Alain S.
Vous...
Wiim Amp Pro
Nice dac amp (power dac) based on a TPA3255 chip + PFFB. The real added value of this amp is that it offers a parametric...
Fiio BR13
En soi concernant le BT il fait son job. En revanche l equalizer paramétrique bug puisqu on ne peut pas le sauvegarder ( bug...
Customers reviews - There are 19388 reviews.
Attila R.
Decent quality for the price
I bought this for ground cables so I was not really worried if the quality is not high-end. I think for the price this is a good spade plug but I would definitely not buy this for my speakers. Soldering is a pain in the back and the finish is far from flawless. Still, I have no doubt about the specs and usefulness of the product.
Attila R.
Just buy it!
I find it somewhat funny that I rate a soldering tin online, but it seems there still are small things in life that amaze me :) This Mundorf tin has a high amount of silver so I was doubtful about the ease of use. I have tried multiple tins with silver, most of which were unusable or extremely hard to work with. These need a bit more heat than your average tin (I have used 370C) but once it melts, it flows! And I mean even the silver plated wires will suck it in perfectly.
I found the best tin, I can honestly say. If you are into soldering and want the best quality, look no further.
Rene R.
Excellent produit, facile a souder et parfait pour les bras ayant des tubes de petit diamètre ( bras uni pivot,
Résultats audio a la hauteur, preferable au cables argent.................
Belles et efficaces, mais ...
Attention ! avec ZEF Max OK, mais éviter avec ZEF, étamer avec de la soudure à l'argent car sinon les vis de serrage sortes de leur filetage.
Arnaud F.
Parfait pour un iPhone
Le connecteur est de bonne qualité et fonctionne parfaitement sur les téléphones Apple. Par contre il requiert une adaptateur CTIA / OMTP pour fonctionner également sur un Android
DIDIER Z.
Pas de quoi s'extasier...
Ca fait du son, c'est léger, y'a un bluetooth, c'est pas encombrant. Pour de la musique d'ambiance lors de l'apéro, c'est pas mal.
Mais pour reproduire de la musique de qualité, mon mono-lampe 2A3 de 2x4w est plus dynamique, transparent, imagé...sur des enceintes à bas rendement en plus! C'est dire...
Lors de la première panne hors garantie ce sera direction poub, évidemment.
Bref, ça fait du son...comme un McDo remplit l'estomac. Quand on a pas le choix, c'est bien. Sinon...
Cyril C.
LINDY CROMO Cable USB 2.0 Type A / Micro-B 2.0m The Cromo series is the most powerful USB cables manufactured by Lindy. This one relies on a well thought out design and oriented towards a technical reality, to meet a need for...
Parfait!
Excellent câble pour ma teensy avec une livraison rapide, suivi, facture... rien à redire.
pierre a.
excellent son
petit par la taille et par le prix ce dac a un excellent son
je recommande
Philippe R.
Comparer à des produits à des prix astronomiques,fait le principal
de la musique.
Laurent F.
Cruelle révélation
Compte rendu d’écoute d’un ampli FDA SMSL AD18 associé une paire d’enceintes Highland 4303. La Source principale est un PC sous linux configuré pour une qualité de sortie CD qui alimente en USB directement l’entré numérique du FDA
Système secondaire utilisé comme « sono pour PC de bureau ».
Ecoute à relative proximité : 2 mètres entre colonnes, 2.5 mètres de l'auditeur.
A première écoute et au regard des commentaires élogieux fait en général pour cet ampli et cette paire d’enceintes, je me suis dit que le résultat était propre, sobre, très correct, plaisant pour moi dans cette rigueur un peu spartiate (avec une puissance très largement suffisante avec les +- 2x 25W RMS de ce petit ampli, précisons le), mais pas de quoi non plus en faire tout un fromage. Je m’apprêtais à me contenter simplement de cette qualité fort honorable, ayant d’autres chats à fouetter dans mon bureau que la qualité sonore du PC...
Et puis, je me suis souvenu des frustrations de ma jeunesse, à l’époque où la HI-FI était une de mes passions et où j’arpentais régulièrement les auditoriums et fabriquais mes enceintes avec des kits, notamment un extraordinaire kit de panneaux de la Maison du Haut-Parleur que je possède encore.
J’avais, à cette époque, fini par prendre conscience qu’un très gros problème était la qualité des enregistrements et pressages des vinyles… Constat que réitérait un cousin ingénieur passionné qui s’était fait construire un auditorium pour profiter pleinement de son matériel : il rapportait régulièrement les disques au magasin, au point qu’une équipe de journalistes spécialisés avait fini un jour par débarquer dans son jardin parisien... pour visiter le "Zinzin" comme il l'appelait.
Je suis donc allé me promener sur les sites de labels véritablement audiophiles, à peu près inconnus du grand public (que je suis devenu avec le temps, avec tout de même des exigences et des frustrations, mais plus vraiment le temps ni l’envie de me préoccuper trop, de sacrifier du temps et de l’énergie, à cela non plus).
Résultat des courses. Je me rends compte à quel point ma collection de CD, à quelques exceptions près, est de qualité moyenne à médiocre.
Autrement dit, ce micro système (à moins de 400 euros soulignons le…), procure un son magnifique avec des enregistrements de grande qualité ; toujours magnifique alors (!), souvent somptueux et dans certain cas époustouflant. Plus précisément : aération, sentiment de présence physique des instruments, de leur matière, de leur éléments constitutifs, des musiciens et chanteurs, de l’espace autour ; oubli de la présence des fines colonnes qui disparaissent, semblent posées là par hasard sans rapport avec le son, grâce à une présence sonore comme démultipliée en rapport d’enregistrements plus conventionnels. C’est ‘’comme une fenêtre qui s’ouvre’’, pour reprendre une expression que j’ai vu passer à propos de ces petits amplis FDA.
Le revers de la médaille, c’est que cette petite installation met aussi en lumière la piètre qualité, ou du moins la médiocrité passable, pas toujours mais en général, des enregistrements des labels les plus courants. Le son en paraît comparativement étriqué, réduit, voir comprimé, écrasé pour les orchestres, à la limite souvent de la saturation, quand elle ne l’atteint pas, et où l’on perçoit bien, par exemple, les chipotages du placage des voix sur le fond sonore compressé de l’orchestre ; le soyeux des pupitres des cordes, particulièrement des violons, par exemple y est alors souvent inexistant : à la place on a un machin, une masse aiguë sans plus ; les pianissimos et les fortes n’en sont jamais vraiment et les orchestres semblent une masse plutôt informe comme enfermé dans un carcan. Je force un peu le trait ici pour la compréhension, mais on n’en est pas loin parfois...
Ces impressions, courantes, je le (re)découvre, ne sont pas le fait de nos installations, en tout cas pas de ce petit système, pourtant de base, mais des prises de son, mixages et CD disponibles en général… puisque avec les enregistrements de ces labels spécialisés audiophiles, ces défauts disparaissent comme par enchantement… Enchantements purs...
Quelle leçon !
Me voilà donc condamné à me refaire une CD téque ou du moins à retourner régulièrement à la médiathèque…
Moralité de cette constatation : muni d’enregistrements plus courants, un système plus coloré, moins fidèle, sera en général probablement plus plaisant (je possède un petit casque économique Koss Porta-Pro pour mes déplacements, qui fait cela à merveille : toujours plaisant, ample, généreux et ''détaillé'' quelle que soit la médiocrité de la source, même très médiocre !).
Corollairement à cette constatation, écouter des labels audiophiles à peu près inconnus, et plus coûteux, sur ces systèmes plus colorés, (moins fidèles pourrait-on se risquer à dire), devient d’un intérêt moindre puisque qu’un enregistrement plus médiocre, et moins cher, y passe déjà très correctement.
C’est le serpent qui se mord la queue…
Une qualité passable, plus passe partout, avec des enregistrements plus compressés pour pouvoir être écouté ‘’confortablement’’ dans de nombreuses circonstances (la mini chaîne de la cuisine, l’installation du salon, le simple lecteur de la sdb, la voiture…) est une norme économiquement plus favorable pour le grand public, probablement moins exigeant en général, mais seul susceptible pourtant de procurer, par sa masse, les mouvements de fonds recherchés par les entreprises qui visent principalement le succès économique, condamnées ainsi par nature à reléguer au second plan un travail rivé et préoccupé seulement du sérieux et de la qualité sonore objective finale. Un label conventionnel, on le comprend fort bien, ne peut se permettre de dire à la masse de ses clients de changer ses installations pour pouvoir profiter de ses enregistrements… Ce type de label s’adapte donc à l’installation moyenne, qui se situe probablement quelque part entre l’installation audiophile de base et l’auto-radio, quand ce n'est pas pire.
Pour finir, je suis bien incapable, je le souligne deux fois, de vous dire si ce petit système (ou cette association), est meilleur ou moins bon que tel ou tel autre. Il faudrait pour cela que je passe quelques semaines à comparer des systèmes différents. C’est hors de mes possibilités matérielles, même si j’en possède déjà cinq ou six de qualités diverses, de l’audiophile à la mini chaîne d’appoint.
Je peux donc seulement dire que cette association économique est déjà un système exigeant pour les sources qu’il révèle assez cruellement, mais capable de procurer un (très) grand plaisir d’écoute grâce à des enregistrements sérieux. C’est pour moi un gage de qualité, mais, je pourrais le comprendre facilement, qui pourrait apparaître aussi comme une caractéristique peu supportable ou du moins rébarbative ou trop contraignante à d’autres.
Jean-Pierre f.
Tout en finesse
Acheté aussi par curiosité (afin de le comparer à mon Supra Quadrax) en le branchant directement fils nus en bicâblage entre mes Sonus Faber et mon ampli Marantz. Résultat immédiat tout en clarté et fluidité. Apport évident par exemple dans les transitoires du piano solo en musique classique ou le rendu d'un orchestre symphonique. Sa finesse autant physique que musicale est à essayer sans hésiter.
Hugues L.
ALLO eMMC Card 16Go with Micro SD Adapter Allo offers a high performance eMMC card of 16GB, delivered with a Micro SD adapter to connect it to your PC or SBC.
Bien reçu cette carte, je voulais faire comme Renaud D. ci-dessus mais mon PC ne la reconnait pas :(. Comment se mettre en relation avec Renaud D. ?
David T.
Bananes de qualité, accepte mes cables de 8mm sans broncher.
Livraison ultra rapide et très bien emballée. 100% satisfait
Attila R.
Amazing value, highly recommended!
I have tried a few cables in my system and although I am not a fan of power cable upgrades it was obvious I need to buy proper cables for all equipment to maximize its potential. This cable seemed to be the right value for the price in all aspects.
The chinese cable I used seemed to work way better than the factory supplied one. Then I changed to mid tier Isotek cables (same gauge as the AC14) and although it prooved to be a decent upgrade giving more detailed sound, it seemed to restrain the bass register for some reason.
Now that I have changed the cables to the Pangea, I have even more detail (in the highs too) and surprising amount of improvement in the bass register. It also seems like the stage is deeper a tiny bit. I do not wish to upgrade to anything more as I believe it really gives a chance to my Arcam and Primare integrateds and phono preamps to show their full potential.
I am truly happy with this purchase and Audiophonics.
J-C- P.
Une belle surprise
J'attendais un léger mieux avec mais au final, c'est véritablement un surprenant petit câble ! Même entre un boitier TV et un petit amplificateur il fait merveille. A recommander sans hésitation !
PIERRE R.
Capacité vraiment HI FI
Condensateur d'exception avec une grande transparence et beaucoup de dynamique . Il convient malgré son prix ,pour le découplage des alimentations de préamplificateur .
ANTONIO M.
muy buena fuente lineal
Indispensable para mi DAC irDAC-II de Arcam. Ahora sí suena bien bien bien
Frederic P.
QUESTION
"Storage up to 512Go" mais sur leur site ils disent "Extendable Storage MAX 1TB" et Il n'y a qu'un seul slot SD card.. Merci d'eclaircir.
Sur le papier il accepte 1TO ...
Mais nous n'avons pu vérifier faute de présence de ces capacités sur le marché (nous les attendons depuis 2016).
Hans H.
Excelent boots.
The little rubber feet have tot be glued. If the design would be a Little different this would not be necessary. Greater feet or...
Not all micro USB connectors Will fit, There is not much space due to the ( Nice) foot of the box.
Franck D.
moyen
Lecteur valable seulement avec un dac externe car celui monté dans le produit ne vaut rien, attention en usb tout les dac ne sont pas reconnues .
Autrement c'est un lecteur de bonne qualité, le point noir c'est le pilotage par dlna impossible .....
L'alimentation interne PWM semble limité la qualité de restitution dommage.
Serge R.
Bon produit. Je m'en sers pour relier ma tablette à mon DAC pour écouter ma musique et il remplit parfaitement son office. Fait produit de qualité.
Christophe D.
Impeccable pour ampli guitare
Je l'ai utilisé pour changer celui de mon ampli guitare qui était "pourri" et vraiment ça lui donne un coup de neuf vraiment bluffant, les trous sont à la bonne taille et c'est de bonne qualité, à voir dans le temps mais j'ai suffisamment de tissu pour en changer.
Très satisfait de mon achat.
Lionel C.
un Ampli casque à Tubes exception
J'ai acheté récemment cet ampli à tube pour un Sennheiser HD 700 - avec un réglage de gain "5" - cet ampli permet une restitution sonore optimum idéale pour écouter de la musique classique pendant des heures et des heures sans fatigue auditive ( comme avec un ampli à transistor basique donnant des aigus souvent trop agressifs ) avec une précision dans tous les détails de l'enregistrement -
Sur le pop rock et toute autre forme de musique moderne , il donne un son doux et une scène sonore incroyablement riche tant dans l'aigu que dans le grave - mais il révélera aussi tous les éventuels défauts de la source car cet appareil est réellement un produit haute fidélité ...
un 10/10 pour ce produit et un grand merci à Audiophonics pour nous faire connaître cette marque Little Dot qui permet de rentrer dans le monde de la hi-fi à tubes sans se ruiner...
excellent câble
Aprés plus d'un an d'utilisation, et quelques essais avec d'autres marques plus chères, je garde ce modèle.Son rapport qualité prix est imbattable,
J'ai essayé du câble atlas a 27 euros le mètre, et franchement, faut arrêter...
Rien a dire si ce n'est la section, qui est quand même importante.
parfaites
Pour le prix, on s'attend pas à cette qualité.
Les fiches tiennent parfaitement, montée sur du mogami 2524 pour un caisson.
Livraison rapide.
cable subwoofer
Câble utilisé pour un caisson, ça fonctionne très bien.
Livraison rapide.
Emanuele D.
ottimi connettori
connessione buona ed assemblaggio semplice.
Romain B.
Connecteurs trop gros
Les connectiques sont trop grosses pour mon ampli. Les deux connecteurs RCA sont en contact lorsque je les branche....donc impossible de les utiliser.
Les connecteurs ont tendance à se dévisser tout seuls et la petite bande rouge ou noire n'est pas moulée/peinte mais est un autocollant qui s'est vite décollé.
La gaine tressée fait bel effet mais les extrémités en plastique brillant semblent assez fragiles.
Dans l'ensemble ce câble permet d'avoir un élément qui paraît beaucoup plus cher que les 10€ qu'il coûte vraiment. Mais ne le regardez pas de trop près....
Romain B.
Bien mais connexion instable
Quand il fonctionne j'en suis très satisfait. Le fait que le réglage de volume influe aussi sur la sortie RCA est très appréciable.
En revanche la connexion est relativement instable sur mon MacBook Pro 2017 ; je perds la connnection sans raison (ordinateur et récepteur dans la même pièce) une à deux fois par jour. La reconnection est toujours fastidieuse.
Le mode d'emploi n'explique rien du tout, impossible de savoir à quoi correspondent les séquences de couleurs des LEDs (parfois vertes et parfois rouges, mais il semble que rouge signifie que tout fonctionne et vert annoncerait un problème) et il semblerait ne pas avoir de moyen d'effectuer un "reset" complet de l'appareil.
Maxime S.
Excellent...
Reçu début septembre, Colis livré à date prévu et très bien emballé. Rapport qualité prix imbattable. Fonction Bluetooth excellent ( essais à + 10 M concluant sans perte ). Connectique complète. Encombrement mini. Parfait pour mon système d'enceintes Bose Accoustimass 3. Seul Bemol : la fonction Hifi ( Direct source ) n'est pas présente dès l'allumage et donc petite manip. en plus.
Gérard T.
Module indispensable
Pour ceux qui utilisent des liaisons symétriques, il s'agit d'un module de très bonne facture qui fonctionne effectivement tel que décrit. Juste un petit bémol, il manque en entrée un filtre HF en PI de type double self VK200 et un condensateur 1nF si la ligne est très perturbée. On aurait aussi pu prévoir une alimentation 48V DC (pour micro amplifié avec sortie équilibrée sur transformateur) mais ceci n'enlève rien aux capacités de ce petit module.
Condensateurs très bien finis, du Mundorf quoi, encombrement réduit pour des valeurs plutôt élevées, très content de ce choix !
Fiches de haute qualité et polyvalentes, pour un prix très correct, construction de qualité très bien fini, aucun reproche !
De la qualité
De la qualité, pour un tarif somme toute peu élevé au regard du matériel mis en oeuvre.
Belle pièce
Composant de très haute qualité, très bien fini, mais attention à son encombrement, il sera parfait dans une enceinte, mais pour un ampli à tubes, prévoir beaucoup de place, il fait la taille d'un bouchon de peinture en bombe.
Magnifique
Tout simplement magnifique, construction hors-normes, pour un composant très bien fini, un seul dommage, qu'il soit caché dans mon ampli...
snif !
Belle pièce
Construction parfaite, pour un produit parfait, que demander de mieux ?
MUNDORF MCAP SUPREME EVO SILVERGOLD Capacitor 1000V 0.33µF Since 2015, the MCap Supreme EVO SilverGold capacitors have been the undisputed top-of-the-line product from Mundorf. It combines all of the brand's technical strengths, such as...
belle qualité
Matériel Audiophile, très belle construction et finition, le top !
Magnifique
snif !
Knob Aluminum D Shaft 30x28x22mm Ø6mm Silver This aluminum knob with a 6mm flat axis, silver color and dimensions of 30x28x22mm is ideal for DIY integration, for example in the design of an amplifier, preamplifier or any...
Belle pièce
Bouton de très belle facture, finition au top, très content de cet achat !
Claude B.
Excellent DAC et SAV au top!
J’ai acheté la version précédente de ce produit en 2016 pour complémenter un kit RaspDac DIY, qui m’a donné satisfaction, même si j’ai vite noté la présence d’un bruit de fond qui devenait gênant lorsque j’écoutais de la musique à volume (très) élevé, ce qui est, disons-le, assez rare. Le temps a passé, et ce n’est que récemment que je me suis décidé à parler de ce souffle au SAV d’Audiophonics, car je me demandais si le problème ne venait pas de l’alimentation lambda que j’utilisais. J’ai reçu une réponse très rapide et courtoise de la part de David Aubert, qui m’a proposé quelques tests pour localiser le problème. Après différents essais, il est clairement apparu que le souffle trouvait son origine dans la carte DAC elle-même. David Aubert m’a alors demandé de renvoyer la carte. Après contrôle par le SAV de la réalité de la panne, la carte a été gracieusement échangée pour une V4, et ceci bien que le produit retourné ne soit plus couvert par la garantie ! Le bruit de fond a complètement disparu après montage de la nouvelle carte, mais il s’est avéré que le câblage de l’écran du RaspDac n’était pas le même que sur la V3. Le SAV d’Audiophonics m’a alors envoyé les câbles adéquats, là encore gracieusement.
Merci encore à David Aubert et un grand bravo à Audiophonics pour la qualité exceptionnelle de son SAV !
Gareth J.
Super rapport qualité - prix
Cable à visser, sonorité et rapport qualité prix au top.
Mais attention toutefois aux trous qui ne conviennent pas aux cables de forte section comme les Elecaudio OCC FEP et les vis où la plus petite clé Allen de 1.5 mm ne rentre pas. Ni des instructions de montage ni de clé ne sont fournis mais j'ai finalement réussi à visser avec une Torx T5. Je maintiens 5 étoiles pour le premier point.
Xavier C.
astuce pour Daniel L
Le niveau de votre source est peut être insuffisant pour profiter de toute la puissance de votre ampli. Vous pouvez l'optimiser via le sélecteur DIP situé dans le boîtier (4 vis à enlever pour ouvrir la partie supérieure du boîtier) en positionnant le switch 4 sur on.
En revanche, pour ceux voulant réduire un gain trop élevé, cela n'est pas possible : le réglage usine est au minimum.
dany g.
ampli pour caisson de basse sono
livraison en temps et heures, correspond pour le prix à mes attentes, étamer les pistes rail d'alim et sortie transistors, et c'est nickel.
ailettes radiateur un peu petites, et mauvais sens, mais c'est pas grave pour mon montage casson de basse sono.
je regrette tjrs comme mes premier achats chez ljm, la doc qui n'est pas fournie sur une feuilles A4 lol, mais rien de grave, internet est là(transfo conseillé, ampérage pointe des transistors, ou comment les bridger, , je pinaille , là. je reprendrai des modules ljm, et suis content du site et du suivi.
yann M.
excellent appareil
appareil etonnament bon et pratique
il ne manque rien
la portée du bleutooth est impressionnante
Andrew M.
Power your I-SABRE DAC board & Pi
Bought this to power the I-SABRE DAC
Andrew M.
Great DAC and design
I first bought the complete system with case, pi, dac, etc and was very impressed with the unit and the sound. Having the audio and power on the same side as the I/O on the Pi is a great design and makes for a cleaner config. Wanted the same DAC to use with another piCorePlayer I want to build for another room because the sound quality. Long over due. The fact that it also works with a 2 line OLED display for smaller packages is another bonus.
Petter Jacob L.
Elna capacitors are normally a very good choice.
Have used Elna electrolytic capacitors in several electronic components and have never regretted.
Petter Jacob L.
Seems Solid
The potentiometer seems solid. Rotation of serrated axis is solid and fine. Have not used it as volume control yet.
Petter Jacob L.
Nice and compact size.
