Paul M.
AVIS CONFORME
Pour le prix, le DAC est idéal pour obtenir une excellente sonorité de la télévision et d'un lecteur Blueray-DVD.
Paul M.
AVIS CONFIRMANT CEUX D'AUTRES AUDIOPHONIPHILES
1.- Seul inconvénient mineur : difficile à porter avec des lunettes.
2.- Casque assez hénaurme, dans le genre heaume-cinéma...
franck G.
transfo sur mesure réalisé pour ampli a tubes vintage
réalisation parfaite pour une cabine leslie 147. l'ampli était alimenté en 220V ce qui à notre époque en 240V...
Customers reviews - There are 20211 reviews.
Robert g.
FOSI AUDIO ZP3 Balanced Preamplifier NE5532 The Fosi Audio ZP3 is a balanced preamplifier based on NE5532 AOPs. It offers interference-free sound reproduction over a wide dynamic range, minimizing ground loop effects. The...
The sound quality is amazing for the money, the ZP3 sound is neutral without being too dry, transparent enough, with exemplary resolution for a the budget range. What I really like is the bass control and dynamics, especially on the hi-rez files that have a higher dynamic range. ZP3 presents the soundstage correctly, with correct positioning of the sound sources in space, without exaggerating or compressing the width of the stage, or the depth. This is almost on par with my E88CC unbalanced tube preamp - a mu-Follower configuration with capacitor output and mild NFB - except for the apparent 'naturalness' of the tones of natural instruments and human voices, otherwise the Zp3 has the edge on any other chapter!
On the audio tracks with a Dynamic Range more than 10, the modern recordings with avant-garde jazz, contemporary classical music or full scale orchestral works could sound 'scary' in a healthy impressive manner. Some music albums examples here, that I used to evaluate the SQ of my ZP3 unit:
- Mussorgsky: 'Pictures at an Exhibition'; Gürzenich Orchestra Cologne, Dmitrij Kitajenko; 2019 [Oehms]
- Mats Eilertsen Trio: 'Sails Set'; 2013 [Hubro]
- Jonathan Faralli: 'Percussion XX'; 1999 [Arts]
- Bach|Gubaidulina, Anne-Sophie Mutter: Violin Concertos | In Tempus Praesens; 2017 [Deutsche Grammophon]
- Aaron Copland: Orchestral Works CD1; 1996 [Decca]
My unit came with LME49720 opa factory installed, to my surprise, and I left it how it is, after briefly testing AD8599, which proved not to be on par with the LME chip.
This preamlifier is a keeper for those loving a neutral - studio like sound - transparent, decently detailed and dynamic sound, that faithfully reproduce the recordings as god as they are, and do not bother the lack of a volume control display. The remote set provided inside the package is quite handy, and works well from all angles, having enough power, like any decent remote.
Despite ordering my unit was was not on stock, the Audiophonics announcements, packaging and tracking service was exemplary: merci a vous !
My audio set consists in: custom balanced DAC with AKM4499; Fosi ZP3; Fosi V3 Mono x 2; 2way custom made passive 98dB sensitive speaker with Beyma 15LX60V2 low-mid driver and Beyma CD10 Nd compression driver in a Polish horn SEOS15 by Autotech, with 2-nd order crossover implemented with CD passive equalization.
Will give it 4 stars out of 5, because:
- lacking of a volume display
- it is advertised to allow the customer to easily swap the 2 output opamps, which in practice is almost impossible for a less skilled owner, as the black glossy acrylic decorative sheets from the L/R case sides are very hard to remove in order to reach the 4 screws of the aluminum side plates of the case (are attached with double-sided tape)
- on balanced mode, the volume control chip does enter in a kind of soft mute mode, especially when the unit is freshly started, a mute and un-mute sequence from the remote set being the cure. I do not find this normal, but it does not affect the SQ so far after the 'fix'.
Pascal H.
Demande technique avant vente , réponse reçue dans la journée
le service est très réactif et surtout de bon conseil.
Commande reçue très rapidement en point relais, le tout à un tarif très doux.
Merci à l'équipe Audiophonics,
SMSL A200 Class D Amplifier Infineon USB HDMI ARC Bluetooth 5.0 2x70W 4 ohm The SMSL A200 amplifier is a Class D amplifier incorporating two Infineon MA12070 amplifier chips for output power of up to 2x 70W @ 4 ohm. Versatile and compact, the A200...
L'aspect de cet appareil est flatteur, vis à vis du prix. Certains adorent les Vu-Mètres ! Plus sérieusement, enfin un ampli avec une alimentation interne et un cordon secteur, ras le bol des amplis soi-disant puissants, mais alimentés par un bloc secteur externe et son petit câble coaxial. Le son est clair, plutôt doux, aucune stridence, aucune sifflante (voix de cantatrice sur les forte), impossible de déterminer que c'est de la Classe D, on pense plutôt à un ampli à tubes, mêmes qualités, mêmes défauts, extrémités de la bande passante très légèrement raccourcies, mais c'est insignifiant. Image très profonde, plus que large. La dynamique est raisonnable sans atteindre le niveau des stars de la Classe D, on privilégie le confort d'écoute. Aucune fatigue auditive. Je l'utilise sur des enceintes à haut rendement, les gros boomers sont plutôt bien tenus. Il est à noter des borniers plutôt sympas. Un appareil que l'on peut emmener partout, mais que l'on n'a pas envie de cacher, trop mignon. On apprécie également une vraie télécommande pour la partie préampli, volume, sources (et même tonalité).
N.B. : Attention ! La sortie subwoofer n'existe pas, erreur dans la présentation, point faible par rapport à des concurrents bien connus.
Marc C.
AUDIOPHONICS DIGIPI+I2S Digital Interface WM8804G for Raspberry Pi SPDIF I2S TCXO This Audiophonics DigiPi+I2S interface expands the output connectivity of a Raspberry Pi, giving it an additional panel of digital audio outputs. It includes a Toslink optical...
Utilisée en roon endpoint avec Riopeee, il faut choisir da
Marc C.
Vraiment bluffé !
Packaging sérieux. Utilisés en XLR et rien à redire...
Si le prix ! Un double mono à ce prix, c'est purement impossible de trouver ailleurs. Et la qualité est bien là.
Marc C.
Très étonné !!!
Je cherchais à connecter ma paire d'enceintes frontales à la fois pour mon système hifi et pour mon système A/V. Au début j'ai été dubitatif quand à l'achat de cette petite boite, n'aimant pas trop multiplier les connections entre les électroniques et les enceintes. Puis je me suis laisser porter par les autres avis.
Bien m'en fait puisque cette boite de répartition apparait bien transparente... enfin à mon oreille. Allez-y c'est du bon.
Merci à Audiophonics pour ce produit.
David S.
impeccable
Conforme à ma spécification un peu complexe: 0-11-22-40V et un second enroulement 0-4V: le tout très bien repéré et dimensions conformes au configurateur.
Délai un peu long, mais c'est du sur-mesure.
Mon vieux transport CD Audio Note dont le torique vibrait un peu trop ces derniers temps est de nouveau bon pour le service.
Merci Audiophonics!
Richard P.
Naturel
Je l'ai comparé à l'Albedo et bien pour moins cher il légale voir le dépasse si vous aimez un spectre moins montant qui apporte plus de détails mais moins de naturel. D'où mon titre naturel. Le bon équilibre pour mon système et mes oreilles !
Yannis G.
Petit mais costaud dans le haut grave et medium aigu
Mon 2 ième achat pour un ami qui l'utilise pour ses enceintes 3 voies diy monter par lui même en multi amplification il l'as utilser sur son medium 18 Sound 8NW650 et aigu beyma hd1030 parfait pour les fréquences haut graves et aigu , les borniers sont pitoyables pour les branchements mais on peut pas en demander plus pour le prix .
Pierre P.
HATTOR AUDIO THE BIG Balanced Passive / Active Preamplifier Takman REX OPA2134 Black This beautifully crafted Hattor Audio passive/active preamplifier features two high precision attenuators with Takman REX AMRT carbon film resistors, ensuring very low...
J'ai possédé son petit frère il y a quelques années.
Ce modèle actuel est toujours aussi bien fabriqué. Il procure une transparence exceptionnelle, surtout si l'on ne met pas en oeuvre la partie active.
Je le recommande totalement.
IBASSO AMP16 Raytheon JAN6418 Amplifier Module for DAP DX340 Silver iBasso's AMP16 is an amplifier module specially designed to be used with the brand's DAP DX340, providing tube amplification with an impressive 2000mW+2000mW at 32Ω.
Pour ibasso dx340
Ibasso amp16 change la DONNE LA QUALITÉ DE SONORITÉ EST SUPÉRIEUR SURTOUT SUR LE MODE TUBE HEUREUSEMENT QUE AUDIOPHONICS VEND CE PRODUIT VOUS POUVEZ ACHETÉ FACILE A INSTALLER VOUS AVEZ LE TOURNEVIS POUR LE MONTAGE
Arvydas V.
JANTZEN AUDIO SUPERIOR Z-CAP Capacitor 800V 1.5μF Jantzen Audio's Superior Z-Cap range consists of high-end, non-polarized capacitors designed specifically for audio to allow your audio system to reproduce every nuance, every...
A
Mohammed B.
Im Vergleich zu Mundorf CFC Spulen spielen die Mundorf nervöser härter heller und offener, aber die Jantzen spielen ohne Kantten weich und mit richtige Tempo und sind viel billiger als die Mundorfs
sehr zu empfehlen für Musik Genießer und Audiophieler.
Mohammed B.
Im Vergleich zu Classic WBT spielen die Jantzen Dnamischer offener
und mit mehr Druck im Bass aber die Standard WBT spielen sauberer und zurückhaltender und im Vergleich zu WBT CU Polklemmen spielen die WBT CU viel sauberer echter harmonischer mit super Bass widergabe.
Wer etwas mehr Dnamisch und offenheit braucht soll die Jantzen kaufen obwohl man bekommt die vollkupfer XANGSANE oder von Eizz hier bei Audiophonics billiger und klanglich viel besser.
Mohammed B.
die
audiophile und lässt keine Wünsche offen. Im Vergleich zu standard bzw Messingsteckern und andere CU Steckern von andere Herstellt spielen die Furutech viel realistischer und Neutraler.
Ich habe von Vibrog und Monus Audio ich finde Furutech viel besser
die Monos Audio spielen etwas gekünstelt und mehr Bass aber die Führutech spielen durchsichtiger und viel Realistischer ausgewogener und ausgeglichener.
Sehr zu empfehlen!
Für Musikanlagen die sehr zurückhaltend spielen nicht zu empfehlen.
Mohammed B.
Super Stecker und Top Preisleistung
die
Sehr zu empfehlen!
Mohammed B.
Super Stecker mit top Klang und preisleistung
die steckern spielen sehr realistisch warm flüssig detailreich angenehm
Sehr zu empfehlen!
magique
C'est ma 2e, associée aussi avec le vondita, sur le dac et c'est juste exceptionnel. C'est naturel, ouvert, détaillé et sans agressivité....
EXCELLENT CÄBLE
C'est le second que j'achète, la coupe a été un peu plus généreuse, 10 cm de plus (sur le premier, pas un cm de rabe), c'est appréciable sur un câble aussi onéreux. Et ça laisse plus de marge étant donné la section. Sur mon dac nuprime avec une FURUTECH FI-E46 NCF (G) et une FURUTECH FI-C15 (G), Il ne bougera plus comme sur mon intégré. C'est le câble le plus naturel que j'ai écouté. Cher, certes, mais juste parfait.
Tsvetan A.
Simply outstanding!
I have bought the Purifi to use for my Monitor Audio Silver C350 center, which before was powered by the receiver (Marantz SR6015), i wasnt expecting much, but to be honest the difference is big, much clearer voices/effects in movies, and for music... everything is better - voices, highs, even bass is tighter. Now a new problem - the rest of the speakers are lacking, heh. I Recommend it for center speaker with two hands!
Bernard B.
FIIO BTR17 Headphone Amplifier THX-AAA Portable DAC 2xES9069Q 32bit 768kHz DSD512 Blue With the BTR17, FiiO offers a portable headphone amplifier and DAC based on a pair of ES9069Q chips for digital/analog conversion, handling signals up to 32bit 768kHz PCM and...
fiio BTR 17
Pas d'ataptateur secteur pour la recharge de la batterie, dommage.
Envoi très rapide.
Laurent G.
Petit mais super efficace !!
Je viens d'un Sugden pure classe A, je peux affirmer que cet ampli n'est absolument pas froid, bien au contraire, les basses sont bien présentes, très définies et tout le spectre est bien mis en valeur. Le plus remarquable est sa transparence, Il alimente mes focal 948 avec aisance, fluidité et subtilité et s'efface pour transmettre le meilleur de mon pré ampli eversolo A8 (branchement XLR). Une véritable réussite à son prix.
Alain S.
SOFTEARS TWILIGHT Dynamic In-Ear Monitors IEM 16 Ohm 116dB 15Hz-40kHz With the Twilight, Softears presents top-of-the-range dynamic in-ear earphones whose lightweight, high comfort fit is only equalled by the quality...
Vous n'écoutez plus de la musique mais êtes au cœur de celle-ci et ça change tout .
A noter l'étonnant form factor qui permet de loger ces intra dans les oreilles de toutes dimensions.
Wiim Amp Pro
Nice dac amp (power dac) based on a TPA3255 chip + PFFB. The real added value of this amp is that it offers a parametric equalizer and we can therefore use the EQ optimized by Spinorama org for acoustic correction
FIIO BR13 Bluetooth 5.1 Receiver QCC5125 DAC ES9018K2M aptX-HD LDAC 24bit / 96kHz The FiiO BR13 is a Bluetooth receiver equipped with a high-performance DAC. KEY FEATURES: Bluetooth 5.1 QCC5125 receiver chip SBC, AAC, aptX, aptX adaptative, aptX...
Fiio BR13
En soi concernant le BT il fait son job. En revanche l equalizer paramétrique bug puisqu on ne peut pas le sauvegarder ( bug Fiio connu et non corrigé honteux !
Didier T.
Mitigé...
Serties (et non soudées) sur du Ludic Silenos (2,5 mm2 multibrins), elles m'amènent aux constats suivants :
- un excellent "grip" une fois insérées dans les borniers femelles qui assure un excellent contact sur la plus grande longueur insérée
- un sentiment de relative fragilité provenant de la finesse du matériaux : si elles n'ont pas vocation à être manipulées régulièrement, certains câbles qui rigides ou lourds peuvent mettre à l'épreuve leur solidité
- un impact sur l'équilibre sonore empreint d'une certaine forme de "maigreur aigrelette" de timbre : cela me donne le sentiment d'une transparence factice, confinant dans certains cas à un peu de dureté
En fin de compte, elles ne sont pas restées en place.
Thierry H.
upgradable
J’ai acheté la version précedente XQ-50 pro ( tout court ! )dont le pro 2 semble être le frère jumeau il y a 5 ans , très bon appareil , récement j’ai eu l’idée de l’ouvrir : comme sur le xDuoo xd05 basic v2 , l’AOP de sortie est sur un suport dip tulipe , donc facilement interchangeable !
Avec un opa 2134 le xq50 pro devient vraiement très très bon
Bruno R.
DD TC01BF USB-C Male to USB-B Female Adapter Gold-plated The TC01BF adapter from ddHiFi consists of a female USB-B connector and a male USB-C connector. Its gold-plated contacts ensure good conductivity and resistance to oxidation....
Semble OK
Contrairement au précédent acheté sur amaz.. celui-ci ne semble pas du tout affecté le transfert des données (donc le son) entre mon ordi Qobuz et mon DAC.
Belle finition, bon produit.
Radek P.
neotech nei 1220
Félix M.
6P1 Tube for Amplifier / Preamplifier (Unit) This durable and reliable 6P1 tube will allow you to replace a similar faulty model or design a tube amplifier/preamplifier. This tube corresponds in particular to those...
TUBO 6P1
LES TUBES ONT BIEN FONCTIONNÉ MAIS LE COLIS EST ARRIVÉ TOUT CABOSSÉ ET CASSÉ JE NE SAIS PAS COMMENT ILS ONT ÉTÉ SAUVÉS, MAUVAISE MANIPULATION DU COLIS MÊME S'IL ÉTAIT BIEN EMBALLÉ.
Axel P.
TOPPING HYNOTONE ARES Guitar Distortion Pedal Topping, following on from its Topping Professional range of USB audio interfaces, unveils a distortion pedal for guitar with its new Hynotone range.
Top à ce prix
Guitariste et audiophile, j'étais intrigué par cette pédale fabriquée par une marque issue du monde de la hi-fi et j'ai donc sauté le pas.
Niveau qualité de fabrication, rien à dire, c'est propre, les switchs et les potards inspirent confiance, le boitier est robuste. je trouve les potards très agréable et à titre personnel, je trouve le design générale simple mais très efficace.
Niveau son, on a bien affaire à une distorsion, un peu aigue à mon gout mais pas criard pour autant. Les potards agissent plutôt bien sur le son. Par contre il y a à redire sur les switch.
Le boost fonctionne très bien, on entend clairement la différence quand on l'active. Il a le même effet qu'un boost placé avant la pédale, il fait ressortir des harmoniques et donne un son plus tranchant, plus "metal". Une réussite pour moi.
Par contre, je n'entends pas du tout de changement de son avec les deux autres (le bite et le tight). Le tight est préconisé pour les guitares 7 cordes, ce que je n'ai pas, il est donc normal (je suppose) de ne pas entendre de différence. Le bite n'est pas préconisé pour une config en particulier et je n'entends aucune différence avec ou sans. A voir si on entend quelque chose sur une autre config.
La pédale a été testée sur un ampli à lampe blackstar avec une Ibanez équipée de Di Marzio air norton et tone zone.
Conclusion: Une excellente pédale pour ce prix même si certains switch ne semblent pas impacter le son. Comparé à une Chug Lite, elle n'a pas à rougir. Juste une question de goût.
Panikos K.
Nice
Very good & useful accessory and at extremely good price.
Jean-Baptiste G.
J'adore ce câble.
Musical fin délicat précis tout est bon..
Jean-Baptiste G.
FOSI AUDIO BT30D PRO Class D 2.1 Amplifier 2xTPA3255 Bluetooth 5.0 2x125W+250W 4 Ohm The Fosi Audio DT30D Pro is a small, powerful and affordable Class D amplifier, ideal for the integration of a simple but powerful audio system. It embeds for that two TPA3255...
Acheté pour mon son tv pour y ajouter un caisson passif.
Le réglage indépendant du caisson est très pratique.
Son un peu plat il faudra lui ajouter un dac gagner en clarté surtout pour les voix.
Les aigus même tournés à fond cela ne suffit pas.
Jean-Baptiste G.
Bon rapport qualité prix.
Ça fonctionne.
Jean-Baptiste G.
Je ne vois pas de point négatif pour le prix.
Mais si on lui ajoute un dac et un pré ampli relatif au prix, un intégré FDA de 100 watts fera équivalent ou mieux avec moins d'encombrement.
Jean-Baptiste G.
J'adore ce câble.
Très beau câble un son tout en finesse précis sans perte de grave.
Bonne protection de la gaine.
Un diamètre minimum de 3,3 pour supporter 450 watts sous 4 ohms.
Je recommande sans problème ce câble un gros coup de cœur.
NIKOLAOS K.
My highest recommendations!
Bought it together with the PANGEA IEC to C5 Platinum Gold Plated Crystal Plug Adapter to replace the included standard off the shelf power cord of the KEF LSX ii LT speakers and the result is spectacular!
I expected nothing less, so thank you AUDIOPHONICS.FR!!!
NIKOLAOS K.
Essential necessity, of high quality, too!
'Engineered in USA -manufactured in China'
I bought it to replace the included standard off the shelf power cord of the KEF LSX ii LT speakers with the AUDIOPHONICS STEALTH Power Cable Schuko C15 OFC Copper Shielded 3x3.5mm² so the spectacular result is the combination of both products.
I couldn't find any other IEC to C5 adapter of this high quality and although far more expensive i decided not to take any chances and i purchased it together with the Audiophonics Power Cable.
My highest recommendations for both of them, thank you AUDIOPHONICS.FR!!!
Jean V.
sur le message précédent 5 étoiles, bien sûr !!!
Jean V.
Utilisateur de 2 blocs mono Hypex Ncore 500, j’ai souhaité voir ce que pouvait apporter les modules Purifi, sans conviction débordante !
Eh bien, je m’étais lourdement trompé !!
Dès les 1ères notes, la différence est flagrante et saute aux oreilles !
Naturel, transparence, neutralité, définition, richesse d’informations, douceur du haut médium aigue, tout a franchi plusieurs crans. La définition spatiale, la précision, le naturel de la représentation de l’image reproduite, son architecture, sont vraiment devenue addictive !
Si le médium et l’aigu gagne une richesse de micros informations digne des meilleurs classe A, ce qui m’a étonné, c’est que l’on retrouve cette richesse, même dans le bas du spectre !
De plus, la dynamique est impressionnante, ce qui est, peut-être, lié à la l’alimentation sous 70V !
Superbe acquisition, qui me fait redécouvrir des enregistrements que je pensais, parfaitement, connaitre !
Contexte d’écoute : musique essentiellement classique, enceintes Revel Performa 228 Be dans une salle dédiée, indépendante, construite spécialement, traitée acoustiquement. Système piloté par DSP.
Merci à Bruno Putzeys pour la conception des modules et à Audiophonics pour la mise en œuvre.
Jacques E.
moyen
Trop fragile ! La connexion de masse est vraiment fine et fragile...déçu !
Pierre S.
Beau résultat
Bel effet visuel sur la câble, c'est quand même plus sympa qu'un gris "plastoc".
mickael C.
Une des meilleures prises
mickael C.
Michel P.
FIIO DM13 BT CD Player Ripper on Battery 2xCS43198 Black FiiO's DM13 BT is a portable CD player with a sleek design and undeniable internal component quality. Its aluminum body houses two DAC chips from Cirrus Logic to offer a...
Michel P
Lecteur CD très sympa et qui semble être de bonne qualité. Utilisation pas évidente surtout au début. Une notice en français digne de soi serait le bien venu. Une télécommande serait un plus.
Merci a Audiophonics pour leur excellent service. Envoie très rapide même pour l’étranger.
Jean-Yves V.
Très satisfait du produit!
Utilisé sur des tweeters Scanspeak, les détails musiquaux sont très bien restitués.
Il faut l'essayer pour se faire une réelle idée.
SMSL DO300 DAC ES9039MSPro XMOS XU316 Bluetooth 5.0 aptX HD LDAC 32bit 768kHz DSD512 MQA SMSL's DO300 DAC, little brother of the DO200, takes the technical base while updating its components for improved performances. Its digital/analog conversion stage is now...
Petit cr
Voi i un dac très silencieux ( surtout en mode fast linear)
Très bel équilibre tonal et scène large mais un poil de manque de profondeur.
Diaphane très faible, un très bon dac mais il y a mieux en débourser un peu plus.
Pierre S.
Très content du résultat
Ça faisait 30 ans que j'utilisais les câbles originaux Cabasse "Marron", achetés avec mes Clipper II.
Quelle baffe avec ces nouveaux câbles, je redécouvre mon système (Accuphase E260/ Cabasse Clipper II) étant donné le prix, ça vaut vraiment le coup.
Par contre visuellement, on a peu l'impression d'être sur un chantier, je pense mettre une gaine tressée dessus pour les rendre un peu moins "bruts", c'est vraiment pas terrible visuellement comme ça milieu du salon.
J'ai aussi un autre système beaucoup plus HDG où j'ai investi 20 fois plus dans les câbles HP (qui sont excellents) , je regrette presque de ne pas avoir essayé cette solution avant...
Gilles M.
SMSL PL100 CD Player CS43131 Black The SMSL PL100 CD player is the perfect way to enjoy your CD collection. It's essentially based on a CS43131 DAC chip and a PLL (Phase-locked Loop) circuit for sound...
Rapport qualité prix imbattables comme toujours chez SMSL.
Testé en analogique et coaxial pas de différence pour mon oreille. Moi au contraire de beaucoup de commentaires, l'esthétique me plaît, ça change des standards idiophiles a 400€, voir plus, pour une boîte 3 fois plus grande et quasi vide. A voir dans le temps pour le chargement, mais les autoradio était costaud alors pourquoi pas. Qualité sonore, encombrement minimum et simplicité d'utilisation son au rendez vous. Je recommande.
