensable pour protéger l'entrée de la carte SD) n'altère pas son look.
L'écran est très lisible, fluide, je m'en inquiétais un peu avec mes gros doigts.
Je lui trouve cinq défauts d'ergonomie :
-1- On ne pas lancer un album entier en un seul clic, faut rentrer dans l'album et cliquer sur le 1er track (une manip de trop quoi !).
-2- Je tags moi même ma musique avec mes "genres". Ils apparaissent bien dans la liste mais mélangés à d'autres genres. Là, je ne comprends pas. Toute ma musique retaguée est reconnue sur AIMP, médiacenter, bluesound ... mais pas sur le DIHIZS qui me rajoutent des "genres" que je n'ai pas. J'ai vérifié la SD sur un éditeur de tags. DIHIZS est mythomane.
-3- La lecture aléatoire se fait uniquement sur l'ensemble du contenu de la carte SD.
-4- L'aléatoire encore. Pas possible d'être en aléatoire sur un "genre" souhaité. Là, suis pas content du tout. J'aime écouter en aléatoire sur le tag "genre". Par exemple, en Jazz, j'ai les tags "jazz-piano, Jazz-rock, Jazz-word ... Si je veux écouter aléatoirement parmi les artistes répondant au tag "Jazz-Piano" ... je ne peux pas.
-5- Quand vous demandez les albums d'un "genre" il vous les donne par "Album" et non par "Compositeurs -Album" :
Soient tous les albums de Pink Floyd, de Airbag et de Porcupine. Vous aurez le résultat par ordre alphabétique des Albums. C'est ballot ...
L'essentiel à présent : Le son.
Là, c'est magnifique. J'ai un casque Divore Addict filaire ET Bluetooth APTX-HD, j'ai exactement ce que je souhaitais entendre. Du silence entre les notes, de l'aération, du grave présent mais pas bourrin. Le DIHIZS est très puissant et possède deux systèmes d'équalisation performants. Un classique et un très sophistiqué MSEB qui m'a surpris par son efficacité.
Prochain essais sur un casque filaire haut de gamme.
Je recommande ce baladeur pour son prix et son excellent son, je remettrais une étoile si quelqu'un m'explique comment enlever les 5 défauts d'ergonomie ;)
Laurent M.
Ras
Produit conforme, livré en temps et en heure...
Marc L.
Belle et bonne gaine pour des cables a grosse section
Plamen T.
Good looks but bad material
These are from some kind of alloy with bad conductivity, not copper. Gold plating is not enough to conduct such high currents. Look for a real copper terminals.
Bruno G.
L'acquisition de cette alimentation ipower est-elle une bonne chose ? Je crois que la réponse est oui. Les gains sont multiples, en tout cas, dans le contexte de l'utilisation du petit dac usabre d'audiophonics. Ce dac, très bon au demeurant, devient excellent. L'amélioration de la transparence, des petits signaux, du relief et de l'extinction des notes, entre autres, donne une lisibilité et une musicalité accrues.
lezzoum h.
TOPPING D90 Balanced DAC AK4499 XMOS XU208 I2S 32bit 768kHz DSD512 Bluetooth 5.0 Black A direct successor to the D70 Topping, the D90 benefits from the same refinements as its big brother while updating its DAC with a newer and more efficient version, the AK4499...
Satisfait, un gain significatif,
Bonjour, d'abord bravo à l'equide d'Audiophonics, qui m'ont envoyé le produit aussi rapidement, sachant qu'on est sous confinement, le DAC est utilisé comme dac pure sur un streamer attol 200 "son agressif"et préamp attol pr 300 qui est équipé d'une puce AKM =4490, ampli Marantz mm 7025 et enceintes Chorus 836, je peux dire que j'ai un gain significatif en qualité sonore, plus de profondeur dans les graves, le medium reste relativement neutre pour mes enceintes, y compris dans le haut medium"maillon faible de mes enceintes" transparence, le timbre et qualité des aigues très appréciés, bref je ne regrète pas mon achat, ah oui pour l'instant j'utilise l'entrée coaxal et sortie RCA, je n'ai pas branché encore avec la sortie XLR directement sur l'ampli Marantz, d'ailleur je demande si quelqu'un peux me conseiller sur un cable XLR qui va avec la gamme de mon matériel. Je reste disponible pour partager ma modeste expérience .
Ce streamer véritable couteau Suisse est une très bonne affaire a ce tarif, il est "presque" résolument hifi, en clair excellent pour une écoute de très haute qualité et il est dommage qu'il soit entachés de bugs qui sont difficile à résoudre. De plus le firmware fourni par smsl ne rend pas justice à l'appareil un groupe de passionnés Russe ont réussi a faire une rétro ingénieries sur le firmware et ont supprimé une particularité de l'original qui consistait à réinjecter sur canal gauche le signal inversé du canal droit et affaibli de 18db c'est une astuce qui permet d'obtenir a l'écoute une image plus large et plus profonde mais au détriment de la signature réelle de ce Dp3 qui en devient presque brouillon.
Si vous cherchez ce firmware sur Gogol cherchez à Pogoo + forum des indépendants. Je ne sais pas si Audiophonics laissera passer cette info mais si oui sachez que ce lecteur excellent en deviendra fantastique.
Par contre désolé j'ai pas testé le Dac et je ne le ferai peut être pas.
Musicalement
Eddy R.
Très bonne qualité
En remplacement de mes 12AU7 Cayin d'origine, ils apportent plus de détails dans les haut médiums et aiguës, plus de clartés, je n'en suis qu'a 20H d'écoute j'espère ne pas devoir revoir mon jugement après plus d'heures.
Cernat G.
Good
For this price...it works! :)
Jean-Marie G.
surprise !
Bonjour, ...... oui grande surprise.
Excellent amplificateur, sur les premières heures d'écoute: grave excellent, aigus très fin et détaillé - de l'air ! - le medium à peine moins bon que les deux extrêmes pour l'instant...
Le contexte: ampli pas rodé, auditeur habitué aux tubes ( qui restent, à ce stade, plus à mon gout, sur le médium uniquement, car pour les extrémités du spectre c'est du très très qualitatif !); les enceintes ont deux modes,
Mode 1:des large-bande Phy-hp ( 21cm, bobine argent ) sur petit baffle plan avec en parallèle deux 38cm Yamaha dans 75 litres chacun filtrés par self de 3.8mH et un peu boosté en bas, obligé.
Mode 2: le même que le précédent avec un filtre actif numérique ( mini dsp ) qui le coupe à 780 Hz et relayé donc par ampli tubes (pp 6v6 schéma Dynaco ) qui alimente des compressions Altec 802D sur pavillon 811 avec en // à l’arrière une paire de compressions Yamaha sur petit pavillon Guigue filtrées par 1 microF orientées vers le haut, à l’arrière du pavillon 811 donc. Le mode 2 est donc une bi-amplification 3 voies et demi, actif/passif.
Ca matche parfaitement, cet Amp25 fait le job jusqu'à 780Hz et la transition ne se fait pas sentir..... Si le medium s'adoucit avec le rodage ça va être terrible en mode 1 ( large-bande ) ! Je reviendrais poster un avis plus tard, merci à Audiophonics d'avoir choisi d'importer ce petit bijou.
Pas testé le bluetooth...
Ludovic L.
Cela fait plusieures fois que j'achète ce modèle et pour son tarif il n'y a rien à dire. Les finitions, la fixation du câble et la connection aux borniers sont excellentes.
Ludovic L.
Utilisés pour doubler les sorties d'un préampli, la finition est excellente et l'objet est très qualitatif, aucune perte du signal.
Ludovic L.
J'ai acheté ce préampli pour installer deux amplis Tripath Trends TA 10.2P en blocs mono chacun amplifiant son enceinte. Je ne voulais pas dépenser une grosse somme mais avoir un contrôle de volume et de tonalité.
C'est plutôt pas mal du tout. Pour le moment j'ai juste essayer avec mon baladeur Hi-Res.
Dominique A.
MATRIX X-SABRE PRO MQA FULL DECODER DAC USB I2S ES9038PRO 32Bit/768kHz DSD1024 Black With this updated version of the X-Sabre Pro, Matrix offers us a 32bit DAC based on an ES9038Pro chip. This new version adds support for Master Quality Authenticated (MQA)...
superbe qualité de fabrication et superbe écoute .
Bonjour , livraison rapide , très content et satisfait de ma commande . Produit sérieux , de qualité , construction haut de gamme . Qualité son sublime . Merci AUDIOPHONICS .
A. D.
Sandro R.
One of the best
It will certainly be the most neutral cable I have ever had.
High quality construction
Nice Price
Helmut H.
TOPPING A50 Headphone Amplifier Balanced Silver The Topping A50 is an efficient and affordable sedentary headphone amplifier. Its careful design makes it an ideal ally for any audiophile wishing to enjoy a rich and clear...
I also like that Amp..
.. but I'm only a listener, it is my second Headphone-Amp. For me it sounds nice and can drive a Sennheiser HD650 at +9dB loud enough for my ears.
I can't say anything more than the reviewer before, it's all I perceive myself.
The ordering process from Germany was very agreeable. I had one RMA, but it was a problem with the source I connected, not the Amp itself. The RMA was really painless. The concerns ordering a product outside my country are discarded. Thanks for that nice and gentle process!
Kirsch p.
IFI AUDIO HIP DAC Portable Balanced Headphone DAC Amplifier 32bit 384kHz DSD256 MQA iFi Audio presents the HIP DAC, a DAC combo and nomadic symmetrical headphone amplifier, both compact to accompany you in all your travels or on your desk, but also benefiting...
Avis d'un néophytes ^^
Étant mon premier DAC je ne peut pas vraiment être objectif mais cest que je peux dire c'est que j'ai redécouvert mes morceaux il est précis et l'ouverture de scène qu'il apporte est gigantesque (de mon point de vue de débutant^^) il y à un peut trop de basse a mon gout mais je suis un psychopathe du son neutre donc bon... Rien a redire pour moi à si les leds sont sensé changer de couleur en fonction du type de fichier du coup j'ai essayé un fichier en mQa pour le voir s'illuminer d'un magenta mais la couleur n'a pas changé.
Eemeli V.
Automatic Input Selector 4 Stereo RCA Inputs This module automatically switches between 4 stereo sources. The selection of sources is carried out fully automatically from a signal of at least 0.2V.
Not for HI-FI audio!
If your plan is to connect multiple audio sources to active speakers or ampfilther THIS IS NOT THE RIGHT DEVICE! When input is selected a loud "bang" noice is heard from your speakers. And when there is no output the device continously switches between inputs and same sound will be heard again and again.
Michel B.
Très bien mais pourrait encore mieux faire
Mécaniquement il est très bien et robuste.
Ergonomiquement il est facile à souder avec une pin centrale qui permet d'enfiler le câble central profondément, et un corps facile à souder avec un système de serrage du câble par pincement correct. Sur ce point, le OYADE est plus abouti, mais je ne suis pas certain que ce soit mieux en pratique.
Le diamètre du trou de passage du câble est largement suffisant pour tous les câbles utilisés en DC, même si vous utilisez un 4 conducteurs 24-AWG.
Pas loin du sans faute donc pour la partie mécanique et ergonomique.
Parmi les connecteurs DC disponibles, c'est le seul avec le OYADE à indiquer le métal utilisé: Laiton pour les 2 fabricants, mais le OYADE est 2 fois plus cher...
En terme de rapport Q/P, il me fait l'air bien mieux placé que le OYADE qui propose le même matériau (laiton). Si OYADE proposait du cuivre, l'écart de prix pourrait se comprendre.
Cependant pourquoi ne trouve-t-on aucun connecteur avec contact en vrai cuivre ??
Sans aller jusqu'au UP-OCC, on est légitimement en droit d'espérer un connecteur DC en cuivre !
Les fabricants auraient-ils oublié à quel point la qualité du matériau est essentielle dans un connecteur ?
Robert P.
Nice looking box on a budget
On the plus side the box once assembled looks good for a relatively budget box and is performing the job I required.
On the negative side the small bolts that are used attach the base and the top plate to the side plates are very short and only just catch the nuts they screw into, they are effectively one shot use. If you need to remove the top plate to gain access after assembly the bolts will be scrap and need replacing, fortunately there are some spare bolts in the kit I had.
Another negative is that there is no electrical continuity between the components which if you intend to put mains voltages in the box is potentially dangerous. As I was constructing a power supply one of the main components was a transformer from 240v to 12v so this was an issue for me. To get continuity I had to remove the paint from all the jointing faces in order to get an electrical continuity and enable the box to be earthed, not ideal.
Pierre B.
Etonnant
Pour 45 € vous ne risquez rien saut d'être très agréablement surpris.
Comme constaté sur un avis précédent le gain est faible (28 quand même) mais avec un préampli de qualité , à tube chez moi, le résultat est excellent. Monté en double mono avec des toriques 2 x 30V, les modules d'alimentation 4 x 10.000 µ / 50V; les protections HP 11657 le résultat est bluffant pour du bipolaire.
Bande passante mesurée de 5 HZ à 200 KHz, puissance avant écrêtage 78 V crête à crête pour 2,8 V en entrée ce qui nous fait 95 W efficaces avec une alimentation à +/- 44 V.
Pas un souffle pas une ronflette.
Très bon achat à conseiller.
Photos du montage en du signal carré à 1KHz à disposition.
Pierre B.
Super rapport qualité prix
Rien à dire j'en suis à ma troisième paire, fiable silencieux, bonne réserve de courant même sur un double mono en classe A
Olivier W.
Filtres... Quoi comment pourquoi ?
Ravi d'utiliser ce DAC, mais quelqu'un pourrait-il m'expliquer la signification et l'utilisation des différents filtres présents sur ce DAC ?
En l'absence de notice et d'explications, je suis totalement incapable d'exploiter ces fonctionnalités ajoutées, et cela est bien dommage... Merci pour votre aide à tous !
Voici l'article le plus complet que nous connaissions sur le sujet :
https://www.audiostream.com/content/what-are-digital-filters-and-why-are-they-requried-todays-audio-dacs-resonessence-labs-tech-3
Mikhail I.
Topping DX7 Pro
Great service and fast delivery. Item arrived in perfect condition.
christophe S.
Trés bon rapport prix
Se connecteur et le plus haut de gamme de chez viborg meilleur que la pure cuivre, ou la gold .Elle a une tenue du grave, une aération un timbre plus juste sans coloration ou chaleur superflu pourtant elle n est pas froide ou montante elle sonne juste sans douleur de certaine prise roduim,elle laisse juste couler la musique .( Cable secteur oyade tunami v2 schuko viborg aluminuim roduim et cette iec roduim).Rapport prix de haut niveau.
Clément M.
A-t-on encore besoin de le recommander?...
La référence quasi-absolue dans l'univers du DAC/ampli/preamp.
Reconnue mondialement autant par le milieu professionnel qu'amateur, on sait ce qu'on achète: C'est Made In Germany, c'est garanti 5 ans, ça mesure super bien et c'est utilisé tant en studio, qu'en conception d'ampli... et finalement dans les salons pour une simple utilisation Hi-Fi.
- Matthias Carstens de RME, le concepteur, est ultra actif sur les forums et montre un niveau d’ingénierie et de connaissance technique sans faille.
- Le firmware est régulièrement mis à jour avec des ajouts bienvenus.
- La partie préampli est vraiment un sans faute. En Auto Ref Level, on a juste accès à l'ajustement de volume le plus clean et précis que je connaisse pour driver un ampli de puissance.
- Les parties ampli casque et IEM ne sont pas en reste avec une transparence sans faille (et "suffisamment" de puissance pour 90% des casques)
- Les possibilités de DSP sont exceptionnelles, même si personnellement, je l'utilise en réglages "stock".
- Inutile de vous prendre la tête sur la "sonorité": C'est d'une neutralité et d'une transparence parfaite. Point barre.
L'avantage, c'est que quand on en possède un, inutile d'aller voir ailleurs, la concurrence est littéralement larguée. Oubliez les marques pseudo-audiophiles et leur discours marketing douteux. Oubliez l'idée qu'à deux ou trois fois plus cher, vous pourriez avoir mieux. Ici, on joue à un autre niveau... celui des pros.
Michel B.
Des connecteurs excellents à tous points de vue !
Des connecteurs XLR il en existe des dizaines, mais lorsque l'on cherche des connecteurs de qualité, cela devient beaucoup plus difficile.
Concernant le matériau utilisé pour les contacts, ces YARBO sont les seuls où le mot "cuivre" est prononcé, au travers de l'appellation "alliage de cuivre". C'est imprécis mais c'est mieux que pas d'indication du tout, ou une indication "laiton".
Certes cela ne vaut pas le cuivre UP-OCC des NEOTECH haut de gamme, mais ces derniers valent 3 fois plus cher.
Entre le prix de ces YARBO et celui des NEOTECH, il y a de la place pour des connecteurs en cuivre de haute qualité, ce qu'aucun constructeur ne propose (en tout cas pas trouvé).
Pour le reste, ces YARBO affichent un sans faute: la construction mécanique est exceptionnelle, d'une solidité à toute épreuve !
Même la partie foncée (par où rentre le câble) est en métal et pas en plastique.
La vis qui sert à verrouiller le connecteur une fois monté est en métal et le filetage dans lequel elle se visse est lui aussi en métal !
Enfin, la pièce qui tient les 3 contacts est indestructible: contrairement à ce que l'on peut lire sur d'autres connecteurs, vous pouvez souder et chauffer, elle ne fondra pas d'un yota.
Voici des connecteurs XLR mécaniquement exemplaires, et avec des contacts comportant du cuivre (ce qui est devenu rarissime).
Il reste à espérer que YARBO ou d'autres sortiront un connecteur en vrai cuivre, à un tarif à mi-chemin entre celui et le NEOTECH UP-OCC.
zeev m.
n'hésitez pas... c'est probablement le meilleur
La qualité FDA (full digital) est impressionante.
Malgré certaines mesures de la distortion (audiosciencereview...) l'AD18 reproduit les sons de manière exceptionnellement naturelle et on entend les plus aigus des sons aigus (guitars, pianos percussions...).
pas de distortion audible, cela s'explique par:
1. le volume d'écoute habituelle ne produit pas trop de distortion
2. notre oreille n'entend pas des différences si minimes.
3. j'ai plein a'autres hypothèses...
MAIS ATTENTION : sur le line-in l'ad18 n'est pas très bon mais pour moi aucun intérêt, l'AD 18 n'est pas fait pour analog et on écoute actuellement surtout sur bluetooth.
Pour ceux qui hésitent avec le SA300, l'AD18 est nettement meilleur (j'ai comparé, mais pas d'avantage sur line-in)
Nicolas C.
Petit boitier
Je l'utilise pour rendre une enceinte Muse connecté au réseau, afin de mettre des histoire à ma fille. Ca fonctionne parfaitement. Le boitier est visible sur BubbleUpnp , spotify (et d'autres que je n'ai pas testé).
Attention au premier paramétrage. bien lire la notice, pour l'associer au réseau WIFI il faut appuyer sur le bouton WPS, ceci afin que le logiciel Audicast le reconnaisse et que l'on puisse le paramétrer.
Ce M5 fonctionne comme borne WIFI avec son propre réseau, ce qui peut être pratique si vous perdez le réseau principale. Ce n'est pas du gros débit, environ 2-3 mbits.
Nicolas C.
Cable Male USB-C 3.1 to Female Jack stereo 3.5mm 10cm This cable consists of a USB-C male connector (3.1) and a Jack 3.5 female plug. It will therefore allow you to connect a 3.5mm jack device to a device that does not have this...
A recommander
Câble tel que je l'attendais, fonctionnel, prix correct. Ne pas s'attendre à un DAC. Je l'utilise pour connecter mon téléphone sur des enceintes (kit 2.1 pc) que j'ai installé dans mon garage. Parfait.
Nicolas C.
Jean-Francois C.
Super!
Achetées pour remettre en état mon AUDIOMAT "Prélude" de 1994... Incroyable, ce sont les mêmes que celles d'origine! Une fois encore merci à Audiophonics pour la sélection rigoureuse de leurs produits (en l'occurence MONACOR)...
Pas très pratique à utiliser
Ma note ne concerne pas la qualité du son puisque celui-ci est équivalent à un câble coaxial Wireworld Ultraviolet en ma possession.
Ce câble-ci est beaucoup trop rigide et donc difficile à utiliser sans causer une pression sur les connecteurs.
Connecteurs qui ne sont pas de bonnes qualités à mon avis. Dans l'ensemble, je ne recommande pas ce câble.
Un câble coaxial blindé et par définition plus rigide que tout autre conducteur, dans votre cas je m’inquiéterais plutôt du manque de rigidité du votre.
Concernant les connecteurs ce sont l'une des rares référence de vrai connecteurs 75 ohm sur le marché.
Ils ont éprouvés depuis des dizaines d'années dans le milieu audio et vidéo sans le moindre soucis.
Sami M.
Very Good
Very good amplifier. Im using this with hifiman edition xx
Sami M.
Best dac that i have ever own
this dac is good and have features that competitors can only imagine at this price point
Istvan J.
Un bon rapport qualité / prix
À ma grande joie, j'ai reçu la livraison du Topping D50S la semaine dernière. Je l'ai inséré dans mon système audio. Le résultat confirme pleinement les opinions lues jusqu'à présent, il a une excellente voix, et même dans les graves, les médiums et les aigus. La dynamique du médium est étonnamment bonne, les chanteurs se font entendre devant les haut-parleurs. Mon système appartient à la catégorie moyenne, j'ai deux amplificateurs, un Cambridge Audio - Azur 640R, et un tubulaire (2X15 W, fabriqé par moi). Les haut-parleurs sont Tannoy (Dual Concentric) 635 Black Ash D50. J'ai beaucoup d'enregistrements DSD, ils sonnent trés bien, j'utilise le lecteur audio Foobar2000. Fait intéressant, l'entrée coaxiale ne reconnaît pas les signaux de mes deux excellents anciens lecteurs CD Philips (CD608 et CD614), mais je ne suis pas déçu car le lecteur DVD Pioneer DV-2850 et le lecteur CD Cambridge Audio 640C se comprennent parfaitement.
Xavier B.
Retour après quelques mois d'utilisation
Preamp très efficace pour le prix, le schéma électronique est simple et efficace, pour à peine quelques dizaines d'euros j'ai recapé l'ensemble avec de bon composants, la métamorphose est impressionnante on gagne de manière très importante en précision, donc au final très satisfait surtout pour les possibilités de tweking de l'objet sans arrière pensées.
CLAUDE S.
Il fait le boulot !
Matériel : PC ASUS K750J ; casques Sennheiser HD-25, Audiotechnica ATH-A1000Z, Fostex 7BB, Beyerdynamic DT-770 250 ohms. Musiques : principalement, jazz et classique.
Le Fiio K5 PRO a été rodé une semaine (allumé jour et nuit ; je n'ouvre pas un débat, je le fais à chaque fois). L’appareil est simple d'emploi. Il est solide. A l’écoute, il se révèle un parfait auxiliaire du son. Tout y est : soundstage, détails, basses, médiums, aigus non agressifs. Bon rendu des voix. Naturellement, moyennant un portefeuille plus garni, on peut sans nul doute trouver mieux. Mais il fait le boulot et dispose d'une bonne réserve de puissance. Le reste est affaire d’affinités. Ainsi, je dispose également d'un ampli-dac Fiio K10 dont la puce PCM5102 donne peut-être un son plus rond, plus chaleureux que la puce AKM AK4493. Mais là, c'est comparer un Bourgogne à un Bordeaux : une question de goût. En achetant le K5 PRO, le but était de pouvoir driver en toute quiétude un futur casque comme le Fostex T50rp MKIII. On verra ça. L'aventure ne fait que commencer. NB : merci à Audiophonics qui a livré sans problème le boîtier après un long temps d'attente pour les raisons que l'on connaît et indépendantes de sa volonté et qui m'a rassuré quand le temps me semblait long.
Didier G.
Mundorf 50+50uf
Produit finalëment reçu avec pas mal de retard lié au covid 19,
Mais trés satisfait
zeev m.
comparé à AD18
J'ai hésité pour le nombre de stars...
il n'est pas si mauvais mais comparé à AD18 ..... on comprend pourquoi AD18 est si récompensé...
J'ai attendu deux mois (corona) mais était impatient de recevoir cet ampli... justement pour comparer à mon AD18, et surtout puisque les mesures de la distorsion paraissent exceptionnels.
Mais l'AD18 gagne en marchant
la raison est probablement la qualité FDA (donc full digital) de l'AD18.
MAIS ATTENTION : Comparaison faite uniquement sur Bluetooth, sur le line-in l'ad18 n'est pas bon donc rien à comparer là (et c'est probablement là où le SA300 est meilleure, mais pour moi aucun intérêt à comparer cela, l'AD 18 n'est pas fait pour analog cela et on écoute actuellement tout par bluetooth).
Malgré les critiques des chiffres (audiosciencereview...) l'AD18 reproduit les sons de manière exceptionnellement naturelle et on entend les plus aigus des sons aigus (guitars, pianos percussions...). Ce n'est pas le cas avec le SA300, dont la sonorité est "plus douce" (mais pour mois moins "réaliste").
pas des différences audible concernant la distortion, cela s'explique par:
1. le volume d'écoute habituelle ne produit pas des large différences
3. plein a'autres hypothèses...
Donc la sonorité de SA300 est probablement plus " traditionnelle " mais cela signifie plus étouffée et plus loin des vrais sons des instruments/chant (j'ai quelques instruments de musique à la maison, ça se sent tout de suite)
Bluetooth également moins réactif pour SA300
J'ai fait des tests aveugles avec plusieurs membres de ma famille qui étaient tous d'accord avec moi...
Les haut parleurs était Davis colonnes ( les plus simples... sont excellents)
