Daniel Z.
Very Good
Top Quality.
Daniel Z.
Compared to JR 4580, NE 5532 and LM49720 the Sparkos has more Dynamics, Brighter Soundstage, its more musical and don't...
Daniel Z.
Very Good
I use it for ES9019K2M Audiophonics Dac Board.
Customers reviews - There are 19572 reviews.
jean-rené C.
jean-rené C.
JR
nickel
Ian C.
MINIDSP DIRAC SERIES DDRC-88D Audio Processor DSP 7.1 Digital Dirac BNC The Dirac DDRC-88D fits between your digital source and your DAC. Like all Dirac Livre DSPs, the DDRC-88D allows you to measure your listening space in all its complexity in...
Great DSP and Enjoying DIRAC
I blew up my nanoSHARC recently which was a sad day, the DDRC-88D is not quite a drop-in replacement for the now-discontinued nanoSHARC, but I am really impressed so far.
The nanoSHARC ran filtering at 96khz, whereas the DDRC is 48khz only. I was a bit worried about that. I suspect that miniDSP did that to allow for more FIR taps for DIRAC processing.
I have not noticed the drop in internal sample rate affect the sound quality at all. But, I will say that the DIRAC processing has been simpler than performing FIR correction on separate outputs as I was doing on the nanoSHARC.
The unit is aimed at the 5.1 or 7.1 market but it is suitable for up to 2 x 4 way speaker active crossover. I am using it for a pair of 3 way speakers.
The unit in my setup takes digital (CD quality and 96khz/24 bit) from a DAP over SPDIF and then outputs to 3 Khadas Tone Boards, again via SPDIF.
Pretty easy to configure a crossover, I had used the nanoSHARC before and the DDRC-88BM plugin is similar.
DIRAC is a different software tool for measurement, which is a bit frustrating, but it has worked for me OK.
Overall really happy. Going to try and see if I can use different configurations (up to 4 configs) to allow me to cycle through the 4 SPDIF inputs. That would allow me to use it as a 4 input digital preamp, and switch between DAP and my ADC from my turntable. I am fairly sure that will work, but if not, then I will have to purchase some kind of SPDIF switcher.
The only pain is that all the SPDIF connections are BNC. I looked at getting a different Tascam style 25 pin connector with RCA plugs, but that wasn't cheap. Some BNC to RCA plugs solved the problem in the end.
If you are going to use this in a home audio scenario, then make sure you get the SPDIF version if you have SPDIF level kit. The AES/EBU version does run at higher signal voltages IIRC.
Renaud D.
Ultra polyvalent !
Les fonctionnalités de l'appareil sont nombreuses: DAC, pré-ampli numérique, ampli casque, réglages graves et aigus, crossfeed, loudness, égaliseur paramétrique, afficheur graphique, réglage des niveau de sortie, télécommande ...
La connectique est largement suffisante (entrées coax, optique et USB, sorties rca, xlr et casque).
A l'utilisation, on sent que chaque petit détail a été pensé (comme par exemple la possibilité d'éteindre l'écran lors de l'écoute).
La faible impédance de la sortie casque et la puissance disponible lui permettent de faire face à n'importe quelle situation.
Utilisé avec un casque Focal Clear, le son est absolument parfait.
Le prix n'est certes pas négligeable, mais la réputation de la marque et la qualité de fabrication (made in Germany) me font croire que ce sera un bon investissement sur la durée !
Je recommande ce produit sans restriction.
Renaud D.
Parfait pour le prix !
Amplement suffisant pour connecter un lecteur CD avec un ampli Hifi
Jerome v.
PARFAIT
Recu tres rapidement avec emballage nickel.
installation ok tres facile sur RPI3B+ avec le drive R-PI DAC dans la configuration du DAC Modele, y'a plus qu'a voir avec mon ensemble hifi la qualité du son.
TOPPING TCR1-25 RCA Cable Male / Male Silver Plated OFC Copper 25cm Topping offers with the TCR1 a very good male / male RCA cable. It benefits from a beautiful design with a Silver Coated OFC copper conductor offering excellent signal...
Un câble de qualité pour un prix raisonnable.
Je viens de recevoir ce câble qui assure la liaison entre mon DAC et mon ampli casque. Outre sa qualité de fabrication les premiers résultats sonores sont excellents, musicalité, neutralité et équilibre sont les maitres mots. La dynamique est au RDV, bref un achat raisonné qui me donne entière satisfaction. Envoi rapide, merci à Audiophonics qui propose des produits de qualité à des prix abordables.
Chris W.
Awesome TAMP
I was made aware of this board via a German diy audio site who nick-named it the Gremlin. It received glowing reviews so I decided to give it a go. I have been using the amp for about 14 months and can report back that it exceeds expectation. Its unbelievable what it accomplishes for the price. The sound is huge and detailed. I follow forum advice and run it at 36V. People reported that higher voltages result in a 'harsher' sound but I can't comment. Although the amp is billed as 2x500W, in reality (8ohms, low THD) its more like 90W. I use this in conjunction with a cheap 6J1 buffer/preamp and couldn't be happier (ymmv).
Bruno l.
phénoménal !
j’avais acheté dernièrement le isilencer 3,0 de la mème marque. Cela apportait tellement à mon audio GD NFB 29H que j’ai voulu essayer la version plus évoluée du système de chez IFI.
Bien m’en a pris, c’est époustouflant ! La mauvaise nouvelle, c’est que c’est encore mieux en utilisant le isencer 3,0 en sortie de PC et le Ipurifier 3 en entrée du DAC. C’est mieux mais c’est plus cher...Mais l’investissement est vraiment pertinent. Timbres , dynamique, rythme, harmoniques, réverbes, profondeur, etc, on gagne sur tous les plans. Cher mais finalement par rapport au résultat, c’est un excellent investissement.
tony r.
superbe finition
apporte une vraie belle finition sur des câbles gainés, parfaitement conçu
tony r.
pourquoi payer plus cher ?
finition, maintien, emboîtement, vis, finition... tout est très bien. parfaitement adapté à la pose d'un thermorétractable. Emboîtement ferme dans les bornier de mes enceintes focal (ce que je souhaitais)
tony r.
caoutchoucs inutiles
contrairement a ce que laisse penser la photo, les caoutchoucs ne portent pas sur le sol, du coup inutiles. Sinon ce sont des contre pointes, ca fait le job
Claude H.
Un beau produit
Mon appareil était bien assemblé et a fonctionné parfaitement dès la première mise en marche. Le transformateur toroïdal ne bourdonne pas et la tension de sortie est exempte de bruit et demeure très stable, Seul bémol il n'est pas possible de commuter la tension d'alimentation pour utilisation avec un secteur à 120 Volts. J'ai résolu ce problème avec un transformateur élévateur 120-240 Volts et je suis tout à fait satisfait du résultat.
Claude H.
Performance a coût raisonnable
Un CNA (DAC) performant et bien intégré au lecteur RaspiTouch. Assemblage sans difficulté avec le RPI 3 et le boîtier RaspiTouch
Dhafer D.
Reçu il y a 2 semaines, utilisation avec un AKG 702.
1 - Le produit : tout en aluminium, très bien fini et très bien monté. Les composants sont très bien présentés et je ne retrouve pas de composants reconditionnées. Tout semble d'origine et neuf.
2 - L'installation :
- Windows 10 : build 1909, directement reconnu, j'ai pu sans difficulté le faire fonctionner en bitperfect avec foobar et le plugin asio avec les fichier HD sauf le dsd.
Après l'installation du pilote en téléchargement sur audiophonics.fr, les choses ne s'améiolrent pas , toujours des sifflement et des bip avec le dsd.
J'ai installé les pilotes disponible sur le site de xmos, et là tout fonctionne : tout passe sans accro du simple mp3 au dsd et en natif.
- ubuntu 18.04 : reconnu directement et fonctionne mieux que sous windows . Pour avoir du DSD en natif, il faut choisir le bon kernel
3 - L'écoute : ayant vécu plusieurs temps avec un dac AKM, le son m'a paru sec et métallique , je m'y attendais un peu car j'ai lu beaucoup de commentaires sur les puces ESS. Mais quelle précision !!!!
J'ai perdu un peu de la musicalité des dac AKM, mais j'ai gagné en précision.
Les 2 sorties casques et lignes sont trés différentes. La sortie ligne avec l'aop OP275 perd de l'image stereo par rapport à la sortie casque et son JRC5532, mais gagne en finesse et douceur dans les aigus. La sortie casque est faite essentiellement pour piloter tout genre de casque : puissance, equilibre, bonne image stereo, bonne profondeur, mais manque de musicalité.
Conclusion : Au final je ne peux qu'être satisfait de ce DAC exceptionnel. Il lit tout sans changer de configuration à chaque fois. Meme si le son d'origine est un peu froid, il commence à s'attendrir au fil des heures, mais surtout, on a toujours la possibilité de changer les aop pour changer de signature sonore.
donc le bonheur est double : à l'utilisation et à l'évolution :-)
MCAP EVO 1µF
Condensateur de bonne qualité.
Utilisé en bypass (// à un condensateur chimique)
La nouvelle géométrie EVO (capa moins long, mais de plus gros diamètre) permet une fixation aisé sur pcb.
Aucun problème
Produit recommandé
Kristijan K.
Almost perfect
This is my first external DAC. I bought it to replace the HT Omega Claro Halo XT and Asus Xonar ST PCI sound cards (both upgraded with AD797BRZ and BBOPA627AU opamps). The D70 technically works correctly and very nice. Turns on with the computer (USB) or TV (optical), shuts down a minute after shutting down the computer or TV (you can actually disable this), runs cool, transition between tracks with different frequencies/bitrate/format is completely flawless and silent (Foobar2000), quiet and fast relays, it has nice display that doesn't bother in the dark at all. Feels robust as if made to last. The Topping USB driver also works good for now. It shows that this is a dac version 1.04. The only thing related to the driver and worth to mention is that if you want to upsample/convert PCM to DSD, DO NOT convert to DSDxx/48Khz format or you risk some serious damage to your gear and your hearing.
Seriously. Lot of noise and crackling will be generated and pass through the driver. So be warned! I guess the D70 obviously do not support DSDxx/48, only DSDxx/44. At least not using Foobar2000 with SACD/DSD processor or ASIO Proxy plugins (various versions). Anyway, after some serious blind tests with various PCM files (natively and converted to DSD), I am definitely sure that PCM actually sounds best if played natively.
And now something (subjective) about the sound of this dac. I am using it connected via the little Chinese tube preamp (similar to FX-Audio Tube-03) that uses a pair of Voskhod 6J1P-EV tubes and a single dual NE5532 opamp on the board.
The preamp is connected to the Fase Performance 3.5 integrated amp which serves a pair of Dali Zensor 5 speakers + SVS SB-1000 sub. The sound of my previous setup including my sound cards is really tube like. Warm, soft, spacious, with very nice sonic controlled bass, everything floats, pretty exciting sound you can listen for hours. As I can see from the D70 board pics, there are three L49720NA opamps on the output soldered. One for the RCA path and two for the balanced output paths. Unfortunately they are not on sockets so not interchangeable easily without soldering and warranty void.
I am not really a fan of these opamps due to their very analytical and somewhat dry sound with a low emphasis on the bass (my experiences with these opamps and my sound cards).
So I was wandering if putting the D70 into my gear chain will produce some unpleasantly surprise. And an unpleasant surprise happened :-( The sound was pretty much what I thought it could be using 49720NA on the output stage. The magic collapsed. Yes, there were some new qualities such as more details and better highs that this dac provided compared to the sound cards, but velvet sonic warm heaven on the Earth tube bass has gone and the stage depth narrowed. Instead there was a dry and thumpy unexciting bass. A real disappointment and I was allready preparing in my head it's boxes to send it back on the day one. Because changing the RCA output opamp to something much better was not the option, got the idea to change the opamp (NE5532) in my tube preamp to something from the sound cards and to hope that maybe, but just maybe the magic could somehow return.
Believe me or not, when I changed the NE5532 in my little tube preamp to the BBOPA627AU, the magic came back over the big door. Seriously. The magic of all that warm velvet tube like soul touching bass sound came back. But this time with noticeably better vocals and highs. This is something BBOPA627AU obviously do and it is a real shame the D70 doesn't have easily replaceable opamps. So, there is a light appeared at the end of the tunnel. Finally no more obsolete PCI slots and outdated sound cards. This dac actually gives a lot, it just needs to be paired with the right equipment that can harness the potential. As soon as the warranty is over, I will definitely modify it's opamps.
Serge B.
JANTZEN AUDIO ALUMEN Z-CAP Capacitor 100V 6.8µF Jantzen Audio Alumen Z-Cap capacitors are based on the Silver Gold Z-Cap series with a more neutral and musical tonal presence. This Aluminium Polypropylene series provides a...
Sublime, sublime
Que dire de plus que dans les descriptif, je les ai remplacés en lieu et place de Mundorf pourtant excellent.
Certes l'investissement est relativement important, mais la différence est sans commune mesure.
J'ai eu l'impression de changer d'enceintes, tellement la différence est importante sur mes tweeters ScanSpeak Revelator.
Je recommande sans aucune hésitation.
Un grand merci à Audiophonic de les avoir commercialisés
MUNDORF MCAP SUPREME
Super qualité
Cette gamme de condensateurs d'excellente réputation est idéal en liaison / filtrage
Le 10uf est un beau bestiau
106mm x 36 de diamètre...
Le tout encapsulé dans un cylindre d' aluminium.
Rien à redire
Serge B.
ETI BP-20C Binding Post Gold Plated Pure Copper Ø19mm (Pair) The ETI BP-20C are very high performance terminal blocks at contained prices. Made of 1100 Series Hardened Copper conductor with 102% IAC (conductivity index), these terminals...
Excellent, excellent
J'ai monté ces prises en cuivre pur sur un Audi GD Master 10, en remplacement de celles d'origines en chrome plaqué or, la différence est flagrante à l'écoute, les prises de mes enceintes sont aussi en cuivre pur.
Un grave bien plus profond et plus tendu, une scène sonore plus large, quelques micros informations en plus, magique!!!.
Sur cet ampli, cela m'a demandé pas mal de temps.
Sur le plan technique, il y a un petit ergot sur les rondelles des fiches, il faut avec un cuter les retirer, car il n'y a pas d'encoche sur le châssis arrière de l'ampli pour pouvoir les rentrer.
Pour info, attention en démontant l'arrière de l'ampli, il y a deux platines qu'ils faut démonter, avec de tout petit fil pour alimenter toutes les prises de sorties, certains fils ont été dessoudés, prendre une photo avant de l'ensemble pour repérage.
François L.
Excellent DAC pour un prix très compétitif
Nous sommes en cours de test comparatif de ce DAC, mais les premiers résultats le placent d'emblée devant d'autres DAC bien conçus. Il est particulièrement détaillé.
De plus, le rapport qualité/prix est plutôt intéressant.
Gaine Coton
Très bien, pas cher !
Produit recommandé
Pompe à dessouder
Fait le job, à voir sur la durée... très bien pour une utilisation ponctuelle
JEAN-PHILIPPE B.
Excellent câble à recommander d’urgence
Encore un produit audiophonics à la qualité duquel je ne m’attendais pas. Le câble assure la liaison numérique entre le transport réseau et le dac, permettant de profiter pleinement de la qualité de ces appareils. Le niveau de performance de ce câble est incroyable : la scène sonore est devant moi, très aérée avec une mise en perspective des instruments de l’orchestre parfaite. Les aigus sont tenus jusqu’en haut du spectre.
Compliments au technicien d’audiophonics pour le montage et la qualité du produit envoyé dans un fourreau de protection adhoc.
Bravo et merci.
jean michel G.
Un plus
Après remplacement de mon bnc standard, j'ai eu plus de details avec mon dac, belle finition, je recommande.
Jean-Marie G.
Excellent tube
Je ne suis pas guitariste, acheter une paire pour un ampli hi-fi pp6v6 avec un schéma simple: c'est très bon. Pour ce qui est des vintage nos je crois comprendre que ce qui plaît souvent c'est un caractère descendant vers l'aigu et/ou un bas médium-haut grave mise en avant, sans doute à essayer mais c'est très cher ! Alors que ces reste de prix raisonnable (même si c'est relatif car pour 30 euros un module class d et une alim de récupération et on a un ampli.....) merci et vive la musique.
Max N.
DATS
Very fast delivery. The product is of high quality. It costs its money. I did not expect it to be so multifunctional. In general, I am glad that I purchased this device. I advise everyone.Очень быстрая доставка.Товар качественный.Он стоит своих денег.Не ожидал,что он будет таким многофункциональным.Вобщем рад,что приобрел этот прибор.Всем советую.
Max N.
DATS
Thomas v.
IAN CANADA FIFOPI Q2 ULTIMATE Reclocker Module FIFO PCM 32bit 768kHz DSD1024 DoP The  FiFoPi Ultimate  from  Ian Canada  was designed to significantly reduce the jitter of the digital audio signal produced by a Raspberry Pi, before...
Perfect way to transport your audio onto your dac!
This module is the absolute best way to transfer your audio from your Raspberry Pi (or other single board computer). This modules enables you to upgrade the very important clocks (for instance with ACCULUSION clocks). The module is extendable with other products from Ian Canada or can transpass the audio onto your dac via I2S.
Thomas v.
Shrinks good and does not burn.
Good shrink tube! Shrinks perfectly and does not burn when heated with a lighter. Also does not melt when heated with a solder iron.
Thomas v.
Excellent quality solder.
This wbt-0800 4% silver solder is really a must have! The solder flows nice and contains flux. Would recommend this for audio diy equipment.
Olivier F.
Très content
Très content de ce produit. Je viens de Modifier mes enceintes RCF actives avec des HYPEX PLATE AMPLIFIER FA252 calibrés sur les sensibilités du WOOFER et TWEETER RCF. Le Crossover est un LR48, et il me fallait compenser le décalage de phase en FIR. Connecté en input SPDIF de ma carte son MOTU, il ressort en AES/EBU vers mes RCF "MK5" made home DIY, et ce MIDI DSP non seulement me convertit le TOSLINK vers AES, et je peux changer le volume avec le gros bouton PUSH, appliqué le F.I.R, bref contrôler et corriger ma nouvelle SONO/HIFI . Je viens de mesurer avec un micro RTA et REW : phase parfaite même avec mes SUB, avec 2048 taps FIR calculés dans le logiciel gratuit REPHASE comptabile avec les fichiers .bin du mini DSP. très content et en plus livraison rapide et pro :)
Jean-Yves H.
Super ampli/DAC pour casque
Ayant un casque DT 990 PRO haute impédance, il est difficile de trouver un ampli casque puissant ...
Plus de problème avec ce modèle et la musicalité est bien au rendez-vous !
Que du bonheur !
Je recommande.
Luis C.
Bon produit, assemblage facile et avec très bons contacts.
Malheureusement, je l'ai acheté parce que le PI-26Gc était trop long mais, avec une entreé max de 16,5 mm, n'est pas possible d'installer le câble CS-361B.
(Un avertissement d'audiophonics aurait été aprécié dans ce cas)
Christophe P.
Bon potentiomètre
J'ai acheté ce potentiomètre pour écouter ma platine vinyle directement en sortie d'un préampli phono (avec un casque 32 ohms, ça le fait, sachant que j'ai des enceintes actives donc je mets soit le casque, soit les enceintes et pas besoin de préampli et d'ampli en plus. Pour mon DAC c'est pareil;
Il n'y a pas de craquement ou d'interphérence, le niveau est suffisant pour mes oreilles - c'est fort en fait - et le bouton est de bonne qualité. Le son est très bon.
Merci encore une fois à Audiophonics pour l'envoi rapide et soigné.
marc t.
Bon rapport qualité/prix - Service sérieux et efficace
J'écoute la musique en démat, ce mini DAC est parfait pour ce que je recherchais, j'étais en vacances chez les parents où j'ai une petite installation hifi, je voulais écouter la zique de mon mac, (via AUDIRVANA) via cette installation, sans que cela ne me coûte plus que quelques dizaines d'euros, vu ce qui se prépare sur nos futures retraites, il était sage de ne point investir... Je suis TRES satisfait par ce boitier car il est plug and play et fait le taf LARGEMENT pour le prix demandé. C'est pas un son aussi ample et aéré que ce que j'ai avec un DAC de salon mais pour une trentaine d'euros, on va pas demander la lune, non?
Première fois que j'achète chez AUDIOPHONICS, ça respire le sérieux et l'efficace, je reviendrai sans souci, c'est sûr, mais j'attends de voir les annonces du premier ministre avant de me lancer dans des folies pour le plus grand plaisir de ma paire d'oreilles.
Sélecteur de Source
Produit conforme à la description (4 contacts / 3 positions)
Fonctionne bien,
Rien à redire à part un axe un peu court mais ça ne pose pas de problème avec le bouton que j ai choisi :
(https://www.audiophonics.fr/fr/boutons-volume-6mm/bouton-aluminium-axe-meplat-38x25mm-o6mm-argent-p-11812.html)
Marc M.
DuHaut de gamme á petit prix
J ai utilisé ce câble pendant plus de quatre ans . La curiosité m a amené à vouloir essayer d autres câbles puisque d un systeme comprenant enceintes biblio je suis passé à des enceintes colonnes. Après pas mal d essais avec des câbles de marque á un prix raisonnable, je suis revenu au mogami 3103. Ce câble est vraiment le maillon indispensable à mon systeme et restera sur le haut du podium dans la catégorie petit budget. Mon rega brio peut s exprimer sans retenue sur ma paire de Dali Zensor 7.
Claude d.
super sav
bonjour,
suite à une erreur de ma part j'ai renvoyé la commande.
Dans la demi-journée, l'argent a été recrédité sur mon compte.
Merci audiophonics
claude
laurent d.
Très bonne facture. Alimente mon Mac mini (avec le kit uptone pour l’intérieur du macmini) et la freebox mini 4K. La différence est très importante, je ne peux plus m’en passer. Le son est bien meilleur. La différence la plus importante est tout de meme au niveau de la Freebox! Et le son est meilleur par rj45, directement de la freebox à l’ampli (h390) qu’en passant par le mac mini (rj45 puis usb). Donc la bonne formule c’est de mettre des alimentations linéaires bien amperées ET de supprimer au maximum les intermédiaires.. La freebox reste le maillon faible, pas facile à remplacer.. l’ajout d’un switch audiophile entre la freebox et l’ampli pourrait encore améliorer le son, selon un dossier test lu récemment. Apres peut etre qu’il y aurait des gains à réaliser en mettant de meilleurs cables sur l’alim achetée ici.
david b.
ARYLIC COBBLESTONE WiFi Receiver AirPlay UPnP DLNA Multiroom 24bit 192kHz The Arylic Cobblestone is a WiFi receiver that allows you to easily and efficiently stream your files from your network, smartphone/tablet or your favorite streaming services....
L'efficacité liée à la simplicité
Simple d’utilisation et efficace il ne faut néanmoins pas lui demander des performances extrême. il faut l'associer à du matériel plutôt de bonne facture pour avoir un plaisir sonore digne d 'audiophile et de mélomane. Cependant je cherchais une solution simple et efficace sans passer par google chrome, et donc , sans allumer ma télé, ce petit matériel esthétique de sir quoi fait le job a merveille. Il a le mérite d’être à la fois beau mais aussi sa petite surface faite d'une matière proche du velours ajoute à l’expérience sonore et visuelle une expérience tactile intéressante.
Tout ceci dans un petit objet.
Alimentation Audio gd
Premières impressions :
Utilisée pour alimenter un buffer (PASS B1)
J'utilise les sorties 2x 9v en série pour sortir 18VDC
Subjectivement les résultats sont bons
(il faudra que je mette un petit coup d'oscillo pour voir la propreté du DC délivré)
Concernant cette alim
Le pcb est propre avec des composants de bonne facture
Des potentiomètres multitours permettent d ajuster finement la tension de sortie (avec une bonne réactivité)
NB La tension de sortie chute un peu lorsque les transistors de sortie sont chauds
(Cela est dû à l'absence de contre réaction voulue par le constructeur)
Comme mon montage accepte de 18 a 24 v
Je l'ai réglé pour l'instant a 19,1 v à l'équilibre thermique ...
Le transfo d alim est un 2x15 (de 12 a 18v recommandé )
Enfin pour la dissipation thermique, je l ai fixé sur les perforations d aération d un boîtier hifi2000
Patricio A.
Un excelente DAC !!!!!
He recibido hace dos días este maravilloso DAC que me tenía sin dormir esperando su llegada, actualmente estoy mus satisfecho con ALO BOSS DAC V1.2 el cual es muy bueno y tiene una potente salida.
Al principio me costo tiempo y frustracion el setup de I-SABRE ES9038Q2M, lo instale usando un RasppBErry Pi 3B+ & PiCorePlayer 6.0, escogi el DAC Audiophoincs Q2M del menu de DACS y todo bien, una vez configiurado LMS y PCP sobre WiFi lo apague y lo lleve al lugar donde estaría definitivamente ubicado, pero al encender el aparato se recalentaba mucho y se reiniciaba.. lo deje para el día siguiente y me di cuenta que era falta de potencia de la fuente de poder, le conecte a la fuente de poder propia de RaspBerry 5V-3A, le agregue unos disipadores de calor y funciono perfectamente, me la he pasado escuchado varias horas y debo decir que es un DAC espectacular, un sonido
cristalino sin excesos en BASS ni TREBBLE me gusto mucho más que el ALO BOS DAC 1.2 que es excelente y tiene más potencia de salida.
La atención de Audiophonics es muy profesional y cordial a la vez, la tecnología Europea es excelente.
Muchas gracias por todo, seguramante estaré comprando más componentes para mi equipo DIY ideal.
Atte.
Patricio Almeida
Ecuador.
Jari S.
Very good binding posts for it's price, well very good in any terms. Accepts bare wire, forks and bananas. Has a good soldering option for internal wire and has good insulation. Might feel a bit loose parts when not installed in place, but are solid after they've been put together and tightened. Have bought them already several pairs and will buy more in future.
Serge P.
Magnifique !
Grâce à cet amplificateur classe A, j'ai redécouvert mon vieil Sennheiser HD 565. Totalement transcendé ! Et quelle musique ! Très large scène sonore avec beaucoup d'aération entre les divers instruments. De la profondeur aussi un étagement des registres bien tenu.
Le message fourmille de détails, on perçoit très nettement les bruits de salle, les respirations et chuchotements. Les enregistrements Hi-Res (24/192) sont restitués avec un tel réalisme que très vite on oublie le casque pour se laisser aller totalement au gré de la musique qui nous emporte.
Une autre chose importante que ce K214 V2 m'a confirmée de façon plus claire encore, c'est la nécessité de "ripper" au plus vite mes meilleurs CD et les mettre sur disque dur (musique dématérialisée), car associé à un bon DAC USB (E-MU 0202 "euphonisé"), puis branché pour comparaison en sortie d'une platine CD renommée, je vous l'assure : c'est la gifle !
Patricio M.
Excelente DAC
Mi primera experiencia en el mundo de los lectores de red (para disfrutar de Qobuz) fue un sistema RPI con un dac is2 iQuadio. Buscando algo más de calidad pasé a un Auralic Mini. El sonido mejoró pero nunca estuve completamente satisfecho con su manejo a través de dispositivos Apple para oír Qobuz. Quería volver a probar algo en el mundo RPI y a la facilidad de manejo de BubbleUPnP, sin sacrificar prestaciones sonoras y me decidí por esta pequeña joya. Más transparente que el Iquadio y algo más relajado en altas frecuencias que el Auralic Mini. Excelente integración con MoOde ya que puedes acceder a los filtros predeterminados en el PCM5122. He visto una evolución claramente favorable desde las primeras versiones de MoOde que probé hace un tiempo. No uso Volumio ya que el manejo de las playlists es insoportablemente lento pero también suena muy bien. Lo tengo todo alimentado con una alimentación lineal comprada aquí. Recomendación total.
Davide D.
XLR caps
Excellent quality at the right price. For those who love hi-end accessories
Davide D.
RCA caps
Davide D.
Furutech 8n Connector
Unquestionable superb quality of Furutech
Davide D.
Perfect Weight Record
This 1877Phono weight record is perfect. Satin and soft touch surfaces, nice to look at. Recomended for wood or black turntables
