Peter B.
Recomendded!
Edwin P.
Zywno H.
Perfect!
Fast delivery, wonderful DAP.
I strongly recommend!
Customers reviews - There are 19156 reviews.
je suis bien d'accord avec Franck P se préampli phono rest vraiment extraordinaire le tube monté dessus n'est certainement pas là pour faire joli je conseillerais simplement de changé le tube d'origine chinoise qui lui effectivement n'est pas terrible par un tube NOS us ou européen pour le transcender et cerise sur le gâteau on peut même remplacé le tube 12AU7 par un 12AX7 .
avec ma cellule bleue point EVO III MC 2,5mV il fait des miracles!!
A bon entendeur...
Istvan M.
SUPTRONICS X20-DAC DAC Module I2S RCA ES9028Q2M 32bit 384kHz 1x AOP NJR MUSES 8920 This X20-DAC module will allow you to benefit from a very powerful DAC with I2S input, while being compact. Thus, you can upgrade your DIY audio system based on a Raspberry Pi...
X20
Although they are still maturing, they have a very nice sound, high quality Dac panel. Easy to install. It deserves better coupling capacitors, say Elna Silmic. Unfortunately, the Volumio IS2 DAC is not listed or officially supported. Identifies Hifiberry as DAC. But it still works. It is a question of making the most of its potential. Moode, on the other hand, supports it.
Istvan M.
SUPTRONICS X10-PWR Regulated Linear Power Supply Module for X10 / X20 Modules This X10-PWR module will allow you to enjoy a quality regulated linear power supply to power the other modules of the X10 or X20 series and your Raspberry Pi. A set of modules...
X10-PWR
Very good panel, but it's a shame that it's not ready for full service on the Raspberry pi 4, even though it's been available for over half a year. A 5.2 V branch instead of 2.5 A would be good if you knew 3 A. Still maturing, but very promising.
Jacques D.
Prof
Excellent amplifier at a *very* good price. I've seen amps built around the same Hypex module selling for hundreds more. Speedy (1 week) delivery to the USA.
Pas mal
Module compact, belle réalisation, facile à alimenter, fiable en liaison BT, facile d’appairage, bruit de fond pas trop important bien que présent dans le silence.
Par contre la sonorité est assez sourde, des graves riches (un peu trop ) et des aigus trop étouffés.
Je vais essayer de trouver mieux.
pourquoi s'en passer
Augmente considérablement la portée de mes récepteurs BT.
Le connecteur fonctionne parfaitement.
Alors vu le prix pourquoi s'en passer.
Trés content
J'ai déjà parlé de ce module plus haut, ce doit être le 5eme que j’achète, donc tout va bien.
LED Fuse Lamp Warm White for Vu-Meter / Tuner 6.3V This 3 LED shuttle light bulb emits a warm white light. Ideal for illuminating the meters of a HiFi device or as a replacement for a defective bulb. This one is powered by 6.3V
C'est parfait
Très bonne luminosité, mème un peu forte pour moi (je mets une résistance en série pour la chuter un peu)
éclairage à 180° température de blanc chaud, et comme elle ne chauffe pas on peut mettre sans soucis un correcteur de tinte collé dessus.
Pangea Audio génial
Un adaptateur haute gamme très utile est pratique robuste de plus fait partir la gamme Vincent Audio audiophile super produit année 2020 merci !
Constantin C.
Metallic sound!
If you like metallic sound with a lot of details this is for you.
AUDIOPHONICS DAC I-Sabre ES9038Q2M sounds 10 times warmer without this reclocker.
Nicolas G.
Tissu acoustique
Très déçu par ce produit, tissu de très mauvaise qualité. Le prix élevé suggérait une bonne qualité..., il n'en ai rien. Il y à beaucoup mieux ailleurs.
Le grand gagnant
Durant ces quelques mois j'ai testé plusieurs tubes de puissance et le grand gagnant est à mon gout ce Tung-Sol El 34B
Le Shuguang Treasure 6CA7-Z est trés typé Jazz, cordes et voix, avec une tendance à donner un son un peu sirupeux sur certains médiums (voix), mais trés beaux graves.
Le PSVANE 6CA7-TII MARK II  est la copie du Shuguang Treasure 6CA7, crée par d'anciens cadres de chez Shuguang. Son identique, mais gros bémol, j'en ai claqué 2 et sans raison..
Le Tung-Sol El 34B est mon préféré. Ni top ceci, ni trop celà.
Absolument neutre sur tous les registres. Tous les genres musicaux passent et trés bien.
Du plus aigu, aux basses les plus profondes, le rendu est superbe. Les voix sont trés naturelles aussi.
Trés dynamique et répond au quart de tour, comme s'il avait beaucoup de couple.
Le tube se fait oublier. Je ne lui trouve aucuns defaults.
Base d'écoute:
Qobuzz HI-Res
Audirvana +
Dac Audio-gdR8
Enceintes Tanno précision 6.4
Gaine Tressée
Bons résultats
habillage des cordons de modulation impeccable
jf a.
très bon rapport qualité/prix
pas de pilotes nécessaires sous GNU/Linux ou windows 10, pas besoin d'alim extérieure, et un vrai plus pour driver mon beyerdynamic 32Ohm.
Marc V.
Excellent value for money
This is a great unit which, when combined with audio grade power cables, will deliver clear improvements in sound quality. In my setup the soundstage, imaging, detail and base control clearly improved. The results will depend on your equipment of course.
The unit has excellent overall build quality and is delivered with clear instructions.
I have Just 2 remarks:
1. My audio grade power cables fit a bit loose in the power plugs. Maybe the problem is with my cables...
2. For optimal result, you should replace the standard power cord delivered with an audio grade power cable a well. I did this and the improvement is clearly audible. This is obvious and it should be mentioned in the description. Even better, an upgraded power cord should be offered as an option.
Hello,
Power cables are available as accessories for this product.
VIABLUE Splitter NF-S1 16x12 to 2x8mm The splitters commonly used for ViaBlue cables prevent the ends from breaking while providing professional and well-designed guidance of the individual conductors.
Splitter Viablue
Un peu cher mais done un look très pro aux cordons de modulation
Denis E.
Encore ...
Lire mes précédents avis: j'en ai acheté, j'ai recommencé et le referai ! Rapport qualité / prix parfait. Contact excellent : la juste mesure entre la bonne fermeté et la fiche qui détruit la borne ! ;))
Emballage parfait + livraison en 72h
Denis E.
Esthétique et qualité
Facile à mettre en oeuvre moyennant un système "d'aiguille". beau résultat à bien lisser. Attention à ne pas fondre la tresse en posant la gaine thermorétractable de finition car la température de fusion est vite atteinte.Transforme un bête câble en objet de luxe ;) Emballage impeccable, livraison en 72h
Denis E.
Du costaud
Un peu difficile à mettre en oeuvre du fait de l'épaisseur du matériau mais résultat parfait avec la colle intégrée. Très rigide une fois refroidi. Emballage impeccable et livraison en 72h
Denis E.
Résultat Impeccable
Se rétracte bien et vite au pistolet à air chaud. Jolie finition pour des câbles d'enceinte. Emballage impeccable et livraison rapide (commande le dimanche; dans ma BàL le mercredi).
martyn w.
Superb!
Based on the few reviews I could find, I decided to go for it. SO pleased that I did. Great sound and solid build. Brings me closer to my favourite music than anything I can recall, including my old Ayre AX7 e. Soundstaging, detail and punch, all there in crystal clarity. Highly recommended. Great service from Audiophonics too.
Kit Câble RCA
Bonne affaire, acheter le matériel séparément revient à plus de 72€
Il faut procéder avec soin pour montrer les RCA
Qui sont trop petites et fragiles de mon point de vue.
Premiers essais ; câble assez mât sans être plat
Il me semble qu il enlève un peu de brillance au son
Pas forcément négatif avec un DAC analytique ES9018 et ampli à tubes....
Connecteurs RCA
Bel aspect extérieur...
Mais Fragile
Très voir trop compact
cela laisse peu de place pour les soudures (surtout côté blindage !!)
(Le corps de la prise à visser limite encore la place dispo )
de plus la fiche encaisse moyennement la chaleur du fer à souder et se degrade rapidement au fil des soudage/desoudage (pin central qui bouge, jeu sur cosse de masse)
J en ai détérioré une (entièrement de ma faute !) en utilisant une pince plate pour tenir le point froid tout en vissant le corps de la fiche
Le câble se fixe avec une mâchoire métallique, j aurais préféré une vis avec meplat
Le câble réalisé avec fonctionne cependant parfaitement
À l'occasion j opterai pour des connecteurs plus 'lourds'
Didier G.
Rapide, conforme à mes attentes et au meilleur prix
Fonctionne avec une télécommande "Logitech HARMONY 655", sur une "Freebox révolution". ATTENTION, sur le configurateur "Logitech", il faudra sélectionner "Alice TV - L-HD03A" et pas "Freebox révolution"
Ron P.
Ron
Works fine I had the image Volume 2_20180326_2.3.89_ raspD i get for free from Audiophonics
Only delivery time was bad Orderdate 11Th Jan Recieve 25Th jan
Xavier B.
Excellent Rapport qualité prix
Petit préamp qui fait bien le job, pas un souffle.
Meilleurs en mode sans correction, notamment dans le registre des aigus qui dans mon cas sont bien meilleurs sans la correction, même potar à fond.
Pour le prix excellent, manque peut être un peu de définition mais à 54€ difficile de faire mieux .
Georges B.
Pied caoutchouc
Utilisé pour une ancienne platine vinyle MIcro Seiki dont les pieds se sont affalés avec le temps(40 ans). Impeccable,la platine a repris du service,pieds très stable et amortissant.
Georges F6goz
Georges B.
Bouton Alu Massif
Très bonne qualité ,je m'en sers pour un encodeur numérique sur mon transceiver de construction maison,l'emplacement du doigt sur le bouton permet de tourner très vite pour la recherche de stations par exemple.
73 de F6GOZ
www.gozgeorges.fr
Énorme !
Un câble de très grosse section, lourd et assez rigide. Il faut le brancher à des appareils aptes à supporter son poids. Quant au son, tout simplement meilleur. Ne pas se priver..
Simple, beau et efficace!
Un beau boitier, des connections par le dessus très pratiques. Attention avec les gros câbles secteurs lourds, il a tendance à basculer. Quant à l'essentiel, il apporte de la sérénité et améliore sensiblement l'ouverture sonore par rapport aux multiprises classiques. Il manque un testeur de phase dans la boîte pour être parfait.
Et la musique respire !
Damien F.
Très bon ampli / Dac
Grande qualité de fabrication, bonnes finitions, taille mini rikiki pour une intégration au top, télécommande fonctionnelle ( à l'instar du SMSL AD18 ).
Uniquement utilisé avec le service de streaming Deezer Hifi et branché en USB sur PC Windows 10, je profite du DAC intégré réglé en 16 bit 44100Hz.
J'apprécie beaucoup le rendu sonore avec une paire de colonnes Triangle Zerius 902 ainsi qu'un caisson de grave DIY ( HP Magnat 30cm - Ampli classe D Klipsch ), le tout dans un salon de 21m².
La perception musicale étant personnelle et subjective, je ne rentrerai pas dans les comparaisons d'audiophiles. Je n'ai pas les moyens de m'offrir du matériel High-end et je ne m'y intéresse pas. Je laisserai le soin aux "spécialistes" de s'en charger dans les futures commentaires.
J'aime me faire plaisir musicalement, cela passe par le fait de pouvoir faire évoluer mon matériel quand j'en ai envie.
Pour 140€, tout est appréciable dans cette petite machine, qui, rappelons-le, n'a pas de concurrence directe avec du matériel vendu dans les boutiques classiques ayant pignon sur rue.
Damien F.
Pour un câble vendu 10 euros, il n'y a vraiment rien à reprocher.
Joel B.
Prix compétitif, livraison rapide et jolie couleur bleue claire pour cet article parfaitement adapté aux vu-mètres de mon ampli.
didier S.
excellent !
ce petit boitier fait de la musique ! présence limpidité, placement, justesse, espace .... si vous cherchez la transparence , avec lui vous la trouverez ! associé à des câbles et des éléments de qualité il va ravir les mélomanes ! l'astuce est effectivement de l'alimenter en externe grâce au cordon et l'alimentation appropriés.
ifi Audio iPOWER Adaptateur secteur / Alimentation Audio faible bruit 5V 2.5A
Câble adaptateur USB-B pour alimentation Jack 5.5 / 2.1mm Femelle
Christian H.
SUPER PRODUIT
Conforme au descriptif et à mes attentes.
Livraison rapide.
Très satisfait du produit et du site !
Chouette petit module
Très bon module pour entrer en I2S dans un DSP. Je l'aurais noté 5 étoiles, si les embases RCA étaient de meilleure qualité, voir carrément absentes.
Et avec la possibilité d'insérer soi-même des embases qualitatives, avec les bons pas, comme des WBT-0234 par exemple.
Anders L.
Best solder
By far the best solder I've used. Flows very well without the need for additional flux.
Anders L.
Superb wire
I used this wire as internal speaker wire for an amplifier. I chose this diameter because it fit the holes in the circuit board. The results were very good with a detailed and balanced sound. As a backup plan I was going to use a thicker wire an drill wider holes but this was unnecessary.
Anders L.
Excellent value
I used these to replace old style speaker posts (nickel/steel) on an amplifier. The results exceeded my expectations. A big improvement in sound and usability. A very cost-effective modification. These posts are quite large and heavy, which was right for my amp.
jean claude O.
Impressionnant
Je l'ai branche sur mes cabasses jonques (colonnes d'entrée de gamme de cabasse dans les années 90) ça marche vraiment bien, je retrouve les qualités de clarté de ces enceintes dans le haut du spectre. Pour les basses, cet ampli leur fait sortir tout ce qu'elle peuvent sortir, ça descent pas très bas mais tout ce qui sort est très propre. Côté ergonomie, faire toutes par un seul bouton rotatif n'est pas ce qui se fait de mieux, mais on s'en contentera en pensant à l'exceptionnel rapport qualité prix de cet ampli.
Daniel G.
5 *
Comment dire... bluffant, et je ne parle même pas de prix.
Écoute sur Spendor S100 / VTL 75-75, système qui ne pardonne pas grand chose.
De quoi remettre en cause pas mal de certitudes sur le matériel haut de gamme, quand on entend ce que ce petit engin est capable de produire.
Franchement, pourquoi dépenser plus, d'autant qu'en jouant avec les tubes (d'origine pas mauvais du tout selon moi), on peut encore améliorer (modifier?) le rendu.
Il timbre merveilleusement (porté sur le médium dit on mais je n'ai pas trouvé), belle spacialisation, tenue des basses typée FDA, personnellement j'aime bien.
Après, pour qq centaines d'euros voir quelques milliers, on aura un tout petit peu mieux, peut être, et encore, même pas sur...
Mieux vaut investir dans d'excellentes enceintes ainsi que dans un ampli apte à les tenir, encore que sur ce point il semblerait que les chinois soient en train de faire bouger les lignes.
Jean-Philippe C.
Efficace mais simpliste
Sonorité et boîtier de qualité. Simpliste
Manque tout de même un bouton on/off!!! Portée 10 m maxi. Pas dit qu il fasse mieux que certains appareils sur batterie. Rapport q/p moyen.
frederic D.
Interconnect Cable Female XLR - Male XLR 1m CANARE L-2E5AT White This XLR cable, although sold at an affordable price, offers a very good quality design. Its Canare cable integrates two copper conductors and a drain to efficiently transmit...
cable xlr
cable utilisé en liaison pre/ampli, il délivre un son qui me parait neutre et qualitatif c'est tout ce que je lui demande.
remi p.
haut parleur TECTONIC BMR TEBM35C10-4
haut parleur de tres bonne qualité , et adaptable sur enceinte bluetooth JBL charge 3 , meilleur son qu'avec les haut parleur d origine et ne sature pas , je recommande
Barrie G.
Perfect replacement.
Used to upgrade the ageing drivers in a pair of Optimus Genexxa LX-5 speakers and they were a perfect fit. They also sound much better with a clean strong bass with no distortion to high levels.
Adrian W.
Killer cable
Beautifully full open ,sweet cable with solid bass,no part of the frequency spectrum is out of place,all presented in a cohesive whole,things appear out of the mix with astounding clarity,but unforced and naturally placed ,just outstanding quality....this occ cable is well made and very affordable when you consider what is on the market,what matters most is its musicality fast open clean clear warm and very addictive ,this cable just sounds right ,one word of caution do change the brass plugs for pure copper ones to get the very best ,i upgrade the banana plugs for the ramm audio Tellurium copper gold plated plugs and it just made a great cable even better....For me the search is over and now my pmc speakers sing freely with these cables .....highly recommended .Zavfino have achieved what they have set out to do with this cable GREAT STUFF.
Adrian W.
Quality
I have tried various plugs and have found Tellurium copper plugs to be the best sounding ,these plugs have a naturalness to them and transmit the sound with ease ,i upgraded the plugs on my Zavfino prima loudspeaker cables with these beauties which made a great cable even better,no brainer buy with confidence sit back and enjoy your music
Serge J.
Borne de masse
Très bon produit conforme à la description.
Francisco Javier R.
Produit de qualité
Parfait pour souder directement les AOP
