Claude T.
Bonne config
L'ensemble
- Monitor Pro contrôleur.
Apporte un plus...
Claude T.
Bonne config
L'ensemble
Apporte un plus...
Customers reviews - There are 19335 reviews.
florent n.
SHANLING CA80 Amplifier Class D ICEPower 100AS2 CD Player DAC ES9219MQ Bluetooth 5.0 100W 4 Ohm Black The Shanling CA80 is a particularly versatile integrated amplifier, CD player and DAC. It performs these tasks brilliantly, thanks to its meticulous architecture and...
So much unfulfilled potential
It's an attractive device and is very well built. kudos to the design team
Sound wise, it's really good. I bought it to supplement my class A Accuphase that draws a lot of juice and which I don't always feel like using for casual listening. Honestly, the Icepower module plays on par with the big japanese amp. The RCA output on an amp is a rare but very useful feature as it allows me to listen to the Accuphase while using the CA80 as a preamp. I can think of Audiolab amps having it and a few others but it's pretty rare. The headphone amp works well.
What disappointed me before the purchase was the absence of at least another analog input or digital input. It would have been great, but that's a compromise I made willingly as it had BT as a fallback solution for my bluray player. Except, that eventhough the bluetooth works flawlessly with a phone if connected to a transmitting dongle, the CA80 BT implementation is buggy. It requires the user to resort to some idiotic procedure to get the sound...and if you switch to another input and back, you will have to do this all over again
For the other negatives, there is - the barebone CD implementation: No resume functionality. you will have to restart the cd from the start each time you switch inputs...
- the god awful remote which has less than 3 meters of range
- the slow response from the the remote and other universal remotes. It's unacceptable and makes using the device beyond a desk use, frustrating. The buttons on the other hand are perfectly responsive. Maybe it can be improved through a firmware update?
- the cd spinning is kind of noisy. Not a problem but I expected better
I will keep it as I can live with the drawbacks but what a shame of what could have been. It'd be a killer device with a couple extra inputs, cd resume functionality and a better remote control and BT implementations
Marc R.
Son parfait. Reste frais.
Très satisfait de la qualité sonore. La source est un Fosi ZD3, connecté en XLR équilibré.
Alimente deux enceintes colonne Jamo. La réponse en fréquence est linéaire. Son bien détaillé.
Un grand avantage de la classe D est que l’appareil génère très peu de chaleur. Je l’ai placé dans un meuble fermé, avec un ventilateur à l’arrière. Il reste très frais.
Un petit inconvénient : le boîtier n’était pas stable, deux pieds ne touchaient pas le sol. Cela était dû aux deux vis avant qui fixaient le panneau supérieur. Les trous dans le panneau n’étaient pas exactement alignés avec le filetage du châssis. Après avoir légèrement desserré les vis, le boîtier était stable. Je pense toutefois qu’il devrait l’être même avec les vis bien serrées.
Sebastian J.
Some serious problems
I bought this device because I found the connection as a CD transport via USB very appealing. Unfortunately, there are three serious problems, which is why I had to send the device back after a few days. Firstly, it takes too long to read the CDs. Much too long. Once the CD is playing, the player makes very loud humming noises, like a poor quality computer CD drive. The last point to mention is some inconsistencies in operation, such as the non-intuitive button assignment on the front of the device and the display, which is far too small. Overall, it's a shame that this device didn't live up to expectations. The quality appearance of the casing was otherwise very good.
Gregory O.
NEOTECH SOST-30 Wiring Cable UP-OCC Solid Pure Silver PTFE 30AWG 0.0509mm² Neotech, leader in high-tech HiFi cable, continues its research in the field of sound reproduction and today produces the ultimate in cabling wires. The SOST Solid Core Silver...
Ethernet RJ45 Cable
Made Ethernet RJ45 Cable out of this to see what would happen. No shielding . Use it to stream Disney 4K and X Box games. had other pure silver cable from A-Phonics on it but this looks better to me. Once broken in this has a wow factor on the right material I have recently found out that NEOTECH SOST-28 Wiring Cable UP-OCC Solid Pure Silver PTFE 28AWG 0.081mm² will fit as well. Thanks A_F for your great company.
MINIDSP ADEPT ADC ES9842 Phono Preamplifier with DSP 32bit 192kHz miniDSP ADept is an ADC with phono preamplifier and DSP. It is based on an XMOS interface and an ESS ES9842 Pro conversion chip. This enables it to convert analog signals up to...
Bien pensé
produit bien pensé, dans la tradition minidsp. Idéal pour alimenter un filtre nanodigi ou autre de la marque.Préamp MC et MM paramètrables à souhait, convertisseur AD performant . alimentation séparée, déjà upgradée avec une LHY 12v faible bruit. Avec une écoute musicale, vivante et naturelle qui met en valeur une petite ortofon quintet blue installée sur une Transrotor zet 1, à merveille !
Jan S.
GUSTARD C2 Digital Coaxial Cable 50Ω BNC 1m The Gustard C2 digital cable with BNC connectors can be used as both a clock cable or coaxial cable, whether with a clock generator, interface or DAC.
Good quality
I bought this one because I have two if them already. Good built quality. I've not compared it with something else. Works flawless.
Jan S.
Small effective amp.
With TPA3255 chip it's a really compact and perfect match to my needs. With tone control i can adjust the sound to fit my situation. Bought 12pcs to a exhibition.
Thierry H.
Découpe IEC
suite à des achats précédents et à des visuels sur le site j'étais persuadé que les boitiers 1U avaient tous une découpe IEC pour l'alimentation j'ai été étonné de voir que ce n'était pas le cas .
sinon les boitiers hifi 2000 galaxy ou slimline sont parfaits ( celui çi est le douzième que j'utilise.....)
Jerome A.
7HZ X CRINACLE ZERO II In-Ear Monitors Dynamic IEM Ø10mm USB-C with Mic Silver The 7HZ x Crinacle ZERO II in-ear monitors are dynamic IEMs that are affordable but no less powerful. An evolution of the 7Hz Salnotes Zero, they feature a number of...
IEM au rapport qualité prix incroyable
Avec un dac/ampli fosi DS2, ce casque est incroyablement bon, tout est là, sans exagération, précis, en mobilité, c'est excellent.
Il place la barre très haut pour un prix très bas !
Bon câble ...
Bon câble, mais un peu fin du niveau du diamètre ext, pour une bonne fixation dans la plupart des connecteurs
Rien à redire, c'est tout bon !
Emmanuel A.
Pas mal
J’ai utilisé ce câble en liaison modulation sur un dac rega et un amplificateur à lampe
Je ne suis pas très satisfait du rendu global
Il manque beaucoup de détails et la scène sonore ne s’ouvre pas comme avec l’autre modèle de la marque
Le l2-t2s qui lui est bien meilleur sur toute les fréquences
Bernard L.
Très utile
C’est tout à fait l’adaptateur dont j’avais besoin.
Pedro V.
DE CONTI TRIO N60 Speaker Stands Black (Pair) De Conti's Trio N60 speaker stands have been designed to position your bookshelf speakers optimally. With a height of 60cm, they bring the speakers to ear level, in a seated...
Very good stands
Despite the affordable price these stands are sturdy built and elegant. I took one star because the supplied plastic bags for mass loading have some holes in them, rendering them more or less useless.
André C.
ATAUDIO Q8RM Male RCA Connectors Ø7.5mm (Pair) This ATAUDIO Q8RM male RCA connector features 24k gold-plated pure copper contacts. Their metal and carbon-fiber body provides insulation against interference, while the...
Satisfaction
Depuis longtemps je rechercchais des connecteurs RCA de bonne facture qui de par leur diamètre (12mm) pouvaient faire le job sur un Revox B77 , sur lequel les prises RCA sont très resserées .
Ces connecteurs montés avec du Sommercable Olbédo sont parfaits.
BRUNO B.
NEOTECH NEUB-3020 Cable USB-A Male/USB-B Male 2.0 Gold plated 24k OCC 1m The Neotech NEUB-3020 USB AUDIO class 2.0 cable offers superb digital playback quality using innovative technologies that challenge the hierarchy of high-end USB cables.
J'avais déjà un câble USB de qualité.
Lisant les avis, j'ai tenté le coup.
Je suis impressionné par le résultat.
A la fois plus de douceur et de présence.
Des basses enfin à la hauteur, très nettes et propres.
Mon matériel : ampli SMSL A8 et enceintes Infinity Renaissance 90.
Petit boîtier parfait ?
Ça y ressemble !!
Connecté au Mac Mini en USB il a été immédiatement reconnu par Audirvana, décode tous les formats (Mqa compris) et il est relié à mon Dac en Spdif.
Il est très plat ce qui m’a permis de le glisser sous mon Dac.
Envoi rapide et sécurisé.
Jerome A.
AUNE S17 PRO EVO Discrete Class A Balanced Headphone Amplifier Preamplifier 7500mW 32Ω Black With its S17 Pro EVO, Aune unveils a powerful Class A headphone amplifier that can also be used as a preamplifier in a Hi-Fi installation. This headphone amplifier features...
Une main de fer dans un gant de velours !
Cet amplificateur est puissant, il devrait alimenter sans problème la majorité des casques, même ceux gourmands.
Pur classe A, comme mon Singxer Sa1, il est plus chaud, dans tous les sens du terme... la chaleur dégagée par cette ampli m'inquiète sur son espérance de vie, et son utilisation en été ?
Mon Singxer SA1 est un peu moins bon, mais pas ridicule, et surtout il ne chauffe pas autant.
La fonction permettant de modifier le courant "50mA ou 100mA" n'est pas toujours facile à entendre, selon le casque, et d'après mon expérience, il faut attendre quelques secondes pour l'entendre... ce qui ne facilite pas les tests. Je laisse à 100Ma pendant l'écoute, et bascule à 50Ma lorsque je pose le casque pour quelques minutes/heures, ainsi il redescend en température (Max 55 degrés après 3H avec 21 degrés dans la pièce).
Belle finition, mais bouton de volume peu précis, et toucher/feeling bas de gamme, c'est vraiment dommage.
J'utilise la télécommande pour régler le volume, plus précis, et plus agréable que ce bouton, point faible de cet ampli.
Si vous avez le budget, très bon ampli, sinon pour 50% du prix, le singxer SA1 est très sympa aussi, et il chauffe beaucoup moins.
A l'heure ou j'écris ce commentaire, un kit vendu sur ce site permet de bénéficier du casque Audio Aune AR5000 pour un prix très sympa, je ne l'avais pas vu avant...
David R.
MOONDROP LAN In-Ear Monitors IEM Dynamic 10mm 120dB 32 Ohm 15Hz-37KHz Moondrop unveils dynamic in-ear headphones with the LAN, featuring a compact stainless steel shell and a changeable cable. These IEM headphones, although very affordable in...
Complémentaire au Chu 2.
Les + :
- Construction semble robuste.
- Confort, légèreté.
- Timbre, neutralité.
- Définition et scène supérieures à la moyenne.
Les - :
Pas pour amateur de basse charnue.
Bonne séparation mais devient confuse en présence de trop d'informations et lorsque le volume augmente.
Conclusion :
Clarté et scène holographique sont au rendez-vous.
Les Moondrop Lan sont axés sur une écoute critique, neutre et sans coloration.
Plus technique et défini que le Chu 2 .
Roland L.
Tweeter DC28F8
Excellent tweeter, très détaillé, pas trop directif, vraiment un très bon rapport qualité prix
Sergey O.
OPA2210 Dual OPA DIP8 (Unit) This OPA2210 is a dual OPA mounted on DIP8. It is built on Texas Instrument's Super Beta precision complementary bipolar semiconductor...
normal operational amplifier
The soldering was done very sloppily. The role of operational amplifiers is greatly exaggerated. The sound does not change as globally as many buyers and bloggers describe. Yes, the bass is stronger, the highs are clearer and cleaner. But don't expect anything supernatural from the sound.
Bon rapport qualité prix, belle fabrication
Génial, ouf, ni interrupteur ni fusible, ni voyant, rien pour dégrader, parfait. Les contacts sont francs. Il ne manque à cette barrette que des pattes de fixation, ou quatre trous filetés M4 ou M5 voire M6, pour fixer cette excellente barrette. je l'ai donc collée (gel colle souple) sur un support lourd.
Jean-Marc B.
excellent DAC
Très bonne finition, excellente sonorité, très musical, je le préfère au Topping DX3 pro que je possède également. Puissance de l'amplificateur casque un peu limite pour certains modèles.
Dommage qu'il n'y ai pas d'interrupteur marche arrêt à l'arrière. Sinon que du bonheur.
Sebastien D.
DD TC05 M2 USB-C Cable OFC Copper Silver Plated OTG 10cm The DD TC05 M2 is a USB-C OTG cable with an OFC copper core shielded by silver plating to guarantee signal quality. It can be used to transmit information or simply to charge a...
Bon cable USB-C pour remplacer celui d'origine de mon Fosi audio DS2, il a belle allure et semble solide,
aspect luxueux,pour le prix :)
Stasys I.
Almost nice case
Steel is very soft, easy to work on, but one of corners came bent. Thats ok, put that corner on bottom. Worst part is anodizing is not uniformon front panel, it has something like darker/brigter stripes, and there is no fix for that.
A H.
FURUTECH FP-TCS21 OFC (Alpha) Power Cable Ø12.8mm A very high performance 3-conductor mains cable dedicated to uncompromised audio applications, the FP-TCS21 is a high-quality, high-quality, high-end technology. This mains...
Nice cable for amplifiers / Joli câble pour amplificateurs
I use this one for amps and the 022 is better for digital equipment.
With this cable and the corresponding plugs (rhodium for a typical high end feel or gold for more emotion) one can easily make a very good cable for very little money.
/ utilisez celui-ci pour les amplis et le 022 est meilleur pour les équipements numériques.
Avec ce câble et les fiches correspondantes (rhodium pour une sensation typiquement “ high end” ou or pour plus d'émotion) on peut facilement fabriquer un très bon câble pour très peu d'argent.
A H.
Aluminium wall plate Schuko Double socket for FURUTECH FI-E30 Silver We designed this all-aluminium wall plate to cover the Furutech plugs FI-E-30 (G) and FI-E-30 (R) and thus transform it into a complete wall socket.
Very high quality / très bonne qualité
Beautifully made. It is slightly larger (155 mm) which is mote than I could wish for, it has a perfect fit on the PEHA Standard surface-mounted frame, like the two were made for each other.
/ Magnifiquement fait. Il est légèrement plus grand (155 mm), ce qui est bien plus que ce que je pourrais souhaiter, il s'adapte parfaitement au cadre en saillie PEHA Standard, comme si les deux étaient faits l'un pour l'autre.
POUR RECÂBLAGE D'ENCEINTES....
Après avoir laissé un avis sur la possibilité d'utiliser ce câble en modulation, je viens d'effectuer le recâblage interne d'enceintes Davis Mani mkII avec du Jantzen 6N (section: 0.5 mm2). Ces enceintes sont équipées d'un tweeter à chambre de compression et je doutais qu'un recâblage améliorerait encore ce très bon produit, or le résultat est sans appel, la définition est meilleure dans tous les registres, l'aigu est très détaillé et doux à la fois, les timbres sont superbes, et je tiens à me démarquer de certains commentaires citant un "dégraissage du grave", or il n'en est rien, devrait on plutôt dire que le Jantzen 6N fait perdre au grave son côté parfois pneumatique (qui n'est rien d'autre qu'un traînage), pour lui conférer une netteté et ceci sans rien perdre à la profondeur ni au poids des impacts. Attention toutefois à bien respecter un temps de rodage d'une quarantaine d'heures (la différence avec le câble neuf est flagrante). Bref, n'hésitez pas à réaliser le recâblage interne de vos enceintes, vous risquez bien de les transformer ... pour le meilleur.
Fabrice B.
JJ ELECTRONICS ECC803S / 12AX7 9-Pin Dual Triode Preamp Tube (Unit) The ECC803S /12AX7 tube from JJ ELectronics is a double triode preamplifier tube with a noval base (9 pins). This long-plate Hi-Fi quality tube is...
Tubes installés sur un ampli Fezz Audio Titania en remplacement de GENALEX GOLD LION. Tout le spectre sonore passe très bien, très bon équilibre et j'ai surtout retrouvé le grave qui avait disparu avec les GOLD LION, c'est le jour et la nuit. Le tout pour un prix très compétitif.
Pascal M.
Très bon petit ampli , écoute améliorée après changement d'aop par un muse 8920 , aucun souffle à vide avec l'alimentation fournie , pas de chauffe , excellent rapport qualité-prix.
Pascal M.
TANG BAND W4-2142 Speaker Driver Full Range 25W 8Ω 88dB Ø12.5cm Tang Bang's W4-2142 full-range driver offers extensive sound reproduction thanks to its 12.55cm-diameter diaphragm. It has a power handling capacity of 25W, a paper diaphragm...
tang band w4
Excellent large bande de 10cm , montées dans des enceintes de type "métronome" l'écoute est très dynamique et le grave bien restitué (mieux que le fostex 108 sigma) excellente qualité de fabrication ,une petite merveille .
Jean Pierre G.
HIFIBERRY DAC+ DSP DAC Board with DSP for Raspberry Pi Burr Brown 24bit 192kHz The HiFiBerry DAC+ DSP combines both a digital to analog converter based on a Burr Brown DAC chip - with a digital input and output, as well as an analog output - and a powerful...
J'ai acheté cette carte DAC + DSP pour essais
J'ai acheté cette carte, car elle figurait dans la liste Volumio des DAC compatible; mais aussi pour tester une puce Burr-Brown ( je suis plutot AKM ); enfin pour ses fonctionnalités : Sortie analogiques RCA, Sortie numérique sur SPDIF optique, entrée numérique optique. Plus DSP; mais cette fonction ne m'intéresse pas.
Voici mon ressentis
Sortie analogique : bof ....un peut brut de décoffrage
Sortie numérique Optique : WAOUH.....relié à un Topping D90. Et ça passe le 24 bits
Cette carte va donc remplacer définitivement mon HIFIBERRY Digi
Les autres fonctionnalités ne m'intéressent pas.
Bien sur cet avis n'engage que moi; mais je tenais à faire part de cette trouvaille.
Bien audiophilement
Giorgio B.
Excellent pour l'Audiophonics HA-B6120
Mes v7 vivid sont venus remplacer des AOP double J-FET OPA2604 dans mon ampli casque HA-B6120 de chez audiophonics.
Sa fais 2 mois que je les ai. Bon, sa a transformé mon ampli.
Les basses sont plus percutante, les mediums et aigus sont moins criards, tout est plus détailler et surtout, les v7 vivid vous offres une plus grande scène sonore beaucoup plus réaliste, et BEAUCOUP plus de dynamique - Les explosions de db sont impressionantes.
Je suis trés satisfait de cet achat et je vous les conseils aussi si vous avez des AOP d'entré ou moyen de gamme.
Peter B.
One of the ordered two was defected. Otherwise I tested the working one. I'm not impressed, I expected more based on the specs and reviews. For example the opa1656 is a much better choice.
Pascal O.
Très bon récepteur
Je possède ce récepteur depuis 5 ans. Donc a priori fiable. A été branché en optique sur un DAC pour écouter des fichiers flac stockés sur mon mobile. Très bonne restitution. Actuellement raccordé via les RCA analogiques sur un Cyrus 8 vs2. Différence inaudible par rapport au lecteur cd Cyrus 8. Sa batterie intégré permet de le brancher rapidement sur n'importe quel ampli pour faire des tests ou écouter sa musique sur d'autres installations.
Michel S.
SHANLING SM1.3 Streamer DAC AK4499EX Headphone Amplifier WiFi LAN Bluetooth 32bit 768kHz DSD512 Black With the SM1.3, Shanling presents a streamer and DAC that aims to become the core of any good HiFi system. Its AKM AK4499EX and AK4141 chip combo enables it to handle signals up...
Décevant
Soyons clair, le Shanling SM1.3 est inattaquable en terme de musicalité. Cependant quelques minutes d'utilisation mettent rapidement à jour des bugs et défauts divers.
Connexion au WIFI capricieuse, couplage avec l'application Eddict Controller aléatoire, serveurs de mise à jour en ligne indisponibles, intégration des services de streaming quasi inexistante, interface appareil manquant de clarté, télécommande au fonctionnalités limitées, etc...
L'application de contrôle n'est pas en reste et souffre elle aussi de problèmes : Pochette affichée sans rapport avec l'album joué, deux albums au titre identique se retrouvent intégrés dans la même liste de lecture, l'appli autorise le téléchargement des MAJ mais l'installation n'aboutit pas, certains réglages programmés via l'appli ne sont pas pris en compte par l'appareil, etc...
Enfin mon exemplaire ronronne comme un ampli à lampes malgré plusieurs solutions mises en place.
En conclusion je dirai qu'en l'état cet appareil ne risque pas de bousculer la hiérarchie des streamers autour de 1 000 euros. Eversolo peut dormir tranquille...
Gérard B.
LETSHUOER S08 In-Ear Monitors IEM Planar Magnetic 26Ω 105dB 20Hz-40kHz Silver The Letshuoer S08 in-ear monitors are planar magnetic IEMs. They feature a high-quality design with a custom 13mm-diameter planar magnetic diaphragm and dual voice coils. The...
Excellents écouteurs
Je suis très content d'avoir acquis ces écouteurs. Le son est très détaillé et reste bien équilibré, la scène sonore, la séparation des instruments sont d'un excellent niveau. Je pense qu'on peut mettre des sommes beaucoup plus importantes dans des intras sans dépasser la qualité de ceux-ci . L'écoute est des plus reposantes,même sur de longues périodes d'écoute. De plus la taille réduite des coquilles permet de les porter sans aucune gène.
J'écoute essentiellement de la musique acoustique, Jazz ou classique et les Lesthuoer S08 sont formidables pour ces genres.
Ce qui ne gâte rien ce sont les accessoires et notamment le câble d'origine, de très bonne facture qui est livré avec deux prises jack interchangeables, pour écouter en asymétrique avec la prise 3,5mm ou en symétrique avec la prise 4,4mm.
Brice C.
JANTZEN AUDIO CROSS-CAP 001-0263 Capacitor 400V 9.1µF Jantzen Audio Cross Cap capacitors offer a high level of performance and quality at a very reasonable price. This is a versatile model, using metallized polypropylene foil.
Parfait et abordable
Utilisés pour refaire les filtres de mes B&W, pour le prix j'en suis ravis!
Attention cepedant aux dimensions considérablement plus grandes que de vieux electrochimiques.
Brice C.
JANTZEN AUDIO CROSS-CAP 001-0256 Capacitor 400V 6.2µF Jantzen Audio Cross Cap capacitors offer a high level of performance and quality at a very reasonable price. This is a versatile model, using metallized polypropylene foil.
Brice C.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 8.2µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
Brice C.
Lois g.
match
Bonjour, je voulais modifier la signature sonore de mon ampli primaluna evo 400 déjà très bon avec les tubes d'origine . J'ai donc mis en duel ces psvane s avec les genalex gold lion et le résultat a mon gout et mes oreilles est sans appelle. tout d'abord ma configuration , pièce dédié et traité de 20 m2 , enceinte haut rendement 98db + caisson de basse rel spécial carbone. J'ai bien sur pris le temps de roder ces deux paires de tube, 200 heures par paires avant de vous décrire mon avis. j'ai commencé par les psvane s et d'entré de jeux un voile ce lève et j'ai était surpris par l'image 3d holographique de ces tubes. après rodage tout c'est mis en place et sa fourmille de détailles . Ces tubes sont envoutant et le kick sur le bas médium est inédit . Certes ont a l'impression que le sont et montant mais pas du tout , il est ouvert ,précis détaillé et holographique. Quand je suis passé au genalex gold lion j'ai ressenti une perte énorme et j'ai mis sa sur le compte que les tubes étaient neuf. Après rodage, le son est bon mais plus intimiste , moins ouvert un peu plus sombre moins détaillé et je n'ai plus ce kick que j'avais avec les psvane s. Donc vous l'aurez compris , je remonte sans hésitation ces fabuleux psvane s et je pense que je vais essayer les EL34 de cette marque .
David H.
LUDIC MAGICA Speaker Cables Banana OCC Copper Gold Plated Cryogenic Treatment 2x3.5mm² 2.5m (Pair) Lucid's Magica speaker cables offer top-quality design for optimum conductivity. In fact, they feature an OCC copper body combined with triple gold shielding to ensure flawless...
Superbe qualité
Cable incroyable j ai changer meme mon modulation ( orpheuse ) difficile à trouver en France et sur mon système audiomat aria et maestro 3
Cabasse Pacific scs et tantôt autographe mini j était Cable tout eterna et la surprise vraiment parfait mon système et libéré de tous ces bouchon a un prix fou comparé à Ludic qui fait des Cable qualitatif et expressif je vous satisfait à tous points de vue de mon système hifi que je ne suis pas près de remplacer
Un grand merci à Ludic !!!
Szabolcs D.
great!
Very flat, clean and powerful amp. Ideal companion for passive studio monitors. My ATCs came to life with this amplifier. The overall soundstage became more forward, widescreen, direct, firm and uncoloured compared to my previous A/B amp. I was affraid my snobbish and picky speakers would hate it, but the exact opposite happened.
Eric z.
exellent petit FDA
comme toujours commandé un matin avant 10h reçus le lendemain !! utilisation pour l'audio de mon PC en combinaison avec un dac SMSL SU-1 pour alimenter des petites enceintes avec un rendement proche des 85 db le DO3 se comporte très bien niveau alimentation et musicalement très neutre, comparé à mon Fosi audio V3 qui est plus puissant et plus pêchu je trouve le DO3 plus adapté à mon utilisation d'écoute de proximité
ses 2 modèles sont vraiment étonnants !
FRANK D.
Coup de genie?
Mine de rien ce petit produit devrait trouver sa place dans les tiroirs des melomanes/audiophiles.
Toujours utile a avoir chez soi.
naturel et finesse
Bonsoir, voici mon 2 eme vondita ,un sur l ampli et la sur mon alimentation allo shanti pour mon phono. Ce cable a une tres grande resolution, medium fin et tres fluide ,un beau timbre corsé , une tres bonne dynamique , j ai eu une vingtaine de cables secteurs c est certainement le plus naturel! Franck
Ioannis P.
XANGSANE XS-5N Banana Speaker Cables OCC Copper Silver Plated 3m (Pair) Xangsane's XS-5N speaker cables are made up of 12 strands of silver-plated 5N single-crystal OCC copper to ensure electromagnetic impermeability and perfect conductivity. Each...
This is a very high quality product, I think it will satisfy most casual users, and for me it is about the maximum I'm willing to spend on cables. However the quality exceeded my expectations. About the sound, It is very hard to comment, I'm no specialist, I just tried to match the quality of the cables to the quality of my speakers and I think they serve the purpose. The shipping, packaging, and overall professionalism of this store is exemplary.
Michael S.
Does not work with Raspberry Pi 5
Works with older Raspberries, but not with Pi 5
