Robert g.
Pascal H.
Jorge G.
Excellent for an Audio Research Reference 3
Excellent for an Audio Research Reference 3 as a PS tube driver, event better than Winged 6550C SED C. I don't understand why AR suplies 6550 Sovtek.
Thierry P.
Tout simplement parfait pour relier ma platine cd Marantz Cd 5005 à mon amplificateur Cambridge cxa60 .
Prix tout à fait raisonnable pour ce câble de très bonne qualité de fabrication et d'écoute.
Rune E.
works well
Does what it does. Quick delivery from France.
John B.
TOPPING P50 Regulated Linear Power Supply Ultra Low Noise 2x 5V 1A + 15V 1A Black This regular linear power supply Topping P50 offers excellent performance and allows a HiFi system to be powered properly and thus promotes the sound reproduction quality of the...
A worthwhile and affordable upgrade
I’ve been using Raspberry Pi and various HAT combinations for a few years around the house, in the bathroom, bedroom, garage etc. Powered from a selection of switching mode power supplies. No complaints, they sound fine. But for my “main” system I persuaded myself that I needed to upgrade. I am glad I did. I have removed all the switching mode power supplies from nearby and I am running an Audiophonics iSabre DAC and a Pro-Ject Phono DS2 Ultra from this Topping device. The improvement is tangible. The sound emerges from a quiet background and it has atmosphere and presence. Particularly enjoying the recent release of Bill Evans at Hilversum. I recommend this inexpensive upgrade. (Other components are - iconAudio 40i Stereo Valve Amplifier, ATC SMC11 loudspeakers, picoreplayer, Logitech média server.)
Prix dérisoire son nickel
Connecté entre une télé tcl et convertisseur musical fidelity ; impeccable pour le prix.
UN SANS FAUTE
Image fine et détaillée mais de façon naturelle. Prix très raisonable.
Une révélation
Je posséde plusieurs câble AES, après comparaison ce cable me donne vraiment Les meilleurs résultats ,on passe du tout venant a l'exceptionnel.Bravos Audiophonics pour cette réalisation au rapport qualité prix trés intéressant .
Diego D.
bonne rétractation
Diego D.
parfait bonne rétractation
Thierry R.
J'avais besoin d'un câble court, 50 cm c'est parfait pour moi, l'ampli étant juste au dessus du lecteur CD. Ce câble est effectivement très rigide, sans problème dans mon cas. Fonctionne parfaitement avec un IN200 Signature et un lecteur Marantz.
Un appareil à l'excellent rapport qualité/prix
Mise à part une livraison particulièrement pénible (près de 15 jours) due , parait-il aux conditions sanitaires voilà enfin cet ampli en service, couplé avec le DAC SONCOZ nouvellement importé par Audiophonics. Le résultat musical est absolument parfait pour ma part. La puissance est énorme et mon casque Focal Clear respire comme jamais . L'aigu est restitué avec finesse et sans agressivité , le grave est parfaitement tenu est puissant et le médium n'est pas en reste. Je suis intégralement en liaisons symétriques jusqu'au casque. Bref un bien bel appareil, certes un peu massif mais quand on voit la qualité de la construction on comprend mieux, et enfin le prix, même si 649 € ce n'est pas rien qui permet à de nombreux audiophiles d'avoir un appareil de qualité.
Thierry R.
Pratique
Cette alimentation me permet d'alimenter une chromcast, une chromcast audio et un switch. Le tout pouvant être coupé d'un seul coup plutôt que de rester alimenté en permanence. Elle est assez stable entre 5V et 5.2V. Parfait
Pierre B.
Module unbalanced to balanced symetrizer JRC 4580DD BTL stereo This audio module balances any HIFI-RCA-CINCH line-level asymmetric signal into a balanced-XLR signal independently and qualitatively. Equipped with quality passive components,...
Super rapport qualité prix.
Circuit imprimé et composant de qualité, bien monté. Audiophonics fourni trois connecteurs à visser pour les entrées sorties, on a donc le choix pour le câblage, super bonne idée, par contre pas d'entretoise ni visserie (un détail).
Les 5532 sont sur support j'ai fait des essais avec ces AOP et comparé avec des AOP 2134 il y a une légère amélioration mais rien d’impressionnant.
La carte est assez encombrante pas forcément facile à caser dans un boitier existant pour une réparation / mise à niveau.
Joao C.
JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 3.9µF Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a...
Amazing Seller - Super Fast + Great Price and Communication
I bought 2 Jantzen Alumen Z-Cap capacitors, and although I was expecting a real long time from France to Portugal, it was very fast, the capacitors arrived very well packed and fast. Not only it was the best price among all other sellers, the Audiophonics were impeccable, very fast answers and very polite and friendly, highly recommended, I'm a long term internet buyer and Audiophonics for their professionalism, speed and communication, are amongst the best I ever came across!
Alexandre D.
Petite boîte qui rend le service annoncé. Utilisé avec un Raspberry (MoodeAudio) pour envoyer du son sur le DAC d'un Marantz PM-6005, sans aucun problème. Je note pas différence de qualité avec la sortie Toslink d'un ancien PC de bureau que ce Raspberry remplace.
Reconnu nativement sous GNU/Linux, monte bien jusqu'en 24/192.
Sublimatissime
J’utilise un Dac R2R Audio-gd R8 , couplé à un ampli à tubes, des enceintes Tannoy et je diffuse du HI-RES Qobuzz, via le lecteur biperfect Audirvana…. et là déjà le son est grandiose.
Quand j’ai branché cette interface reliée au dac en HDMI, j’eu instantanément eu la sensation d’avoir changé de dac.
Comme si tout d’un coup mon dac s’était débridé.
Ce qui frappe en premier c’est l’image qui passe de stéréo à tridimensionnelle.
Ensuite c’est tous les micros détails que je n’avais jamais entendu, les aigus qui filent encore beaucoup plus haut, proprement.
Les basses qui sont encore plus articulées à merveille et j’entends à présent les reverb sur les basses.
Les silences sont d’un noir abyssal et sur les morceaux très complexes chaque instrument et sons gagnent en intelligibilité et finesse.
Une source HI-RES comme Qobuzz ou Tidal, un bon dac comme le R8 + cette interface, c’est du son very HI-RES avec les timbres analogiques.
A côté un simple Cd fait pâle figure.
Je ne suis pas assez technicien pour savoir ce qui se passe entre ces machines et leurs horloges Accusilicon respectives, mais ca se passe vraiment.
marc g.
expérience intéressante à mener
Disons le de suite: ce n'est pas de la Hifi. en revanche, si vous voulez épater la galerie en diffusant du son propre, voire très propre, sans qu'on sache d'où il vienne c'est bluffant. Pas de réelles basses, un rendement tout à fait déplorable, et un objet fragile. Voilà pour les inconvénients. Mais c'est idéal dans des applications originales: HP dans la salle de bains, remplace avantageusement une horrible barre de son, voire si on en met plusieurs, sonoriser une grande pièce pour répartir le son. ATTENTION: coller sur surface plane obligatoirement. après essais, le mur en placo marche très bien, le bois massif un peu moins, la pierre pas très bien. De toutes façons, il faut une surface qui résonne. Amusez vous bien!
Nicolas C.
WONDOM AA-AB31282 Mono Amplifier Module Class D T-Amp 1x200W 3 Ohm The Wondom AA-AB31282 amplifier is capable of delivering 1x200W of mono power under 3 Ohm. This substantial power reserve allows this amplifier to be associated with demanding...
Parfait!
Alimenté sur batterie en 32v cet ampli tient ses promesses: sur un sub de 8" il sait donner de la voie sans que la distortion se fasse entendre. L'efficacité semble être au rendez vous: il chauffe peu et les batteries durent plus longtemps que ce que j’avais calculé. A recommander!
Rousset O.
feutre et bitume grande qualité
Très bon produit, la couche de bitume est pas mal du tout et rigidifie bien les parois de l'enceinte, le feutre est très absorbant. J'ai disposé ces bandes de feutre tout autour du haut-parleur dans l'enceinte. Le résultat sur l'écoute est bluffant, plus aucune résonance. Par contre l'épaisseur est importante c'est difficile à couper, on ne peux pas tout avoir :).
Kristijan K.
Great sounding tubes
I am using these tubes on all three of my FX-Audio Tube-03 preamps and they sound great. Tried Chinese 6J1, 6K4, Russian 6J1P-EV and 6ZH1P-EV but these tubes definitely stand out above the rest. Way above the stock tubes. Excellent bass, details, wide and deep stage, great separation, warmth. But they definitely need some burn-in (I would say 20-30 hours at least) to eliminate the distortion that can occur in the lower frequencies (bass) when they are new.
Diego D.
qualité
bonne souplesse, soudure facile
Diego D.
TINYSINE AUDIO-B PLUS Bluetooth 4.0 Receiver Module If you want to build a Bluetooth amplifier simply and stream your music from your smartphone, then the TinySine Bluetooth AudioB Plus receiver module is an excellent choice. It...
simple et conforme à la description. qualité audio appréciable
Angelo B.
A real surprise, Khadas
The Khadas returns a perfectly neutral sound (no hum), ideal for audiophiles who like me seek definition without compromise (tested with Schiit Modi Multibit V2 chip). I recommend this highly prized DAC to all those who are very demanding in the world of high fidelity. I thank David who is always quick to reply to e-mails, but above all very competent in technical advice, and also very careful to offer very good quality products at fair prices. Thanks Audiophonics!!
JEAN-LUC F.
Fonctionnel et efficace
J'ai fait l'acquisition de cet ampli afin de pouvoir rattraper un kit 2.1 (Gigaworks T3) tombé en rade. Il fait le job et bien câblé, il me permet donc de réutiliser les satellites et sub de Creative. Néanmoins, je trouve qu'il chauffe un peu, et malgré les 96W de l'alim, je n'ai pas l'impression d'avoir récupérer la puissance que j'avais avec les originaux. Pour la qualité du son non plus. Pas de mode d'emploi en effet pour le réglage des différentes plages, même si j'ai tenté de le faire à l'écoute.
Bref, un boitier qui fait le travail et qui permet de ne pas jeter votre kit si jamais son électronique tombe en panne.
franck C.
WM AUDIO CS-320 Female RCA Connectors Gold Plated Ø6mm (Pair) These good quality and low cost female RCA connectors are ideal for designing RCA extension cables. Their 24k gold plated contacts ensure very good signal conductivity and...
facile à souder bonne connexion, j'ai mis que 3 étoiles car en comparant avec la photo sur le site j'ai aucune bague de couleure pour les distinguer. mais trop tard elles sont souder. C'est au moment de brancher que je me suis aperçu qu'il n'y avais pas de bague de couleur j'ai dans le colis rien trouver à savoir qu'ellles n'étaient pas dans un emballage à part mais en vraque dans le grand colis. J'ai eu beau fouiller retourner le colis les différents pochons mais rien pas de bagues. Oublie ou ...
Arnauld B.
Arnauld / L'émotion par la Hi-Fi
Bon,
Je dois dire que c’est assez troublant :)
Après deux semaines d'écoute, je ne me lasse pas.
Nina est là, Mark est là, Agnès est là, Lou est là, Fink est là, Serge est là, Oscar est là et tout l’orchestre d’Hans aussi. Forts de leurs émotions et de leurs timbres.
Avec une précision et une netteté incroyables.
Les mouettes des the XX sont dans la maison et je demande aux gens qui hurlent sur le vanishing act live de Lou de se taire. (ÉNORME).
Troublant car cet appareil coûte le prix d'un cable pour relier mon DAC à mon Ampli pure Class A (très sérieux tous les deux)...
Bref, downsize de prix, de l'encombrement, mais pas du plaisir.
Je découvre les capacités de mes enceintes (Von Schweikert VR4Jr). Très neutres et très étendues.
Son préamp Phono et sa sortie casque paraissent au niveau (peu écouté encore).
On oublie la hifi classique, sa tech, sa façade alu ostentatoire, les gros boutons, le poids, pour savourer un plaisir frais et net de ce petit boitier bien dessiné et pur.
On ferme les yeux et on savoure ce son ultra-précis.
Tellement précis, que la source doit être impec (enregistrement, mastering pressage etc.).
Tellement fidèle que parfois, çà frotte un peu, exactement comme en présence d'un violon, d'un piano ou d'une trompette en live!
Les basses semblent infinies mais ne couvrent pas le triangle.
Les infos reçues permettent à mon cerveau de recréer une bonne spécialisation. La batterie de Melody est au bon endroit :)
Bref, un ampli pour ceux qui n'ont pas envie de mettre de la crème de cassis dans du gevrey-chambertin en disant que c'est plus "doux".
Seuls légers bémols :
l'interface est un peu déroutante avec toutes les options de sur-échantillonnage et de traitement des basses, inutiles avec une bonne source et de bonnes enceintes...
Et l'écran inscrit en gros la source ou le logo Hi-Res (vraiment inutiles) et pas le volume sonore par exemple...
Et la taille mini des connecteurs enceinte. Pas super pratique.
Mais ça ne mange pas une étoile pour ce produit troublant de rapport valeur émotion / prix.
Je découvrirai un jour un produit qui le dépassera, mais rien que pour sa manière de mettre les pendules du son à l'heure, je suis très content de cet achat.
Nicolas r.
Bons câbles
Qualité de fabrication irréprochable.
Nicolas r.
AURALiC ALTAIR G1 Hi-Fi Streamer DAC 32bit 384Khz DSD512 AES/EBU Femtoclock Black True high fidelity HUB, the Auralic ALTAIR G1 combines the functions of streamer, DAC, preamplifier. It delivers a breathtaking audio reproduction with flawless ergonomics.
On frôle ici la perfection !
Commandé un jeudi en milieu d'après-midi et reçu le samedi matin. Qui dit mieux ? Chapeau bas à l'équipe Audiophonics !
Superbe appareil magnifiquement assemblé. De l'emballage à lecteur lui-même en passant par l'application, tout respire la qualité. Cela faisait des années que j'étais à la recherche du lecteur parfait. Je n'en ai pas essayé beaucoup mais je crois bien désormais l'avoir trouvé ! Tout y est bien pensé et bien fait. Si vous avez le budget alors n'hésitez pas une seconde. Vous allez redécouvrir vos musiques préférées ! Le seul petit nuage dans ce ciel bleu azur est l'absence d'une entrée IR arrière qui m'aurait permis de l'intégrer à ma télécommande universelle. Pas de drame toutefois, la qualité est tellement au rendez-vous que ce petit détail est vite oublié !
L’Altair G1 dispose de la fonction SmartIR (avec un capteur IR en façade) qui permet de programmer n’importe quelle télécommande du marché via le menu de configuration en façade.
Patrick G.
alimentation audiophonics lpsu25 220V vers 5V
branché au DAC sankrit 10 th anniversary:plus de naturel,de transparence et belle image;un plus evident;merci audiophonics.
Karl R.
Do what they're supposed to.
Not much to say. They're firm plastic feet that are easily glued to your device of choice.
Bernard L.
AC adapter 100-240V AC to 12-24V DC + 8 Jack adapters If you find it difficult to find a power supply that matches your device, or if it is no longer available on the market, this power supply with a universal adapter will make...
À éviter. Alimentation instable et bruyante
Le bruit généré par cette alimentation est extrêmement audible et déplaisant. Deux exemplaires commandés, deux comportements similaires. Bruit de distortion électrique très fort transmis dans l'amplificateur, non filtré, différent pour chaque voltage, et augmentant en intensité proportionnellement au voltage. INSUPPORTABLE !!
Philippe F.
XDUOO XQ-50 Bluetooth 5.0 Receiver aptX QCC3008 DAC ES9018K2M xDuoo offers with its XQ-50 a Bluetooth receiver with integrated DAC very practical, qualitative and affordable. It will allow you to stream your music directly from your...
Manifestement un bon produit
Facile à installer (en RCA stéréo sur le vieil equalizer associé à mon ampli Yamaha). Connexion très stable depuis mon PC, même à plusieurs mètres avec des obstacles occultant complètement l'angle de vue. Une led "HD" s'allume quand le codex aptX est utilisé. Finition flatteuse. Quant à la qualité du son, je ne peux guère en juger, les sources que j'utilise n'étant en général pas très bonnes.
Stephane M.
Beau produit
Accepte fourche, banane, cable nu.
La connexion interne peut être soudée (prevoir un fer puissant) et ou vissée.
Stephane M.
DYNAVOX NC5 Carbon Fiber Brush for Turntable Needle The carbon fiber brush Dynavox NC5 removes diamond dust from the needle of your turntables. An ideal tool to maintain the needle of your turntable but also to eliminate dust...
indispensable
Permet de nettoyer votre pointe sans avoir recours à de l'alcool isopropylique qui peut s' avérer dévastateur sur certaines suspension de cantilever.
Stephane M.
L'isolant ne se déforme pas pendant le soudage.
Connexion et déconnexion facile avec les Amphenol Audio ACPR Connecteur RCA que je recommande également.
Stephane M.
Bonne surprise
Plutôt robuste et bien fini pour le prix.
Les faces latérales peuvent être retournées ce qui ne nuit pas à la présentation (au contraire même) et permet de gagner quelques milimetres de largeur utile pour integrer un PCB.
Une jolie petite plaque en laiton ou plexy sur la facade et vous avez une présentation "pro"
Rémi H.
WONDOM AA-JA32472 JAB2-30 V2 Class D Stereo Amplifier Module Bluetooth 5.0 DSP 2x30W 8 Ohm Here is a versatile Bluetooth 5.0 Stereo amplifier module that delivers 2x30W with 8 ohms load. It belongs to the JAB series that offers amplifier modules for mobile use.
Très bon produit.
J 'ai utilise cette carte pour la création d'une enceinte 2x30 watt. elle fonctionne très bien sur alimentations secteur et batterie, pas de parasite ou bruit, Bluetooth fonction bien. Le son est très propre. J en suis très satisfait.
Jesse D.
Matériel de très bonne qualité, lourd avec un bon grip.
Du plus bel effet sur mon ampli a tubes.
Proposé a un très bon prix.
Jesse.D
Rudolphe D.
Pas prévu pour utilisation hifi
Bas médium et grave court avec un manque de délié et relief évident en comparaison avec d'autres câbles
Alain D.
Produit conforme.
Après plusieurs recherches sur d'autres sites, j'ai trouvé mon bonheur.
Reçu rapidement.
Jean-Marc A.
DYNAVOX RCA Stereo Cable OFC Copper Gold Plated Connectors 1.5m This Dynavox RCA cable incorporates a 99.99% purity OFC copper conductor to ensure excellent audio signal conductivity and ensure that your system is soundproof.
Livraison très rapide et conforme à la commande. Ce produit est visuellement de qualité et bien réalisé. L'aspect est de bonne qualité, l'écoute pour un câble de ce prix est excellente. Je conseille le produit.
Jean-Marc A.
LINDY CROMO LINE Male USB-A / Male USB-B 2.0 Cable Gold Plated 0.5m The Cromo series is the most powerful USB cables manufactured by Lindy. This one relies on a well thought out design and oriented towards a technical reality, to meet a need for...
Câble USB Audiophile
Livraison rapide et conforme, la différence à l'écoute par rapport à un câble USB Classic et surprenante pour un petit bout de fil de 50 cm. Je conseil.
Pascal B.
A la hauteur de mes attentes
Très facile à assembler, le guide d'installation est très bien fait.
La qualité est au rendez vous. Le boîtier est solide, les composants sont de belle qualité visuelle aussi.
A l'écoute c'est parfait. Il est branché à un Sansui AU5900 avec des Yamaha NS360. Et le résultat est superbe. C'est vif, dynamique, précis. Très propre aussi. Mais surtout ça ne tombe pas dans le chirurgical, ce n'est jamais fatiguant.
En bref je suis ravi. C'est un appareil au service de la musique. Il sait se faire oublier. C'est ce que je cherchais donc c'est parfait.
Didier B.
Très bon produit de grande qualité impressionné part le poids je conseille vraiment
fiole magique !
Ce précieux "élixir" pour contacts rend la restitution plus naturelle. On entend tout mieux, tout simplement. Le son est plus riche : plus de matière, plus d'aération, plus de précision dans l'image stéréophonique, les petits détails qu'on entendait pas ou peu deviennent évidents mais sans "effet loupe". C'est particulièrement évident sur les voix. Certes, le prix est élevé mais on en utilise très peu à chaque traitement.
Antanas k.
Antanas
Great cable in terms of price and quality. Thank you Adiophonics.
franck C.
pour info
attention à utiliser un fer à souder d'au moins 60w minimum si non vous allez galérer.
franck C.
MUNDORF L140 Air Core Coil 1.4mm 0.15mH Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this...
trés bien sur mes aigus
que demander de plus. Je m'aperçois en fait que mes selfs d'origine étaient bien fatiguées. j'ai l'impression après avoir refait le cablâge en interne et changer toutes les selfs, condos et résistances de retrouver mes colonnes comme neuves.
franck C.
MUNDORF L140 Air Core Coil 1.4mm 0.33mH Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this...
bien
sur un filtre pour médium que du bonheur en remplacement des vieilles selfs d'origine de 1980 de marque audax qui étaient le must à l'époque. plus de détail et un gain en plus.
franck C.
géniale
celles ci sont utilisées juste avant les médiums aigus, redonne du gain et du détail à recommander
