Gianfranco P.
crystalline
Alexandre G.
Thierry C.
Customers reviews - There are 19513 reviews.
Giovanni G.
neutral, armonic and rich sound cable
this is a really good, wonderful cable.. it's outstanding considering it's price. i think it's at the same level of furutech occ cable at 1/3 the price.
the only cons it's about the internal conductor that are stiff, so it can be difficult to terminate (i have done a good job with viborg vr109g)
Srboljub S.
Good
Sound is great, incisive yet well balanced and with natural timbre. It's punchy and dynamic too.
The only reason I'm taking a star from it is that plastic build and parts fit could be better for this price. Viborg has much better build for one third of the price, but can't compre sonically to this Furutech.
Srboljub S.
Fantastic
These Furutech RCAs have very clean and energetic sound, with balanced tonality.
Compared to WBT next gen silver ones... These are less bright but more full-bodied and more punchy. I think these are simply more musical and prefer them to very open but slightly brittle sounding WBT.
Build quality is top notch and it's very easy to work with.
Srboljub S.
Awesome Socket
I have tested this socket against few others and can say it's worth every penny and then some.
Sound with it is precise and 3D, but very natural and not too sharp or too bright at all.
Just needs 300h to break in properly, it will sound nasty at moments before that happens.
Srboljub S.
Great buy
I used these RCA sockets in my tube DAC. Their quality is fantastic and since I haven't compared them to other sockets directly... The overall sound of a DAC is top notch.
Guillaume F.
DAYTON AUDIO DSA135-PR Passive Radiator 27.9 Hz Ø13cm A well-built passive radiator with aluminum diaphragm, designed to fit most medium-format (13cm) loudspeaker modernization/repair projects. It boasts a high excursion of 8mm,...
DSA135-PR
Petit radiateur passif de bonne facture.
L'aspect de la membrane en aluminium est du plus bel effet sur un caisson noir mat.
Couplé au bon haut parleur actif, ce haut parleur passif descendra relativement bas (dans les graves) compte tenu de ses dimensions. Idéal pour la fabrication de caisson de basses de très petite taille.
Guillaume F.
Bornier Atohm
Produit simple et efficace. Bonne finition pour la pièce plastique ainsi que les pièces métalliques. Aucun problème pour emmancher les fiches banane.
Maurizio B.
Extraordinary
I used to be a pioneer in the high-end computer based reproduction back a t the time when the problem was to have a bit perfect chain (yes, it was a long time ago). I now sold my trusted Weiss DAC202 and introduced the D90SE. The result is astounding. The transparency, the details and the musicality are simply great. If that was not enough, the price makes buying this DAC a no brainer.
Maurizio B.
It does what it promises
A simple device that does what it promises. In my case, it allowed me to turn on and off my Projector by adding a couple of smart sockets and monitor the load interrupted by this switch.
Daniel P.
Mauvaise connection.
N'entre pas bien dans une embase Furutech, ni dans une embase ampli d'ailleurs, le connecteur VF502 est meilleur, la matière n'est pas la même.
Rob L.
Great Product And Service
The product is top-notch, both in build quality (with a very unassuming, but attractive, industrial design) and in the excellence of its sound reproduction across the audio spectrum. Plenty of output power for digital sources, but when amplifying the signal from my phono stage, there is not a lot of headroom. That could be the fault of the phono stage, though. Anyhow, an excellent product. I am very happy with it, and will have it in my system for a very long time. I don't think it could be replaced, actually. Great value. The reps who looked after my order were very accommodating, as there were a number of complications due to my not having a phone. They provided me with some effective workarounds. Very enviable patience on their part, too. Merci beaucoup, Audiophonics!
Patrice L.
Une liaison XLR enfin réellement équilibrée.
Côté source :
1 fil bleu + tresse sur le pôle 1(masse) de la fiche xlr.
1 fil bleu sur le pôle 3 (-) de la fiche.
1 fil blanc sur le pôle 2 (+) de la fiche.
Le second fil blanc est coupé au ras de la tresse.
Côté ampli :
Pôle 1 le fil bleu sans tresse.
Pôle 2 et 3 avec les fils correspondants .
Utiliser un multimètre calé sur test sonore de continuité afin de repérer les fils à leurs extrémités du cable ( notamment les fils blancs AVANT d'un couper un ).
Monté avec des fiches Neutrik plaquées argent, vous obtenez un cable xlr dont les trois pôles sont équipés de fils identiques , comme le cable Pangea xlr, mais ..... à un tout autre tarif.
Le résultat sonore est juste ... bluffant .
Un dernier conseil: Tester après montage, vos fiches mâle et femelle au multimètre ( calé sur test de continuité Bip ) , pin 1 mâle sur pin 1 femelle , etc.. afin de confirmer la bonne correspondance des cables ( pas de plantage de couleur ).
Frederic H.
Je les utilise en remplacement de chimiques sur filtres d'enceintes
avec de très bon résultat
Tolérances très serrées , comme toujours chez Jantzen
Gilles G.
EXCELLENTE PRISE / alternative à la FI50ncf
J'ai acheté plusieurs de ces prises en remplacement de FI50ncf rhodium, ces dernières faisaient monter mon système, c'était fatiguant et je ne prenais plus de plaisir. Une par une j'ai remplacé les fi50 par des fi 46, même dynamique, ouverture, chaleur, j'ai retrouvé enfin du plaisir à l'écoute. Je recommande chaudement.
David j.
Connectique de très bonne qualité de fabrication. Montage des câbles HP facilité par le système de vissage. On a à faire a du solide. Idéal pour monter des jumpers de bon niveau.
David j.
Connectique de très bonne qualité de fabrication. Montage des câbles HP facilité par le système de vissage. Les embouts de la fiche peuvent s'écarter ce qui permet une stabilité optimale du contact avec les bornes HP.
David j.
OYAIDE TUNAMI TERZO RR RCA Interconnect Cable 1m (Pair) This high quality modulation cable is assembled with the most famous Focus 1 connectors and a 102SSC cable, a top of the line model from Oyaide. This cable is presented to us...
Très bon câble de modulation
Ce câble est très cohérent sur l'ensemble des registres, donne de la définition et procure beaucoup de naturel à l'écoute. Les variations dynamiques sont très bien rendues mais sans exagération. Belles image et profondeur également. Il sonne très légèrement mat.
David j.
Je recherchais un préampli aux fonctionnalités simples (volume et sélecteur de source point barre), neutre, musical, de (très) bonne qualité de fabrication, à un prix très accessible pour driver un ampli DIY LFA-50 Optim-A dont je viens de faire l'acquisition. Ce préampli remplit parfaitement ce cahier des charges.
Ce préampli, preuve de sa neutralité, est très sensible aux câbles de modulation utilisés. en possédant plusieurs non utilisés, je me suis amusé à faire différents essais : les différences sont clairement audibles (couleur, définition, équilibre général, largeur et profondeur de la scène sonore).
J'ai donc fait le choix de lui associer des câbles de modulation et d'alimentation de qualité. En entrée du préampli j'utilise un câble argent de chez Audiocadabra (relié à un dac Gustard 20H) et en sortie du préampli un câble OYAIDE TUNAMI TERZO RR (vendu sur ce site). Pour l'alimentation, je n'ai pas hésité également à lui associé un câble FURUTECH The Empire E (également vendu sur ce site).
Les résultats à l'écoute dépassent largement mes attentes. Le rapport / qualité de ce préampli est imbattable. Il mérite des câbles de qualité.
Merci à Audiophonics pour la qualité des produits proposés et à l'efficacité et gentillesse de son équipe.
Giovanni-Mattia P.
MINIDSP UMIK-2 Low Noise Omnidirectional Measuring Microphone USB XMOS ASIO 32bit 192kHz The UMIK-2 is the second generation MiniDSP omnidirectional low-noise measuring microphone. It takes advantage of everything that made the first version, the UMIK-1, so...
Excellent product, easy setup, accurate results
Perfect service by Audiphonics, excellent measurment microphone, easily set up for working with Room EQ Wizard on Windows via ASIO driver. No problem in obtaining the individual calibration files from MiniDSP. All in all, five stars.
David L.
Symmetrizer This balancer has an unbalanced stereo RCA input and a balanced stereo XLR output. It will allow you to provide a balanced output to an audio device that does not have one
Dans l’objectif de réduire le bruit trop élevé sur un ampli XLS avec hp haute sensibilité j’ai tenté ce convertisseur pour passer en xlr. Ca marche impeccable, le signal est boosté de 8db environ permettant après réglage un bruit final bien diminué. La boite est bien construite pour le prix, pas parfaitement finie mais parait solide, et je l’ai choisie car le signal reste tres propre (cf mesures par L7audiolab). Il y a un léger bruit d’alim mais inaudible une fois en place dans le rack.
Joost B.
Gustard A26 dac
This dac with the new AKM AK4499EX chip is a real bargain. It benefits greatly from it’s linear power setup, using two big toroidal transformers for digital and analogue stages. I came from a RME ADI2 FS dac, this is a big step up. Wider soundstage, more detail, more natural sounding instruments. Also terrific experience with Audiophonics again, fast delivery, good packaging.
Eric J.
XDUOO MT-605 Tube Amplifier 12AU7 TPA3116 2x30W 4 Ohm The MT-605 from xDuoo is a small and affordable amplifier, combining the performance of a Class D with the musicality of a tube system. Its amplifier stage is indeed based on a...
Bon ampli type lampe, sans réglages, puissant
Sonne assez bien, mais iI n'a pas la dynamique et la précision des amplis transistor, dans les basses, la rythmique.
Il lui manque les réglages basse, aigu. Il donne un son assez clair, vivant, plutôt puissant. Pour moi, sa puissance de 2*30W, équivaut environ à la puissance d'un mini ampli class D de 2*100W. Mais les basses étant moins affirmées, les mediums sont les plus sonores.
Un autre ampli lampe avec réglages, et le bluetooth en ferait un idéal par rapport à celui-ci.
Eric J.
SMSL DA-6 Class D Amplifier Infineon 2x70W 4 Ohm Black The SMSL DA-6 is a small, practical, high-performance and affordable Class D amplifier based on an Infineon amplifier chip offering high efficiency and capable of developing...
Pas aimé le son
Son aseptisé. Il est peu puissant, mais il y a les réglages basses, aigus, brillance, suround...qui donne de l'intensité sonore. (branché sur des hauts parleurs de 10cm, eltax monitor I, 87db)
A part la télécommande pratique, et le petit boitier bien fait, des connecteurs correctes, l'écran numérique, il est pas très utile. Pas de bluetooth.
Il y a mieux sur ce site, pour la richesse sonore.
Eric J.
Fonctionnel
Pour le prix, un ampli peu puissant, avec réglage basses aigu, et caisson de basse, du bluetooth. Le son est agréable, réaliste.
Par contre, l'alimentation est abscente, 22€ à ajouter. La puissance 2*50W, ça va pour des hauts parleurs de 10cm, mais pas plus. Il a pas de réserve. Je n'ai pas utilsé de caisson de basse. Les connections de câbles sont minuscules et rapprochées.
Pour moi, idéal comme ampli de dépannage, de test ou pour donner un fond musical et la radio.
Claude G.
Un tissu acoustique de très bonne qualité
Le tissu acoustique Jantzen Audio possède l'avantage d'offrir un excellent rapport qualité/prix : son aspect visuel ainsi que les qualités de son tissage ne laissent aucun doute sur sa vocation à protéger efficacement les haut-parleurs de mes enceintes colonnes, tout en étant totalement transparent à leurs émissions sonores.
Julien R.
Câble de bonne facture, très bon produit.
Marino M.
Qualité
Câble de bonne facture son plus aéré par rapport à des RCA !
Marino M.
ATAUDIO FLAGSHIP Power Cable Schuko IEC C15 Silver Plated OCC 7N Copper Double Shielding 1m With the Flagship, ATAudio offers a power supply cable with an exceptional design at a reasonable price. The special design consists of three silver-plated 7N OCC copper...
Le son
Je n'y croyais pas au câbles d'alimentation ! Je peux vous qu le son est nettement meilleur et il ,n'y a pas photos !
Marino M.
Piéces de trés bonne qualité superbe finition !
Gilbert H.
Cable HP media sun
Commandé par erreur à la place de la mme section en cuivre argent ( deja utilisé) je vais m'en servir pour câbler en interne des HP de grave sur mes enceintes Davis Balthus 90.
Gilbert H.
STYROFLEX Capacitor 65V 0.0068µF 2.5% Styroflex axial cylindrical capacitors can be integrated in many electronic assemblies. They have a tolerance of 2.5%.
Styro 65 v
OK les meilleurs pour l'audio en // sur des MKP basiques
Gilbert H.
Borniers Dayton BPA 38 hg
J'ai deja utilisé ces borniers , je les trouve de bonne qualité et bon serrage.
Gilbert H.
Tubes 6sn7 shuguang
Je les ai montés sur mon préampli ( SRPP) en remplacement des Electro Harmonix qui ont tenu 10 ans. Ils sont en rodage et après environ 40 heures d'écoute ça me semble bon.
Gilbert H.
Bor
Très bon serrage ,bonne qualité je les ai utilisés plusieurs fois.
gilles b.
Très pratique à l’usage , à l’écoute je l’ai trouvé très ”vivant” belle dynamique, je le préfère à mon ex auralic pour beaucoup moins chère en prime.
Cet isolateur est remarquable, il rend justice aux musiques enregistrées et légitime l'usage d'un canal USB (sortie ordi-entrée DAC) sur un système HIFI de bon niveau
Patrick d.
Nice product
Has a lot of options, great for the diyer
Patrick d.
Great product
Good quality, nice and sturdy, does the job without disturbing klicks or other noises
Henri V.
Bons résultats à bon compte
Une alimentation linéaire qui remplace avantageusement 2 alimentations à découpage.
Les alimentations à découpage même les plus "silencieuses" ont tendance à polluer les appareils connectées sur le même réseau électrique.
Le résultat est variable d'un appareil à l'autre mais toujours positif.
Vivement conseillé !
Nnanna E.
XDUOO MT-604 Headphone Amplifier 4x 6J1 Tubes Transistors Class A Balanced The MT-604 from xDuoo is a headphone amplifier based on the use of 4 6J1 tubes to deliver a soft and warm sound. These tubes are associated with transistors for the Class A...
Cheap and cheerful tube amp
I’m surprised by the performance of this hybrid tube amp. Simple and powerful enough to drive my HE1000SE headphones. Would certainly recommend for any newbie tube enthusiasts
Nnanna E.
DD TC44A DAC CS43131 Male Lightning to Female Jack 4.4mm 32bit 384kHz DSD256 This TC44A DD adapter for smartphone is composed of a male Lightning connector and a female 4.4mm jack. It also includes a CS43131 DAC for efficient conversion of the audio...
Portable and high quality
Connects easily with my iPhone and with my 4.4mm balanced earphones. Decent sound quality
Nnanna E.
DD TC44A DAC CS43131 Male USB-C to Female Jack 4.4mm 32bit 384kHz DSD256 This TC44A DD adapter for smartphone is composed of a male USB-C connector and a female 4.4mm jack. It also includes a CS43131 DAC for efficient conversion of the audio signal...
Simple yet effective
Very portable DAC that connects to my iPad Air and my 4.4mm balanced earphones. Sound quality is decent. Happy customer here
Miroslav Z.
TOPPING LA90 Amplifier Class AB 2x90W 4 Ohm / 1x180W 8 Ohm Silver Topping offers with its LA90 a powerful and efficient amplifier, which can work both in stereo and mono mode. In the first case, it is capable of delivering a power of 2x90W...
Miro.
Very clean and detailed sound, really very nice and robust mechanical design. Superb. :)
Denis D.
Qualité de finition irréprochable. Le produit est solide, bien construit et bien fini. La navigation dans les menus est intuitive.
La qualité sonore est quant à elle vraiment top. C'est précis, détaillé, dynamique mais cela relativement transparent. Un excellent produit que je recommande (associé avec un WIIM pro).
Patrick J.
Petit mais puissant
Très utile quand on manque de place
Patrick J.
DAYTON AUDIO HDN-8 Speaker Driver Exciter Bodyshaker Full Range Weatherproof 50W 8 Ohm 40He - 15kHz Ø10.2cm A weatherproof electrodynamic exciter that can be placed virtually anywhere, Dayton Audio's HDN-8 literally makes any surface "ring". The product is...
Système de fixation un peu étonnant...
Mais bon, ca fait le job pour sonoriser une caisse de Pincab
Patrick J.
Grave puissant et profond
La connectique est soignée, parfait
Andrea F.
Sicuramente un buon prodotto
Ottimo il rapporto qualità prezzo. Suona davvero molto bene, è veloce con una buona risoluzione. Non pensavo di ottenere questa qualità sonora. Purtroppo mancano le istruzioni anche se il funzionamento è molto semplice. Unico neo il led di funzionamento rosso è molto forte se si posiziona l'apparecchio sul fronte. Per il resto un prodotto che funziona alla grande.
Andrea F.
E' un buon cavo
Niente da dire, ottimi connettori, la sensazione di qualità costruttiva è effettiva. Buon suono, molto neutro e veloce.
Jérôme E.
A voir dans la durée
Produit propre, contact franc, la gaine Thermo est un plus
