Efthymios X.
As per title really.
Efthymios X.
As good as it always was
Plus reliable. That's it :)
Patrick R.
Customers reviews - There are 21000 reviews.
Denis L.
Validé !
Bon rapport qualité prix. Je rejoins les divers commentaires.
Bien mieux sur les sources . Branché sur le Dac audio gd r1 un trés joli mariage : Musical et détaillé.
Attention aux codes couleurs. Jaune pour neutre .
Douglas G.
Tres magnifique!
I am very happy with my purchase. The amplifier is a great value, with crystal clear sound from a small, light chassis at a very reasonable price.
Jean Luc D.
Impossible de la brancher
J’ai déjà installé une centaine de prises secteur
Mais celle ci c’est une catastrophe
Au bout de 2 heures j’abandonne , les connecteurs sont en 2 morceaux et ne sont maintenus par rien . Ils se baladent . Mon câble étant rigide ..impossible de faire un branchement
Martin B.
TOPPING A50 Headphone Amplifier Balanced Silver The Topping A50 is an efficient and affordable sedentary headphone amplifier. Its careful design makes it an ideal ally for any audiophile wishing to enjoy a rich and clear...
Satisfied
this is my first headphone amp but im very satisfied, nice build quality, i paired it with Beyerdynamic DT 880 Edition 250 Ohm and it has plenty of power to spare, based on sound source its really loud at 11 - 12 oclock on high gain
btw ordered from Slovakia at night from Sunday to Monday and it was delivered on Friday that week and it was carefully packed
Torsten S.
Very hard to assemble, not good for small cords.
It is quite impossible to assemble this connectors with tight and safe contact when using smaller cords. After trying to assemble them for about an hour, I felt that it may not be safe to use them.
Douceur et tenue
Schuko oyaide 79 en bronze et plaqué or possede un son riche ,tres doux, ( indulgente) ronde et puissante,avec un medium tres plein tenue excellente,,ideale pour systeme un peu montant ,trop clair. Pour moi une des meilleures schukos .Franck
Jean Marie F.
Extra
Après avoir lu pas mal d'avis positif et vu le prix de vente dérisoire je me suis laissé tenter.
Ce petit joujou et vraiment surprenant.
Rien ne manque la musique coule naturellement.
Après le rodage des tubes cela devient délicieux !
Vraiment pourquoi dépenser plus ?
Je viens d'en commander un autre en noir tellement j'en suis satisfait.
Je compte l'intégrer dans un gros boitier ainsi que le Fx phono avec une grosse alimentation régulée et des entrées supplémentaires, sélecteur de sources ect .. pour en faire un pré-ampli complet et musical.
Mention + + + à Audiophonics pour la rapidité à traiter les commandes mais surtout de nous dénicher ces petites merveilles.
Didier P.
RAS
Très bien, bon produit.
Cordialement.
patrice f.
Fiche viborg 401
Très bon produit,deux vis de serrage câble qui assurent une bonne
transmission du signal audio.
Bon maintien dans les entrées ampli .
Amélioration du rendu sonore.
Excellent rapport qualité /prix.
Ludovic H.
Condensateur elna
Acheté pour remplacer sur mon ampli marantz produits parfait conforme rien a dire
Jenistan C.
MUNDORF E-CAP ECAP100 (BR100) RAW Capacitor 100VDC 32VAC 10μF Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not suitable for space or cost...
Filtre très bien sur mon haut parleur full range, plus aucune bass sur celui-ci
Jenistan C.
DAYTON AUDIO DSA90-8 Designer Series Speaker Driver Full Range 20W 8 Ohm 85dB 66Hz - 15kHz Ø7cm Broad band speaker. Versatile and easy to use. Good solution for beginners in speaker building / tuning
Je suis satisfait de mon achat, haut parleur avec une fabrication de très bonne qualité, et le son est top.
FREDERIC M.
Solide te bonne continuité électrique avec le cable lié à la multiprise
Douglas G.
Tres Magnifique
I am very happy with my purchase. It’s small, light, and sounds fantastic. Bravo Audiophonics, job well done.
christophe S.
Pas convaincu
Après un rodage très long
connecteurs 004 oyade est fi38 furutech je suis assez déçu de se câble, trop sombre, transitoire lente est manquant de définition .
Pour le positif beaucoup de chaleur est de douceur
Je pense que se câble a besoin de connecteurs 50ncf furutech pour optimiser le rendu , autrement un effet bouchon peut se produire.
Je lui préfère le tc31 furutech, beaucoup plus indulgent.
Amaury C.
Excellent produit !
Mon objectif était de pouvoir utiliser mes enceintes principales stéréo autant en écoute "audiophile" que pour le HC en ayant 2 systèmes d'amplification distincts. Ce sélecteur me permet donc de commuter vers l'ampli HC ou vers l'ampli Hifi en fonction de l'usage du moment. Une chose est sûre : aucune perte audible en faisant transiter le signal audio en sortie HP via ce sélecteur. La qualité de construction est digne des appareils audio de qualité avec un beau boîtier en alu épais et de superbe bornes d'entrée et sortie HP. Le commutateur est franc et ne génère aucun bruit parasite en passant de A à B et inversement. En conclusion : appareil tout à fait recommandable pour son usage.
Matthew d.
Received mine yesterday! And I have to say that I am quite pleased with it! The case itself has a nice feeling to it, appears very clean. Soundwise out of the box it sounds very clear, hooked it up to my Floorstanding KEF Q5's. It has no over saturated bass or treble, rocks the building without going above '35' of soundvolume (unable to hold a conversation at this volume without yelling). Bluetooth pairing goes without a problem aswell. Only thing that's less charming is the IR remote, you really gotta point to the lcd screen otherwise it just wont function.
P.S. mine came with the 'new' power supply that previous owners got as replacement
Big thumbs up from me!
thierry l.
bien
utilisé pour un bureau, mais testé sur des colonnes Klipsch ......ça le fait bien. Dommage que Qobuz parle d'une sortie casque que je ne trouve pas .....
Charles S.
Sonorité clean et agréable, satisfait de ce petit achat :-)
Chez moi, petit ampli de secours, pour l'instant essayé en association avec un "The Preamp" de Musical Fidelity et des enceintes Rogers Ls2A/2 au rendement de 87db, il est bien assez puissant et s'en sort plutôt bien. Sa sonorité est clean et agréable, bien plus naturelle que les petits amplis au même prix que l'on trouve sur les grands sites marchands.
Satisfait de mon achat :-)
benjamin D.
FX-AUDIO BOX02 Phono MM/MC Preamplifier NJM2068 TL071 The FX-Audio BOX02 is a low-cost phono preamplifier, offering a very high quality design. It supports the board with MM and MC cells, a switch under the device to select one of...
renaissance de mes vinyles
après avoir beaucoup hésité et des conseils précieux d'AUDIOPHONICS je me suis lancé sur ce préamplificateur phono et je peux confirmer que ça a transformé mon installation .
Ayant une platine technics , ampli vintage sony et enceintes jmalb ,
le BX02 a ravivé tout l'ensemble , les voix sont beaucoup plus claires un gain et un son plus péchu . le boitier est tout en aluminium très qualitatif et solide .les réglages aussi sur le type de cellule la captance et la charge sont très interessante pour affiner .
le Tout à livré très rapidement à un prix imbattable .
merci à toute l'équipe audiophonics .
Sylvain a.
AU TOP
Très BON SERRAGE
maintient dans la prise au top
rapport Q/P IMBATTABLE
Franck B.
La qualité, et la précision selon Vishay
Acheté selon les recommandations de la marque de mon préamplificateur pour en abaisser le gain...
philippe d.
CORNELL DUBLIER Aluminium Capacitor 80V 10000µF Cornell Dubilier's 380LX series capacitors offer excellent performance and will find their place in many applications, especially for switching power supply input and output...
avis sur ce produit
Je suis très satisfait de ce produit et du délais de livraison.Je recommande Audiophonic .
Bruno N.
Bien fait, et beau
Ça respire la solidité. Bien stable.
Nicolas L.
Très qualitatif
Cet adaptateur est très qualitatif et parfaitement adapté à ce que je cherchais. Un produit durable, solide et a la qualité sonore neutre. Utilisé pour écouter un casque Grado sur baladeur Fiio M11, c'est un vrai plus en comparaison avec un ancien adaptateur bas de gamme pas très solide. Ce produit est fait pour la vie.
Vincent F.
Confirme pas ecrit sommercable sur le cable mais du nexans, sinon ras
Vincent F.
Conforme
Conforme au visuel, bonne qualité d'ensemble
Vincent F.
Très bon rapport qualité prix, ras
Olivier b.
Très bonne qualite
Bloc secteur livre rapidement alors qu’il n’était pas en stock, tres bien emballé (double emballage). Le bloc est lourd, 3 kgs, et tiens bien au sol pour éviter un retournement avec des câbles rigides. Je l’utilise sur un ensemble HI-FI haut de gamme et l’ai acheté pour regrouper mes branchements sur un seul bloc (8 prises filtrées, il y a de quoi faire), éviter les surtensions du secteur. Et en plus, il est beau !
A ma grande surprise, a la première écoute le son me semble meilleur, plus ample, davantage de basse. C’est peut être psychologique mais peu importe... cela me convient bien.
Donc très satisfait, tant de la logistique d’Audiophonics que de la qualité du produits livré.
A recommander sans modération.
Philippe e.
Trop rigide ?
Est-il nécessaire que ces câbles de 11 soient aussi rigides ?
D'autre part les gaines individuelles des fils adhèrent trop au conducteur qui est fragile avec ses fils très fins et provoquent quelques ruptures de ces petits fils au dénudage - rendu assez difficile.
Codes couleur fantaisistes.
Philippe e.
Finition soignée mais heureusement, car ce n'est pas donné.
Le fabricant aurait pu indiquer les dimension intérieures pour faciliter le dénudage de la gaine.
Gilles L.
Surprenant dans le bon sens du terme. Génial !
Un son puissant, je l'utilise principalement avec un intra Final Audio Heaven IV (16 ohm/116 db) et un casque Fostex TH 610 (25 ohm/98 db) Dans les deux cas le son est excellent. Avec le TH 610 pour une écoute normale le réglage du volume est à peu près à 30% ce qui laisse une réserve de puissance très importante (encore plus importante avec le Final Audio). Dans les deux cas aucun bruit de fond et aucune distortion. Avec des fichier HIRES Qobuz le résultat est bluffant à tel point que je me demande si il y a un intérerêt à utiliser des produits beaucoup plus sofistiqués, encombrant et beaucoup plus chers...
Je suis conquis.
Tero J.
SHANLING BA1 Bluetooth 5.0 Receiver CSR8675 ES9218P aptX HD LDAC LHDC Shanling's BA1 is a desktop Bluetooth 5.0 receiver. It is equipped with a CSR8675 Bluetooth receiver chip, an ESS ES9218P digital/analog conversion chip and is particularly easy...
Very beautiful, nice size and connect immeadiately.
Stephane I.
sommercable ORBIT 240
Marque que je découvre tardivement ,qui est excellente ,si j'avais découvert ce câble plus tôt ,je n 'aurai pas gaspillé autant d'argent en câble HP ,il est honnête ,les voix sont réalistes ,la stéréo est excellente ,il est un peu vert mais sans agressivité ,les instruments sonnent justes ,je vais tester leur câble secteur ,je ne pense pas être déçu en vue de la qualité musicale des produits ;je vous le recommande ,produit musical pas de marketing .
Soundcare standard
Rapport Q/P correct pour cette pointe/contrepointe.
Le decouplage est performant. Le reglage hauteur pointe aisé. Je les ai installées sous toutes mes colonnes et mon caisson. De Plus, le déplacement des enceintes est facilité par rapport à un ensemble standard ou la contrepointe s'enlève au moindre déplacement.
Stephane I.
sommercable Goblin
Cable de modulation ou micro surprenant, par ses qualités en rapport avec son prix ,transparence ,musicalité et dynamisme sont au rendez-vous ,il remplace avantageusement des câbles OCC beaucoup plus couteux qui m 'ont déçus ,ils creusaient le médium et tiraient l 'aigu ,câble qui s efface devant la musique ,un bon choix en attendant d 'investir dans un EPILOGUE qui est le must des RCA .
Superbe platine cd
Déjà très belle finition, mécanique silencieuse
Après quelques heures de rodage,très très bien ce petit lecteur cd
Transparent,vif,que du bonheur
J'ai essayer la sortie numérique avec mon micromega mydac,eh ben c'est moins bien à ma grande surprise !!
Bref a recommander sans réserve si vous avez une belle collection de cd
Gérard K.
Excellente station de soudure
Très bon produit qui m'a permis de faire des soudures très précises (4 soudures dans des fiches jacks symétriques 4,4mm). Très simple au niveau utilisation avec le réglage de la température.
Zoran G.
Qualité sonore top, présentation bof.
La qualité sonore est indéniable. Cependant, la boîte et l'aspect du produit fini ne valent pas les 209€.
La boîte ressemble à une... boîte en métal que l'on peut se procurer dans un magasin de bricolage. Il a l'air assez banale.
Le couvercle fumé de l'écran est en plastique et vulnérable aux rayures. Il est arrivé avec une belle égratignure dans le coin supérieur droit! Probablement parce qu'il est seulement protégé par une feuille de papier, qu'il faut enlever avant le montage. Le manuel d'utilisation n'en fait pas mention.
L'écran à l'intérieur n'est pas horizontal et le couvercle arrière semble fait de carton noir. Les deux couvercles avant et arrière ne sont pas au même niveau que le boîtier.
La sortie numérique centrale n'est pas horizontale (endommagée lors du transport ?) et est légèrement orientée vers le bas par rapport à la sortie analogique.
L'emballage est du même niveau de finition que le produit : un peu trop hobby-like à mon goût. Les pièces sont enveloppées de morceaux de carton et de beaucoup de ruban adhésif.
L'emballage de la carte DAC était trop serré et contenait beaucoup trop de ruban adhésif, ce qui rendait le déballage inutilement ennuyeux. La sortie numérique a peut-être été pliée à ce moment-là?
Est-ce très grave tout ça ? Non, pas vraiment... Le système fonctionne, et c'est là tout l'intérêt. Mais le boîtier semble mal adapté et un peu amateur. Dommage.
En fin de compte, je ne pense pas que le boîtier vaille la peine.
Désolé Audiophonics, vous donnez l'impression d'avoir passé plus de temps sur l'électronique que sur la finition.
Nous vous aurions aidé à la mise en œuvre sur simple demande.
Concernant les pièces endommagées dans le transport, contactez le SAV via le formulaire du site, ils feront le nécessaire.
L’arrière du produit est dans le même acrylique que l'avant et en effet ce produit représente l'entrée de gamme de toute une famille de streamers.
rectification avis du 25/02/21
J'ai éssayé de nouveau cette prise suite à ma première déconvenue. Connecté à un cable blindé avec une fiche iec rhodium viborg sur un vieux lecteur cd pionner de plus de vingt d'age le résultat est bluffant .
Gilles R.
Tubes chaleureux
Il y a une différence évidente avec les tubes qui étaient montés d'origine sur l'ampli.
Plus de graves et le tout plus chaleureux.
GEORGIOS N.
ARYLIC UP2STREAM AMP 2.1 Amplifier Module 2.1 WiFi Bluetooth 5.0 Tone Control 2x50W + 100W The Arylic Up2Stream Amp 2.1 is a 2.1 channel amplifier with full wireless connectivity. It will allow you to use a subwoofer while enjoying the convenience of audio streaming....
Very good for small diy projects
I coupled this board to an SMPS300RS regulated power supply, feeding it with clean and adequate power at 24V. Overall the board does what it advertises and the build quality is very good, with the exception of the cheap plastic knobs. I would only review the sound quality which, although powered by a decent supply, is subpar to entry HiFi standards, do not expect do get a sound like a decent inexpensive integrated amp, The class D circuity implemented in this board lacks clarity and instrument separation, sound thick overall. I compared this board sound to a TEAC integrated class D amp I have rated at 2X20W @ 8 ohm using ICEPOWER 2X50W 4 ohm circuity, and the TEAC win hands down. Also this board has an integrated DAC with DSP capabilities, as shipped the sound seems too bright and I needed to reduce treble way down to be at an acceptable no fatiguing level. Also the bass seemed elevated, so overall I guess a U type of preset is available boosting lower and higher frequencies. In order to be able to tune the DSP settings yourself you need to purchase a $20 software that gives you access to the internals of the DSP of the DAC. I do not have this at the moment but its a must if you are serious about music quality. Overall 4 stars, the one star missing is for the amp section of this amp that is lacking, but as they say you should not expect so much for a €95 board, it is a very good choice for TV bars or Bluetoorh style small speaker.
GEORGIOS N.
Makes a big difference for DIY Boards
I bought this for an ARYLIC UP2STREAM AMP 2.1 Amplifier Module diy project. Previously I had the board connected to a 19V 4.5A brick from an old PC and the sound was very thin for a satisfactory music experience. Once I connected the SMPS300RS wow! Robust sound levels with no sweat from this power supply, it doesn't even get hot, not at all. No hum noise whatsoever, everything sounds impeccable and drives effortlessly any small diy amplifier board. Highly recommended, the 4 stars due to the build quality of the of the copper winding of coils which is not at par with the rest of the board.
Julius v.
Nice cables for the price
Just buy these, they are perfect for the job!
Emmanuel D.
Très bon produit pour le prix
Très heureux de ma première journée d'écoute avec le LOXJIE A30 sur des Tangents spectra X5 et en source un Rasp3 ALLO DIGIONE.
Le mode Direct est correct malgré certains avis critiques.
Il réagit bien à ma petite playlist de test dans tout les styles (Dire Straits - Idris Muhammad - The Midnight - Recoil - Masaaki Suzuki).
J'ai débranché sans peine mon ADVANCE ACOUSTIC X-I60.
Merci Audiophonics pour votre réactivité.
Jean François N.
Jean François
Mis sur ma Thorens 147
Très belle fabrication à un prix raisonnable.
Plaque très bien le vinyle
Jean François N.
Jean François
Mis sur Thorens 147 en remplacement du plateau caoutchouc.
Améliore très sensiblement la qualité d'écoute.
Ne laisse pas de déchet sur la surface d'appui
Julius v.
Works fine!
Does it’s job. Doesn’t include a power adapter, but hooked it up to an old iPhone brick (1A) and an old Micro USB cable.
Julius v.
Great amp for great price!
Replaced a REGA amp, and the sound is so much clearer! Love this little amp!
Franck B.
A comparer avec les modèles de chez Hifiberry pour voir...
J'en possède une achetée ailleurs... et je suis resté sur ma faim.
Pour son prix, un simple dac, sans boîtier avec une telle fiche technique devrait faire bien mieux.
Il n'arrive même pas à la cheville de la sortie audio de mon macbook...
Une dynamic plate et une stéréo avec tellement peu de relief...
J'en garde un si mauvais souvenir que mon projet de faire de mon rasp une plateforme multimédia fut abandonné et je n'ai jamais pu le refourguer d'occase au passage (le dac).
Sinon il est bien fini et la fabrication semble de qualité, d'où la note moyenne, c'est froid et plat.
