Dominique R.
Hautement recommandé
Dominique R.
Marc J.
Customers reviews - There are 20174 reviews.
antonino a.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 39µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
very very good
antonino a.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 22µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
very very good
antonino a.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 18µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
very very good
antonino a.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 1.8µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
very very good
antonino a.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 1.5µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers.  Made in Europe, this new competitor of the...
very very good
antonino a.
very very good
François C.
PANGEA PREMIER SE BALANCED XLR Modulation Cable Balanced 0.6m (Pair) PANGEA cables benefit from technologies rarely encountered in this range. An excellent alternative to the market leaders offering high quality affordable design, the first...
Très bon câble de modulation tant en qualité de fabrication qu’en restitution totalement transparente.
arnaud b.
Marche correctement.
RAS
arnaud b.
Conforme. RAS
François C.
SMSL M300 DAC AKM AK4497 XMOS Dual NDK Clock 32bit 768kHz DSD512 Red The SMSL M300 is a powerful and compact DAC in an atypical format. Integrating high quality components, it is the perfect ally to offer your HiFi audio system a...
Reçu le MKII à la place de celui-ci, incluant donc une télécommande et une alimentation dédiée qui a le mérite de libérer la prise micro usb. Le MKII perd en revanche une entrée en fusionnant optique et spdif en une seule jack / optique.
Cette première mouture est donc à choisir en fonction de ces critères : quelle entrée privilégiez-vous ?
Optique + coax (par exemple lecteur réseau + CD) : prenez celui-ci.
Usb (PC, ou NAS) ? Prenez le MKII.
Musicalement, pour ceux qui ont un DAC ou un ampli Hi Fi équipé du déjà excellent DAC AK 4490, cette évolution en conserve toutes les qualités. L’ajout de ses 6 filtres ne modifie pas la restitution de façon décisive.
arnaud b.
Fait le job.
Bon choix de différents diamètres.
arnaud b.
RAS
Bon produit même si la partie métallique pourrait être de meilleure qualité (matériaux et usinage).
arnaud b.
Conforme et respire la qualité.
arnaud b.
Câble un peu trop rigide
Fait le job.
arnaud b.
Tôles épaisses. Revêtement solide.
Bon produit même si la notice n'est pas très explicite. Attention aussi, ne pas hésiter à prendre la plaque perforée du fond en OPTION...
arnaud b.
Bon rapport qualité/ prix
RAS
arnaud b.
Conforme. RAS.
Stratos P.
Amazing
It was smaller than expected. The dac does its job and does it well. I have a pc with a lot of noice coming out of the usb, this dac made the pauses completely silent.
Sébastien w.
bon produit .
l' image et le son, largement de meilleur qualité qu'un câble standard .
pas besoin d'être un pro pour le voir .
Didier R.
Livraison et produit parfait
Sébastien w.
j' aurai pas cru que petit morceau de câble ferai un tel change sur le son sur une installation audiophile . La bande passante plus nette , le son plus mieux équilibré.
ce câble donne un son plus chaux .
Sébastien w.
qualité prix imbattable .
très bon produit fait son travail comme il faut .
pas besoin de payer plus chère .
Gilles G.
support un peu léger
L'aspect céramique et doré de ce support octal est attirant, mais dans la réalité sa constitution est assez légère. Le bloc céramique est correct mais les pièces métalliques sont de faible épaisseur et de ce fait lèvent un doute. Les cosses ont tendance à sortir de leurs logements, il faut les vriller légèrement pour les arrêter. Il est possible que la tenue dans le temps soit aléatoire, surtout pour les contacts avec les connecteurs de chauffage (sous 1 A) qui risquent de s'oxyder et par suite d'entrainer une panne. Sinon la fixation est classique et le soudage facile.
Sébastien w.
Bernard g.
Bluffant sur des enceintes colonnes
j'ai acheté ce produit sans trop de conviction mais en me disant que ce serait plus efficace qu'un bout de métal.En fait le résultat sur mes enceintes colonnes est bluffant : plus de basse et élargissement de la scène sonore.Je suis très satisfait de ce produit.A recommander sans modération.
Isolant
Livraison rapide et conforme
J'utilise ce produit comme isolant dans la carrosserie automobile, pour éviter les bruits de résonance, très bon résultat
HIFI 2000
Boitier très simple, robuste et facile à travailler.
Il ne paye pas de mine mais une fois terminé, il a un look super vintage.
Borniers audiophonics
Borniers de bonne qualité, robustes et simples
Yannick S.
Transparent, simple et efficace pour de la multi-amplification. Exactement ce dont j'avais besoin.
Frederic H.
Pas tout à fait neutre
Testé et comparé à d'autres câbles abordables en modulation RCA , j'ai trouvé le L4E6S coloré.
C'est vrai qu'il est plutôt doux et assez définis dans l'aigu , mais il y a une chaleur assez systématique dans le bas médium, voir de la lourdeur...
Serte , c'est assez agréable mais pas tout à fait neutre
Peut convenir avec des électroniques un peu sèches ou montante
Pierre F.
Preamp tube
Marche très bien et silencieusement.
Emmanuel T.
Très très bon... donc très content ! :)
J'ai acheté cet ampli-dac sur ce site début Septembre 2019, j'ai donc 8 mois de recul pour donner mon avis.
Il alimente des Magnepan 1.7 (rendement de 86 db et impédance de 4 ohms) dans un salon de 14m2, les doigts dans l'nez !
Je suis toujours autant sidéré de la facilité qu'il a à les faire chanter sur n'importe quel type de musique et l'association des 2 marques me donne le plus de plaisir sur la musique classique, le jazz ancien ou moderne... avec énergie, avec douceur, avec finesse et tout le temps avec musicalité.
Même sur les films (en 2.0), je ne me pose aucune questions tellement il colle aux effets sonores avec justesse, le réalisme est bien là.
Bref, soyons très clair, le rapport qualité prix est vraiment de haut niveau : aucune frustration, aucun regret... que du plaisir ! :)
Une petite question technique, par simple curiosité, à l'adresse d'Audiophonics : sauriez vous me dire la puissance de l'alimentation (500VA... ?) et la valeur du facteur d'amortissement du Quloos QA690, s'il vous plait ? Merci d'avance. :)
Christian R.
Au delà de la livraison et du soin apporté à l'expédition du produit je recommande audiophonics c'est sérieux et sans mauvaise surprise c'est ma deuxième commande, j'apprécie la justesse de la description des produits vendus on est dans le pragmatique pas dans la physique quantique moléculaire appliqué à des câbles. Parlons de ce câble ! après avoir fait le tour des câbles usb collecteur de flux et de polarisation des électrons aux prix absolument délirant...non mais franchement quel culot ou quelle honte de vendre des câbles USB à 800 € voire 1600 €...j'hallucine sur le discours qui va avec également . Celui ci est simplement conçu avec des matériaux haut de gamme , conducteurs en argent , fiche plaqué or finition d'une qualité irréprochable et sans bla-bla nébuleux. Le prix de ce câble est très correct il est justifié et il s'explique pour effectivement une restitution numérique redoutable : le très haut gamme pour un câble USB ne coûte pas 100 € le cm....Je relie ce câble à mon lecteur DAC Esoteric et mon mac book air, les audiophiles vont hurler au scandale quoi ? un appareil Esoteric et un câble de looser lol lol lol ...Non sérieusement vous cherchez du vrai haut de gamme sans mensonge pour relier votre DAC , ce câble est juste ce qu'il vous faut et avec le reste vous pourrez vous payer un restau gastronomique. Une revue hifi anglaise à qualifié ce câble de crème de la crème c'est juste vrai et sans vous ruiner, parce que ce qui va vous ruiner ce sera de vous laisser séduire par les argumentaires et des prix proche de l'escroquerie de certains fabricants.
christ yannick b.
Je m'étais trompé à la commande je n'avais pas vu que ce n'était pas pour ampli.
Au premier branchement j'ai cru le renvoyer tout de suite. J'ai inversé sur la prise et je crois que ça s'est mis en phase et là c'était génial.
Branché sur un Atoll IN30 ou un taga harmony hta 700 v2 ça fait un excellent travail. Il a remplacé mon audioquest nrg y3 à 120e.
Un son plus équilibré. Et de la mid bass sur mes elac début 2 bookshelf.
Le câble audioquest avait un meilleur rendu sur les voix mais il manquait cruellement de kick. Là c'est mieux.
Pour le prix je recommande chaudement.
Je vais surement en prendre un deuxième dès que c'est en stock.
Surprenant!
Monté en supplément de l’excellent AXF-100 PRO III Filtre Alimentation USB de la même marque sur une tour PC dédié uniquement à la musique.
Suppression presque totale de bruits parasite transitant du DAC Audiophonic U-SABRE sur mon ampli casque LITTLE DOT II.Du coup je pense compléter l'upgrade avec l'ifi Audio iPOWER .
Marco P.
Wonderful online store and excellent product
The product is wonderful. He arrived in Italy in four working days. I am happy to have known your site and will buy from you again.
Tomas C.
Fantastic upgrade!
I am so happy to find these amazing connectors. If you get them in hands you immediately feel their quality (not cheat brass light connectors). The most important is that the main contact is copper, not brass!!! If you look for connectors with copper contact (VERY VERY TOP level WBT), you find out that you have to spend so much more! I use these connectors in my vintage McIntosh preamplifier, DACs, wherewer I can and I am soooooo satisfied! Great product for great price! Do not hesitat and buy them!
Jean-Charles g.
Très bon intras pour débuter dans l'audio nomade.
Le son est détaillé et la qualité de construction irreprochable.
A ce prix il y a très peu d'équivalent
nicolas b.
Enfin du propre
Je possède plusieurs 6SN7, des Shuguang et PSVane. Même après 3 jours de burn-in, ils produisent un bruit aigu, assez dérangeant, qui ne semble pas vouloir disparaître
Mais pas ce tube. 3 jours de burn-in. Son nickel et propre. Plus de bourdonnement, pas de sons aigus.
vincent c.
Permet d'avoir une finition très soignée.
vincent c.
Très bon câble HP, il a rééquilibré mon système en améliorant considérablement les fréquences haut médium et aigu qui était en dessous du reste du spectre sonore. Le placage argent doit y être pour quelque chose. Je suis très satisfait car j'ai obtenu le résultat que je souhaitais, ce n'est pas si souvent que cela se produit lors d'un achat en aveugle (ou plutôt en sourd).
vincent c.
PANGEA FIRST SE Phono Cable RCA / RCA with Ground 1.25m The Pangea Premier SE is a high end vinyl turntable cable incorporating a ground conductor is a neat design. It integrates Cardas and OFC Copper conductors, PE insulation and...
En comparaison du cable fournit pour l'ATPL7, le gain n'est pas extraordinaire mais il y a eu du mieux dans la définition général du signal et la tenue du bas medium et du grave. Je recommande pour son bon rapport qualité/prix.
Freddy D.
Classe A !
Bien mis en oeuvre tout simplement extraordinaire ! Absence de bruits , très belle ouverture , tout y est ! de quoi redécouvrir l,écoute au casque ,pour ma part j,ai changé le potar pour un Blue Alps , alim en 28v , une très bonne carte ...
christophe c.
Après un Onkyo 989...
Je donne ici un avis purement amateur n'ayant pas la fibre hifiste de certains.
Je n'ai pas pris la peine de faire d'écoute d'autres amplis dans cette gamme de prix. C'est un achat impulsif mais je ne le regrette pas. Mon onkyo a trouvé son remplaçant.
Mon ampli Onkyo était en effet exclusivement dédié à une salle home cinéma (7*4) et les écoutes Hifi n'étaient pas mémorables malgré la puissance annoncée.
Je suis en transition dans une nouvelle maison. La zone d'écoute est beaucoup plus fermée (12m2 ouverts sur 30m2) ce qui favorise le fx audio mais, malgré tout, la différence d'écoute entre les deux amplis est flagrante.
Là ou l'onkyo avait tendance à arrondir le son, le 2160 cisèle l'espace et les instruments. Non pas qu'il soit trop analytique mais bien plus "réaliste".
Le contre argument, c'est que là où l'onkyo permettait des enregistrements "limites", le 2160 vous les restitue dans leur laideur. Bref, attention à la source.
Niveau puissance, ma zone d'écoute étant relativement restreinte, je n'ai aucun problème à ce niveau là. Je rejoins d'ailleurs un autre commentaire plus bas. A 01, le son est déjà conséquent, loin d'une écoute d'ambiance. J'utilise un pc branché en USB ( et aussi en rca sur une carte son asus xonar hdav deluxe mais je ne perçois pas de réelles différences entre les deux). Je baisse donc le niveau via l'application utilisé en lecture. Je pense donc qu'il peut être utilisé dans des pièces plus vastes vu la réserve qu'il possède.
Je pense avoir atteint les limites de mon matériel avec cet ampli (mes enceintes sont des Energy Connoisseur C3). Il semblerait que l'ajout d'une alimentation (vendue sur le site) apporte un plus dans le grave d'après mes lectures, ce sera la prochaine évolution de mon matériel.
PS : j'ai eu des soucis avec la télécommande d'origine qui fonctionnait par intermittence. Le SAV d'Audiophonics a marché à la perfection. Renvoi rapide sans supplément. Que dire mis à part parfait. La livraison elle aussi a été rapide. Je ne peux que féliciter Audiophonics ;).
Daniel k.
MATRIX ELEMENT I DAC Network Player ES9028PRO XMOS WiFi DLNA AirPlay 32bit 768kHz DSD512 The latest addition to Matrix's Element range, the Element I naturally takes up the design basis of the other models, taking advantage of the excellent performance and numerous...
excellent appareil
J'ai reçu cet appareil il y a un mois, recul suffisant pour poster un avis, d'autant que Qobuz a été récemment intégré dans l'appli MA Remote propriétaire ce qui me permets d'écouter ma musique en Hi-Res dans les meilleures conditions.
La qualité du son est excellente aussi bien en qualité CD qu'en Hi-Res où la scène sonore est époustouflante de largeur et de profondeur. En Hi-Res, la précision spatiale des instruments et des voix est absolument bluffante tout comme le sont les timbres. Le rendu sonore en 192/24 tient toutes ses promesses et le bond qualitatif dans ce format est évident: transparence, précision, résolution.
Seul bémol: l'application MA Remote est perfectible pour la gestion de la musique sur Qobuz
Je recommande vivement cet appareil très accompli.
John Kenneth W.
Pi Power Management Module PI-SPC V2
It's not clear from the add, but this is not a purely electro-mechanical solution and requires scripts to be loaded and config file edits on your SBC before it will work.
The scripts and edit instructions provided by support, were not compatible with my Pi4B/MoOde 6.5.2 combination, so I could not get the unit to function at all and I gave up on it in the end.
Hi,
It's pretty clear for us and every other customers who have bought this solution has a stand alone product or as a feature on our DACs
ex : "The functions of this card are natively supported by the following software solutions: DietPi, Max2Play, piCorePlayer."
"function available without script"
"Installing the script"
"You will find on our forum the indications concerning the manual installation of the script on our forum:" etc ...
you have total right to doesnt read a product page but please dont blame us for that.
Best regards
John Kenneth W.
TOPPING D90 Balanced DAC AK4499 XMOS XU208 I2S 32bit 768kHz DSD512 Bluetooth 5.0 Silver A direct successor to the D70 Topping, the D90 benefits from the same refinements as its big brother while updating its DAC with a newer and more efficient version, the AK4499...
Topping D90 Review
Excellent sounding DAC with plenty of input options.
Lots of detail coming out of a jet Black background.
LAURENT L.
Parfait pour le quotidien
A ce prix à il est impossible d'avoir mieux, livré en plus avec tous les adaptateurs nécessaires. Parfait pour le quotidien !
LAURENT L.
INTENSO Memory Card Micro SDXC Class 10 64Gb This Micro SD memory card has a storage capacity of 64GB. An essential memory card to accompany and provide storage space at your SBC such as a Raspberry Pi or Allo Sparky. Of...
Fonctionnement un peu aléatoire
Bon produit mais régulièrement lorsqu'on le met dans le baladeur HIDIZS AP80 acheté en même temps, la carte n'est plus reconnue ou il est demandé de la reformater (ce qui st très ennuyeux).
LAURENT L.
HIDIZS AP80 DAP HiFi DAC ES9218P 32Bit/384kHz DSD Bluetooth aptX Gray With its AP80, Hidizs offers a DAP in a really small format to accompany you throughout your day, while ensuring excellent audio performance. Indeed, the portable player...
Superbe rapport qualité / prix
Excellent appareil, compact, très belle qualité sonore, un rapport qualité prix exceptionnel !
