peter S.
peter S.
peter S.
Customers reviews - There are 19608 reviews.
Trevor J.
KHADAS TONE BOARD VIM EDITION ES9038Q2M DAC Module USB XMOS U208 SPDIF 32bit 768kHz DSD256 Khadas' Tone Board uses an ES9038Q2M decoding chip. This is not only the flagship ESS product, but also one of the best current hardware solutions for high-fidelity audio...
Good for something but not music
Strong clear bass and treble but the sound stage and image are non existing. The sound is just on the speakers.
Vic T.
Does The Job
Has a nice finish, similar to other silver stereo components I own so fits in well. The footprint is larger than I would like, given that all the box is meant to do is select between 4 different inputs and nothing more -- no other electronics on board. But it does serve a purpose, acting as a counterweight to 5 pairs of cable tugging at its back, allowing it to stay in place. Personally, I would have preferred something smaller but with the same weight. The walls and faceplate are already fairly thick (5 mm), so additional weight might be achieved by adding a thicker bottom. The selector switch itself is nice looking, but I would have liked more distinct increments; the switch has rather soft settings instead of stiffer click-stops. Having said all that, I don't regret purchasing this item. It's doing what it's supposed to. My streamer/amp only has one RCA input and I have several components that need to share that input. The selector looks good with the rest of the equipment, is holding its own against all of the cables that are being routed through it, and I've grown accustomed to the soft switching.
Fantastique
Fantastique, exceptionnel pour son prix.
J'espère que dans le temps il va perdurer.
Merci à Audiophonics pour leur conseil et pour leur envoi en temps et impeccable.
Lennart B.
Great product and great service
It’s my first tube and I am super happy with my purchase. Sounds sweet and a lot more fun than my solid state amp.
Other than that, I can only recommend this shop. Fast delivery to Germany and great after sales support.
Nuno N.
SMSL DO200 DAC 2x ES9068AS XMOS Bluetooth 5.0 LDAC 32bit 768kHz DSD512 MQA SMSL offers with its DO200 a small, powerful and complete DAC. Its digital/analog conversion stage is equipped with 2x ESS9068AS DAC chip, able to offer a transparent, rich and...
Simply amazing!
The DO200 is a linear Dac with an overall signature of being crystal clear and dead silent with the noise floor.
The midrange of DO200 is clean, detailed, vivid, and very wide.
The bass feels sharp and deep, dense, but not overbearing in amount.
The treble is clean, airy and brightly open, with good extension up to the highest treble notes.
The soundstage is not just wide, but also deep.
Overall an awesome Dac from SMSL
For more follow me in Instagram @darkwish_aesthetics
jerome m.
FX-AUDIO DAC-M1 DAC ES9038Q2M XMOS 32bit 768kHz DS512 Bluetooth 5.0 Gray FX-Audio's DAC-M1 is a compact, affordable and powerful digital-to-analog converter. It is based on the use of an ESS ES9038Q2M DAC chip, associated with an XMOS XU208 USB...
parti pour un loxjie et je me retrouve avec ce FX audio
Très bon DAC, j'adore la commutation automatique entre le casque et les enceintes, il suffit de débrancher le casque et il bascule automatiquement sur les enceintes, le volume est propre à chaque mode. cela marche plutôt pas mal avec mon PC, Je l'ai relié en optique au pc et en rca à mon ampli enceintes, le son est bon pour un prix correct. Merci audiophonics.
Andoni G.
For isolated electric line
I buy 20 meters for make a isolated and exclusive electric line for my high end equipment
Affordable and good shielding
Andoni G.
Incredible usb
Nothing to say about Furutech. This brand is quality and this cable is affordable for the improvement
Henrik H.
Good choice
Ordered this with a Sundara, also using it with an AKG K7XX.
It is very practical, like the remote, i dont even have to touch the thing.
Had some trouble with losing signal, but a PC reinstall solved it, it is also compatible with Win 11, plug&play.
The volume knob is very loud clicky, but since I use the remote, not a problem.
I also have my active speakers connected to its RCA out, and my favorite feature is by far the 1 button switch from headphone to speakers and back, dont have to plug in/out anything anymore, or change output devices in the PC, just 1 push of a button.
The display is nice and smart, only shows info when needed, and by auto it shuts off, only leaving a little yellow dot when not in use, no blinding power leds..
Sound is.. it's an amp.. it shouldn't have a sound.. and it is dead silent when not playing, no loopbacks, no hissing.
One con: The power adapter cable is kinda short for me, will get something for it.
Overall, it is a Yes from me, would buy again.
Henrik H.
Almost perfect
Ordered this with a DX3 Pro+, its a perfect match for it.
I EQ-ed it to the Oratory Harman curve (with +5db extra bass, and linear subbass) and it is awesome, planar bass is a game changer, it goes as deep as my SVS sub, only missing the tactile feeling (just ordered some shakers :))
Design is very good, massive, adjustable with nice clicks, it wont come loose I'm sure.
Padding is very comfy, nice feeling.
So, it is a yes from me. Would buy it again if i have to.
Oh and one con: The cable.. its horrible.. I knew from the reviews that it is bad.. but really.. it needs a replacement.
JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 6.8µF Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a...
Excellent condensateur mérite l'investissement
Il faudra être patient pour obtenir le meilleur de ce condensateur ( environ 100 heures et le "bouchon" saute). Idéal sur le filtre médiums hauts - aigues en particulier avec des tweeters à ruban. Je l'utilise sur une 2 voies filtrée en 12 DB avec un Ess Amt. Après des Mundorf Suprème qui étaient déjà très bons, les Alumen m'ont fait passer de la 2D à la 3D avec beaucoup de détails, tout devient précis, les médiums s'expriment, les voix sont magnifiques, le son devient naturel , les ambiances concert sont retranscrites parfaitement.
Excellent cable
Je possède ce câble Triangle depuis quelques années et malgré plusieurs essais avec d'autres câbles je le remets sur mes systèmes.
Je le conseille vraiment
Elsa A.
Excellent module SMPS300RS
Faibles parasites EMI, faible encombrement, si la fiabilité est comparable aux SMPS 500 et 600 on est proche de l'optimum
Elsa A.
Excellent module
Excellent module amplificateur, outre les possibilités de configurations (du mono au quadri) la qualité est bluffante, associé à la SMSP 300 le résultat est Top, de plus les dimensions permettent d'implanter un double mono dans le même boitier avec une seule SMPS300.
Les EMI sont compatibles avec la réception radio sans parasites.
Elsa A.
Rectificatif
Je rectifie mon avis précédent : ce module a été testé à nouveau , le précédent essai ayant été réalisé dans un environnement bruité par l’extérieur.le bruit externe a apparemment disparu; ce module a été plus sensible que le symétriseur à base de NE5532, qui, lui avait fourni un résultat moins détaillé mai exempt de parasites, d'où ma première impression.
Le niveau de détail et la scène sonore s’avèrent meilleurs avec les DRV 134.
Dhafer D.
Excellent Ampli Casque
Acheté suite au conseil d'audiohonics pour piloter un AKG 702.
Je trouve après 3 mois d'utilisation que le mariage avec ce casque est réussi. Il ya assez de puissance ( potard à 10h max ).
Le rendu est assez neutre je trouve : essayé avec plusieurs DAC que je connais bien, il retranscrit les caractéristiques de chacun d'entre eux vers le casque.
Contrairement à ce que j'ai pu lire, il ne chauffe pas tant que ça, pour un classe A c'est vraiment normal et acceptable je trouve.
Si y a un point négatif à remonter c'est peut être une sorte de distortion audible dépasser un certain volume, mais là encore je cherche la petite bête car je vais jamais jusque là niveau volume sauf par curiosité c'est tout.
Pour moi c'est un excellent ampli qui fait très bien ce dont il est conçu pour, rien de superflux.
Dhafer D.
DAC Imbattable à ce prix
Acheté suite au conseil d'audiophonics pour piloter un AKG 702.
Excellent DAC : son détaillé, équilibré et non agressif.
Par contre j'ai trouvé que les basses ne sont pas assez maitrisées et que les medium sont un tout petit peu mis en avant (je cherche la petite bête)
Cela n'enlève en rien son coté chaleureux et son incroyable musicalité et abscence de distortion.
A ce prix franchement, imbattable !!!
jean-françois v.
Excellente horloge
Excellente à tous les niveaux, voir mon commentaire similaire sur l'Accusilicon à 45 Mhz. Merci au audiophonics pour les conseils toujours de qualité.
jean-françois v.
Excellente horloge
Après avoir installé un le Recloker FIFO PPI Q3 de Ian Canada sur mon Streamer à base de Raspberry PI4, j'ai décidé de changer les horloges d'origine de cet excellent recloker. Que dire si ce n'est que je redécouvre mon installation tout est mieux à tous les niveaux. En premier lieu ce qui frappe, c'est un gain dans les micros détails les fins de notes avec un silence profond. J'ai des enceintes haut rendement DIY à base de Altec 414 et de Moteur TAD - TD 2001+ pavillon rendement mesuré + de 100 db et j'ai un silence de fous dans mes pavillons. Attention cependant les premières écoutes sont un peu dur il faut attendre plusieurs heures avant que les horloges se rodent un peu, ensuite ce n'est que du bonheur !! A acheter les yeux fermé, surtout au vu du prix, merci à audiophonics pour leurs précieux conseils.
jean jacques v.
Audible
Je n'écoute qu'en streaming, radios et Qobuz sur une paire de KEF LSX50W2, relièes par des RJ45 Audiophonics entre elle et à la Box via un simple switch Netgear. J'ai pris cette alim qui est plus petite que je pensais, et elle n'est pas moche, dans le but de la mettre sur ma Box Orange sur laquelle j'avais déjà une alimentation IFI AUDIO IPOWER X.
J'ai fait un premier essai en mettant cette alim sur mon switch internet en laissant la IPOWER X sur la box. Le résultat n'était pas satisfaisant, manque de présence avec un voile. J'ai interverti les 2 alimentation et là... C'est bluffant, une transparence, une présence, une netteté...c'est incroyable...et je ne suis pas du tout un audiophile pointu, mes oreilles ont plus de 60 ans. J'avais déjà optimisé mon installation avec une multiprise Audiophonics et des cables RJ45 Audiophonics, et là je suis comblé, je suis persuadé que ma petite chaine est au maximum de ses capacités et le résultat est magnifique, sur des sources correctement enregistrées en Flac.
Henri G.
Ce produit fonctionne vraiment bien.
Je n'ai jamais été convaincu par les filtres secteur passifs. Ceux-ci tassant la dynamique.
Ici rien de tout cela, au contraire un gain de la dynamique est ressenti. On gagne aussi en détails et en ouverture de la scène sonore.
Du coup j'en ai 3.
1 sur la prise murale desservant le système audio et le système vidéo.
1 sur la multiprise desservant les alimentations linéaires audio.
1 sur la multiprise desservant les alimentations à découpage audio.
Le résultat est excellent.
Frederic F.
Excellent produit...
J'ai reçu l'article dans une petite boîte.
Le plastique autour de la fiche laisse une impression de "fragilité" mais le produit reste qualitatif.
J'ai associé ce connecteur IEC au connecteur Schuko de la même marque et aux câbles Neotech UP-OCC Cuivre ; Et le gain est au rendez-vous : plus aéré et plus précis.
Je voulais avoir 100% de cuivre depuis mon transfo d'isolement à mon équipement hifi et je ne regrette clairement pas mon investissement.
Frederic F.
J'ai reçu l'article dans une petite boîte, le tout accompagnée d'une petite clé allen pour les borniers du connecteur.
J'ai associé ce connecteur Schuko au connecteur IEC de la même marque et aux câbles Neotech UP-OCC Cuivre ; Et le gain est au rendez-vous : plus aéré et plus précis.
Frederic F.
VIBORG VE01G Power Plug Schuko Type F Pure Copper 250VAC 16A This Viborg VE01 socket uses high quality materials to ensure a perfect transmission of the electrical signal. The contacts are made of pure copper. This allows to maximize the...
J'ai reçu l'article dans une petite poche celée, le tout accompagnée de 4 vis pour fixer l'embase et d'une petite clé allen pour les borniers de l'embase.
J'ai associé cette embase à des connecteurs secteur de la même marque et aux câbles Neotech UP-OCC cuivre et le gain est au rendez-vous : plus aéré et plus précis.
jean-françois v.
Excellent !!
Pour ceux qui souhaite porter leur Raspberry PI au plus haut niveau en utilisant ce reclocker, la sortie i2S via les broches du GPIO (GPIO côté propre) donne d'excellent résultats. Pour info ma liaison numérique est toute en I2S à savoir et comme suit : sortie du Raspberry I2s vers le FIFO Pi et sortie du FIFOPI en i2s vers un filtre actif numérique Najda qui possède une entrée en I2S. Ce qui change avec ce recloker en premier lieux, une scène sonore élargie, un excellent positionnement des instruments dans l'espace et un niveau de détails hallucinant du grave jusqu'à l’extrême aigue ( attention il ya un petit rodage des horloges car au début c'était un peu dur pour le haut médium aigue). Cela vaut vraiment le prix, mieux encore changer les horloges d'origine pour de l'Accussilicon et là on atteint le nirvana.
David S.
La qualité de fabrication est plus que satisfaisante et propre pour cette gamme de prix.
Bien sur les puristes vont critiquer l'interrupteur, mais bien pratique pour garantir une mise hors tension. Associé à 2 câbles PANGEA AC-14SE MKII, un pour remplacer l'alimentation du bloc, l'autre pour mon ampli Lector audio ZXT70. La section de ces 2 câbles laisse passer largement le courant nécessaire à ma configuration.
Pour le gain à l'écoute je vais éviter de faire un commentaire à court terme sur ce sujet subjectif.
Imrich R.
Excellent cable. Completely neutral very beautifully rendered music scene, hologram 3D. The dynamics are also at a very good level.
I highly recommend.
Imrich R.
Excellent cable, very neutral with excellent dynamics, which gradually improves as the cable burns down.
So far, I've gone through a few major speaker brands, but this one is really the ultimate for me. After Nordost cabling, this Canare is a great choice.
I can only recommend.
Apml: Egg Shell Classic 15.1
CD payer: Mcintosh MVP-871
Bluesound Node 2i
Dac Adi2fs
Speaker: Fisher octavia ambiente - Limited edition
Arthur S.
Volume drop
Experienced a volume drop, may not be as universally compatible as one would expect. But very low distortion amp if it is compatible in target product.
Jonathan D.
Le Meilleur même a ce prix
Relié entre ma prise murale FURUTECH FT-SWS NCF (R) et ma barette LH Audio 8 embases chêne avec comme connecteur les VF503S et VE503S de chez Viborg j'ai encore gagné en clartés et timbres par rapport a mes habituelle câbles de chez YARBO, le SP-1100PW Câble secteur Triple Blindage OCC qui eux vont de ma barette a mes éléments HI-FI, tous mes câbles sont en longueurs de 2 mètres. Merci Audiophonics.
Jonathan D.
NEUTRIK NADITBNC-MX Impedance Transformer XLR AES/EBU 110 Ohm Male / BNC 75 Ohm Female This digital adapter consists of a 75Ω female BNC connector and a 110Ω male XLR. It allows long cables to be installed via a low attenuation coaxial line, while...
Pratique
Fonctionne très bien, m'a permis de relié ma source Cocktail Audio X14 depuis la sortie coaxial RCA vers mon DAC Audiolab M-DAC+ sur son entrée AES sans aucune perte ni changement de qualité, merci Audiophonics.
Does what the marketing says
Hi had used a variety of power conditioners and the most recent expensive one squashed the dynamics and made the sound glary and harsh.
For once, the marketing is to be believed with this product. It really smoothes out the sound without any loss of detail while letting more detail through.
I have it in use less than 24hrs and already its proving its worth. A reallly terrific investment.
Danitza P.
Excellent préampli
Audiophile depuis plus de quinze ans, et client depuis de nombreuses années, n'ayant jamais été déçus par le professionnalisme des gens de chez Audiophonics, une fois encore cela c'est avéré exact.
Contexte: après avoir envoyé un mail à M. Aubert lui expliquant que suite à la mise en réparation de mon ampli intégré habituel (Cambridge Audio), j'ai mis en service un petit (mais puissant) ampli de classe D (SURE A2100 Explorer), afin d'alimenter mon système à base d'enceintes larges bandes (Fostex), d'un caisson JBL, d'une platine Marantz et d'un lecteur numérique FIIO, le tout orchestré par un Mini DSP 2X4 HD. L'écoute du classe D par rapport à mon ancien ampli s'avérait très neutre et plaisante avec une belle qualité des timbres, mais à mon gout manquait d'un poil de dynamisme.
L'achat d'un préampli pour vitaminer tout ça, me paraissait indispensable (c'est souvent ce qui ressort avec les amplis classe D, ou l'ajout d'un préampli apporte une réelle plus-value à l'écoute).
C'est donc en ayant suivi ses conseils que j'ai acheté ce préampli j'ai donc reçu l'appareil de "format moyen" (ni tout à fait compact, ni au format habituel des appareil hifi). Ce dernier s'avère excellent dès les première notes (Classe A oblige), transparent, très dynamique, facile à utiliser. ça a radicalement changé mon système. De très bon, il est passé à excellent. La qualité de fabrication n'est pas en reste: boitier, boutons… et mention + à la connectique très qualitative. Seule la LED rouge en façade est un peu dérangeante, elle éclaire trop… (c'est malheureusement souvent le cas avec les appareils d'aujourd'hui).
Pour le prix, vous pouvez y aller les yeux fermer, vous ne le regretterez pas, je pense même qu'il rivalise sans soucis avec des appareils beaucoup plus chers.
Merci et bravo à toute l'équipe d'Audiophonics.
Jonas Å.
Instant upgrade!
I bought two and put the first one between my PC and a buss-powered 4-port USB 3.0 hub. The second one is plugged into the hub right before an iFi idefender. The iDefender then connects to a USB 2.0 hub that has been modified with grounding, extra shielding and power filtering. This hub then connects to a usb to coax decoder.
Each iSilencer added resulted in instant improvement! Sound became softer, more pleasant. Very happy with purchase!
I also tried putting them in empty USB jacks next to the cables but this didn't work as well. Seems to work best in series.
Nikolaus N.
Zauberkästchen für mein Digione
Ich habe dieses Netzteil bestellt, da mein bisheriges keine CE Kennung hatte. Deshalb habe ich es ohne Erwartungen gekauft. Es sollte einfach nur ein Austausch sein.
Aber nach den ersten Takten der Musik war mir klar, dass das Teil viel mehr kann. Die Musik löst sich über den gesamten Frequenzbereich mit viel mehr Details von den Lautsprechern. Was für ein glaublicher zugewinn! Kann ich nur empfehlen!
Lautsprecher: ELAC Navis arf
DAC: SMSL M400
Transport: ALLO Digione
Supra Cable
Florent L.
YARBO SP-1100 PW
Une autre planète pas la peine d'aller plus loin wow WOW c'est quoi ce câble YARBO IL Y A QUOI dans le câble rapport qualité une tuerie monté avec les Viborg je suis bouche B je recommande à 10000000%.
Un peu long à monter mais le résultat est là.
YARBO J'y suis j'y reste un point c'est TOUT je vais commander d'autres c'est sur WOW WOW!! merci encore Audiophonics
Martin S.
Fast delivery. Really good product for a very good price
Marcel M.
Remote Control for FX-Audio D802E / D2160 This FX-Audio remote control is the same as the one supplied with the FDA amplifiers D802E and D2160, so it will be perfectly suitable as a replacement for a defective model for...
Pas compatible avec le D2160 MK2
Attention, cette télécommande est celle de l'ancien FX-AUDIO D2160 MK1.
La Télécommande du FX-AUDIO D2160 MK2, actuellement commercialisé n'est pas la même. Les boutons sont différents et certaines fonctions ne sont pas accessibles avec la version du MK1.
Florent L.
YARBO SP 8000PW
Acheté sur les conseils d'audiophonics pour alimenter ma barrette en cours de rodage patience....très beau produit top qualité YARBO...j'ai été surpris par la souplesse vu le diamètre du câble. J'ai commandé aussi le SP 1100PW OCC en vue d'une comparaison monte sur des fiches VIBORG pour les deux câbles le plus effet.
Merci encore Audiophonics
Pas mal
produit bien fini comme le reste des produits viablue, et fait le boulot.
J'ai hésité avec les furutech, qui ont l'air supérieures mais pas le même prix.
Bon rendu sonore
C'est l'essentiel, je les préfère du coup aux neutrick nf2cb2 qui sont plus douce mais plus ternes, en association avec le stratos.
C'est naturel aéré, et pas fatigant.Les fiches sont plutôt réussies esthétiquement.
rendu naturel, sans agressivité, associé aux fiches viablue t6s.Celles-ci paraissent plus définies que les rca neutrick nf2cb2 montées sur le stratos aussi.
Krzysztof S.
I'm dissapointed. No volume control on volumio (version 2.x and 3.x). Huge problems with installing the power button. In Volumio 3.x, I was unable to get the button to work. Only the downgrade to 2.x helped. It gives 2 stars instead of 0 only because the sound quality generated by this DAC is very good.
Hi,
This DAC doesnt have an hardware built in volume control but you can always use the embedded to volumio software volume control.
This feature has been removed we are not responsible of that ...
Hermann B.
AMANERO COMBO384SE Digital interface USB 384kHz / SPDIF WM8804 to I2S / DSD Combo384SE version also incorporating a bidirectional S / PDIF WM8804 interface which can function as input or as output according to the needs of your project.
Excellent customer support
my request was resolved very quickly
Hermann B.
excellent customer support
customer service is fast and excellent
Poor clamp
I sent this back as the cable clamp did not grip a 12mm cable. Poorly designed.
Great connector
Build and finish is excellent. The cable clamping is very cable friendly, unlike Furutech and others that splay heavy gauge cables and I use 10AWG cables.
As plugs go, they impart great air and spaciousness to the sound.
Terrific cable
An excellent cable for the price. Have it paired with Furutech copper/rhodium plugs and sound is smooth, detailed and open.
Excellent cable
I paired this cable with Ramm silver/rhodium RCA plugs. Really gorgeous textured sound and not at all bright.
Tomas H.
Easy to work with
Nice quality-cable!
Straight forward and clean, straight sound - but IMHO not as musical as my Belden 8402 who plays a warmer sound with a bit more low´s and depth.
