Dominique R.
Hautement recommandé
Dominique R.
Marc J.
Customers reviews - There are 20174 reviews.
John M.
John Zwolle
Perfect sound!
Judith K.
Best power and speaker cable at the moment
I have used Neotech, Siltech, van den Hul and Furutech powercords and alltough they are also very good there is a common problem. Shielding closes the sound but you can dig up more details from the noisefloor and there is less digital hash. Unshielded cables on the other hand have the boogie factor because the transients can come through at the expense of some noise pick up. Cables act as compressors. Enter the Ramm cable. The construction (6 wires x 16 awg OCC copper from 7 x 0, 5 mm2 strands) with air dielectric is a near perfect choice. The air dielectric between the strands and the inner core is extraordinary for this kind of money. And you also get a lot of OCC copper. The shielding is very subtle on this cable with a thin foil around the 6 conductors and a general thin foil with a drain wire. Sound is great with a lot of options for connecting. (power cable, single wire, biwire, triwire). Expect a non-congested open and round 3D sound with no hard edge. OCC gives depth and there is a lot off slam. It doesn't kill the Boogie factor! Pair it with good connectors (oyaide c-037 or c-004) and you have a 1000 euro cable for far less money! Only downsides are the size and because of the solid strands it is not easy to bend. But who cares. This is foottapping happiness and hands in the air waving kind of music making.
CHRISTOPHE G.
Répond parfaitement à mes attentes. Montage sur cable Réal Cable 3D avec fiche bananes Norstone. Finition propre de l'ensemble.
Livraison du produit sous enveloppe à bulle parfaite.
A recommander sans soucis.
alain M.
drive cd de base equivalent à un drive HG ...si
vous filtrez au maximum l 'alimentation secteur du iPurifier ... j 'ai utilisé 4 filtres quiet line en série sur 1 barrette ordinaire ... et ensuite encore mieux ... 1 batterie power bank pour smartphone 5v 1000ma ... à recommander très fortement !
Mate P.
Great
Great sounding amp. Best value for money. Need good power supply.
Mate P.
Danger
AC input voltage must not exceed 24,8V because input capacitor is only 35V DC.
Rectified AC 24.8V is 24.8*1.41=35V
Now I need new PSU.
Carlo V.
Alientek D8
It's a perfect budget amplifier; few adjustments allowed but good overall quality..
Damianos D.
Practical case, almost as described
The characteristics and dimensions of the case is as described. It has anything you might need for assembling a pi2/3 with a digione, even screws and spacers provided also by digione. The assembly is easy and intuitive. However, in my case it was not a black acrylic but a light brown cardboard. I'm OK with that, I would order it in any case, but for this difference in description I can't give the fifth star.
Francis L.
Simplement parfais
Sur mon installation un câble qui fait parfaitement son travail
Une qualité de fabrication sans reproche
Damianos D.
Excellent performance at a reasonable cost
Excellent performance with pinpoint imaging. Quick and easy assembly and integration with either pi2 or pi3. Easy setup with Moode Audio. Quick delivery (4 working days to Greece) via La Post with reasonable shipping cost.
Børge F.
Great product
Very nice finish, look and feel.
I just wish you could order the backplate without the cutout for the Schaffner filter (just like for the 2U, 3U and 4U)
Jesús G.
Buena compre
Tienda seria, envío rápido y buen precio. Recomiendo actualizar firmaware a última versiçon (02/19) vía wifi. Este fiio mejora notablemente a sus antecesores, tanto en diseño, funcionalidad y sonido. Recomendable su compra.
Christian F.
rapport qualité-prix monstrueux !
Après quelques jours d'écoute non -stop, je ne peux que me féliciter d'avoir acheté ce casque. Il est beau, bien fabriqué, fourni avec de nombreux embouts (12 paires ), un joli boitier de rangement. Il sonne très bien, couplé à un lecteur Cowon et des fichiers Hi-Res c'est un vrai plaisir ! Il tient parfaitement dans l'oreille, sans fatigue sur les longues écoutes. Seul regret, dommage que le connecteur jack du câble ne soit coudé, pour plus de solidité. On verra sur la durée. Vraiment content de mon achat et merci aux avis précédents qui m'ont aidé à me décider.
pas emballé.
j ai deux autres modèles à la maison et ils sont meilleurs .
attention il ne rentre pas dans les neutrik xcc pour câble aes / ebu .
trop gros.
mon prochaine essai sera le canare DA 202 .
Emmanuel G.
EXTRA
Excellent rapport qualité/prix pour ce câble "de base".
Il convient parfaitement à mon ensemble préampli/ampli ATOLL et enceintes DALI Zensor 7 (ensemble à plus de 2000€ tout de même) et je l'ai même préféré au modèle EPILOGUE de ce même constructeur dont je trouvais la tonalité trop descendante.
Avec ce "petit" ONYX, aucune frustration côté bande passante, une scène sonore très aérée et beaucoup de micro-détails.
A tester sans a priori !
Michel B.
Knob Aluminium Notched Shaft 40x17mm Ø6mm Black This 40mm diameter and 17mm deep black Aluminium knob has a 6mm diameter notched pin. A perfect button for mounting on a DIY project or as a replacement for a damaged button, at...
Bouton Alu. 40mm
Parfait, conforme a la description, délais OK. Merci
jean-claude G.
excellent cable, clarté ,équilibre et profondeur du message respectés
jean-claude G.
WBT-0442 Cable Crimping Tips with Insulation 24k Gold-Plated OFC Copper 2,50mm² (Set x10) Crimp sleeves for 2.5mm² cable, 24k gold-plated.
très bon produit facile à installer
Hervé B.
Très simple, très bon et pas cher.
J'ai commandé ce bornier pour mes diy car c'est celui monté sur mon Goldmund. J'ai essayé plus gros/cher et je n'ai pas senti de différences.
Hervé B.
Très bonnes prises
J'ai commandé différents modèles de RCA et celui-ci, j'y reviendrai, c'est du tout bon.
Hervé B.
Très pratique
Un bouton offrant de nombreuses possibilité, qui semble solide et sur lequel il est facile de souder sans voir le plastique fondre immédiatement. L'éclairage est un peu puissant mais on s'y fait vite.
Attention au diamètre important, tout le monde n'a pas un foret de 25mm à la maison, mais une fois monté c'est agréable à utiliser.
Alain R.
Bon condensateur à utiliser à bon escient
J'utilise ce condensateur pour les filtres d'enceinte, mais pas pour le passage direct du signal vers les HP, pour les retours à la masse ou les compensations d'impédance du HP. Ca forme particulière, gros diamètre et longueur faible, permet de faire des filtres qui tiennent sur des plaques de plus petites surfaces.
Alain R.
Article au top
Je me sers de ces bandes pour faire la jonction entre de gros condensateurs à vis. La section est assez importante pour passer de forts courants mais on peut quand même souder un fil de grosses section dessus, pour peu que le fer à souder fasse 80W
Hervé B.
Tres bien / trop bien?
Sur mon Marantz 2238BL ces ampoules éclairent vraiment très bien, mais leur puissance plus importante que les originales changent l'éclairage et donne un aspect presque trop moderne à l'ampli. Ce n'est pas rédhibitoire, mais si vous tenez à un aspect vintage il vaut mieux prendre les navettes à filament.
Christophe M.
De bonne facture
Fiche de qualité qui associée au mogami 2549 ne pose aucun soucis de mise de oeuvre, soudure aisée chaque conducteur s'insère sans difficulté dans la fiche.
Étonnant et même très bon
Étonnamment bon cela marche bien pour le prix
Et la fonction subwoofer est géniale car avec une paire de satellites et un bon subwoofer c'est génial l'illusion est impeccable pour un prix dérisoire. Le bluetooth en plus est bon un peu de souffle mais franchement rien a redire a acheter les yeux fermés pour une petite chaîne Hi-Fi, de bureau ou aide a une TV
Belle évolution et excellent dac
Possédant le hat 9023 en tcxo et en plus le smsl m8 en essayant 9018 contre toutes attentes le 9038 va plus loin et est bien meilleur testés sur plusieurs oreilles le verdict est sans appel il est plus doux dans les aigus moins brillant ou clinquant , moins flatteur mais plus liquide plus analogique en sommes. La scène sonore est très agréable les voix aussi. franchement je voulais m'orienter sur de l'akm très belle découverte que ce 9038q2m en hat Raspberry.
Conditions: Pi3b volumio et alim AUDIOPHONICS dédiée ampli casque AUDIOPHONICS en classe A cf test qobuz et toute la gamme momentum Sennheiser filaire y est passée , testé sur klipsch rf82 et atohm eurus et ampli Pioneer et smsl 2.1
Stéphane R.
Insonorisation portière
Produit acheté pour améliorer l'insonorisation de portière de voiture.
Commandé le jeudi, livré samedi :)
Associé au stuffson 5k que j'ai posé sur la partie tôle extérieur, le résultat est satisfaisant avec une diminution du bruit dans l'habitacle et un son beaucoup mieux défini.
Rik R.
TOPPING DX3 PRO DAC 2x AK4493EQ XMOS XU208 32bit/768kHz Headphone amplifier Bluetooth aptX HD Silver Topping's DX3 Pro fulfills both functions of DAC and headphone amplifier. It offers excellent performance when connected to a digital source by wire or Bluetooth. Multiple...
World of difference
Befor plugging this little beauty into my iMac, i was listening with my m50x cans directly plugged with jack or using my old Soundblaster USB dac. Thought i had the best sound ever. No. I did not. This DX3pro opened my ears.
There is so much detail, and at the same time the listening experience is smoother. I can turn the volume very low and still hear all details. Which my former soundblaster usb-dac did not provide.
The volume button is lovely with little metal clicks you feel when turning. Just look after yourself because the sound is so clean, you will forget your loud volume easily. But the same is true for the opposite: you can turn it very low and still enjoy detailed full music.
Just hooked the usb cable to my iMac and MacOS automatically added the external audio device. Plug and play, no problems. Just enjoy.
Adam t.
KHOZMO ACOUSTIC Passive Preamplifier / 10k Source Selector this passive attenuator uses a precision resistor that is connected in parallel with a 1% SMD mechanical resistance switch. this resistor is connected to the potentiometer,...
Top produit (aucune coloration ni perte, finition exemplaire)
Je cherchais un preampli passif de qualité pour relier deux sources à mon ampli de puissance. Celui-ci répondait à mes besoins. La finition est à la hauteur du prix. Aucune coloration ni perte audible. L'atténuateur est un plus (mais je ne l'utilise pas). Son seul défaut: le long, tres long délais d'appro (5-6 semaines dans mon cas, très loin des 2-3 semaines annoncées)
Frédéric H.
DAC Module 2x AKM AK4497EQ I2S SPDIF XLR RCA 32bit 384kHz AOP NJR 5534DD This module will allow you to design a DAC that is extremely efficient in terms of musical and precise reproduction. Based on two AKM AK4497EQ Digital to Analog conversion...
Un DAC à découvrir
Il faut reconnaitre que la construction de cette électronique est faite dans les règles. Le montage comme la mise en œuvre ne pose pas de problèmes particuliers. La première impression est bonne !
A la première écoute, je dois avoué avoir été un peu déçu. Il manquait des détails, la scène sonore était brouillonne.
Mes doutes se sont portés très vite sur le relais (situé à coté des embases RCA) . Composant plutôt cheap commutant le signal de sortie pour éviter clic et pop...
Je décide de retirer purement et simplement ce relais et de remplacer le contact travail du signal par un simple strap.
La preuve est faite à la fois de l'inutilité totale de ce relais, et surtout de son effet dévastateur sur le signal de sortie.
Tout s'arrange...et même beaucoup plus. Cette électronique est transfigurée. Précision, justesse des timbres, profondeur du grave, image sonore...c'est magique. Ce convertisseur fonctionne à merveille, apportant tout ce que l'on peut attendre d'un DAC en se faisant oublier.
L'écoute est réellement musicale et de très haut niveau.
Fabrice L.
Effet immédiat et positif
Après 2 semaines d’utilisation, je peux confirmer que ce filtre marche diablement bien. Je précise que j’ai du courant porteur à la maison. Je n’ai donc certainement pas le secteur le plus propre du monde. Je l’ai mis sur ma barrette secteur. En début de barrette j’ai l’ampli, le caisson de basse, puis j’ai mis le filtre. Ensuite j’ai le préampli et le streamer. L’effet est immédiat et très clairement notable. Tout devient plus précis, les aigus sont plus rapides. Les basses plus tendues. On gagne également en profondeur de scène, je n’ai pas noté de gain en largeur. Pas d’effet négatif sur la dynamique non plus. Lorsqu’on le supprime, tout devient plus fouillis, plus brouillon. Attention aux systèmes ayant une tendance à la brillance. Cela risque d’être accentué du fait de l’augmentation de précision. On perd un peu en douceur, en rondeur, forcément… Si le système est équilibré, il le restera.
Stefano T.
TOPPING DX3 Pro...really good product.
I was looking to improve the sound of my system based on an integrated amplifier Yamaha CA-800 plus a couple of Epicure 10 (2 ways speaker) both coming from the '70s connected via DAC (USB Sound Blaster external card) to a Lenovo T420 Win7 with a JRiver player. The sound improve really a lot, deeper bass and more defined mid range tones. Even as a headphone amplifier there's no compare with my previous DAC. The quality of service from Audiophonics has been very good (fast shipment, clear & good communication). Happy with my new DX3 Pro!
Ben R.
Great little DAC
I got the pi/DAC bug a few years ago and have owned/own a iqaudio, Boss v2.0, terradac and pi-fi V2.0. All sound superb and offered fantastic bang for your buck on the music front.
But I wanted to experience DSD and have been looking at options but nothing had caught my eye.
Then I found this little beauty.
Easy to build and set up - well nothing beyond the usual pi stuff. Once up and running, wow. Plays anything I throw at it, gets a bit warm when playing DSD files but to be expected with the extra processing power needed. Sounds amazing, much warmer than the other pi/dacs ive heard. I wouldn't even like to think how much you'd have to spend on a turnkey solution to get such an engaging sound.
Only issue was the crap sd card supplied, corrupted within a few weeks. This isn't a major problem, I've always got a few spare lying around. But make sure you have too, otherwise you'll be without music for a day or 2.
philippe t.
pour découpler un lecteur blu-ray
Très bonne qualité et finition . Le réglage des pieds permet de parfaire le réglage de l' horizontalité de la mécanique de lecture et donc d' améliorer un peu le suivi de piste et d' éviter des contraintes mécaniques mal réparties sur l' axe de rotation sachant qu' avec les blu-ray la vitesse de rotation est plus élevée qu' avec un CD . De plus pour améliorer l' atténuation des vibrations lors de la lecture je n'utilise que trois disques découpleurs de pointe et la quatrième pointe est en contact direct avec le support : cela permet un fonctionnement différent des quatre pieds car les symétrie renforcent les phénomènes de résonance .
Merveilleux
Je croyais être arrivé au bout du bout en qualité et ce petit truc a encore repoussé les limites..... encore plus de détails, une spatialisation à couper le souffle, et une clarté entre les instruments incroyable.
En remplacement de l'AOP d'origine, déjà trés trés bon du modéle " AUDIOPHONICS DAC AK4495SEQ 32bit 384kHz Asynchrone USB XMOS "
Merci à Mr Aubert et l'équipe d'Audiphonics qui me font progresser dans le monde de la musique dématérialisée, grâce aux conseils techniques et très pédagogiques.
Petit préampli mais grand son.
Que peut on demander à un bon préampli? En premier qu'il soit neutre, deuxièmement qu'il soit fonctionnel. Ce PGA2310 offre ces deux qualités, avec en plus une reproduction sonore de premier ordre. J'ai été surpris par la qualité des timbres qui offrent une belle palette sonore. Quel régal sur les voix qui restituent toute l'émotion d'une œuvre. Les écarts de dynamique sont bien dosés et offrent une belle qualité rythmique à la musique. J'ai fait part à un ami de l'acquisition de ce préampli qui au niveau écoute m'a séduit. Ce dernier sans même l'avoir écouté, m'a demandé de lui commander un exemplaire, intrigué par mes impressions d'écoute. Je suis surpris de sa demande, sachant que ses écoutes tournent autour de marques telles que Mark Levinson, Vincent, Bel Canto. Affaire à suivre donc.
Joel C.
Du bon
j'ai couplé ce DX120 avec un intra Ibassi IT04, il contient deux microSD de 200G chacune tous style musical.
Venant d'un DX80, je trouve que le 120 est plus sec au niveau du son, plus clair et moins ''tassé'' dans la restitution globale. une fois mon réglage trouvé Filtre numérique ''Filtre à pente très douce'' Mode sonore ''Référence'' (à vous de tester chacun son oreille) il est parfait et d'une qualité rare pour un produit dans cette gamme de prix.
Je conseille sans hésitation.
gilles F.
excellent produit et facile à mettre en oeuvre.
bon rapport qualité prix.
CHARPENTIER P.
Il faut l'entendre pour le croire !
J'utilise ce câble pour relier un préampli / dac SMSL M10 à mon ampli en symétrique sur XLR.
Déjà satisfait par l'ELECAUDIO 2210, je ne m'attendais pas à une telle transfiguration de l'écoute par un câble d'apparence somme toute banale, utilisé sur un appareil coûtant à peine plus de 500 € !
Qualité des timbres supérieure, image stéréo plus précise, aération et dynamique ample sans crispation sur les forte, l'écoute fait un bon qualitatif qui donne l'impression d'avoir changé le M10 pour un appareil beaucoup plus cher !
Un upgrade spectaculaire et un RQP finalement excellent malgré le prix élevé.
JEAN-BAPTISTE C.
Facile à installer, il fait ce qu'on lui demande, mais ...
J'écoute Spotify depuis ma tablette Samsung sur une enceinte JBL Xtreme 2. Avantage : je peux me balader partout dans la maison avec la tablette et le JBL.
J'ai acquis ce récepteur Bluetooth pour profiter de l'installation du salon : paire de colonnes Triangle Antal 150 W branchées sur un ampli Pioneer VSX 522 K, quand je suis confortablement installé dans mon fauteuil, le SMSL B1 étant relié en coaxial. Pour l'instant, mes écoutes me laissent sur ma faim, je trouve le résultat moins défini que lorsque j'écoute Spotify sur la même installation mais à partir d'un PC portable branché relié à l'ampli via un DAC Audioponics USB ES9023 TCXO. Inconvénient du PC portable : pas de télécommande pour le contrôler à distance, alors qu'avec la tablette dans les mains, tout est sous contrôle direct.
Détail bizarre : la petite loupiote verte ne s'éteint pas toujours même quand on a tourné le bouton à fond à gauche sur OFF. Il faut parfois actionner le bouton plusieurs fois avant extinction totale. Pas plus dérangeant que ça, sauf que si la loupiote reste allumée, c'est que la batterie interne risque de se décharger pour rien ?
JEAN-BAPTISTE C.
Epoustouflant ! Incroyable !
Ce minuscule ampli a remplacé avantageusement mon Kenwood "Vintage" KA-6100 2x40 W sous 8 Ohms et qui pèse plus de 10 kg : délivre la même qualité de son - pour mes oreilles tout du moins - tout en consommant considérablement moins d'énergie. En effet, le Kenwood "brûle" 480 W, même quand il n'y a pas de signal, alors que l'Alientek s'éteint de lui-même le cas échéant.
Seul bémol : pour une raison inconnue, parfois le D8 refuse de s'allumer, l'écran reste tout noir. Après moult tâtonnements, j'ai fini par comprendre que l'USB n'était plus sélectionné comme entrée par défaut. Il faut donc allumer le D8 manuellement, et on a alors la surprise de tomber sur un menu ... en chinois ! Heureusement que j'ai trouvé sur internet la solution : https://www.youtube.com/watch?v=AXCX6kUGkGI
Au début, j'ai cru comprendre l'origine de cet "auto reset" intempestif : le port USB de mon PC est défectueux et il suffisait de bouger légèrement le câble pour provoquer ce reset. J'ai alors rangé les câbles afin d'éviter que cela se reproduise. Eurêka ! ça a marché quelques jours, puis ce matin, rebelote : j'allume le PC comme d'habitude et j'appuie sur le bouton rouge de la multiprise sur laquelle sont branchés mes périphériques, dont l'Alientek. Ecran noir, allumage manuel, menu en chinois, etc...
J'ai alors branché l'Alientek sur une autre prise, permanente celle-là, et je vous tiendrai au courant des suites d'ici quelques semaines, sauf si le reset survient encore à nouveau entretemps...
Question aux techniciens : en laissant le transformateur branché en permanence, quelles sont les conséquences sur sa consommation et sa longévité ?
Volkher H.
Excellent player (and excellent service)!
I needed a small CD-player for a pair of active speakers and chose this one after reading around the Internet for a couple of days.
I decided to order from Audiophonics because they had the most sensible price (in Europe) and, apparently, excelllent service. And the player arrived here excellently packaged and quickly. I'm very happy with Audiophonics' service! Thank you!
The player also turned out to be excelllent. I have 4 other CD players (three Marantz, two of which are top of the line) and one (older) Teac. This Shanling performs equally well (!) and is just fun to "play with".
If anyone is reading this, the build-quality is excellent (the remote not so much, which you have to unscrew to replace the battery), the sound is excellent and it is a small hefty enough machine to exude a feeling of trust.
It would have been nice to have an English language instruction manual (the one provided is in Chinese), but I don't even know if one exists.
Iwould have only needed it to figure out the USB specifications, because, apparently, that part of he player's functions adheres to age-old standards (in regard to number of tracks, folder management, etc.). I still haven't figured that out in detail, but putting an album or two onto a USB stick (flat) results in quality sound! But, in regard to implementation, it seems to be more of a gimmick because display notifications are minimal (at least for my tagged files).
All in all, at a price of around (or below) $200, an excellent little machine whose longevity I cannot comment on yet. At the moment I'm quite sure that it will last for a long time.
Malcolm R.
M Ross
An excellent product, the sound quality is much higher than the usb to spdif converter I was using before. Highly recommended.
Francis B.
précision
Il faudrait indiquer qu'il s'agit du modèle court car du coup je me retrouve avec des fiches qui ne me servent à rien car pas adaptés
alain M.
à priori c est positif ... en début de ligne AC
il faut malgré tout ... simplement filtrer les éléments les uns par rapport aux autres car ils s auto polluent ... et finaliser en incluant 1 filtre ifi audio en debut de ligne ou en sortie de prise murale ...
michel F.
Electronicien utilisateur ...
Ce petit module permet d'être utilisé avec peu de place et offre des performances plus qu'honorables pour terminer un montage dans des conditions d'écoute déjà puissantes et de qualité . Son absence de gros radiateurs est un gain de place appréciable . Une notice plus détaillée serait la bienvenue ainsi que l'utilisation du " mute " ? Mention bien !
Frederic S.
RAS
Bonne qualité de matériaux et d'ajustements.
carole b.
IBASSO DX120 DAP HiFi Music Player DAC AK4495 32bit 384kHz DSD128 Blue The iBasso DX120 is a high-end digital music player (DAP) that delivers high-flying audio performance thanks to its clever design. DAC AK4495, USB XMOS XU208, Quad Core CPU,...
Très belle finition
Un son de belle facture..un Dac utilisé à son max ce qui est rare ..ici pas de course à 2 ..3..Dac..mais un Dac AKA de nouvelle génération..
Scène aérée..son délicat et précis.. digne de baladeur valant le double du prix..une belle surprise
Merci à Audiophonics pour votre sérieux et vos produits..
Francois M.
J'ai une alimentation 12V secouru avec Batterie, j'avais besoin de 5V pour alimenter un RASPBERRY et cela marche.
