Richard H.
Dayton Audio BST-300EX
précis et chaleureux
Eric v.
bonne prise
Jens H.
Bad plug
How can these get 5 star ratings? Must be a mistake.
Buy the normal round black 2-pin DIN plugs instead.
This is difficult to fit the cable, shoddy quality and may even degrade sound.
Only fit if you are using it for lab experiments, not for audio.
Jens H.
Terrible plug
This plug is a bad construction. It is sometimes difficult to insert the cable because of the way it is constructed - the socket hole closes as you screw up the screw, because the socket part moves out of the plastic shell as you open the screw.. Hard to explain.. But you can use only very thin cables and it is troublesome.
Moreover, the general quality is poor, it even degrades sound compared to the more standard black round 2-pin DIN plugs. I recommend these instead!
I wish there were high end 2-pin DIN plugs, for us who are vintage audiophiles..
fabien H.
DD TC35 PRO EYE Adapter Headphone Amplifier DAC USB-C Hi-Res ES9281AC 32bit 768kHz DSD512 MQA 6cm The DD TC35 Pro Eye is a USB-C male to 3.5mm female adapter, integrating a DAC and headphone amplifier ES9281AC. It is therefore ideal for use with a smartphone that does not...
Puce à tout faire
Le TC35 est reconnu directement par android et par win10, micro inclu. Sur un samsung S10e, pas de révolution par rapport à la puce intégrée, un peu plus de puissance. Par contre très appréciable avec le zenbook qui n'a pas de prise jack.
+ trés bon son, compact
- port usb court, tendance a tirer sur le fil pour debrancher
Manfred W.
Good industry standard improved "sound"
I have connected this cable with the Telegärtner Cat6 connectors. So for less than 25€ you get a high quality Ethernet cable. Covered it with a black sleeve for optics only. Compared to a CAT8 certified finished cable, which I used before, there is a noticeable improvement.
I use the Ethernet cable after a fibre/optic to Ethernet converted to connect to my Allo USBridge Signature streamer.
Only downside of this cable is, it is a bit stiff.
Compared to the Viablue 7S Ethernet cable, which has basically the same specs (23AWG solid core conductors, and they are not silver coated as in the description from Audiophonics!!) the Viablue cable is 5x the price of this Sommercable. The performance of the Viablue EP-7S is slightly better and the Viable is more flexible.
For longer runs of cables, I would go with the Sommercable, for shorter runs my choice is the Viablue EP-7S.
Both are really worse the effort to replace any standard CAT cable in your system.
Dominique P.
Une erreur !
Bon, vu le prix, pas une grosse perte pour moi mais comme Philippe, malgré l'aide d'Audiophonics, je n'ai pas réussi à faire marcher l'adaptateur avec MOODE sur l'USBridge signature que j'utilise.
Par contre, je reconnais qu'avec VOLUMIO il a fonctionné.
Dominique P.
Excellent appareil question son
Parfait soniquement pour moi (timbres, dynamique, scène sonore...) mais attention ! Même s'il est dit que l'appareil fonctionne tout de suite, il demande quand même un minimum de connaissance ou d'habitude de l'informatique. De plus, on n'est jamais à l'abri de bugs avec une machine à base de Raspberry, bugs qui ne viennent pas de l'appareil lui-même bien sûr.
Après avoir essayé Volumio, j'ai tenté MOODE et je suis resté avec.
Dominique P.
Excellent préampli !
Clair, précis et transparent avec des timbres neutres mais laissant passer l'émotion. Belle scène sonore aussi. Donc vraiment génial ce petit appareil pour ce qui est du son, surtout à ce prix.
Par contre mon exemplaire présentait un défaut physique : En branchant mes câbles, j'ai constaté que le bloc RCA sur le panneau arrière bougeait légèrement mais je ne me suis pas inquiété outre mesure, surtout vu le prix de la bête... Ce n'est que plusieurs jours plus tard, quand j'ai voulu brancher un autre câble que j'ai constaté que le bloc rentrait un peu dans le boîtier en enfichant la prise. J'ai alors constaté que les vis qui tenaient le bloc n'étaient pas bien serrées. Je les ai donc resserrées mais l'une d'elles tournait dans le vide. Pas top ! Ne voulant pas renvoyer l'appareil pour ça, j'ai résolu le problème en remplaçant la vis par une autre plus longue. J'ai aussi dû refaire une soudure car une tige de masse du bloc s'était ainsi déformée.
Dominique P.
Basses et aigus réglables
Ne l'oubliez pas !
How to enter the tone adjustment mode method:
- Press and hold the Volume button. the display“Treble” will twinkle.
- Then rotate the volume button to adjust the Treble +/ -10dB range.
- Press one time again the Volume button. the display“Bass” will twinkle. Then rotate the volume button to adjust the BASS +/ -10dB range.
Silence a bord!
Bonjour ,fi46 or ncf associée a un tunami V2 oyaide et iec charlin sur mon nuprime ida8,apres 30h rodage ( je pense 200 h minimum ) la fi46 ncf un sonoritée legerement chaude ,analogique , avec un silence tres tres poussé , bruit de fond tres precis, bonne dynamique , basse equilibrée , ma meilleure schuko a ce jour ( j image la fi50 encore meilleure ) le ncf est vraiment au dessus des autres ! franck
Andrej V.
good amp
excellent dynamic sound, subwoofer output works well, laptop with Windows 11 and mobile phone with Android 11 connects immediately to usb-no need drivers, tv via optical input plays great, overall I'm happy with the purchase and delivery speed I just need to replace the speakers for something better - )
Rapport Q/P hors norme
Je rejoins les précédents avis.
Un produit étonnant en termes de rendu sonore et de finition au regard de son prix plus que démocratique.
La perfection sera atteinte avec un meilleur contrôle qualité en fin de chaîne de fabrication (une résistance a été oubliée sur mon exemplaire mais vite corrigée par Audiophonics)
Tom B.
Aucun problème après 1 an d'utilisation polyvalente
Je n'ai pas d'expérience sur d'autres cartes son. Ce produit me sert depuis 1 an sans avoir jamais eu de soucis. Je l'ai trimballé un peu partout avec moi. Je m'en sers sois avec une paire de focal alpha 80 pre-amplifiée, soit avec un ampli casque geshelli archel 2.5 pro + HD650 (excellente combinaison). La télécommande est pratique.
Antony G.
Top connexion Ampli & Barette d'alimentation
Bonjour, j'ai fait l'achat de 3m de ce câble pour faire des test sur différentes sources audio, la meilleur application : cordon pour ampli et barrette multiprises. Avec le Sommercable NYM-ST-J votre installation va s'améliorer dans l'ensemble du registre : des graves bien assis qui ne baves pas, un medium plus naturel et un aigu cristallin. Le point négatif du câble et la rigidité de torsion, par contre le positif il prend forme sans s'abimer. Pour info je lance prochainement une chaine YouTube avec des idées de dépannages et des tests de produits audio et vidéo. Je communiquerai le lien prochainement. Vive la musique et la qualité.
Du punch !
Connectée sur cable yarbo cuivre/argent avec fiche schuko or élecaudio en amont . Un apport en définition et dynamique indéniable sans agréssivité , l'écoute est impliquante ; très bon , meilleure que certaines fiches rhodium qui apportent un son propre mais beaucoup monis vivant .
Lennart H.
3E AUDIO Amplifier Board Stereo Class D Balanced TPA3255 2x 225W 4 Ohm This stereo amplifier module integrates a TPA3255 amplifier chip, allowing it to develop a consequent power of 2x 225W under 4Ω (1% THD+N) while taking advantage of the high...
Trevlig krets
Lennart H.
Trevlig krets men det finns många att välja
une des meilleures
Une restitution d 'un grand naturel avec des détails mais transmis de façon homogéne . Scéne sonore épannouie .Connectée à un cable yarbo cuivre argent sur ce même site . Je la préfére à la viborg or /argent sur le même type de cable . une écoute sans fatigue proche de la réalité.
Edmond S.
FURUTECH FT-SDS NCF (R) Power Plug Schuko Type F for Power Distributor Rhodium Plated The Rhodium-plated Schuko Furutech FT-SDS-R NCF plug is a new version with a body using the brand's technological advances. Taking up the recognized qualities of the technical...
la barrette neodio pw1, contient un filtre mécanique, qui je pense fonctionne sur un des deux principes qui animent la prise NCF, donc peut etre double emploi.
Edmond S.
bonjour
votre alimentation avec le cable sommer dédié est deja excellente. avez vous noté avec la prise NCF . si il y avait un peu plus d'air entre les instruments et si ils etaient mieux détourés (c'est assez subtil) et . si vous utilisez un caisson de basse (la prise etant sensée travailler sur la resonance du 50 herz) si celui ci est un peu plus mélodique?
Nils B.
Un Monster truck !
Comment définir ce beau camion ?!
C'est du très lourd. Tu branches ton casque et il envoie toute la réserve d'essence et de nitro ^^
Il est très simple à installer avec toute fois les driver USB à installer sur Windows.
L'écoute est impressionnante de détails.
À acheter sans sourciller.
Nils B.
C'est du propre !
J'ai un AKG 712 à la maison. La vraie différence pour moi est que ce casque est plus chaleureux à l'écoute.
Pour la musique classique est l'électro je préfère l'AKG 712 pro qui à plus d'Aigue et d'ouverture.
Les cinq étoiles vont pour tout le reste. Un casque bien finie et qui gêne pas sur ma tête.
Nils B.
Un très bon ampli dac !
J'ai pus comparer cet article avec mon:
-Audio-gd nfb-11.38 performance edition
J'ai passé la soirée à les comparer brancher à mon PC en USB.
Casque de test Meze 99.
L'Audui G a plus de peps, plus de dynamisme. Alors que le Topping est beaucoup plus neutre. Pour ce qui est des graves, aigue, médium c'est délicat de juger. La différence est pas difficile à Percevoir pour moi.
Mais le Topping à la sortie symétrique. Et là, ça fait la différence. On retrouve une bonne pêche et le dynamisme manquant.
J'ai branché le câble officiel Meze symétrique en 4.4.
Mais alors pourquoi pas toutes les étoiles ? La télécommande n'est vraiment pas pratique. Faut être pile en face pour changer les sources etc et elle fait pas solide du tout.
Surtout que impossible de changer via l'ampli lui même.
Un grand remerciement à David Aubert qui m'a beaucoup aidé.
Alexandre F.
C est une bombe !!!
J'avais commandé son petit frère un peu juste pour les FOCAL ARIA 948.
Celui ci est juste magnifique
Mais alors MA- GNI- FIQUE
Des potes a moi travaillent chez Focal a st etienne m ont recommandé Audiophonics. J avoue qu au debut je n y croyais pas et voulait me tourner vers Rotel ou chose comme ça mais alors je conseil à mon tour.
Merci Audiophonics
eric m.
Utilisé avec Mpd et Rapberry Pi OS sur un Raspberry 4 sans aucun problème.
Le Dac est reconnu out of the box.
Jorge P.
Excelente
Um cabo excelente, equilibrado, tem tudo o que se exige de um cabo hi end, silencio, capaz de reproduzir sem excessos nem limites o que o seu sistema tiver para dar.
Pedro P.
JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 4.7µF Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a...
A "écouter" sur ma modeste vidéo sur Youtube: https://www.youtube.com/watch?v=QnNnxdCaS5k&t=42s
Sur un tweeter d'exception comme le ruban Viawave et sur des MarkAudio, mon filtre s'est mis à chanter grâce à ces fabuleux condos. Avec un meilleur préampli à tube et ampli de puissance, la transparence de ces condos est évident. Détails infimes, micro et macro dynamique, la 3D... Aucun son propre, aucune fatigue. Il est cher, certes, mais il fait aussi bien que des Audyn True Copper Max, sans se ruiner.
Nico V.
Male Micro USB Connector Gold Plated with Shell This Micro USB connector is ideal for the design of DIY cables or repairing the same type of connector. With gold palted contacts, it...
Roberto C.
Micro USB type B has always 5 pins. When OTG is necessary connect pin 4 (sense) to pin 5. Clear!
Ivaylo K.
AUDIOPHONICS CANARE Digital Coaxial Cable Ultra Coax 75 Ohm BNC-BNC 1m This Coaxial Ultra Coax 75 Ohm cable with male BNC connectors is assembled in France by Audiophonics, with top of the range components from Canare. This includes an ultra...
Good product
Just like in one of the previous comment I use this cable in the same situation - between Allo DigiOne and a Chord Qutest - it works well, it is also very well crafted - although it is a bit stiff.
Yoann L.
Vs m2tech hice evo
Comme d'habitude, chez audiophonics, une livraison impeccable.
Malheureusement, déception une fois connecté et activé.
Mon m2tech hiface evo lui a mis une claque. Il faut compare ce qui est comparable au prix du neuf.
22 euros contre plus de 30, heureusement qu'il ya une différence.
Cependant nt jattend avec impatience l'interface aes ebu pour comparer.
Merci audiophonics pour la disponibilité
Jens K.
Interconnect Cable Female XLR - Male XLR Gold Plated CANARE L-4E6S 0.5m Black This XLR male to XLR female modulation cable has a nice design quality, using a Canare L-4E6S cable. The cable has copper conductors insulated with PE jackets and is shielded...
Too bright
The cable looks the part and is very flexible, but when it comes to audio performance it is way too bright.
Trés bon cable!
Voilà une recette qui marche bien:
- Câble Viablue EP7, 60cm.
- Connecteur Telegartner MFP8 T568A + T568B.
- 10 ferrites Farnell 355-1463 ou 163-5660.
Un câble montée ainsi donne en première impression de transmettre très bien le signal tout en le nettoyant de toute impureté...
Gerard s.
cablage
bonjour, quelqu'un peut-il me conseiller pour le cablage ? 8 fils pour 3 en besoin...
Trés bon cable
Le câble "Neotech NEVD-2001" est également disponible au mètre (ou plus exactement au 25cm) chez hificollective. Dommage que Audiophonics ne le propose pas aussi.
Voilà ce que j'ai fait:
- 1.5m de câble "Neotech NEVD-2001"
- Connecteur RCA DG-201 ou DG-202.
- 40 Ferrites "Farnell 351-7025" placées sur toute la longueur du câble.
Résultat:
- J'obtiens un son clair, doux et très précis.
- Le résultat est meilleur que le câble Esprit-Audio à 500 euros fournit par TotalDac, ou il subsistait une petite dureté.
- Je l'utilise comme liaison digital entre mon OPPO 105D et un DAC D1-Single...
Peut-être d'autre personne pourrait constater le même effet?
Alain
Hervé B.
Bon article
En revanche, pour le dénuder, la gaine est très dure et costaud ! Risque de perdre des brins.
Original
Tous les câbles Ramm sont vraiment très bien conçu et celui-ci n’échappe pas à la règle.
Isolation à tous les stades de la fabrication. Même les très fins brins des conducteurs sont entourés de papiers isolants
Le résultat est là avec une densité du grave et du bas médium digne d’un très très grand câble.
Il demande quelques heures de rodage pour s’ouvrir sur le haut du spectre
Monté avec des fiches rca WBT de récup ça sonne très bien
RQP IMBATTABLE et en plus il est très beau avec sa gaine or/noir
La grande classe signée Ramm audio
Mamadou N.
Une petite merveille
Ce DAC vous permet de ressentir l’émotion de la musique. Très belle scène sonore, des basses tendues, des aigus jamais agressifs, une multitude de détails et une douceur qui rendent l’écoute tellement agréable. Walaye on n’est pas loin du Wahala….
Bravo, mais
Première impression très décevante à la réception du colis.
Pour 79€, les prises sont livrées dans un simple sachet plastique.
Visuellement, elles paraissent fragiles avec leur corps en plastique léger.
A la soudure, je conseil de l’insérer dans une fiche rca femelle afin d’éviter la déformation du corps et en évitant de dépasser 350 watts.
Avec ces prises j’ai restauré un câble hors de prix, le fameux Esprit Structura 3, qui avait ses prises WBT très endommagées dues à une mauvaise utilisation par son ancien propriétaire. J’ai également remplacé la gaine cuivrée et la gaine grise de finition.
Et les soudures sont réalisées avec de l’étain à 10% d’argent de chez mundorff.
Ces nouvelles prises ont révélé les qualités exceptionnelles de ce câble.
Le voile s’est levé sur une musicalité à couper le souffle. En plus d’une dynamique exceptionnelle, c’est surtout dans les micros informations que le gain est audible.
Bref , pour résumer, ces prises apportent une excellente qualité musicale et méritent leur bonne réputation.
Avec une meilleure présentation, dans une petite boîte par exemple et un matériau moins cheap elles justifieraient mieux leur prix, assez élevé.
Heureusement elles se rattrapent à l’écoute.
Pour utilisateurs avertis
Andoni G.
Room measurements
Umik 1 have a large good history, good cheap usb mic for rew and others.
Gregory S.
BURSON AUDIO SOLOIST 3X PERFORMANCE Headphone Amplifier Preamplifier Balanced Class A A vastly improved version of the original Soloist, released in 2015, Burson Audio's Soloist 3X takes up the concept of the original Soloist, including fully discrete circuitry,...
Un superbe Ampli casque
tout simplement le meilleur ampli casque a transistor que j'ai pu ecouter... une transparence juste incroyable, il vous revelera toutes vos sources avec justesse et précision.
la conception est entierement symetrique, les resultats deja exceptionnels avec une connexion "single-ended" sont encore ameliorés en passant a un cable symetrique .
il drive des planars tres gourmands tres facilement ( hifiman arya ) en high gain
parfaitement silencieux, son mode low gain permet meme d'utiliser des IEM tres sensibles sans aucun bruit de fond!
il peut egalement faire office de preampli dans un systeme hifi de salon, et aussi faire office d'ampli de puissance casque si vous avez déjà un preampli !
point d'attention : la telecommande fournie avec ne marchait pas a réception malgré plusieurs changement de piles.
Gros point positif au service client audiophonics : la telecommande a été remplacée en l'espace de qq jours !!!!
Gregory S.
DAC Au Top
Ce DAC est tout simplement excellent !
la connectique est complete, je l'utlise connecté en I2S a un streamer PI2AES, le brochage est compatible par défaut !
le son est excellent, et les trois filtres font une réelle difference.
l'enorme plus : Le MODE NOS, qui débraie les filtres internes, et qui me permet d'envoyer un flux upsamplé en amont par Hqplayer.
Le réalisme et le naturel de la restitution ont encore fait un bon en avant !
Il me reste explorer la possibilité d'ajouter une horloge externe...
Ce DAC est une vraie réussite, et couplé a hqplayer, il est encore meilleur...
Giorgio V.
Articolo spedito in tempi brevissimi . confezione di alto livello, l'ho collegato al mio XDuoo Xd-05 primo modello. Nessun problema. L'impressione d'ascolto si è rivelata ottima. Non fà assolutamente rimpiangere la connessione via cavo, anzi trovo che non vi sia differenza se non a mio parere in meglio. Praticissimo senza vincoli di spostamento.
Thomas M.
Refined and relaxed
I like this gold-plated IEC in combination with the Furutech FI-E11-N1 (G) Schuko. The FI-15-Plus G provides a lot of refinement while still sounding relaxed and effortless. I use the two plugs with an old Vovox initio power cord, made form silver-plated solid-core copper. Massed strings are simply beautiful with this combo. Silk and cream.
The usual choice for an IEC together with the Furutech FI-E11-N1 Gold Schuko would be the Furutech FI-11-N1-G, of course. But I never warmed up to it. To my ears, the Furutech FI-11-N1-G IEC simply messes with the timing. E.g. instrumental groups in symphony orchestras lose their cohesion. In the long run, it's annoying and tiresome. I tried the FI-11-N1-G time and again, but I simply can't stand it.
To my ears, this Furutech FI-15 Plus (G) is the much more musical, natural and involving IEC plug. And on top of that, it's cheaper.
Thomas M.
Great choice for high-current applications, it seems
I use a Furutech eTP66EG power strip. However, my wall socket is very much pedestrian. I have beeen looking to upgrade the plugs on my Vovox initio power cord (silver-plated solid core copper) that feeds the Furutech strip for some time now, trying all kinds of different plugs. Now, I've found my solution: FI-E11 (Cu) as Schuko and FI-11 (Cu) as IEC. It provides superior dynamics, more authority, weight and slam than e.g. the Furutech FI-E11 Gold oder the Viborg VE501 pure copper.
For some resaon, using the FI-E11 (CU) in the power strip, supplying power to individual components, doesn't work quite as well for me. There it tends to sound a bit tired, with somewhat subdued treble. It lacks refinement. But for the power strip, where the plug has to deliver a lot of wattage and current, it seems ideal to me.
Thomas M.
As solid as beautiful
The knob looks and feels soild indeed. It's flawlessly finished. And it's a pleasure to use. I feel it's a great choice, not just because of its surprisingly low price.
Alexandre W.
La bonne alim
Après avoir testé toute sorte d'alim plus ou moins au de gamme pour mon auralic femto , c'est celle qui sort du lot. C'est le meilleur compromis entre patate et subtilités d'articulation, c'est pêchu et naturel à la fois. On conserve une bonne profondeur avec de l'air autour des pupitres très posés. On n'est plus dans l'analyse mais dans le plaisir de profiter de la musique.
Si vous êtes dans une configuration avec un dd ou SSD en USB et que vous alimenté une interface USB , c'est la bonne alim.
Trés bon connecteur
Très bien conçu, très bon guidage des fils!
Et même mieux: le connecteur se relie au blindage du câble, ce qui permet de conserver la continuité du blindage.
Attention: il y a un modèle T568A et T568B, et il ne sont pas permutable grâce (ou à cause) d'un mécanisme de détrompeur.
Je le recommande...
TELEGARTNER MFP8 T568A Connector RJ45 Ethernet High-End Metal Easy to install RJ45 connector (no tool required). Shield 360 ° C; great connectivity.
Trés bon connecteur
Et meme mieux: le connecteur se relie au blindage du câble, ce qui permet de conserver la continuité du blindage.
Je le recommande...
Montage aléatoire
J'ai acheté cette paire en connaissance d'un risque de problème...
Dans ce connecteur, il manque un guide fil. L'espace pour enficher les fils est beaucoup trop large. Pire: deux des 8 contacts métallique ne sont pas à la même hauteur que les autres, ce qui pousse à mettre les fils en désordre. Donc on contrôle très difficilement l'ordre des fils une fois enficher. Résultat pour moi: les deux fils bleu se sont inversé au moment du sertissage. Alors J'ai donc jeter la paire de connecteur directement à la poubelle...
Je vous conseil plutôt Telegartner MFP8, très bien conçu, guidage sûr des fils, et même mieux: le connecteur est blindée! Attention il y a un modèle TC568A et un modèle TC568B.
Gregory O.
PANGEA
Has improved the picture from my router/internet box to my oled tv. Fast post to Ireland, 5 days Great job again AUDIOPHONICS
BEAU PRODUIT
Il a un bel aspect et une construction solide mais mon soucie est ça télécommande qui est pas très avenante. Et j'aimerai savoir si l'on peut la remplacer par un modèle "universelle" comme pour une TV. Sinon pas de doute sur qualité sonore de cet ampli signé Audiophonics... (testé avec des B&W 607 et Médiasun 2.5 silver) Pourquoi dépenser plus !!!
