Johan V.
Exceptionnel
István R.
not easy to assemble
Paul M.
Excellent speaker cables
Customers reviews - There are 18998 reviews.
fabrice v.
Oui du son
Alors 0 étoile pour le son, beaucoup de choses,mais si vous cherchez une âme, de l’émotion ,il faut passer son chemin.
C'est juste pratique pour un jeune geek qui débute,pour sa console, la TV ou un smartphone.
La puissance annoncée est faussée si cela fait 70 W ,il en perd la moitié en route.
Je ne comprend pas tout ces avis à 5 étoiles. Vaut 10 fois mieux mettre 100 euros supplémentaires pour un ampli bas gamme de marques sérieuses, désolé mais en ce monde on en toujours que pour son argent et souvent moins ,ici ç’est même beaucoup moins .
Par contre toujours 5 étoiles au service Audiophonics !!!!
Martin S.
Absolutely neutral, detailed sound. Real High-End.
I have this DAC in use for two months now, connected via XLR to Preamplifier Topping A90D and Neumann KH 420 G active speakers.
Source is a notebook running foobar, connected via USB, source material is PCM from 16/44.1 to 24/192.
The build quality of the device is very good. Remote control is the same type as every Gustard/Topping/SMSL remote.
Unfortunately, the manufacturer does not provide any user manual, so I found the menu control by accident (press "D-Filter" for 3 seconds).
Stand-by mode does not exactly switch off the device, but reduces the power consumption from 15 watts to 10 watts, so I prefer to use the rear power switch when the DAC is not in use.
I did intensive side-by-side listening tests with Gustard X16/X18/X26 pro, Topping D90MQA/E70V/D30 pro, SMSL SU-10 and Teac UD-501.
A comparison to the lower-priced DACs I mentioned above would not be fair, so I will describe my personal impressions of the sound differences between this device, SMSL SU-10 and Gustard X26 pro.
To my ears, in my system, the SDA-6pro2 performs great (I use the default digital filter, "short sharp"). Sound is precise absolutely neutral and well-balanced in every regard. Tonality, soundstage, dynamics. The amount of detail is stunning, in every frequency range. High frequency are a more on the brilliant side, textures in human voices are clearly audible, without any hint of harshness. Of all the DACs compared it with, this is the most neutral sounding.
For years, I used to prefer ESS-based DACS, to my taste AKM-based DACs sounded always a bit to soft- but the Singxer really changed my mind. It combines the dynamics I like on the ESS chips with the natural and detailed sound of the AKM chips.
In comparison, the SMSL SU-10 lacks a bit of detail retrieval in every frequency range, mid-bass is a bit pronounced and female voices tend slightly to "shout" when listening at high volume levels. The soundstage of the SU-10 is huge and also somewhat diffuse.
The difference in sound compared to Gustard X26 pro is a matter of taste. SDA-6pro2 detail retrieval is on par with X26 pro. Bass definition of Singxer is better, but X26 has more pressure and wall-shaking subbass. In short, X26 pro sounds more spectacular due to punch and dynamics, but acoustic instruments and human voices tend to sound a bit artificial in comparison to SDA-6pro 2, which sounds more natural and refined.
I highly recommend this DAC for customers who want simple, perfect sounding DAC and don't need comfort functions or a fancy user interface.
Eric J.
Appliqué sur les fines parois latérales de mon Rack hifi reconstitué à partir d'un meuble de récup, ce produit supprimé efficacement les vibrations sur celles-ci. Efficace également en couche sous des plaques antivibratoires en mdf.
vincent r.
TOPPING E30 II DAC 2x AK4493S XMOS XU208 32bit 768kHz DSD512 Silver Topping comes back with the compact DAC E30 II, a real evolution of the excellent E30, presenting many technical improvements allowing to reach even better sound performances....
Petit Dac Dual Mono très sympa ; beaucoup doux que certaines autres marques mais très détaillé à l’écoute.
La fabrication est de qualité.
Penser à faire la mise à jour du Firmware avec l’application sur PC
vincent r.
Le produit est très intéressant au niveau de ses possibilités, sa stabilité en Wifi.
Relié en sortie RCA coaxiale avec un DAC externe Topping E30 II ; on a quelques choses de très bien musicalement.
J’ai un ancien Wxc 50 (que j’ai gardé) ; mais je trouve l’association WIIM Pro Plus et Topping E30 II meilleure à l’écoute. Plus douce
Daniel P.
BEATECHNIK x LHY AUDIO LPS-A6 220V Linear Power Supply Module for EverSolo DMP-A6 The LPS-A6 linear power supply module has been specially designed to enhance the power supply stage of EverSolo DMP-A6 and DMP-A6 Master Edition network players by replacing the...
Dégradation de la scène sonore
On parle d'ouverture de la scène sonore mais ça fait totalement faux, je suis très déçu, cette alimentation n'apporte pas un plus par rapport à celle d'origine, peut-être moins performante mais bien étudiée par Eversolo.
Je regrette cet achat. Je vais être obligé de la revendre à perte.
Jean-Pierre W.
Excellent module
Idéal pour remplacement d’ampli dans un caisson de basse , ici je l’ai adapté dans un caisson Klipsch avec boomer 38 , je dirais que la musicalité , voir les basses en HC est milles fois meilleurs que celui de la marque d’origine ( Klipsch).
Il faudrait juste faire un peu d’ébénisterie pour l’adaptation .
Je recommande fortement , bon tarif , livraison rapide et de plus vers la,Réunion .
Jean-Pierre D.
Préampli musical et propre intéressant dans sa gamme de prix
J'avais le P26, j'ai voulu avoir un préampli moins neutre, avec un son moins clair, ce H26 plus haut en gamme est vraiment intéressant, plus doux, cela reste neutre, mais la musicalité gagne, à recommander sur les musiques acoustiques et classiques ou les voix claires, l'image est holographique et très réussie. Cela évite financièrement de monter en prix, construction irréprochable, merci à Monsieur David Aubert pour les conseils. Je recommande ce préampli, j'ai utilisé avec un set de câble Neotech et ampli Audiophonics HP 400 Purifi, l'association est très bonne.
Joseph B.
Très bon produit, conforme aux avis. Niveau son bien mieux que le Bada 5600.
Jamais déçu par toutes les commandes passées.
Jeanphilippe c.
MUNDORF MCAP SUPREME SILVER OIL MKP Capacitor 1000V 0.33μF Mundorf MCap Supreme Silver Oil are capacitors with an oil-impregnated metallized polypropylene dielectric. As the name suggests, high purity Silver is used for the capacitor...
Mundorf
Condensateur utilisé dans un amplificateur à tube pour le couplage. (Tube de puissance. Finesse des timbres, détails des harmoniques, douceur de la scène sonore. Je recommande vivement.
Eric H.
MUNDORF MLYTIC AG Capacitor 25V 22000μF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
Exellent
2eme commande et toujours aussi bon
Eric H.
Très bons connecteurs
Je ne comprends pas les avis précédents disant que les pinces faisaient un mauvais contact
Au contraire, je trouve que le contact est très bon voire même un peu trop serré car il faut un peu forcer pour le rentrer à fond.
Un fois en place, aucun jeu possible...
A part ça très bons connecteurs, bien construits, robustes et qui inspirent confiances.
Les câbles se soudent facilement et en plus vous avez toute la place qu’il faut pour travailler
En résumé, très bons connecteurs en cuivre pur, à un prix très raisonnable et présentés dans une belle boîte avec la clé Allen fournie.
tout a fait d'accord
pas donné mais quel son !
utilisé sur un switch internet
Michael L.
FOSI AUDIO BT20A Class D Amplifier 2x TPA3116 Bluetooth 5.0 2x90W 4 Ohm The Fosi Audio BT20A is a compact and powerful Class D amplifier, offered at a contained price. Its amplifier stage uses not one but two TI TPA3116D2 chips, capable of...
High value for you're money
Very harmonic amp, tone controls adjusted since 12 o'clock might not be 100% neutral, i feel i don't miss anything except when playing loud, there are other amps that can play louder and are more suitable for low sensitive speakers,no pop sound turning it on,off which is super, fast connection via bluetooth and as soon as it's on theres sound, if the source is playing, low price considering you get a 24 volt psu and it looks good to. Driving triangle esprit titus ez
THIERRY D.
affichage defectueux
Depuis quelques mois, l'affichage en Db a perdu 2 segments sur le zero et le trois.
bernard g.
bernard g.
bernard g.
trés bon produit
Alain M.
Problème Qualité !
J'ai acheté récemment 2 sets de 4 pieds DYNAVOX 11329.
L'un des pieds ne possède pas le joint caoutchouc !
C'est ennuyeux ...
Whaou !
Quand cela vous fait dire whaou.. voilà ce qui se passe avec ces AOPs.
bernard m.
cable coaxial
très bon cable et bonne longeur pour petite distance ! parfait :
Le résultat est bluffant pour un câble d'enceinte à un prix aussi modique. Il me sert pour relier les enceintes à mon téléviseur. L'apport qualitatif est très sensible par rapport au câble d'origine fourni avec les enceintes. Merci du conseil où Audiophonics ne pousse pas à la surenchère et essaie d'être en adéquation avec le budget et le matériel du client.
laurent C.
Bien adapté a mon petit système: Elipson planet m Marantz cinéma 70s
Pas d'agressivité bonne définition bien meilleur que mon cable HP précédant
configuration: âme central sur le plus et tresse sur le moins
Acheté ce câble sur les conseils de M. Aubert pour relier un Bluesound Node à l'ampli K214. Le mariage est cohérent et très qualitatif en terme d'écoute à toutes les fréquences. Pour un prix relativement modique, on se trouve avec un produit bien fini, soigné, et très satisfaisant quant au résultat. Et ce sera sans doute encore mieux après une période de rodage.
David S.
WIIM AMP TPA3255 Class D Stereo Amplifier WiFi DLNA AirPlay 2 Chromecast Bluetooth 5.0 2x100W 4 Ohm Silver The WiiM Amp is an amplifier and streamer that's as compact as it is versatile and high-performance! It lets you distribute your music extremely simply via DLNA, AirPlay 2,...
Bonne ampli
Service ups à chier audiophonie rien à dire
Ampli wiim exelent qualité ce marie très bien avec mes focal chora 806 et application très bien pour le moment
Nicolas W.
LHY AUDIO LPS50VA Linear Regulated Low Noise Power Supply 230V to 15V 1.5A 50VA Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply...
Stupéfiant!
A peine branché sur mon Ifi Zen Stream et là je redécouvre un son chaleureux, clair et détaillé avec des basses percutantes. Les instruments et les voix se détachent les uns des autres avec une clarté incroyable. On peut monter le son, ça n'est jamais désagréable. J'avais acheté le streamer d'occasion et l'adaptateur livré était un vulgaire adaptateur ac-dc 12v 1a... autant dire qu'avec cette alim linéaire 15v3A sur le streamer, tout mon système hifi se retrouve mis en valeur... aucune hésitation à avoir à ce prix, le streamer et son alim c'est le top du top!
Tamas C.
A great product
A great product. Using the microphone with HouseCurve and Roon has improved the sound a lot. Audiophonics delivery was great this time too.
Antonio D.
Great improvement
My A6ME went to another level, much improved bass control and presence, better soundstage, voices more realistic and attack to notes much, much better. Sounds overall more refined and it is absolutely noticeable. Very happy.
Eric D.
MOONDROP PARA Planar Magnetic Circumaural Open-back Audio Headphone Ø100mm 101dB 8Ω 15Hz-53kHz The Moondrop Para is a high-quality headphone based on Planar Magnetic technology. It has inherited part of the structure of its predecessor, the Moondrop Venus.
Moondrop para
J’ai fait l’achat de ce casque il y à bientôt deux mois, sans avoir fait d’essai préalable. Casque en 08 ohms sensé pouvoir être drivé par in peu n’importe quoi comme j’avais pu le lire ca et là.
Quelle déception…..que ce soit en direct sur mes divers appareils équipés de prise casque ou sur mon ampli casque à tubes littledot mk2 , et bien le volume sonore reste faible, bien trop faible pour mes oreilles. La qualité sonore du casque en lui même n’est pas en cause. La spacialisation est excellente, l’equilibre entre les fréquences est bonne mais je ne peux tout simplement pas en profiter…..il faudrait simplement pouvoir monter le son ce qui poir le moment m’est impossible. Le littledot mk2 s’effondre dès que je monte un peu le son et quelque soit les réglages sur l’ampli.
Voilà, j’attend desormais de trouver un ampli casque adapté,capable de booster suffisamment mon casque. Pour le moment je ne trouve pas d’ampli qui accepte dans ses specifications la valeur de 8ohms. Un conseil serait le bienvenu, si audiophonics lit mon commentaire, ou toute autre personne possedant un casque similaire.
RENAUD C.
SCHURTER IEC socket for soldering boxes This SCHURTER IEC subbase is ideal for integration into a housing during DIY installation.
Economique et professionnel
Très bon rapport qualité/prix. Construction sérieuse.
RENAUD C.
7025 pour restauration ampli Jolida JD202
Un tube de qualité, silencieux, visuellement très solide. Pas exactement le même gain que la 12AX7 d'origine, mais cela ne se ressent absolument pas dans mon ampli.
johan s.
GUSTARD P26 Discrete Class A Balanced preamplifier XLR RCA Silver Gustard P26 is an elaborate preamplifier / volume controller / strain selector (3 inputs). It will delight audiophiles looking for a fully balanced circuit.
Retransmission fidèle du signal reçu
Je l'ai depuis plusieurs mois. Avec un ampli de puissance Atoll. Le son est fluide et sensible à la moindre modification sur le système que ce soit l'ajout d'un dac, un changement de câble et surtout les AOP. C'est les sparkos que j'ai.
Bogdan B.
XDUOO TA-20 PLUS XLR Balanced Class A Headphone Amplifier with Tubes 1x5Z4P 2x12AU7 An upgrade of the TA-20, the TA20 PLUS from xDuoo features a number of improvements. This fully symmetrical Class A tube headphone amplifier now boasts...
An excellent amplifier in its price range
A very good amplifier that deserves every last penny spent, the sound is unexpectedly good and after replacing the 12AU7 tubes with PSVANE 12AU7-S S Series the sound became even better even though the new tubes didn't have time to burn in. And as a bonus it is also very beautiful. I've been listening to it for several days and I can't get enough of it. I recommend it 100%
Bogdan B.
Very good investment
I replaced the stock tubes on an XDUOO TA-20 Plus headphone amplifier and the sound became much better, it became smoother, the bass is richer and the separation is better.
Laurent D.
Bon produit si on est patient et pugnace
Le colis était bien emballé 2 vis n’étaient pas à la bonne taille et un module de carte SD supplémentaire qui n'a pas son utilité (que je vais renvoyer) Le montage est a la portée de n'importe qui c'est vraiment bien fait. J'avais un PI3 sous la main que je voulais utiliser avec ce Mini Dac. Après moult échange d'ailleurs très pros et concis avec le sav on a réussi à tout faire fonctionner sauf la télécommande qui faut avouer, n'apporte pas grand chose passé 3m de distance. Si d'aventure vous vous lancez dans montage, le résultat est vraiment bluffant le petit écran vous donne les image des Jaquettes et Spotyfy avec Volumio fonctionne parfaitement vraiment un très bon Dac Merci le SAV de m'avoir soutenu dans mon challenge. Un point que je trouve un peu léger c'est l’interrupteur style lampe de chevet sur le fil d'alimentation. Je ne mets que 3 étoiles a cause des sueurs froide et heure perdues a le faire chanter
Très bien mais
Utilisé en remplacement des NE5532 dans un Fosi BT20a Pro qui sonnait trop sec, clinique et terme.
Les Oracle 02 apportent de l'air et une image sonore plus large et profonde, ça respire et la musique n'est plus coincée dans les HP. La musique est plus vivante et reprend des couleurs.
Le haut medium aigu est très beau, sans dureté, avec de la matière tout en finesse, du détail, une très belle dynamique. Quelques sibilances sur les voix féminines.
Les registre grave médium est bien, mais pas à la hauteur du reste.
Si le haut grave est bien articulé et percutant si nécessaire, le médium est parfois confus dès qu'il y a beaucoup d'instruments, les voix d'homme et de femmes sont un peu trop lisses et manquent d'incarnation. Les infra-graves sont quasi absents.
Ceci en comparaison d'OP275 tout aussi transparent mais avec une énergie et une matière égale sur tout le spectre.
Bref un certain manque d'homogénéité à mon goût dans cette configuration, la hiérarchie serait sans doute différente dans un autre appareil. On est cependant à un tout autre niveau que les NE5532 d'origine qui équipent le Fosi BT20a Pro.
Guillaume B.
Bluffant!!
Lourd, bien pensé, beau et fonctionne vraiment bien, je ne m'attendait pas à mieux, mais le résultat s'entend, une espèce de tranquillité générale dans tout le spectre sonore.
Je suis content!!
Guillaume B.
AECO ABI-0611S Speaker Terminals Tellurium Copper Silver Plated (Pair) These aeco ABI-0611S speaker terminals offer excellent design quality. They use low-mass contacts made of high-purity tellurium copper with silver 120µ plating, ensuring...
Jolie!
Très belle aspect (mieux que la photo ;) ), au touché ça sent la qualité, qui se vérifie a l'écoute.
Je vous le recommande.
Guillaume B.
SPARKOS LABS SS7812 Discrete Voltage Regulator +12V The brand Sparkos Labs, specialized in the design of high quality discrete electronic components, has created a range of discrete regulators designed to replace adjustable...
Suite à l'upgrade des composants de la carte d'alim d'un préampli anglais avec un très bon résultat, la pose de ce régulateur apporte une touche de "fond noir" très appréciable sur les silences et du "calme" sur les très hautes fréquences.
J'aime bien mais le tarif moins.
Guillaume B.
Composite Foot Aluminium ABS Rubber 61x23mm Silver (Unit) This stand is ideal to stabilize a device while disconnecting it from an assembly to limit vibrations. It is made of ABS plastic and brushed anodized aluminum. The lower part of...
Bon pied
C'est un bon produit, rigide, bien fait ce qui donne une belle finition.
Marc S.
XANGSANE XS-5N Banana Speaker Cables OCC Copper Silver Plated 3m (Pair) Xangsane's XS-5N speaker cables are made up of 12 strands of silver-plated 5N single-crystal OCC copper to ensure electromagnetic impermeability and perfect conductivity. Each...
Merci audiophonic
En remplacement d'un rc 400tm.
Gain immédiat ( scène élargie, plus de details, aigus medium basses équilibré).
Câble bien construit.
Un super produit.
Sebastien D.
EVERSOLO H2 Balanced DAC Portable Headphone Amplifier ES9038Q2M 32bit 768kHz DSD512 EVERSOLO offers with the H2 a balanced DAC and  portable headphone amplifier  combo wich is compact and powerful. With a USB-C input, it is an ideal companion for...
Bon petit son ce dac, brancher essentiellement pour la voiture avec usb player pro au smartphone belle écoute sur autoradio
Martin A.
Câble utilisé : Elecaudio HP25occ. Sur les photos, les connecteurs semblent bien plus petits qu'en réalité. Pour le soudage j'ai utilisé un brûleur à gaz cfh m20, avec le pistolet à souder je n'ai pas réussi, le liant est du Mundorf Supreme Silver 10%. Une fois que les bornes de l’amplificateur et des haut-parleurs sont bien serrées, elles le restent. Je ne m'attendais pas à acheter des connecteurs en cuivre à un tel prix et d'une telle qualité.
Jérôme B.
Super produit !
Juste sortir le dongle de son emballage, le connecter sur le port USB de la Freebox Révolution, paramétrer la box Alice dans la télécommande Harmony et synchroniser le tout !
Le tour est joué et même pas besoin de changer le Power Toggle !
Tout est nickel.
Anders R.
My second power amp!
Having connected the LPA S400ET in my bedroom stereo I am just as impressed as the HPA S400ET in the TV/cinema room. Both use Sparcos op amps. Maybe I should get a third one for my main rig powering my Magnepan 20.7 The present Bryston 4B is 19 years old now and warranty expires soon. Hmmmm...
David M.
Aluminium Foot Ø30x15mm M4 Black (Unit) This foot is ideal to stabilize a device while disconnecting it from an assembly to limit vibrations. It is made of CNC machined anodized Aluminium and a rubber ring prevents...
Excellent rapport qualité/prix Pied Aluminium Ø30x15mm M4 Noir
Parfait ! Excellent rapport qualité/prix. Pieds très esthétiques, discrets et anti-dérapant. Il y a mieux mais c'est plus cher. Largement au dessus des pieds d'origine de mon vieil ampli 'NAD'. Dommage qu'il n'y ai aucune vis avec.
David M.
Excellent!! Embout séparateur / Splitter 1x11mm vers 4x4mm Noir
Novice, ma 1ere fabrication de câbles hifi en bi-amplification sur du diamètre 11 millimètres 'SPM440 Eléphant 4 x 4mm2' avec gaine ELECAUDIO GB-05 Gaine Tressée Extensible scotché au extimités. Astuce: prévoir dénudage du cuivre sur 8 cm qui sera perdu pour s'en servir d'aiguille lors du passage en 4mm2, puis poussez tout en tirant et résultat 'Parfait' ! Excellent résultat final !! Mon câble semble très 'pro'. Très content de mon achat .
David M.
Excellent! Gaine ELECAUDIO GB-05 Gaine Tressée Extensible Nylon (PET) 07-14mm
Novice, ma 1ere fabrication de câbles hifi en bi-amplification sur du diamètre 11 millimètres 'SPM440 Eléphant 4 x 4mm2'. Très facile à glisser. Prévoir de la perte. Excellent résultat final! Mon câble semble très robuste et cela fait très 'pro'. Très content de mon achat .
Wayne M.
evo oil
very good service, always find the team to be very helpful, my first time trying the evo oil i will use again impressed thank you
Everaldo R.
XANGSANE SP-8540 Speaker Cable Silver-Plated OFC Copper 2x4mm² This Xangsane SP-8540 is a speaker cable whose conductors are both made of 7 strands of silver-plated OFC copper for enhanced conductivity. The...
I'm very happy with this speaker cable.
I used it for my Focal Chora 816's and I have a feeling the highs are a bit more relaxed with these cables than my copper ones. But still a very clear and enjoyable sound with the xangsane sp8540 speaker cable.
