Jean-François D.
Impeccable !
Vasilios K.
Ça Chauffe !
Customers reviews - There are 19303 reviews.
Andoni G.
Big and solid
I used them for 2 big hifi racks. They are big.
Andoni G.
Perfect for a little subwoofer, they are small, I used them for isolate a SVS 1000 sub
Andoni G.
Feel and looks perfect
Solid and good feeling, I bought it adviced by audiophonic.
Gérard R.
SHUGUANG KT66 Tetrodes Power Tubes (Matched Quad) These Shuguang KT66 tubes are power tetrodes, ideal for HiFi design or as replacements for similar models. They are sold factory matched by four units.
EXCELLENT TUBE
Sur un ampli tel le Van der Veen UL40S, le son est top. A recommander sans réserve
Gérard R.
belle découverte
Je cherchais à faire un petit sub pour compléter un LB dans un volume réduit. Dans 22 litres, soit une caisse de 33cm au cube, ce petit haut parleur remplit bien son office en créant un soubassement convaincant. Alimenté par un ampli transistors de 30 watts et filtré actif à 80Hz en 12 dB/octave, çà fait le job à niveau confortable 80/85dBSPL.
Marin M.
Wonderful DAC/AMP! As DAC itself, with signal coming from cd transport it cannot be differentiated from PCM63 or PCM1701 cd players, except in the highs. Headphone amp is also wonderful. It is very warm and sound very natural. I compare it with Topping L30 and the Audio-GD one sounds more pleasant and not that sterile. Only drawback is the highs. As non-oversampling dac, they are rolled off, starting from arround 10-11 kHz. I tried to pass the signal trough DSD, and it then shows the full range of frequencies, but the processing from PCM to DSD that the PC is making does not sounds as much pleasing as the native PCM. I had friends that are 45 years old and above, and they cannot hear the rolled off higs. I can hear it, but for me it is plus for long listening sessions, because it does not bring fatigue.
Eetu B.
Mediocre amplifier board
First boards to arrive were missing components, but thanks to Audiophonics' good support, I was quickly sent new boards. The boards suited well for my project and they sounded decent. The layout and build quality of the PCB is good and most of the parts were genuine parts, altho some regulators seemed to be refurbished. Also I would have wished that more data about the boards had been sent with them. (Testing results etc.) The boards were in a lot of use for about a year, until on the other board, the relay for selecting signal input, died. For the price they are decent amplifiers,
Jacques E.
Fabuleux
J'ai utilisé ce condensateur dans une liaison numérique avant un transfo de sortie ,en lieu et place d'un modèle déjà de qualité (MKP) et bien tout est devenu plus doux mais attention sans perte de définition, fluidité et naturel, voila...
Albert L.
Performance de haut niveau
Me permet d’écouter les meilleurs formats audio diffusés sur internet, mais aussi d’apprécier l’authenticité des enregistrements sur support à partir d’un PC. Cela dit, ce n’est certes pas avec le câble USB fourni que la prestation musicale est irréprochable. Aucune cohérence entre cet accessoire standard et le logo « HI-RES AUDIO » qu’arbore le boîtier. C’est une supercherie. Il a fallu le remplacer sans attendre par un câble USB audio digne de cet équipement. Le câble : « Viablue KR-2 Silver Câble USB-A Male/USB-B » acquis pour l’occasion est l’accessoire complémentaire idéal pour un rendu audio d’excellente qualité. Les trois sorties audio permettent l’utilisation sur un large éventail de système et d’installation, ce qui, en complément d’un PC portable rend la diffusion de la musique polyvalente, avec la qualité, à condition toutefois de s’équiper des câbles audio adéquats. Conçu pour, ou à partir de Windows 10, l’installation est automatique dès la détection du périphérique.
CHRISTOPHE D.
Rapport qualité/prix imbattable!
Très bon produit, fonctionne parfaitement avec le dtoverlay=hifiberry-digi-pro
J'utilise une configuration similaire à Moode Audio (upmpdcli+mpd) pour jouer du Qobuz depuis l'appli BubbleUPNP et cela fonctionne parfaitement.
Très bon timing, pas de problème contrairement à mes DAC USB Asynchrones ou pas...
marc m.
qualité audio top mais doute sur la durée de vie
Très content de la qualité audio.
Fonctionne très bien sous Linux/Ubuntu.
Par contre le premier que j'ai acheté viens de griller au bout de 3 ans et demi.
J'en ai quand même commandé un autre.
Andre R.
SABAJ D5 DAC ES9038Pro Headphone Amplifier Balanced XMOS Altera 32bit 768kHz DSD512 The Sabaj D5 is a solution that acts as both a DAC and a headphone amplifier. It ensures excellent performance, thanks to a careful architecture and components selected for...
Excellent resultat d'écoute
Un DAC qui transpire la qualité de fabrication. Il n'est pas en reste pour les résultats sonores.
Merci pour le conseil.
J'ai quelques difficultés pour paramétrer FOOBAR pour la lecture des DSD en direct (sans passage en PCM). Avez vous un tutoriel.
david a.
ATHOM
EXPÉDITION RAPIDE ENVOI DES COLIS SOIGNÉ ! JE RESTE FIDELE CHEZ AUDIOPHONICS .
Alain c.
bon produit, mais cable alimentation trop court !
bon produit que une très bonne sonorité, mais, malgré ceci j'ai constaté
que le bloc alimentation, n'a pas interrupteur en amont pour l’éteindre
et ce bloc reste en permanent sous tension, raccordé au secteur 220 v.
sa LED rouge est aussi désagréable, et difficile a masquer, car le câble
qui fait seulement 1.20 est bien trop court.
si l'on n'a pas une prise a proximité immédiate il faut faire l'achat
en supplément, d'une rallonge avec interrupteur pour couper l'alimentation, électrique du transformateur d'alimentation du
pré ampli.!
Jean-Pierre G.
Top.
Je viens de recevoir mon câble. Livraison super rapide.
Cable de qualité.
Allez y les yeux fermés.
Vous ne serez pas déçu
My reviews of UcD180HG HxR module
https://www.audiosciencereview.com/forum/index.php?threads/hypex-ucd180hg-hxr-amplifier-module-analysis-and-review.27852/
Olivier P.
Volume Control Board LED Display Remote Control This small volume control module incorporates a red LED display, indicating the sound level. It can be controlled remotely by its built-in IR receiver and the remote control...
controle de volume à télécommande
Ce produit mérite bien 4 étoiles, car la qualité et le fonctionnement sont parfaits, la télécommande n'a pas besoin d'etre en face du récepteur pour agir. Pas de perte pas de temps mort.
david d.
amazing
Great clarity, imaging, tonality, dynamics. It improved my sound by a big margin. I wil buy a second unit soon.
Bertrand A.
Ce DAC est vraiment bon ! surtout si on remplace les 3 AOPs d'origine par des AOPs doubles BURR BROWN OPA627.
J'ai fait l'erreur de me fier à l'avis précédent :
Une DEXA discrete est un AOP simple ; en sortie de ce DAC cela pose un problème de niveau de sortie...
Serge L.
SHANLING UA2 Balanced DAC USB-C ES9038Q2M 768Khz DSD512 Whether you are using a latest generation smartphone that lacks an analog audio output (compatible directly with your headphones / headphones) or you simply want to improve the...
DAC au top
Un petit DAC fort joli, très pratique et polyvalent mais grand par le son. Fonctionne parfaitement sur MacOs Monterey (pas évident), le son au casque (je ne fais pas la liste) et avec les HP (Iloud Micro Monitor) est parfait, bon rendu à fort volume comme à bas volume.
Parfait pour une utilisation Hifi ou professionnelle (studio) car très détaillé et toutes les fréquences passent à merveille. Je recommande vivement.
Je n'ai pas testé la sortie symétrique ni sur Iphone mais je ne pense que cela soit moins bon.
Alain M.
Excellent résultat avec enceintes large bande
Utilisé pour corriger la courbe d'enceintes TQWT avec HP Supravox large bande type RTF215 Résultat bluffant après seulement quelques mesures avec logiciel REW. Correction et transfert vers le minidsp facile moyennant un nécessire apprentissage. Bien plus efficace que n'importe quel filtre passif. Je recommande.
Dorian L.
Efficacité impressionnante
J'ai acheté ce filtre pour l'installer sur le câble d'alimentation de mes enceintes PC et le résultat est là. Mes enceintes étaient tout simplement inutilisables car les parasites couvraient le moindre son qui aurait pu en sortir, après installation de ce filtre je n'entends des parasites qu'à volume très très faible et il faut tendre l'oreille.
Allez y les yeux fermés surtout pour ce prix là !!
Joaquim Y.
Souffle pendant les silences
Ampli bien fini sur le plan esthétique . Je ne suis clairement pas audiophile mais, comme indiqué dans la description, cet ampli présente un souffle notable pendant les silences. La mention n'était cependant pas présente sur le site lorsque j'ai acheté cet article en 2018. À éviter si vous cherchez un tant soit peu un confort d'écoute. Je m'en suis rendu compte en le comparant à un autre FDA. Étonnant que ce produit jouisse d'une telle notoriété avec un tel défaut.
Dans la même catégorie le SMSL AD-18 est bien plus agréable (bien qu'il faille changer l'alimentation qui siffle).
Nicolas D.
Fiches banane Viborg
Très bon produit. Remplaces des fiches à serrage bas de gamme. Celle-ci tiennent bien dans les bornes des ampli QSC. Pas de modification du son, elle sont transparente et c'est parfait !
Frederic p.
Waouh ..!!
Franchement je ne pensais pas que ce câble rj45 puisse m’apporter une différence sonore..!!
Malheureusement j’étais surpris quasiment de suite un gain en clarté et en dynamique .
Une très très belle fabrication dommage qu’il soit pas équipé du VIABLUE EP-7S
Qui a l’air de meilleure qualité que le viable Ep équipe avec ce câble rj45
Franchement a ce prix là il a même pas à réfléchir ..
Henri c.
bonne qualitée
je l'ai depuis peu, je trouve la qualité audio bonne , il se synchronise
bien ,la qualité de fabrication est bonne , l'affichage est un plus agréable , a ce prix c'est une bonne affaire.
Owen M.
AUDIOPHONICS HPA-T400ET Power Amplifier Class D 3 Channels Purifi 1ET400A 3x400W 4 Ohm We are proud to offer you the AUDIOPHONICS HPA-T400ET, a 3 way class D power amplifier based on three PURIFI 1ET400A modules. This ready-to-use version is aimed at audiophiles...
Fantastic
This thing is crazy. I've never in my life heard a quieter amplifier. Well, the Bryston 6B SST I had was pretty close. But that was a $6000 amplifier (and until now was the best power amp I've ever owned). Holding my ear next to the speakers, the only thing I can hear is a very quiet ticking in the ribbon tweeter from (what I assume) is EM noise in the environment (speakers are Elac Carina). That ticking is inaudible from 5 cm away. The typical amp hum is absolutely non-existent. Listening the music (Beck's Sea Change on SACD) is enlightening. I haven't upgraded my surrounds, which are active Tannoy Reveal 6D speakers. Listening with my ear next to the speaker, and the Tannoys have a distinct sound, while the Purifi-driven Elacs sound like... nothing. Just incredible. I've never heard, in my 20 years as an audiophile, a more neutral speaker+amp combination.
Also, the packaging was exceptional, and if you're a minimalist like me, the amp is just glorious. Sturdy, clean design. Feels great in the hand. Binding posts are so sexy I wish I had a reason to use them more. A flawless amp, and worth every cent. Congratulations Audiophonics (and Purifi)!
* One negative: The courier left the package outside my door. This is not acceptable for a 2k€ item. I mentioned this to Audiophonics, and they replied that they'd report it to the courier. Naturally, this is not entirely their fault, so I didn't consider it when rating the amp.
Patrice S.
Quelle surprise !!!
Alors, marche ou marche pas les cables secteurs ? Il y a tant d'avis opposés sur le sujet que je tente régulièrement l'expérience avec du matériel à prix raisonnable.
J'ai donc acheté 2m de ce CS-361B et j'ai équipé deux câbles de 1m avec des connecteurs de la même marque (PS et PI 24).
Je possède à ce jour 1 cable CS-331B, 1 CS-321B et 2 CS-361B, branchés sur une barrette secteur Wireworld Matrix II. Mon matériel audio est tout ATOLL (série des 100) et enceintes Récital Audio modèle Illumine (au passage excellentes enceintes au RPQ très très bon).
EH BIEN QUOI QU'ON EN DISE ÇA MARCHE SUR MON SYSTÈME !!! Mais en fonction des câbles et leur emplacement sur la barette c'est parfois si subtile que je pense que placebo n'est pas loin. En revanche le CS-361B en alimentation de la barrette a eu un effet foudroyant...d'un coup et pas au bout de 40h00, le son s'est libéré, il s'est éclairci, les notes se détachent nettement et finissent lentement, la scène sonore a gagné en profondeur, dans les orchestre les groupes d'instruments sont plus lisibles avec un meilleur positionnement dans l'espace, il est précis, mais attention aux mauvais enregistrements, il laisse tout passer dans mon cas. Ah oui, les masses ont bien évidemment étaient contrôlées avant branchement.
J'ai essayé de nombreuses combinaisons avec mes câbles mais la plus flagrante, et de loint, est de positionner le CS-CS-361B en entrée de la barrette. A ce jour mon système fonctionne avec CS-361B entrée barette et ampli, CS-321B sur le streamer et le CD passera en CS-321B car de mon système j'élimine le CS-331B pas assez dynamique et limitant les médiums et aigus dans mon cas. JE SUIS RAVI, le résultat sonore me convient et cela par des investissements progressifs et peux coûteux au regard du résultat.
Je trouve ce cable assez souple, malgré son diamètre, et pour donner une idée de l'encombrement, il faut un espace minimum de 11cm entre le mur et le meuble accueillant le matériel.
Pour finir je ne peux que conseiller ce câble en alimentation d'une barrette. Pour le prix il faut tenter l'expérience.
Marc P.
Etonnante version MK2 sans les prises branlantes!!
Mon instal ayant pris de l'ampleur, streamer, DAC etc... j'ai racheté une barette identique à la première. La première il y a deux ans amenait une évidente transparence (à priori cable interne de course??) mais avait des prises un peu branlantes. Bon une fois la prise fixée, personne va aller la secouer, mais c'était une petite contrariété. Oh surprise Audophonics a du rectifier le tir car non seulement ce ne sont pas les même prises (plus cossus) mais enclenchement super ferme dans la prise. Le top. Là sans les prises bralantes, je suis bluffé car y'a plus aucun reproche possible et toujours ce petit plus en transparence. Chapeau bas et bravo d'avoir rectifié une (probable) erreur de jeunesse. Surtout gardez les même prise. C'est pas du furutech mais beau placage or et très proche de furutech niveau qualitif (vu chez ami audiophile et toujours du mal à comprendre de tels prix) et pour 8 prises le "coût à la prise" est juste "wow" !!
Kalle J.
Good value.
Upgraded from my NAD D1050 (CS4398) that tragically died.
This unit does everything just as good or better.
- for no USB-C
Super mais pas avec un conditionneur
Avant l achat d un conditionneur keces bd1200 soit toroidale de 1200v/a. Déphasage et filtrage en mode commun. Le filtre Ifi tasse la dynamique. Dommage. Je l est brancher sur l
Une prise mural libre du salon. La PR contre surprise. Le modem fonctionne mieux. Le réseau est devenu plus rapide et bc plus propre. J ai adjoind une Ifi purifier kiné dc entre l alimentation du modem. La encore mieux. J ai un 2eme Ifi noise filtre. Je m en sert sur la multi prise pc portable et n'as. La encore du mieux partout. Le n'as délivré les bits sans perte, propre. En gros une fois trouvé le ou les bons emplacement ses filtre travaille vraiment bien. Mon streamer Ifi zen donne son max. La tv a des images magnifique, mon pc n'a jamais fonctionné aussi bien. Même audirvana en a profité. Achat recommander. Comme une personne ici la dit 2vaut mieux qu 1..Le tweak RQP exeptionnel
Olivier G.
Superbe boitier
Produit reçu bien emballé/Produit aux finitions exceptionnelles
Barrie M.
NEOTECH NEI-1001 II Interconnect Cable Balanced UP-OCC Silver 2x1.17mm² Triple Shielding The Neotech NEI-1001 II is a balanced modulation cable made of 2 Silver UP-OCC conductors with a cross section of 1.17mm². Each conductor is composed of 4 strands of...
Excellent DIY Interconnect Cable
Could tell immediately that this is an exceptional cable . Excelled from get go with I am sure more to come as cable runs in with use . Using to connect Electrocompaniet EMC1 UP ( used as transport ) to Gustard A22 DAC and pair of balanced interconnects for Gustard to PreAmp (ATC SCA2) . Cable has replaced Neotech NEMOI-1220 ( OC UP silver ) . The 1220 is very good but 1001 is better . Highly recommended .
Piotr K.
Pairs as BT device HiFi-IIS
Pairs as BT device HiFi-IIS on my iPhone. Found some loose screws inside and had to open it and remove it. To early to say anything about sound quality.
Albert L.
Bien conçu, très bonne qualité audio
Cela ne se dément pas : c'est un câble USB de qualité tout à fait dédié au branchement des périphériques Audio informatique “Haut de gamme”. Et c'est d'autant plus vrai lorsqu'on le compare à un câble USB Audioquest d'un prix équivalent mais moins convaincant sur le rendu audio. Le son s'améliore nettement : bien équilibré, plus claire, plus détaillé, dynamique et plus percutant. Ce câble VIABLUE acquis pour le branchement entre un PC et un TOPPING D10 BALANCED USB DAC est d'une excellente qualité de fabrication et d'un rapport qualité-prix tout à fait correct. On peut juste regretter qu'il ne fasse pas 25 cm de plus pour l'attribution d'une étoile supplémentaire.
Albert L.
Cela ne se dément pas : c'est un câble USB de qualité tout à fait dédié au branchement des périphérique Audio informatique “Haut de gamme”. Et c'est d'autant plus vrai lorsqu'on le compare à un câble Audioquest d'un prix équivalent mais moins convaincant sur le rendu audio. Le son s'améliore nettement : bien équilibré, plus claire, plus détaillé avec un dynamique plus percutant. Ce câble VIABLUE acquis pour le branchement entre un PC et un DAC USB TOPPING est d'une excellente qualité de fabrication et d'un rapport qualité-prix correct. On peut juste regretter qu'il ne fasse pas 25 cm de plus pour une étoile supplémentaire.
Denis M.
très bon rapport qualité prix
Barrette de qualité avec prise schuko à un prix abordable par rapport à d'autres sites
Livraison ultra rapide d'audiophonics comme à son habitude
Denis M.
1877PHONO COVE-RA Cable RCA to 90° DIN High purity OFHC for turntable 1.2m This cable has been specially designed for analog applications and is intended to significantly improve the input signal of your board.
En remplacement ancien câble d'époque , vieille platine technics encore vaillante , équipée en fiche DIN, type de câble qui vient très difficile à trouver à prix raisonnable, j'ai cherché un moment...
Je ne connaissais pas cette marque, vu le prix, la qualité des matériaux et l'amélioration très audible des finesses sonores je recommande !
Délai de livraison ultra rapide d'audiophonics, un site hautement recommandable avec d'excellents rapport qualité prix
Martin T.
GUSTARD
Very fast delivery only 6 days to Bulgaria Thanks to the team for the quick response
Barrie M.
Musical Dac
The A22 is an excellent DAC . Its foremost quality is its musicality. This is not surprising with dual AK4499EQ DAC chips and dual mono based design . The AK4499 DAC chip is widely recognised as one of the best currently available . I mainly listen to cds and prior to purchasing the A22 I used Electrocompaniet EMC1 UP ( up sampling CD player ) . I now use the EMC1 as a transport with the A22 DAC . In A/B comparison incorporating the A22 provides noticeable sonic improvements . The A22 sounds best with AES interconnect . Highly recommended at the price .
ANTONIO M.
MPA-S250NC SONIDO LIMPIO CALIDO Y POTENTE
calided valvular pero sin el ruido, calor ni lios de las valvulas. Graves con control y corriente mas que una etapa de estado solido clase ab de 200w.... agudos calidos, medios liquidos valvulares, y ademas pequeña ligerra discreta y eficiemte. Sustituyo a Bryston 2.5B SST3 porque suena mejor en ambos extremos del expectro y ademas es mas dinamica y mas limpia
Etienne P.
utile et efficace
léger gain de précision dans le medium et l'aigu utilisé avec vibrapod sur un ampli a tube classe A qui chauffe ils evitent la déformation du vibrapod par la chaleur de l'ampli...
Etienne P.
léger mieux que sans
pour le prix un léger gain dans le medium aigu sur preamp et source CD
Etienne P.
le meilleur en definition pour médium aigu
Utilisé sur un preamp modifié très précis pas de souffle et très rapide pas le plus musical mais très neutre et belle cohérence (les anciens on duré 7 ans) magnifique medium aigu base pas aussi chaleureuses qu'avec d'autres tube mais très bien tenue!
Etienne P.
Un bon tube pour preamp
très bon tube pour mon preamp beaucoup de précision je cherchais ce tube car mon preamp est modifié pour ce tube
Pas le coté chaleureux et aussi ouvert mais très analytique et nerveux!
Dirk d.
petite soirée entre amis
j ai invité 4 amis à passer une soirée spéciale casque audio.
Des passionnés comme moi, chacun d entre eux ont pris leur casque ampli; casque et dac .
quelle soirée...
ça a fini presque à 3 h00 du matin.
En casque audio , on a le focal Elegia et Clear, le Grado, Beyer dynamic 770etamiron ,le Denon d7200,Hifi man deva, Sennheizer 650et 800, le Meze99.
Ampli dac :Advance px1 , Atol hd120, Cambridge 200m ,Xduoo ta10 et Audio gd r28
difficile de dire comme ça qui est le meilleur.
Il y a quand même des différences de son et de qualité.
Par contre, on s est rendu compte que des produits se marient bien ensemble.
Dans mon cas, j ai l audio gd et le focal Elegia et Sennheizer 650.
Au final, le focal parait presque le plus mauvais de tous .
Bref une claque, lorsque j ai entendu le Meze99 et surtout le Denon qui sera mon futur achat.
Mais l audio gd est quand même et reste sur le haut du podium
tout avis confondu .
j ai passé une super belle soirée , et on compte refaire cette échange, et surtout cette convivialité.
STANISLAV V.
Very nice sounding cable
I've used this cable on a pair of Monitor Audio Silver 50; NAD 316Bee V2 and the combination is marvelous - open sound, sweet highs and mids (MA has a warm sweet sound signature) and perfect bass (for the size of the speaker). Details are clearly heard (nearfield setup). Better than the previous noname 2x1 mm2 solid core copper.
AUDIO-GD R-7 2021 Balanced R2R DAC FPGA I2S HDMI Amanero 32bit 384kHz DSD512 Accusilicon Crystek The Audio-GD R-7 is a high-end DAC based on a discreet R2R symmetrical design with optimized high-speed Ladder correction using the FPGA FIFO as a buffer and reclocker. As...
Magique !
J'ai la version 2020 qui n'est plus affichée alors je laisse mon avis ici.
Je suis passé d'un dac Musical Fidelity à ce R7 d'Audio GD et l'écart est énorme. Tout est mieux, la spatialisation, la précision, les fines dynamiques, les timbres d'instruments et des voix, tout y est.
Il est alimenté par un Yarbo SP-1100pw avec des Viborg sur une multiprise Furutech, c'est la moindre des choses pour que ça marche comme il faut.
Monté avec un Neotech NEI-3003 mkIII pour du coaxial, l'ensemble rend super bien et le montage passe tout juste. A moins de 50€ l'ensemble c'est du tout bon comme dirait Jacques ^^
Excellent coaxial
Câble acheté pour mettre entre mon Shanling Tempo en drive et mon R7 et ça marche du feu de Dieu. Question montage je lui ai mis des rca Elecaudio TE-RC90S en cuivre tellurium argent. Le câble passe au chausse pied dans les connecteurs, 8.5mm tous les deux, mais après juste une soudure au milieu et le reste se coince tout seul autour. J'ai bourré avec du teflon après pour éviter tout risque. Non rodé il pulvérise un bon modulation et j'attends avec impatience la fin du rodage. Bien à vous ;)
