Marc C.
Que dire ?
Bertrand j.
neutrik
Ramiro F.
Philippe A.
bon matos
très bonne alimentation, très silencieuse, dommage les leds blanches qui s'allument en permanence en utilisation. je ne regrette absolument pas mon achat.
Fonz V.
Great Power Supply. Great Service
Thanks Audiophonics for the great service and quick delivery of the Power Supply. It's a perfect combo with the Intel NUC and Roon Rock. The power amp does not get warm at all. Sound has more detail and a more relaxed bass. Only minor thing to me is that the red light at the front is 2 strong for my taste.
Jochen B.
A really good bang for the buck
I'm using these tweeters for about 2.5 years now in my active 2.5-way floorstanders. They take over at 3000hz with a brickwall from a Gradient W 130 AL8 and I have nothing to complain. I like the sound and they are very robust.
Clive S.
Great product. I installed it under my raspberry pi. Installation was quick and easy I have a few speaker spikes keeping it off the table. I have a audioquest dragonfly red connected to the pi and what can I say. The bass has increased and it's tighter more accurate. The sound stage has widened everything just sounds better. Ian Canada sure knows his stuff.
Luka C.
I order 2 of Mundorf Mlytic AG Cap
1 Cap Measurement:
Vloss=4.9%, Capacity=22.73mF, ESR=0.09 ohms
2 Cap Measurement:
Vloss=4.9%, Capacity=22.67mF, ESR=0.09 ohms
Quality 10/10
Product 10/10
VINCENT D.
NEUTRIK NADITBNC-MX Impedance Transformer XLR AES/EBU 110 Ohm Male / BNC 75 Ohm Female This digital adapter consists of a 75Ω female BNC connector and a 110Ω male XLR. It allows long cables to be installed via a low attenuation coaxial line, while...
Placé en entrée AES/SPDIF d'un DAC Dangerous Source et connecté à un lecteur CD mécanique Teac via un CANARE Câble numérique coaxial 75ohm BNC-RCA 0.5m. Ainsi l'impédance est respectée en entrée du DAC. Respect du signal ce qui améliore le rendu global.
Comme toujours, livraison ultra rapide de Audiophonics. Merci.
le ventilo souffle en permanence
... meme a très faible puissance et le bruit devient gênant. Comme amelioration j'ai intégré un bilame 45° collé a la pate thermique sous la carte + inséré depuis le bornier d'alimentation du ventilo. Ca fonctionne correctement. Je verrai a l'usage...
Edwin P.
Bon câble
Utilisé pour restaurer un Denon AH-D950 vieillissant, je m'en suis servi pour remplacer tous les câbles internes et externes.
Le son est vif, détaillé, capable à la fois d'un punch remarquable (surtout pour un casque de 20 ans) mais aussi montrer une belle subtilité dans la restitution. Bref, il respecte vraiment bien le morceau d'origine, sans rien étouffer ou trop mettre en avant.
J'avais testé le cuivre OCC sur d'autres produits avec des résultats assez spectaculaires, et ce câble ne déroge pas à la règle car fait un super job, dans le sens où il ne limite pas les performances du casque.
Je ne peux malheureusement pas dire à quel point il surpasse celui d'origine, car j'ai laissé ce petit projet traîner pendant des mois, sans me servir du casque.
Le dénudage et la soudure sont faciles, l'aspect général fait toutefois assez "plastique" (forcément il y a plus de gaine que de cuivre) mais une gaine supplémentaire pourrait corriger cela, au prix d'un peu de souplesse.
J'ai dû également défaire et renouer 4 brins sur une faible longueur, pour les passages et gouttières entre les deux écouteurs. J'aurais aimé l'avoir eu déjà assemblé d'autant plus qu'il existe des versions 4 et 6 brins, mais du scotch, un peigne et de la patience ont fait le job.
Je recommande pour un casque hifi !
Sergio G.
VIABLUE HS SPIKES SILVER Spikes Silver (Set x4) The Viablue HS Spikes help to limit vibrations from your speakers or devices to underlying surfaces. This results in a clear, precise and detailed sound reproduction. The spikes...
S
Great product! Happy with my purchase.
graham p.
Works well
I am using this to turn a Rel T9i on as Rel have a funny signal sense option which I very sensitive.
It fits fine (I checked before i ordered) however, the unit went in upside down (Text underneath). So do check carefully that it will fit. I was lucky
The only issue I had was the 12v cable. I had to buy one with a L shaped connector as when fitted upside down the input socket was blocked by the heat sink.
Sound wise, it's exactly the same to my ears so no concerns there. I checked the ampage load in the Rel manual and it's only 3.x amps. No where near the 8 amp max. I think some have confused themselves that it needs to be 13 amps as per the power cable? But I've been told that is to protect the cable only and isn't something to be concerned over.
Very happy with it so far.
Not exactly the copper one
I ordered a VF502S elsewhere moving from the 503S and the sound quality degraded. Swapping the contacts from the 503S into the 502 effectively gave me a super sounding 512S.
Audiophonics, please stock the 512S models. Sublime sound and cost
Bernard a.
après 2 ans 1/2
Installé en décembre 2019 entre
Qobuz 24 bits / 96kHz sur pc spdif et
une paire d'Elipson bs302 filtres refaits
en écoute de proximité.
Excellent, grave ferme, définition, scène sonore, etc.
Derrière, à 3m, il y a une paire de Magnepan MG 1,5 QR
sur un bloc stéréo AUDIOPHONICS MPA-S125NC
pour une écoute « auditorium ».
Je peux passer de l'un à l'autre, depuis mon siège l'écoute reste cohérente.
christian A.
exceptionnel rapport qualité (pour cable xlr analogique
petit retour d'experience.....excellent résultat en xlr j'utilise deux cables en parallele pour le 2 et le 3 pour la masse (1) un seul fil tout en jauge 24..le tout est tresse ensemble. mes essais en jauge 20 ne m'ont pas convaincu....peut etre essayer ce cablage tout en jauge 28......les aigus sont rafinés bel espace belle profondeur.....mes cables de marque americaine à 400e (boitier de polarisation prises xlr plaquées argent mais de ietre qualité) donnaient l impression d'etre meilleurs car le medium était légerement en avant, aucun regret bien au contraire (c'est une honte....) seul mon nouveau cable analysis plus oval silver apex (a 1200e quand meme fait mieux , mais à quel prix..faites l'essai vous ne prenez pas de risque....je suis équipé full accuphase j'a gagné en douceur en espace en profondeur si vous avez un systeme tres tranparent et precis c'est un excelent choix si votre syteme est un peu trop rond ou "gras" je ne pense pas qu'il soit adapté.......domae qu'il n'existe qu'en rouge......
Bof
Après 4 mois d essais avec plusieurs prises, dont les Furutech conseillée par audiophonique,ce câble à un rendu très dur.
Très loin de Furutech et oyade.
j
Je ne sais pas quoi en faire .
Philippe S.
excellent rapport qualité prix.
Je l'ai acheté avec le distributeur 6 prises audiophonics shuko en aluminium et j'ai obtenu un gain par rapport à un câble standard, l'investissement est resté très raisonnable, je recommande.
Philippe S.
solide et efficace...pour pas très cher!
J'ai acheté ce distributeur pour alimenter une télé oled 65 pouces plus le lecteur blu-ray, un ampli cinéma et le décodeur canal sat, j'ai eu un gain dans la définition de l'image et les couleurs sont plus "pétantes" Je recommande.
Harry P.
It works
Hooked up to Allo USBridge Signature...nice improvement, more open, clear and calm....recommended!
Produit très correct, montage aisé et pratique, facile à alimenter, bonne qualité de fabrication, temporisation correcte. Remplace des modules 11657 qui eux ne m'ont vraiment pas convenu.
Ahmed m.
Excellent cable, excellent dynamics, clarity with amazing transparency
Cedric d.
Ce sac m a permis de transformer enfin ma vielle cdp-x3000es en drive. Look, perfs, rapport qualité prix nickel.merci audiophonics.
Cedric d.
Petit dac performant et pas cher. Attention tout de même si comme moi vous voulez transformer votre platine en drive. Ma platine de 1998 n'avait pas un flux assez régulier et cela engendrer des micros coupures. Pas de souci en usb ou avec des appareils récents.
Frederic S.
TAD GZ34-STR REDBASE Rectifier Tube (Unit) The TAD GZ34-STR Redbase is a faithful reproduction of the legendary British Mullard/Valvo GZ34. It can replace any 5AR4 rectifier tube and has a slightly higher filament...
Utilisée sur un préamplificateur audio et ses trois 6SN7.
Une très bonne alternative à la 274B si le circuit le permet.
Cerise sur le getter, une consommation électrique baissée d'un tiers.
Gregory P.
Much better than a powerbank
I used to power my DACs with a 20,000 mA powerbank. Although I had a black background, I was not fully satisfied. My main complain was a lack of dynamism. After having read everything I could on Shanti, I gave it a try and... I really do not regret it. It is much much better. The sound is much more dynamic, everything has a better texture, trebles are smoother and I have more resolutions. Bass are more powerful too and dryer (read better). Imaging is better. It is as quiet (some say more due to the noise produced by the chemical reactions in the powerbank (maybe, I don't know)) as a powerbank. But, the sound is overall way better hence the pleasure to listen music.
Contiero M.
Eccellente cavetto!
Ho acquistato 1,5m per parte per i miei Pylon Audio Opal 20....che dire...hanno sostituito i Qed Signature Revelation! Appena collegati ho inserito un cd che conosco molto bene e sinceramente non serve davvero spendere più soldi. Questi cavi sono collegati ad un Lector zax 70 integrato da quasi 100 w per canale ma questi piccoli (di dimensioni) cavetti hanno riproposto una scena eccellente, dinamica davvero notevole come anche l'apertura in alto, molto belle le medie tutto ciò nonostante la piccola sezione di 0,75 mm/q ma a me basta visto che ho i diffusori a 1,5 m dall'integrato. Collegati senza terminazioni da ambo le parti, migliori di tutti i cavi avuti in precedenza, davvero non ho mai sentito una musicalità di questa levatura. Li consiglio fortemente a chiunque prima di spenderci soldoni importanti qualunque siano i diffusori e l'amplificazione, al limite valutate sezioni più grandi per misure e diffusori più importanti.
Alex P.
Improved version
It would be nice to be able to buy an improved version of this amp with better components so that I don't have to solder and throw away the replacement parts myself.
EXCELLENT!
Se rapproche pour beaucoup moins chère de son grand frère tunami V2 . Connecté pour alimenter un récepteur bluthoot . Libère une énergie qui apporte un punch considérable accompagné de transparence et d’homogénéité . On ne s'ennuie pas à l'écoute . Très bon rqp.
Matthias K.
Fantastic linear power supply
I can fully confirm everything that has been written about the power supply in other positive reviews.
The benefits of the power supply for a music computer with Roon Rock (in my case Prime Mini i7, DA converter from La Rosita) are unmistakable. I could not imagine such a good performance. The music plays in front of a darker background, more space, improved sound colours, clearly higher dynamics, more space between the instruments, more details over the entire frequency range, bass more contoured, voices stand more freely in the room. All in all, a top unit. Price and performance are right.
Many thanks to the Audiphonics team, service and purchase were first class. Contrary to the product description, a mains cable was also included. A nice extra service.
Stéphane M.
Excellent boitier
Montage très facile
Bien vu le perçage pour l'alimentation
Jean B.
HS après quelques heures
J'en ai commandé deux, pour me dépanner.
Livraison très rapide, merci Audiophonics (ça vaut une étoile)
Je branche, 18V en entrée, 5V en sortie à vide.
Je règle à 15V.
Je branche la charge (0,5 A)
L'ampli casque (mais l'alim n'est pas silencieuse, Hum 50Hz)
Après quelques heures de fonctionnement, ça ne chauffe pas (peu de puissance à dissiper).
Mais je remesure ma tension de sortie et elle ne varie plus...
LM1084 passant sans régulation.
Bref, j'aurais mieux fait d'en monter une sur un veroboard.
Jean
Jerome V.
Vraiment pratique mais vraiment chère.
Utilisez pour un câble symétrique entre un topping A90 discrète et un sennheiser HD 560 ovation II.
Le corps du connecteur se dévisse et c'est très pratique pour monter le câble à souder, même si celui-ci est un peu gros.
Et c'est surtout très pratique pour faire une soudure facile.
De plus, le contacteur à souder avec le câble est biseauté, ce qui, là aussi, facilite vraiment la soudure.
En outre, le connecteur est tout à fait adapté à la taille des contacts spécifiques de sennheiser et tient sans qu'il soit nécessaire de faire des retouches.
Par contre, il est vraiment, vraiment très cher (je ne dirais pas "trop", nul n'est obligé d'acheter).
Jean-Pierre V.
Usage en crossover avec Diraclive
Acheté pour remplacer un BSS FDS 366 qui commençait à donner des signes de "fatigue", il est uniquement utilisé en crossover dans un système en bi-amplification active avec liaisons XLR.
Initialement, je comptais ne pas activer la fonction DiracLive afin de garder le système le plus neutre et le plus simple possible, en conservant les mêmes réglages que sur le BSS (forme des filtres, fréquences de coupure, retard). Mais le résultat s'est avéré plutôt décevant, avec une sensible régression en terme de plaisir d'écoute : son plus plat, plus terne, moins précis...
En désespoir de cause, je me suis donc résolu à utiliser la fonction DiracLive ; le résultat est impressionnant et j'ai retrouvé tout ce qui me manquait (dynamisme, précision, etc.) avec, cerise sur le gâteau, la possibilité de corriger un vilaine résonance qui apparaissait parfois dans les basses fréquences (pas simple de faire passer un système qui descend bas d'une maison à un appartement...).
Abstraction faite de la mauvaise information que j'ai dû compenser avec un nouveau PC (un upgrade de Win7 vers Win10 ou 11 relèvant plutôt de l'utopie), je suis 100% satisfait de cet achat.
Côté ergonomie, le réglage des filtres est assez simple (même si je regrette un petit peu la rigueur technique de la programmation du BSS) et le processus de configuration initial de DIRACLive est plutôt bien cadré.
NB : un grand pied de micro est indispensable pour les prises de mesure autour du point d'écoute.
VASILEIOS K.
RAMM AUDIO ELITE 8 RCA Cables OCC Copper Cryo Gold Plated 0.5m (Pair) RAMM Audio Elite8 cables offer an exceptional design quality, using only high quality materials for a perfect transmission of the audio signal and a transparent, pure and...
Heavy sound.
The elite 8 by Ramm audio sounds extremely heavy. If you are looking for a neutral, natural sound, this is not for you. If your system sounds extremely thin and bright this cable might be a miracle. It will add body and weight in all frequencies. The plugs are tricky. I think that yo have to unlock them first.
Marylène C.
SABAJ A10H Headphone Amplifier Class AB 1W 32 Ohm Sabaj completes its A10 range with the A10h headphone amplifier, a high quality model based on an optimized architecture using carefully selected audio components. The amplifier...
Bien mais pas parfait.
Utilisé principalement pour sa fonction contrôleur de volume entre un Topping D10S et un bloc stéréo Hypex.
Le Sabaj ne masque rien et semble apporter plus de réalisme et de cohérence à la scène sonore. C'est vraiment bon et convainquant.
Il apporte vraiment un plus à l'écoute,
Quelques points négatifs:
La télécommande est assez directive.
Un changement de volume déclenche des cliquetis assez audibles dans le boitier.
Et surtout un léger buzz dans les tweeters ou les compressions qui doit être signalé, indépendant du réglage de volume et inexistant si je branche le D10S directement sur l'amplificateur.
Cela s'est en partie résolu par l'utilisation de câble Mogami RCA vers les entrées XLR du Hypex. (STI400)
Attention sur mon installation les câbles bas de gamme accentuent ce défaut. On l'entend à vide à plusieurs mètres avec des câbles premier prix.
Sinon l'appareil vaut largement son prix et mérite de ce fait ses 5 étoiles malgré ces petits défauts.
Quelques entrées supplémentaires auraient été un plus.
Vito B.
Great, great service
Ordered and received in 3 days! Perfectly working item. A real fine experience which will lead me to buy again from this site.
Thanx Audiophonics staff
Peut mieux faire
Cable reliant un dac R7 à un Master 1 le son est assez bon dans l'ensemble. J'ai juste un petit manque de matière dans les timbres, sur les voix ça s'entend bien. Il faudrait qu'audio Gd ou Audiophonics nous en fassent de meilleure qualité pour rattraper ce défaut. Ceci à 40€ on a déjà un très bon résultat.
Très bon ampli
Ampli acolé à un drive Nuprime CD pro 8 sur dac R7 et préampli Master 1, le tout en acss sur des Focal Aria. Bien penser aussi aux câbles secteur, du Furutech et du Yarbo dans mon cas. L'ampli a une bonne réserve de puissance, il est précis et dynamique même à faible volume, et reste maîtrisé à fort volume. Très bonne stéréo et transrence aussi, reste un petit manque de matière dans les timbres, câbles acss ?
Cable commandé pour relier aussi un Master 1 à l'ampli A1. Il fait son boulot, c'est défini, transparent et assez dynamique, mais petit manque de timbre je trouve. Bonne qualité de fabrication.
Astuce pour propriétaire de iec ou schuko viborg serie bati en alu
Pour garder le batis alu de mes viborg cu rhodium. Par apport a celui ded oayde moins de place et moins protegé des iem. Garder l iec oyade et fixer la sur le bâti viborg. Cela permet une meilleur integration des gros câbles secteur de la meme marque. Le resultat et sympa. Solide et pratique. Garde toutes les qualités de la fiche.. ????
Bien comme protection aux iem.
Employé pour tapisser les dessous de support d electronique. En deux couche en longueur puis en largeur. Servis aussi sur montage DY cable modulation xlr et rca sur ded cables maison sans blindage. Moins lourd que ded gaine cu etamée. Bon resultat.
Sérénité du rendu sonore
Le titre en dit long.
Ce CS est nuancé, clair, avec effectivement des silences impressionnants.
Couplé aussi avec les prises nfc Furutech, la musique est particulièrement apaisée.
Côté technique, le grave est simplement magnifique.
C’est cher, certes, mais je n’ai absolument aucun regrets.
Piotr K.
Summer replacement for Accuphase Power Amplifier
These amplifiers (pair of monoblocs) have been acquired as a summer replacement for my Accuphase amplifiers which are warming my music room to extreme temperatures. Please be mindful that the review is written within first 24 hours of obtaining them and here you will find my initial thoughts which are nothing but subjective. The main concern for me will these amps have enough power to drive my B&W 802D3 speakers. The answer is YES, very much so. Both the deep bass and clear sweet midrange are exactly where they were and where I like them, Off course the treble is as expected, which is very precise. It is not too bright, it is nice. I dare say I am able to hear the decay of the cymbals or notes from piano with better detail than before. I am planning to test these amps for the next week or so and perform a detailed comparison to the Accuphase AMPs. So far so good. I am still worried that the Max power output is 227W which, as tested by ASR, give out continuous (RMS?) power of 131W. So far so good. Class D amps had a bad reputation in the past. I think that the Purify and Hypex crowd are changing the game and giving us music lovers (NOT Audiophiles - although the meaning is same) a whole new perspective on how music can be reproduces with high quality at an affordable price.
Jan Willem v.
Medicre quality
Mediocre quality product, bought two, one does`nt work, it makes no contact to mass. There must be better quality.
Marco K.
TOPPING DX7 PRO Balanced DAC Headphone Amplifier ES9038Pro Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD1024 Silver The DX7 Pro Topping is a model of versatility and performance. This DAC embeds a particularly complete connectivity / connectivity, scanning the vast majority of possible...
Very good value
Very good DAC/Headphone amp with an excellent value for money.
Pourquoi payer plus un convertisseur USB vers RCA ?
J'avais besoin de rajouter une entrée sur mon ampli intégré pour écouter internet (youtube and Co) depuis mon PC.
Pas besoin d'un truc audiophile (j'ai un HifiRose 250 pour ça).
Je voulais simple, efficace et direct : PC+ D10s sur une entrée de mon intégré. Système autonome. Parfait.
Je me suis amusé à comparer un concert youtube entre mon entrée line-1 (PC+D10s) et line-2 (Rose).
Oui le Rose est meilleur mais pas 20 fois mieux (prix du rose = 20 fois celui du D10s).
Humour :
Ce Topping D10s n'est pas assez cher pour être pris au sérieux !
Bon sang... Quel son !
En plusieurs décennies j'ai eu l'occasion de posséder au moins entre 10 et 15 DACS commerciaux + montages de diverses cartes convertisseur D/A. Philips; AKM, etc.
J'ai pourtant été totalement séduit ici par un rendu sonore inhabituel et magnifique, parfaitement équilibré proche des meilleures lectures "analogiques" tout en conservant les qualités du numérique telles : dynamique, silence; etc.
Jamais je n'avais profité auparavant d'une telle d'articulation avec autant de sons à la fois élégants "filés" et fruités à souhait à partir des Dacs conventionnels.
Cet Audio GD R2R R1 proposé à un prix encore raisonnable pour un DAC haut de gamme, procure une musicalité proche de systèmes de lecture vinyle de très haut niveau beaucoup plus coûteux.
De surcroit, ce DAC est exceptionnellement bien conçu et construit sans aucun compromis.
Au-delà de sa conversion par résistances (R2R), de nombreuses alimentations indépendantes en font un véritable "double mono " avec étages de sortie symétriques à composants "discrets", (transistors FET et non AOP).
Ces sorties fonctionnent en pure Classe A et sans contre-réaction, ce qui est quasi introuvable ailleurs.
En bref ce DAC m'a épaté et je ne peux que le recommander ! !
( Je précise que je n'ai pas d'actions chez Audio-GD....)
Musicalité. Equilibre detaillé
Monté avec cosse cuivre occ et fixé au trou des borniers. Simple et trés efficasse. Prendre son temps pour enlever la gaine et pas oublier la gaine fine transparente sur le fil. Quatre fils plat total 2mm2. Les enfilé apres traitement au desoxi gold et sertir a la pince. Attention pas de blindage. Evité de passer ses câbles pres de source electrique. Les iem sais pas bon vous pouvez si probleme acheter ici ine gaine cu etamé. Tres efficasse qui n influe pas les perf. Recommander
Exelent en straps sur bornier d enceinte
J ai confectionné quatre fils avec gaine coton et nylon pour la finition sur des viborg banane cu pl argent qui remplace mes straps de 4mm2 up occ multibrin. Resultat exelent. Grave plus dynamique et puissant plus riche en details. Monté croisé plus med aigus et moins grave. Allié au jmr 1120 cu arg. 2mm2. Equilibre tonal parfait. Plié en une courbe grande. Long des fils 20 cm.
IFI AUDIO iPOWER ELITE AC Adapter Active Noise Cancelling 5V 5A The iPower Elite iFi Audio AC Adapter hides state-of-the-art technology under its sturdy extruded aluminum chassis to provide your audio device with a clean and stable power...
Exceptionnel RQPerformance
Deja utilisateur de la version 12v sur le ifi zen stream. Les resultat sur le BonnN8 sont du meme niveaux. Ali a decoupage de haute techno et qualité, elle vaut des ali lineaire hifi de deux fois le prix avec un silence incroyable. La musique vivante naturel et precise.. Je recommande fortement. Le cable ali 5v est esclave mais d exelente qualité. Pour les plus exigeant vous pouvez y monter une prise elecaudio cuivre telure pl or 5,5/2.1 pizr remplacer celle d origine..
Rodolphe G.
Bien mais…
Résultats incroyables sur Aiyima A007 mais produits reçu abîmé sur un coin !
De plus l’alimentation était juste entourée de film alimentaire ! Même pas de carton de marque, juste calé dans un carton d’expédition…
Comme le colis était intact je suppose que l’article a été abîmé (chute avant expédition) avant l’envoi. Pas sérieux !
Du coup j’hésite à commander les 2 alims supplémentaires dont j’ai besoins chez Audiophinics… dommage.
Nous sommes navré que vous ayez reçu l'alimentation abimée.
Vous pouvez sans problème contacter notre SAV via votre espace client afin d'obtenir une unité intacte.
Teppo H.
So far so good!
I bought this to use with a 10" passive DIY sub as part of my "desktop" setup. And it seems to get the job done admirably in spite of its low price and diminutive size. I can't really say anything about its max power though, since this is very nearfield listening at low to moderate volumes. Even the power supply I use is only 12V 5A, since I had an extra laying around. More than enough for this use case in any case.
One minor minus is that turning the volume pot functions as the on/off for the device, which is a hassle when you want to keep it at a preset level but would still like to turn it off. Also it has quite a bit of "play" before it actually turns the thing on/off, and doesn't really feel that great to turn.
One other thing to note is that this indeed takes a 3.5mm stereo plug and combines the channels for output. The 60W subwoofer amp stated that, while this one didn't.
All in all a handy device well worth its price for smaller-scale applications.
