Gianfranco P.
Wonderful
Peter Š.
Peter Š.
Tomislav N.
Customers reviews - There are 19569 reviews.
pierre b.
un produit d'exeption !!!!!
J'ai testé bon nombre de systèmes du genre avec des résultats discutable pour un prix trois à six fois supérieur et j'avoue avoir été bluffé par le résultat tout à fait impressionnant du rendu sonore.
"Magnifique".
Installé sur un PC monté par mes soins avec filtre de courent secteur, suite de chaine de haut niveau, un bel aboutissement.
André A.
IKKO OH1 Hybrid In-Ear Monitors IEM 18 Ohm With its OH1s, Ikko offers high-end in-ear monitors at a low price. Indeed, it is a model with a hybrid design with two loudspeakers, usually reserved for products at much...
Écouteurs magnifiques!
Livraison très rapide en Allemagne!
Les écouteurs est magnifique. Avis en anglais parce que mon francais n'est suffice pas....
The sound is very good, elevated bass and astonishingly clear bass response for an in-ear-monitor.
Mids are recessed a bit except for low mids which are still affected by elevated bass (low mids are kind of elavated as well) but still very clear and differenciated.
Treble rolls off quite a bit, so you wont get a "bright" or "airy" sound out of them without equalizing very much, but otherwise than that, treble is magnificent thanks to the balanced armature driver.
Timbre is very clean and not overly metallic.
Soundstage is unrivaled in this price class, width is very very good for In-Ear-Monitors, depth is mediocre, not bad but not too good as well.
Over all an In-Ear-Monitor WELL above its price class, Sound like that is normally at least 2-3 times the price.
Also very good build, although the 2 pin connector isnt recessed, so it might come to cable connection issues if you are moving quite a lot. I have been running with them too and no problem, but after having them in while playing basketball, after an hour or so one 2 pin slided out of the port a bit.
Overall, if you want 300€+ Sound for half the price, BUY IT!
Guy V.
Un petit câble très correct.
Ce « petit » câble RCA (aussi bien par la longueur que par le prix) remplace très avantageusement les câble très-très basiques livrés généralement avec les appareils HiFi. Il me sert principalement pour relier le petit DAC FX01 à une table de mixage pour la sono. Et dans ce cas, sa courte longueur (!) est un véritable atout. Juste une petite angoisse sur la grande souplesse des conducteurs dans leurs parties sous gaine plastique. Ça plie beaucoup, mais pour l’instant la qualité du son ne s’en ressent pas. À voir dans le temps…
Guy V.
Une petite merveille incontournable !
Ce petit DAC « entrée de gamme » est carrément bluffant de part la qualité du son qu’il restitue. Même sur des fichiers en 16 bits-44,1KHz extraits directement de CDs, le résultat est superbe. À ce tarif, c’est un « petit cadeau » que l’on peut et que l’on doit se faire !
frederic m.
Pas mal pour le prix
Cers patins sont bien efficaces, cependant la mousse blanche autocollante est peu résistante si vous devez les repositionner... Visez bien avant de les appliquer ;)
William B.
bonne alim
Associée à un transfo torique 12V 50W pour une tension de 5v régulée.Cette alim devrait à terme remplacer l'alim IFI sur mon dac, elle alimente pour l'instant mon Raspberry auquel je vais associer un disque dur. Seule bémol le schéma électronique de la carte n'est pas fourni donc il faut suivre la piste ce qui n'est pas aisé. Personnellement j'aurais mis des condensateurs wima mkp à la place des mkt.
Acheté à nouveau
Profitant d'une commande pour un ami, je reprends un filtre pour le mettre sur mon ventirad. J'avais déjà équipé les ventilateurs de boîtier.
Le filtre est muni de prises pwm 4 broches. Ok sur le ventirad après vérification du fonctionnement.
Pour le rendu sonore, j'en suis très satisfait. Vous jugerez par vous-même, m'étant fait dégommer sur un forum concernant un avis précédent.
Jerome G.
Fonctionne parfaitement
Utilisé en Toslink en entrée et Coaxial en sortie. Fonctionne parfaitement jusqu'au 24 bits 192 kHz. Livré par contre avec un adaptateur secteur avec prise étrangère (UK ou USA ?).
Miroslav B.
Ing. Miroslav Belik CZ
I installed the FURUTECH FP-703 (G) Jack 6.35mm Mono Gold plated Ø8mm (Unit) cable. Although this coaxial cable is for use for other purposes, I used it as a guitar cable. I deal with the production of these belts and I must say that I've never heard such a fantastic sound. Virtually no bass distortion, very singing sound with voice and unlimited details. Well, just nirvana.
Sebastien S.
Qualité - efficacité - Réglage position phase et neutre
Réaliser le phasage sur chaque départ prise pour réduire ou voir supprimer la tension sur le neutre. Câblage de section 2,5 mm2 pour donner de la force en intensité à l'ensemble du système pour studio - concert - hifi , prévoir une rallonge de même section pour être au Top. Qualité de fabrication soigné que je recommande - nettoyage sonore
Jean Louis d.
audio-gd r2r
je sui pleinement satisfait de ce DAC , la qualité de cette appareil est au top il en vas de même pour le son
patrice M.
Avec un joint a l'entrée qui s'adapte a la taille du câble un presse étoupe a visser le tout bien finit ou même les vis sont plaqués or on a un bon produit pour un tarif très raisonnable.
patrice M.
Bel aspect extérieur bien finit,munit d'un joint souple a l'entrée qui s'adapte a la taille du câble en assurant l'étanchéité,et d'un presse étoupe qui se visse.
Le serrage des câbles est assuré par des vis btr,toute les pièces métalliques sont plaqués or.
Un très bon rapport qualité prix pour ce produit,je le recommande.
Skomantas Š.
Amazing price-performance
Bought the Tone Board after reading about it on Audio Science Review forums, as this was a cheap DAC solution that is praised by the community as an end-game worthy piece of equipment. Truly, the product delivers. First of all, it is a plug-and-play solution, at least on Win10. Khadas website offers firmware updates/drivers (optional on win10) with clear instructions on how to install them. Used usb input (which provides data and also powers the DAC) for my setup. The sound is really very clear and a bit more powerful when compared with my Asus Z170-Deluxe MoBo, which is a premium quality MoBo with upgraded sound chip.
Waiting for the aluminium case now.
In conclusion, this is a great option for those to whom USB and spdif inputs are enough, who care about the sound quality and don't mind that the DAC looks simple.
François A.
Souffle désagréable
Je suis ravi de voir que désormais il y a une mise en garde par rapport au souffle très désagréable qu émet cet ampli. Je suis très surpris qu'il n'ai pas été évoqué avant, dans aucun test, sinon j aurais repensé mon achat. Le son est très bon lorsqu'il y a de la musique, mais le souffle est franchement très désagréable.
Je suis assez déçu de ne pas avoir été prévenu avant mon achat. Bravo les test qobuz........
Rien à dire sur la qualité audio hormis que ça fait bien son job.
Michaël M.
Belle finition, Hyper simple à mettre en service et le son est clair, précis, aéré et chaleureux, bref inespéré en Bluetooth. Et audiophonics au top, livraison rapide et emballage nickel
Passive RCA Modulation to RJ45 Extender This RCA modulation extender is composed of two identical small boxes. Each of them has a stereo RCA input / and output and an RJ45 connector. They thus make it possible to set...
efficace
Sur une longueur de 7 métres son plus net et sans perte de qualité.
Gilles H.
Petit prix, grand son !!!
Après 48 h de rodage, cet ampli a mini-prix, fonctionne à merveille.
Couplé a des Klipsch référence 41 , le grave est charpenté, le médium aigu fin, les voix bien restituées !!! c'est pas brouillon à fort volume !!! Bravo !!! A quand, lla version double mono !!!
Merci.
Gilles H.
Raoul L.
beau produit
mais j'ai déjà utilisé d'autres fiches où l'isolation était réalisée par un double tube traversant complètement l'épaisseur du châssis, un système plus fiable.
Pavol B.
IPAR 1023A Preamplifier / Volume Controller / Headphone Amplifier / Source Selector The IPAR 1023A is a hybrid device headset amplifier / preamplifier / source selector that displays excellent audio characteristics including a high power level, two isolated...
Perfect amp. Don´t miss him!
Even though I'm not a sound expert, I don't have top-notch headphones, as well as high-end comparison or test devices, I'll write a few words. First of all, with what I am "testing" the amplifier and why I chose this one. I wanted a desktop but still portable amplifier for my HiRes DAP. But with the ability to plug in more devices at the same time, and with the ability to output a large amplifier. Of course, in an affordable price. The choice fell on iPar. Its design looks good, holds everything firmly together, a nice front panel. The only complaint is the quality of potentiometers, more precisely knobs. They do not hold firmly, they lean out, the "0" mark is just a crooked ribbon on the root of the knob. Certainly I will have to replace them for the better over time. Otherwise everything works fine. The amplifier is without the manual and any original box.
Now, what and with what I used to compare the amplifier. I currently have ATH-AD900, and ATH-ES88 headphones as the DAP QLS360MOD sound source, and DAP Colorfly C4PRO as a second comparison. Music - all WAV and FLAC formats: Ben Lukas Boysen & Sebastiano Plano - Everything, Bliss - John Metcalfe - Kites and echoes, Diana Krall - All for You A Dedication to the Nat King Cole Trio, Maok - Svetloleť .
I immediately set the gain on the amplifier to -3dB. My headphones are not high ohm so the amplifier's power is more than enough. Even at higher volumes, sound-music did not become extremely unpleasant, sharp. Likewise, it is felt that the amplifier has a sufficient margin, it does not sniff so quickly, it does not feel so much its boundaries as the headphones and human ears. Now the sound. The differences are very subtle, it would certainly help to have a wider selection of headphones. Colorfly C4PRO is feeling sweeter, feeling more coherent music, it's like a comparison between CD and magnetic tape. Though some of the finest microdetails are lost, but the music is more plastic, more human, warmer. QLS 360MOD is softer, the sound is silky, not as warm as Colorfly, it is more audiophile. Both can be listened for a long time without fatigue. However, both lack a bit of drive, speed. iPar Amplifier - What I noticed first is already a sufficient performance control, very similar subtlety in sound performance, and a slightly more separated musical instrument, with a wider space around them, their more accurate localization. The whole sound band is exemplary balanced, nothing stands out or vice versa. Mid range - voices exemplified by a man, did not register any sibilation in the voices. The heights are clean. Basses are controlled, solid, nothing is lost in them. Long-term listening doesn't tire at all. From the memory I compare it with the Denon PMA-2000R amplifier, which I have at home - it is certainly faster, has more drive, but for long listening iPar is better. Even though I have not experienced any of them, even the iPar amplifier, on my back, whether it is crying / it is a holy grail to listen to music /, I can say with confidence that iPar is a very good amplifier, not offensive or tired, it is very musical, its sound exceeds the size of the headphones and is lost during long-term listening. Only music remains.
As a bonus, there is a preamp, but I do not have the opportunity to try, compare. And of course multiple inputs. I personally strongly recommend the amplifier.
PS: A few words to Audiophonics - a great service, trying to solve everything. My piece had a slight damage during transport / from China /, and they immediately suggested a discount. It is better to ask them to check the ordered goods before sending them. You never know.
super banane viborg
Bananes viborg d une super finition , clef pan fournie ,gaine termo viborg fournie, son chaud ,matiere, large ,doux, franchement les meilleures pour le prix( mieux que viablue) hesitez pas surtout en pur cuivre ,bravo viborg! Franck
Imre S.
Blanko adapter
Great product. So far he's doing well. I use it for Topping D50 dac.
Myrielle m.
oyaide génial
Rien avoir avec le câble secteur furutech FP-TCS31 oyaide donne plus d'impact ouverture sonore impressionnant plus réalise rapport prix oyaide fait beaucoup mieux lecteur oppo 203 par audiocom sans regret allez y franchement prise secteur furutech NCF à la clés bon produit
Stephane L.
Médiocre.
L'ampli est plutôt bien construit, solide, et semble de bonne facture.
Mais à l'usage (et sans être un puriste, souffle acceptable), des bruits parasites importants en sortie et des ronflements qui s'entendent notamment à faible volume lorsque la musique joue. Après de nombreux tests ainsi que des mesures à l'oscilloscope, difficile d'en trouver l'origine sans schéma électrique de la carte (plutôt liés au secteur Alim dans l’ampli plutôt qu’au secteur Amplification…)
J’ai retourné au SAV (par ailleurs très cordial, merci), ils ont testé avec un neuf du stock, mais constate les mêmes caractéristiques (« léger souffle et petit train de parasites »).
Je vais tenter ma chance vers une autre marque.
IRREPROCHABLE
Pour un prix dérisoire un son incroyable naturel et équilibré , du détail , les basses descendent très bas., Fonctionne avec l'alimentation 5 ampéres conseillez par audiophonics ( je n'ai pas testé l' alimentation d' origine) . Associé à des bc acoustiques niger fait aussi bien que mon ancien ampli bc acostique à 350 euros. Attention toutefois prévoir des fiches bananes ( bornier très petit ). Bravo FX audio.
Pierre G.
Petit mais super
Excellente écoute avec des enceintes de bibliothèque. Utilisé en Bluetooth avec mon iPhone.
Un léger souffle dans les enceintes en l’absence de musique.
Je recommande.
jean francois F.
excellent cable
Très bon rapport qualité-prix. Neutralité, naturel, précision sans agressivité. Pour l'aération elle arrive après rodage (qq dizaines d'heures). Très satisfait, j'en commande une second paire.
Rachid Z.
Parfait en termes de qualité sonore et aussi très pratique du point de vue de la connectique très variée, y compris toslink optique !
Un produit de très haute qualité.
Ludovic R.
Nickel !!!
Comme d'habitude, un service au top, une livraison parfaite et des supers produits !
Que demander de plus !!
Super et pas chère...
Câble très souple et de qualité, Nickel pour un câblage de qualité sans se ruiner.
Tout à fait satisfait
Réception rapide après commande et emballage tout à fait adapté.
Fiche simple à utiliser, penser au fer à souder et à l'étain à l'argent pour la soudure, sinon ce sera sertissage.
Simple et efficace.
Olivier B.
Très bon produit.
Je passe en direct du DAC sur mon ampli lampes single ended 300B et ce petit preampli réglé en gain 1 environ, donne encore plus de dynamique et de chaleur pour mon ampli à lampes (made in maison). Ceci dit un gros conseil : ATTENTION : il déphase ! (Ça ne veut pas dire bien sûr qu’il inverse gauche et droite)... donc rattraper le coup avec les câblage des enceintes en inversé phase, neutre. Sinon pour le prix ! Excellent (peut être que des lampes meilleures seraient de bonne augure mais attention aux arnaques des lampes chères, qui en fait sont des basiques...)
Jan-Paul M.
Impressionnant
Rapport qualité prix imbattable. Associé à une paire de Focal 706 et un vieux Magnat Sub 250A, cet ampli minuscule délivre un son impressionnant.
Bien emballé et livré en trois jours, rien à redire sur le service Audiophonics. Ravi de mon achat.
Eric G.
Bon câble de remplacement
Acheté pour confectionner des câbles d’alim de remplacement pour mes équipements hi-fi.
Bon produit de par sa fabrication.
J’ai pas la Prétention de faire des éloges dithyrambiques sur les pseudos apports sur la qualité sonore.
Mais j’ai remarqué que certaines électroniques vibrent moins, donc moins bruyantes qu’avec les daubes de câbles fournis par les constructeurs.
Donc rien que pour ça c’est déjà un bon plus.
Car une électronique moins excitée par des courants parasitaires liées au champ magnétique alentour est une électronique qui fonctionne mieux, donc dégrade moins le flux sonore
Eric G.
Bonne prive IEC
Bon produit.
Bien fait.
Mais n’est pas fait pour des câble de diamètre supérieure à 8mm.
On ne peut plus utiliser le manchon de protection fourni
Eric G.
Prise mal pour câble alim
Produit bien fait, respire la qualité.
Parfait pour la confection de câble alim de remplacement des daube livrée d’usine.
Gilles C.
équipe les iguana
Odyssée Acoustic utilise ces HP dans leur enceintes Iguana que je possède depuis 2012.
en tweeter un DT-99 également de chez Monacor accompagne ces bas médium.
le tout est vendu 1200€/l'unité
Pierre M.
problème
je ne peux donner mon avis, en effet ce câble (je ne suis pas électricien) me fais tout sauter à la maison, je pense que le problème ne vient pas du câble par lui même mais de mon installation électrique (maison des années 70/80), donc je vais reprendre le même mais en 3x2.5, là je sais que je n'ai pas de surprise, donc attention à vous regardez vos installations avant achat
Pierre M.
produit conforme
Rien à dire ce produit est de qualité, de plus il es conforme aux autres avis publiés, clarté et dynamisme sont de la partie
Pierre M.
bien sous tous rapports
J'ai acheté ces prises car mon est assez petit en espace arrière, vraiment très pratique pour qui comme moi n'as pas forcément de place, rajoute un peu de clarté et de dynamisme à l'écoute
jan willem d.
Superb sound...
Works very well with Roon and my AVM DAC/Amplifier. Acrylic case is a bad choice. Therefore I ordered the aluminum case for about 60 euro's extra. Should be available without the acrylic case!
Yann J.
AUDIO GD USB Isolator for AMANERO Isolator for Amanero USB / I2S
Yann J.
Impressionnant!
Après avoir lue un peu partout que l'ordinateur polluait le signal audio via l'USB, je me suis décidé à monter ce composant dans mon Master 7. Je n'espérait alors pas autant de progrès sur l'écoute.
Mon laptop moderne est décidément une source de perturbation. Mais ce n'est plus un soucis maintenant. Ce seul composant révèle l'énorme potentiel du reste de ma HIFI : M7 + M10 + LS50.
Le montage fut relativement facile car je n'ai pas eu à souder le régulateur de tension CMS.
Cette amélioration vaut bien son coût. Je la conseille si un manque de limpidité dans la texture des notes est ressenti.
Daniel I.
Bornier encastré
Borniers de bonne qualité apparente, seront montés ce weekend sur les caisses Altec. A voir à l'usage et dans le temps.
complément gain
Complément à mon avis : bien qu'indiqué dans la notice, je ne savais pas ce que c'était que high/low gain, je pensais que celà servait uniquement pour les casques. En appuyant 3 secondes sur bouton télécommande gain/direct on passe en high gain, l'ampli devient plus puissant pour des colonnes à faible ou moyen rendement. Sans qu'il y ai de distortion. Sans ce réglage, on ne sentait pas les 2*110w en 8ohms.
Didier B.
Didier
Livraison rapide, produit conforme à sa descrition et de très bon rapport qualité.prix. TOP
Athanasios M.
Very cool!
Exactly what I needed!
Athanasios M.
Very nice!
Materials very good, fit and finish very good!
Athanasios M.
Very nice!
Athanasios M.
Very nice!
Athanasios M.
Very nice!
The materials are pretty good, the fit and finish is very good
