Jean-François D.
Impeccable !
Vasilios K.
Ça Chauffe !
Customers reviews - There are 19303 reviews.
Jerome D.
Mis à l'entrée de mon streamer, il apporte une amélioration très notable et immédiate sur TOUS les critères d'écoute. Recommandé sans réseve
Chan Pong I.
AUDIOPHONICS HC TRIGGER SWITCH MKII Home Cinema Power Trigger Symmetrizer / Desymmetrizer The Audiophonics HC Trigger Switch MKII is a pilot-controlled source selector whose main purpose is to enable you to use your Hi-Fi system as the front channels of your home...
Quick and Auto switch No noise from Symmetrizer
At first, I am only aiming to get the auto/trigger signal function, not expecting the Symmetrizer is an upgrade from no brand aliexpress Symmetrizer.
The device build is great, I did not try the audio sensing mode but only RCA trigger from AV amp.
The switch is so instant without any pops or noise when switching.
I have not encounter any distortion or strange noise from the Symmetrizer function from this device( I notice some noise with aliexpress Symmetrizer). When comparing to what I used before ( actually 2 different Symmetrizers and both from aliexpress) the noise floor is so much more lower on audiophonics. Excellent job from audiophonics to release such perfect device.
If you are going to merge a Hifi system ( XLR output ). and another system with RCA Out to a XLR Poweramp with auto signal switching, this will be the device you are looking for!
Zdenek B.
I didnt expected this quality for this price! Didnt used it yet, but just by holding in hand everything looks great. No cold solder points, connections are straight.
Zdenek B.
Very good power supply. Adjustment is stable. Almost no heat dissipation with the right transformer.
Zdenek B.
These are great quality, sturdy enclosures. Only problem is out of stock :( We need more of them :D
Zdenek B.
Great price, great quality.
Zdenek B.
Module unbalanced to balanced symetrizer JRC 4580DD BTL stereo This audio module balances any HIFI-RCA-CINCH line-level asymmetric signal into a balanced-XLR signal independently and qualitatively. Equipped with quality passive components,...
The picture does not match the color of the actual item, but funktion is exactly the same. I am satisfied with the item.
Zdenek B.
Took a while to be shipped (custom make) but well worth it.
Zdenek B.
Speaker Terminals Rhodium Plated Ø19mm x 50mm (Pair) These speaker terminal blocks offer excellent design quality at an affordable price. Their contacts are made of rhodium-plated, ensuring excellent...
Quality
These are very good quality binding posts for the price. Highly recommended.
jeremy f.
Quelle affaire!
Après un week-end de test , je peux dire que ce lecteur n'a pas à rougir face à un ensemble de plus de deux fois son prix ( transport atoll +dac externe ess9038pro)
Le smsl est un petit peu moins précis dans les aigus, mais médium et grave au top.
La musique coule toute seule. A ce prix, une affaire.
Francis B.
Extra
Toujours un prix juste sur le workshop. Câble qui effectivement rassembles toutes les qualités. Pas d’agressivité, aiguës ciselés…médiums superbes et les basses gagnent aussi en dynamiques.
Superbe qualité.
Blindage double .
Eemeli T.
Hissy
Decent build quality but a bit hissy. Input display was mislabeled in my sample. Choosing USB-input did nothing but choosing BT input enabled playing music via USB, and in fact my PC recognized the amp as a BT-chip (via which, I believe, everythings internally routed). Line-level sub out is unfiltered so therefore more like a mono pre-out.
Jerome B.
AUDIOPHONICS AP310-P250NC Class D Integrated Amplifier NCore NC252MP 2x250W 4 Ohm Versatile and powerful, we offer you with AP310-P250NC an integrated amplifier with analog inputs to which you can add speakers to enjoy your music in the best possible way....
Quand aujourd'hui rien ni personne n'est plus fidèle, voilà au moins un produit qui respecte cette définition !
Il sera donc dit que je serais le premier à écrire un avis sur ce produit !
Comme tous les autres j’ai passé un temps infini sur le net à rechercher, comparer, étudier et finalement me décider. Le plus dur aujourd’hui c’est qu’il existe des milliers de configuration possibles mais quasiment aucune ne sont disponibles à l’écoute. Lors d’un choix les nouvelles salles d’écoute sont désormais le transport aller-retour que nous autorisent les fournisseurs : et ils ne sont pas nombreux.
Bref. Je viens d’une configuration Focal 836V + ampli NAD classe A + Caisson de basse Focal Cub + streamer Wiim pro plus + Platine Rega + vieille platine CD Philips. Ma destination : Focal Aria 906 + ampli classe D + streamer + DAC. Je garde aussi les autres vieilleries analogiques. Pourquoi un ampli classe D ? parce que j’ai eu à un moment un petit ampli Denon de cette classe qui, sans m’émerveiller, me plaisait par son côté « chirurgical ». J’ai eu aussi la possibilité (rare) d’écouter l’ampli Cambridge Audio Evo 150 qui m’a bien plu. Ce qui m’a moins séduit, c’est le tarif. Et puis la classe A, c’est bien, c’est chaud au son, mais c’est lourd et c’est un vrai barbecue.
Alors je me lance d’abord avec l’ampli Wiim Amp Pro. Belle petite boîte, fonctionnalités au top, mais manque cruel de pêche pour bouger des Focal, même petites. La scène est étroite, il manque clairement quelque chose. Cet ampli n’est pas fait pour Focal. Retour chez le fournisseur que je remercie vivement pur cet essai : maintenant un transport c’est moins cher qu’un auditorium.
Je ne retrouve donc chez Audiophonics et je me décide pour une sorte de « compromis milieu de gamme » avec cet ampli AP310-P250NC. Je vous fais grâce des mesures du site « Audio Science Review » (très bien mais peu d’informations quant à la qualité du son) et des fonctionnalités de cet appareil : chacun verra ses propres besoins. Je branche donc tout ce petit monde et immédiatement nous avons une scène large, des détails, une profondeur, largeur, hauteur, etc., etc. Tout le spectre sonore est présent y compris les basses Pas besoin d’une description de chef étoilé : l’artiste est chez moi et l’émotion est là. C’est tout ce que je demande. Même si l’ampli n’est pas concerné, j’en profite pour recommander le streamer Wiim Pro plus car les fonctionnalités sont vraiment excellentes et si le DAC n’est peut-être pas le meilleur du monde il faudra débourser beaucoup, beaucoup plus pour avoir les mêmes fonctionnalités et des performances supérieures.
Pour finir un petit mot concernant Audiophonics : tout d’abord ma commande a été livrée en 24 heures. J’achète sur internet depuis 2001. Aucun autre fournisseur n’a réussi cette performance jusque-là. Mais plus important : je suis particulièrement content d’avoir acheté un produit français. Vous allez me dire que les tripes ne sont pas françaises. Mais il y a bien longtemps que l’industrie du semi-conducteur n’est plus en France alors pourquoi investir quoi que ce soit pour faire la même chose que ceux qui sont déjà à des années-lumière de nous. Non, le vrai métier d’Audiophonics c’est le marketing achat et l’architecture des systèmes audio. Et là ils sont vraiment forts puisque leurs produits sont unanimement reconnus. S’y ajoute un service sans faille et vous avez un combo au top. Alors oui, je suis particulièrement content d’avoir acheté à une boîte française qui a tout compris, et je tiens à féliciter son dirigeant et toute l’équipe d’Audiophonics. Je vous souhaite vraiment bonne continuation et tout le succès que vous méritez.
Eemeli T.
DYNAVOX SDS4 Absorbeurs de Vibrations Aluminium / Silicone 40 x 18mm Noir (Set x4) This set of 4 SDS4 pads from Dynavox for hi-fi equipment and speakers effectively absorbs vibrations from your equipment. They feature a silicone pad encircled by an anodized...
Cannot withstand 10kg/absorber as promised
The described max load of 10kg per pad is nowhere near these absorbers can handle (40kg total). Under a combined weight of just 18kg which is 4,5kg per pad the absorbers lose practically all of the absorbing capability as they bottom out. They work fine with a load of about 2,5-3kg/pad, no more. So do not try to use these under an equipment weighting more than about 12kg total. I bought these to be fitted under my BKE XLS200 mk2 subwoofer which weights about 18 kilograms and they were useless - all of the vibrations were conducted directly to the floor and I had to replace them with my old Norstone absorbers.
Afterwards I installed Dynavox SDS4 absorbers to my gaming set, under a small Audio Pro Subsoniq subwoofer weighting 10kg at which they work adequately and as promised absorbing the vibrations efficiently.
Sergio N.
NEOTECH NES-3004 MK2 Speaker Cable UP-OCC Copper Silver plated 8x1.3mm² Ø 13mm This Neotech speaker cable features an 8-core StarQuad architecture with central insulation to lower the capacitive effect. The 1.3mm² conductors are equipped with strands...
Best copper cable
Naturalness is its strenght, a champion of balance and dynamism
Sergio N.
SMSL SH-8S Headphone Amplifier Balanced OPA564 2x6W 16Ω SMSL offers with its SMSL SH-8s an affordable and efficient headphone amplifier. It uses OPA564 AOPs to deliver, with great precision, a power of 2x6W under 16Ω. It will...
Exceptional amplifier
Powerful refined, infinite details
IFI HDMI ISILENCER HDMI Female to HDMI Male EMI Noise Suppressor iFi Audio's HDMI iSilencer is an HDMI filter designed to reduce noise and jitter in your signal and protect your equipment from surges that can be caused by electrostatic...
un plus en image et son
Bonsoir , j ai mis IFI hdmi isilencer sur mon plasma via wireworld sphere , j ai remarqué que je gagne un peu en chaleur , largeur du son et l image est plus contrastée ,un poil plus de relief ,il y a des petits gains mais c est toujours bon a prendre . Franck
Renaldo V.
Celestion SL6
Merci à Auphonics pour leur rapidité à traiter les commandes.
J'ai choisi les condensateurs ANTZEN AUDIO STANDARD Z-CAP pour mettre à jour mes enceintes Celestion SL6. Ils s'intègrent parfaitement dans le filtre, et le résultat est à la hauteur de mes attentes. Je retrouve pleinement la signature sonore caractéristique des SL6.
Renaldo V.
Celestion SL6
Renaldo V.
Celestion SL6
David n.
La différence est sensible par rapport au câble d'origine de l'alimentation linéaire 12V.
Meilleure qualité apparente et contacts parfaits.
Une meilleure définition générale et une image stéréo plus ample et étagée.
Yoann L.
Fonctionne parfaitement entre une vieille TV qui sort en coaxial et une entrée spdif sur un WiiM pro plus.
Mickael L.
Merci à audiophonics pour les conseils sur le choix des tubes.
A tout possesseur d'ampli pier audio ms88se, je vous conseille le changement des tubes sans attendre qu'ils soient à changer c'est vraiment un nouvel ampli dans cette configuration.
Très content du résultat.
Hocine H.
Super câble
Je l'ai acheté sur les avis et je comprends pourquoi tous sont unanimes sur ce câble.
Il est déjà de très bonne qualité, quoi que un peu bling bling avec sa gaine dorée. Il n'est pas simple à dénuder, il faut de la patience car chaque conducteurs est composé de 3 brins de cuivre qui sont eux-même blindés et enroulés dans du coton. Pour le coup, la protection est poussée à l'extrême.
Un petit détail que j'ai vraiment apprécié; c'est quand on prépare des câbles de modulation en symétrique, le point chaud et la masse sont inversés entre mâle/femelle ; Ici les connecteurs sont placés directement pour accueillir le mâle et la femelle, pas besoin de tortiller le conducteur pour pouvoir souder, c'est du génie, le soucis du détail.
Quant au son, il limpide, neutre, précis, ce que je recherchais avec beaucoup de dynamique, ce câble remplace un câble pur argent, mais je l'ai connecté avec des VIBORG pur argent et c'est du bonheur. J'ai enfin trouvé mon câble de référence.
Hocine H.
Connecteur de grande qualité avec une bague de serrage qui sert vraiment, de ce fait le câble ne bouge plus. De plus la soudure adhère immédiatement sur les pins, chose très appréciable et quant à la qualité sonore, un super son fluide, précis, harmonieux. N'hésitez pas à ce prix, il n'y a pas plétore de connecteurs valables et c'est bien dommage.
Stefano D.
Essenziale e molto dettagliato
circuito essenziale con DAC slave, viene immediatamente riconosciuto dal PC e da' il meglio se lasciato in configurazione 32 bit. Dettagliato e dinamico, l' ho installato direttamente in ingresso all' amplificatore gainclone e casse autocostruite. Si tratta di un componente con caratteristiche Hi-end al prezzo di un componente consumer
philippe C.
Audible
Utiliser cette soudure est clairement "audible". Comme d'habitude Audiophonics a été impeccable dans la gestion de ma commande pourtant compliquée car plein de petits objets de montage pour connectique. Que ferait on sans eux en France ? Pourquoi ne pas leur dédier le cabinet du Ministère des mélomanes...
philippe C.
LETSHUOER S08 In-Ear Monitors IEM Planar Magnetic 26Ω 105dB 20Hz-40kHz Black The Letshuoer S08 in-ear monitors are planar magnetic IEMs. They feature a high-quality design with a custom 13mm-diameter planar magnetic diaphragm and dual voice coils. The...
Très bon Iem. J'aime la sonorité des membranes "planaires". Dans tous les cas : panneaux, casques, ou intras. D'aucun se plaignent d'un manque de grave et d'infra grave... ce n'est pas le cas ici. C'est petit bijou dédié aux mélomanes nomades et il est magnifiquement dessiné et la finition est parfaite.
J'aime bien...
Bertrand T.
FX-AUDIO D01 DAC Headphone Amplifier Bluetooth 5.0 ES9038Q2M TPA6120A2 XMOS CSR8675 32bit 768kHz DSD512 Featuring an excellent 32-bit ES9038Q2M digital-to-analog conversion chip, the DAC FX-Audio D01 offers excellent audio performance with a wide dynamic range, low distortion, and...
FX-Audio ampli pour casque
Décidément une marque offrant des produits avec un rapport qualité/prix déroutant. J'utilise un ampli de cette marque depuis 2017 pour mon streaming Qobuz et mes B&W. Très content
Tres bon amortisseur
Tres bon amortisseur mais pour des appareils assez legers.
Je les ai installes sous un DAC SMSL
Marian U.
DENAFRIPS HADES 12TH Discrete Balanced Preamplifier Pure Class A Silver Elevate your audio experience with the Denafrips Hades preamplifier, a masterpiece born of uncompromising dedication to audio perfection. Designed for the discerning audiophile,...
Very nice
Love this piece, I have with Pontus 15th, best match
Marian U.
DENAFRIPS PONTUS 15TH DAC R2R NOS Balanced 1536kHz DSD1024 Silver The Denafrips Pontus 15TH NOS R2R balanced dual-mono DAC represents an excellent high-end digital-to-analog conversion solution, offering ececption sound performance. Here,...
Wow
Beautiful sound, love it!
pascal v.
excellent pour le prix
Câble Nexans titanex utilisé pour alimenter et recabler une multiprise diy . Grave et spatialisation bien meilleur que le câblage d'origine. Monté avec schuko Bals et gaine elecaudio vipera. Excellent rapport qualité prix
Jerome A.
AUDALYTIC AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Black The Audalytic AH90 is a DAC offering excellent decoding performance and precise sound reproduction, thanks to a careful and intelligent design. And it's reasonably priced for...
Complet et sobre
Ce dac ne fait pas dans l'esbroufe, aucune option inutile, très sobre, l'écran est petit, pas très lumineux, limite triste.
Pas très grave pour moi, car je n'aime pas ces petits écrans quand j'écoute de la musique, d'ailleurs j'ai activé la fonction qui l'éteint après 30 secondes sans activité.
Il reste donc que le voyant en façade, qui est aussi le bouton tactile pour l'allumer/l'éteindre, mais ce dernier ne change pas d'apparence si allumé ou éteint, stupide.
Il m'arrive donc de l'éteindre en voulant l'allumer... ou l'inverse.
On n'achète pas ce dac pour son physique, mais pour ses caractéristiques, et là, il est bien placé.
Je ne rentre pas dans le délire des puces, chacun fait son choix.
Ce dac contient une partie amplification casque, avec 2 sorties, très pratique, des sorties asymétrique & symétriques, nombreuses entrées dont une prise RJ45 pour le streamer, ce qui, pour moi est l'élément déclencheur de l'achat.
Compatible ROON, reconnu immédiatement, c'est parfait.
Toutefois, bien penser à mettre à jour le firmware (assez simple comme opération) sans quoi, le DAC génère une nouvelle adresse mac à chaque allumage, engendrant parfois des conflits d'adresse IP sur votre réseau.
Là encore, étrange, on peut trouver le firmware sur un forum "Head-fi", mais pas sur le site officiel de la marque.
Ce dac est donc à destination des utilisateurs qui recherchent un produit performant sans options inutiles et vu-mètre multi-couleurs, au rapport qualité prix excellent.
Thierry S.
étonnant
montés sur des klipsch rb81mk2. derrière un cayin cs 55 KT88
tout de suite on perçoit une image, notamment sur les voix et bien sur avec un bon enregistrement.
aigus très maitrisés mais bien présents et délicats.
un poil trop à mon goût, ça entraine une petite perte de détails fins. je testerai bien les silver de la même marque.
Le plus étonnant est que au bout de 10 h ou plus, le grave remonte de façon spectaculaire. j'ai l'impression d'avoir changé les boomers.
c'est d'autant plus surprenant que ces 3.3 sont sur les tweeters.
D'enceintes plutôt braillardes on passe à du très propre et même beau par moment, en tout cas bien meilleur que l'origine et en plus insaturable. bien sûr vu la taille, ils sont à l'extérieur sur le bornier juste sous les dernières fiches, il y a un peu de place dans l’arrondis.
Jacques T.
FOSI AUDIO BOX X2 Phono MM Preamplifier with Tubes 2x6A2 Stereo Black With its BOX X2 tube preamplifier, Fosi Audio unveils an affordable, high-quality Hifi device for those wishing to enjoy the warm, coated sound of tube...
Bon préamplificateur phono
C'est par curiosité que j'ai essayé ce petit préamplificateur .
Le résultat est vraiment étonnant compte tenu se son tarif plus que raisonnable.
Sans le modifier pour le moment, le son est déjà excellent, je le teste avec une Thorens TD 125 MK2 équipée d'une cellule Stanton 681 EEE avec un diamant Jico et la comparaison avec des préamplificateur 10 à 15 fois plus cher est étonnante : pas de souffle, une correction riaa stable et une dynamique superbe.
Cerise sur le gâteau il m'a été fourni avec des tubes Ge 5654w de très bonne qualité.
Je recommande fortement ce produit d'un rapport qualité prix imbattable (réservé bien sur aux cellules MM, on ne peut pas tout avoir).
Jacques
Theodore A.
amazing
I built my own DAC based on this. It is an amazing piece, worthing every penny... If you can built a DAC use this R2R, unbeatable for price
Eric E.
whouaou
Je dois utiliser une rallonge pour alimenter mon système qui se trouve au tiers/centre d’une grande pièce. J’utilisais une vulgaire rallonge parce que j’ai toujours douté de l’intérêt de soigner l’alimentation. C’était une erreur, énorme erreur.
Le son de mon système était étriqué, la musique semblait comprimée dans deux boites distinctes et je croyais, à tort, que le problème venait de mes vieilles Infinity, dinosaures âgés de 45 ans, elles vont parfaitement bien en réalité - je me contenterai de nettoyer les potards et changer deux électrolytiques connus pour mal vieillir.
À force d’entendre parler de câbles d’alimentation je me décide enfin en me disant que pour 100€ le risque est limité. Donc je fabrique une rallonge avec Tornado et des prises Elecaudio, je rebranche mon système et... je reçois une grosse claque. Les améliorations sont spectaculaires, le terme n’est pas exagéré. D’abord je suis frappé par le volume qui semble avoir monté de plusieurs crans, puis par les basses propres, précises, naturelles, les voix charnelles, la douceur lumineuse des aigus, puis par l’image sonore large, profonde, limpide avec des plans sonores parfaitement lisibles. Ensuite je constate que mes enceintes s’effacent complètement derrière la musique qui se forme autour d’elles, enfin je découvre des finesses et des détails que j'ignorais. Ce n’est pas un effet placebo, les améliorations sont très sensibles et ma chère moitié les a elle aussi perçues spontanément. Avec quelques heures de rodage une ouverture lumineuse est venue couronner l’ensemble. Je suis comblé et je dois avouer que la redécouverte de certains enregistrements m’a… plus que troublé.
Évidemment je suis impatient de remplacer mes autres câbles d’alimentation. Il me semble que j'ai fait l'inverse de ce qu'il fallait faire, aujourd’hui je dirais qu’il faut commencer par fignoler l’alimentation et s’occuper du reste après. Oui, je suis désormais convaincu que les câbles source et HP ne viennent qu'après.
Il s’agissait de ma treizième commande, je félicite Audiophonics pour la qualité de son offre et l’infaillibilité de son service expédition.
Elom G.
TI LME49720NA/NOPB Operational Amplifier OPA Class AB 2 Channel DIP8 (Unit) The Texas Instruments LME49720NA/NOPB is a high performance 2-channel Class AB, high performance operational amplifier (OPA) integrated in a DIP8 package. This ultra low...
Je suis d'accord les avis précédents. Bon aop bien équilibré. Mais le rendu manque un peu de corps; la musique semble "dégraissée". Avec une très bonne dynamique, presque trop.
Finalement, je ne recommande pas vraiment cet aop
Elom G.
Elom G.
NJR MUSES8820 Dual OPA DIP8 (Unit) The OPA MUSES8820 has been developed by the specialist manufacturer NJR. It is an operational amplifier optimized for high fidelity and professional uses, thus offering very...
Très bon aop, avec le son muse; j'aime beaucoup ! Très bon rapport qualité prix. Peut paraitre un peu brouillon dans le bas, suivant les systèmes, mais il reste vraiment très bon.
Je recommande !
Elom G.
Bon Aop
bon aop, bien équilibré. pas grand chose à lui reprocher, même si finalement je préfère lui le muse ou le burr Brown
Jaring B.
LT3045 Linear Voltage Regulator 12V The LT3045 linear voltage regulator offers excellent performance and is ideal for HiFi integrations, providing a clean electrical signal to the audio circuits. It can be used to...
LT3045 didn't deliver for me
My Netgear GS308 switch is quite sensitive for the 12V power it receives. I already improved the sound quality significantly by going from an L7812 to a LM1085 voltage regulator. I read that the LT3045 is much quieter in terms of noise, as such I wanted to try it out on my switch. The results however are disappointing, as it lacks musicality in the sound. It costs 15 euro, which is 10 times higher than a LM1085 and it didn't deliver for me.
Nikos Z.
Order Detail N°479896 - 2024-10-28
Je les ai reçus le 11/04/2024 17.20
Merci.
Fabrice L.
Le cable équilibré
Pour un besoin de longueur 2× 10m, j'ai opté pour ce cable Triangle au prix contenu.
Choix judicieux, ce cable ne favorise aucun registre et respecte la musique dans toutes ses nuances.
De plus pas de "rodage" particulier, sa qualité s'exprime dès la 1ere mise en place.
Equivalent d'un Sommercable Magellan qui est une de mes références à prix doux.
Patrick D.
Une reussite
Connecté par câbles XLR à un ampli ZA3, et relié en optique à mon Yamaha WXC-50, en coaxial à un lecteur de Blu-ray Sony et en hdml arc à un téléviseur Samsung, ce Dac ZD3 joue les chefs d’orchestre avec une redoutable efficacité. Mes enceintes JMR Folia jubilé (4ohm) restituent un son à la fois précis, légèrement chaud avec des aigus sans aucune agressivité. Hauts et bas Médiums sont superbes et très bien équilibrés. Les basses n’en font pas trop et sont bien contrôlées. Bref que du bon. Le Dac apporte de la précision à ce petit système tout en restant très musical. Cette nouvelle puce ESS 9039 est une réussite quelque soit l’entrée utilisée.
A ce prix c’est vraiment une affaire.
Yannick r.
THIEAUDIO HYPE 4 In-Ear Monitors IEM Dynamic 17 Ohm 105dB 10-22kHz Black Thieaudio presents the latest addition to its HYPE (for Hybrid Performance) series of in-ear headphones: the HYPE 4. With this new model, Thieaudio continues to offer an...
Tremblez les IEM haut de gamme!
Après des mois d'écoutes quasi quotidiennes, je pense avoir pu jauger ces petites bestioles.
Pour ce qui est de l'apparence, chacun se fera son idée, pour ma part je les trouve très sympas, même si je préfère le look des modèles Oracle de la marque.
Pour l'ergonomie, rien à dire ça se positionne parfaitement dans l'oreille, et l'isolation est de premier ordre.
Pour les embouts, je ne peux pas trop dire, je suis vite passé à des SpinFit, l'idéal niveau confort pour moi.
Quant au plus important, à savoir le rendu sonore, eh bien j'en espérais beaucoup, mais pas tant quand même.
En effet, étant mon premier achat chez Thieaudio, j'ai pu comprendre pourquoi certains ne tarissent pas d'éloges à leur propos.
Il ne manque rien, même la scène sonore est plutôt spacieuse pour des intras (j'ai déjà pu tester des Astell&Kern Aura).
Les fréquences graves sont à l'honneur, mais tout en précision, pas de boum boum excessif ici, et le reste du spectre est à l'avenant.
En somme l'équilibre est pour moi remarquable, ce qui rend ces Hype 4 très versatiles.
C'est bien simple, mon Ananda Stealth Magnets, que j'adore pourtant, est en sommeil cryogénique.
Ils consomment un mariage réussi avec le DAC portable iBasso DC07 Pro, j'ai d'ailleurs posté un avis directement sur leur page.
Je ne peux les recommander chaudement, surtout si vous êtes restreints dans cette gamme de prix.
Yannick r.
Un petit DAC peut en cacher un grand...
Voulant un convertisseur transportable, mais quand même de qualité, j'ai tenté ma chance avec cet iBasso.
J'avais bien aimé le son du DC03, regrettant juste le câble non amovible, qui a du coup lâché.
Ici ce n'est plus un problème, mais c'est loin d'être le seul avantage.
En effet, le son produit par ce petit appareil, en association avec une paire de Hype 4, est complètement hors norme.
Déjà la puissance disponible est bien plus grande qu'il n'y paraît, c'est très confortable en fonction des enregistrements.
Mais surtout, la qualité perçue est immense, et ce quel que soit le style de musique écouté.
Branché sur un OnePlus 11 avec l'application USB Audio Player Pro (réechantillonnage activé), ça marche de manière divine.
Le grave s'exprime à merveille, les voix sont parfaitement claires et les aigus présents mais soyeux.
A l'arrivée ce DC07 Pro est un investissement minime vis-à-vis du résultat obtenu.
Je vais quand même tester son grand frère le DC Elite, mais je ne serai pas surpris si le gap n'est pas si important, malgré la différence de prix.
Je peux donc vous le dire, vous pouvez y aller les yeux fermés, vous risquez surtout d'être étonnés.
Rikard C.
TOPPING MX3S Class D Amplifier Infineon Headphone Amplifier DAC Bluetooth aptX Adaptive 2x50W 4 Ohm 24bit 192kHz Silver The Topping MX3S is a true swiis army knife of audio, acting as both an amplifier and a headphone amplifier with integrated AK4377 DAC and Bluetooth receiver. An ideal model for...
My travel partner
Works fine and this is my travel partner, used with a pair of Ino Audio piXM.
The only issue I have is the low level of amplifying when running blue tooth from my Android. When serving by USB-C from Android one gets much more power out and far better sound as well.
Manuel P.
Meilleure définition, basses plus propres ...
Ma recommandation : avant tout investissement significatif et changement intempestif (voire maladif) de matériel, découplez donc vos enceintes et appareils avec ces pointes de découplage ...
