Claude T.
Bonne config
L'ensemble
- Monitor Pro contrôleur.
Apporte un plus...
Claude T.
Bonne config
L'ensemble
Apporte un plus...
GEORGIOS F.
Excellent product, same function as far more expensive 'snakeoil'
Very happy with this product, easy to setup, completely transparent to the PC, autoconfigures as a USB composite device. Immediately noticed the sound becoming more robust and the range extended. Highly recommended.
jacques F.
Parfaites
Belle fabrication, serrage des câbles efficace et contact optimum
jacques F.
Placés sous un caisson de basses, ces absorbeurs de vibrations améliorent nettement le rendu des sons graves.
Rene C.
Excelent test divice with earth, easy to use
Use the adaptor together with your NEW "DIY" mains cable for for BURN-IN, connected fx. your refrigerator for a minimum of 60 days
Use it together with the Elecaudio power line and electrical safety tester for 230 volt and check the polarity / correct connection in your mains NEW "DIY" mains cable
Ivica M.
USBridge
*I want to add to my review: I have posted my DSD problem on Computeraudiophile forum and Allo support has resolved my problem in less than a day!!! GREAT!
Ivica M.
USBridge
I'm overall very happy with my purchase. I have managed to get all up and running, in short few days. I am running roon core on my desktop computer to roon bridge on USBridge. Allo GUI is very easy and useful. However I'm not able to play DSD files yet, since my DAC/Xmos is not supported with ALSA yet, but I believe I'll make it work in the end. PCM works flawlessly and sounds great! Alu box keeps system running on about 50C.
Marc R.
HP d'exception
Acheté pour remplacer le même modèle qui a rendu l'âme au bout de 22 ans dans un caisson home made de chez Elektor et attaqué par un ampli du même age lui aussi home made schéma Elektor.Un haut parleur fabriqué depuis autant de temps est une valeur s^re.En home cinéma ça déchire dans 65 litres.Je recommande vivement. Audiophonics est aussi une valeur sûre.Vraiment très content car j'habite quand même en Martinique
Thomas L.
Well done
Good solid product. Good service. tres bien!
Jean-Charles O.
Bon lecteur réseau
Le DigiOne Player est un très bon lecteur audio, coté son je n'ai rien à lui reprocher. La solution intégrée avec Volumio fonctionne très bien, il y a juste à brancher et a écouter ... Aujourd'hui c'est important d'avoir une solution hardware et software évolutive et OpenSource pour ne pas être bloqué avec des lecteurs réseaux beaucoup plus chers bridés sur certains services (spotify, Tidal, ...)
Le seul reproche que je peux faire à ce lecteur c'est la gestion de l'arrêt et surtout du redémarrage car il n'y a pas de bouton On/Off sur le boitier.
Mon deuxième reproche concerne plutôt Volumio, c'est une super solution mais coté sécurité ils sont un peu dans le rouge ... mais bon tout cela n’enlève rien à la qualité du son.
Coté AudioPhonics, c'est parfait des conseils avisés et un support à l'écoute, la livraison parfaite aussi.
Bonne écoute à tous
Dominique b.
Produit tout à fait conforme à mes souhait.
Livraison rapide
Lionel G.
Commande pour un ampli Madison TA10BT
Un accueil tout à fait chaleureux et généreux en information pour le profane que je suis en matière de tubes. L'envoi est arrivé parfaitement emballé dans des délais très raisonnables...
Recommandation sans réserve.
Bruno P.
Fonctionne bien sous Linux
À condition que le paquet alsa-lib soit à jour (≥1.1.6), le périphérique expose deux interfaces. La première fait DAC + passthrough LPCM en SPDIF (2.0 uniquement évidemment), la seconde fait passthrough DD et DTS (en 5.1).
Dans ces conditions, ce périphérique fonctionne parfaitement.
Gilles G.
Cette pince avec son système à cliquets permet un sertissage sans grand effort et une bonne prise en main.
Gilles G.
Gaine coton
Excellent produit. Souple, solide, agréable au touché et facile à poser sur un câble.
satisfaisant
Le rapport qualité/prix est très bon, ces borniers acceptent du câble de 5mm de diamètre, bien au delà de ce qu'on met dans des enceintes. Le contact semble bon, toute la musique passe sans problème.....Pourquoi payer plus cher ?
Bien !!
bonnes petites cosses, pas chères, qui se connectent bien aux bornes des HP (bornes plates). En tous cas meilleures que celles d'origine de Klipsch !! Se sertissent très facilement (mais j'ai quand même mis un point de soudure). Donc que du bon, on verra ensuite dans le temps.....
Yannick M.
J'utilise ce câble depuis quelque temps, en alternance avec de l'Elecaudio SC221OCC, du Neotech Nemoi 3220 et quelques autres...
A l'écoute il me semble supérieur à l'Elecaudio, pourtant déjà pas mal, plus neutre et un peu plus transparent, avec un rendu global très "relax", et il est un peu moins cher.
A mon avis, à utiliser avec des systèmes suffisamment neutres, car il ne va pas corriger un défaut d'équilibre.
Yannick M.
excellent !
J'ai essayé ce câble de modulation après avoir essayé le ELECAUDIO SC-221OCC, qui me semblait déjà pas mal, peut-être un poil "hifi" dans le sens qu'il semble augmenter la bande passante de façon un peu artificielle, peut-être à réserver à des systèmes un peu trop "médium".
puis le NEOTECH NEI-3004, qui est immédiatement et clairement supérieur à l'Elecaudio chez moi, pourtant il est moins cher.
Bien plus neutre, et plus transparent.
Et pour finir, ce Nemoi 3220, qui au départ me faisait un peu grincer des dents, malgré déjà des qualités de définition et de dynamique, disons que neuf, le son semble trop tendu.
Enfin, il lui faut bien 2 semaines de rodage pour bien se déployer, mais après cette période, ce câble est très très supérieur aux 2 précédents, la dynamique, le légato, la définition, et surtout les timbres les nuances et l'aération, qui font que les sources numériques sonnent un peu comme si elles étaient analogiques.
Du coup, bien que plus cher que les 2 précédents, je trouve que le rapport qualité prix de ce 3220 est bien supérieur !
Je trouve même que maintenant, une source MP3 (webradio) sonne mieux qu'un lossless avec les câbles précédents, c'est dire !
A noter que mon système est constitué d'un ampli monotriode 300B de très haut de gamme et de haut-parleurs Altec à haut rendement. Avec diverses sources, lecteur de CD Nad et µΩ, tuner FM à tubes, et streamer/server musical moOde à base d'Allo Boss.
Il me tarde de pouvoir tester son pendant en câble HP, le NEMOS-3080.
Et peut-être plus tard les versions argent modulation et hp, pour peu qu'elles soient disponibles au mètre.
Pierre P.
Carte très transparente
Une des meilleures cartes usb/spdif sinon la meilleure.
Eric R.
Produit livré très rapidement, conforme à mes attentes , il fonctionne très bien .
je recommande .
Eric
Pierre H.
absorbeur de vibrations
Utilisé pour améliorer les performances de ma première paire d'enceintes, Mordaunt-Short 908, dont le haut-parleur de grave latéral (26 cm) fait fort vibrer leurs parois mdf. Après avoir traité les parois internes de la première enceinte, j'ai fait le comparatif avec celle non encore traitée. Un verre d'eau placé au sommet de chaque enceinte, on joue du grave à fort volume. Constat, l'eau tremble à peine sur l'enceinte traitée, sur celle non traitée l'eau subit de fortes ondulations et même un creux central qui oscille. Une fois la paire traitée, le son est plus propre, le grave ne bave plus, rendant le reste du spectre plus audible, plus présent et mieux défini. Astuce de montage: j'ai utilisé un décapeur thermique à faible température (+/-100°c) pour améliorer l'adhérence du bitume et pour faciliter le retrait du papier protecteur, avant chauffe on décolle 5 cm sur toute la largeur, sinon, une fois chaud le bitume viendra avec le papier. J'ai également utilisé ce bitume pour amortir le capot de mes électroniques. L'air de la pièce d'écoute leur transmet les pressions successives engendrées par les haut-parleurs de grave. Ici l'amélioration d'écoute est plus difficile à cerner, mais les vibrations étant l'ennemi des électroniques, cela ne peut que leur faire du bien, tout en limitant un effet caisse de résonance. Je ne savais pas à quoi m'attendre avant usage et je n'en suis pas déçu.
Pierre H.
Superbe son et réalisation
Utilisés pour pouvoir raccorder de gros câbles Monster MI 4s (bi-câblage) à mes amplis. Les connecteurs WBT de ces amplis n'acceptant pas d'aussi grosses sections (2 gros câbles à réunir sur chaque bornier), ces fiches bananes furent pour moi la solution (10 mm² étant juste suffisant). Je les ai également essayées avec du câble Naim en monocâbalge sur des enceintes Harbeth ou B&W à double bornier pour faire un pontage parfait entre borniers. Par rapport à des fiches banane en laiton, celles-ci en cuivre font réellement la différence, le son est plus clair et limpide, le grave descend plus bas et est plus riche, tandis que le medium et l'aigu sont plus consistant et mieux définis. Leur prix est raisonnable vu leurs performances et leur réalisation très soignée. Elles peuvent sembler fragiles car légères, mais elles sont solides. Seul reproche, j'ai du acheter une clé Torx TX6 pour serrer les vis, au prix de la paire, cette clé aurait dû être livrée. A recommander!
Rudy C.
DAC reçu ce matin donc il est un peu tôt pour commenter la qualité audio.
Le X1s semble solide et bien construit, il laisse une très bonne impression concernant l'aspect lorsqu'on l'a en main.
Je ne compte m'en servir que pour driver mon DT990 pro, et avec tout juste 2h d'utilisation j'ai une très bonne impression. A voir sur le long terme mais ça commence plutôt bien !
La spatialisation ainsi que les détails sont présents et bien définis.
Dans ma configuration , tout simplement exceptionnel !
ce câble n est pas meilleur que les autres , mais après 20 ans de mariage de differents modèle de modulation et hp et a tout prix je viens enfin de trouver le Graal avec celui-ci . mais encore une fois c est une question d associations et de chance . curieusement je l ai testé avec le mogami 2549 en modulation , quelle déception !
Alors comme j'en ai plusieurs paires à la maison je les ai tous passer en revue et le meilleur a été et de loin une série professionnelle Monster câbles studio pro 2000 .
L'écoute est devenu somptueuse .
Je ne l'ai pas utilisé en bi cablage mais j'ai simplement doubler les fils pour passé en 2x8 mm , le défi a été de trouver des fiches bananes adapté à cette taille heureusement internet est là .
ce câble ne vous conviendra peu être pas , mais il a fait mon bonheur .
Claude B.
Correspond à la description
Je l'ai installé en nomade et non intégré dans le caisson
Claude B.
Améliore grandement la vitesse et la qualité finale audio et vidéo
Eric L.
Etonnant
Concentré de technologie a prix canon
Acheté pour driver une paire d'enceintes vintage, super son, puissance et graves présents, branché sur la TV en Spdif et en Bluetooth avec l'ordi, marche d'enfer, je redécouvre mes vieux fichiers audio. Livraison rapide.
Thierry A.
Bluffant
Pour le petit budget dont je disposais, j'ai commandé le set de vibrapod sans grande conviction au départ.
Lorsque je les ai placés sous mon conditionneur de réseau, j'ai pris la précaution de les essayer sur les deux faces pour déterminer celle qui convenait le mieux (dans mon cas la surface la plus large en contact avec les pieds de l'appareil) et là, dans le rendu de l'image sonore, la sensation était que "tout prenait sa juste place".
Seul bémol, la notice non traduite en français et les spécifications d'usage en mesures anglo-saxonnes.
Gabriel F.
AUDIO-GD HE-1 Class-A Balanced Preamplifier ACSS XLR RCA Again Audio-GD strikes hard with its HE-1 of the series HE (evolution MASTER series) proposing a symmetrical Class A preamplifier of an exceptional quality. KEY POINTS:...
Après avoir longtemps admiré l’architecture, les caractéristiques de ce préampli et de l’ampli Master 3 qui va avec, je me suis enfin décidé à franchir le pas.
Car il faut du courage pour résister aux sirènes de la pub, des rédacteurs payés à la ligne ou au compliment et abandonner les marques et leur marketing aliénant pour acheter chinois.
Je ne le regrette pas bien au contraire !
Ces deux appareils pèsent à eux deux près de 60 kg (qui dit mieux) tels que les canons de la vrai Hifi le préconisent depuis des décennies et on en a plus que pour son argent.
En sortie j’ai 2 panneaux Magnepan 20.7, immenses et gourments en courant, qui maintenant sonnent magnifiquement et remplissent parfaitement une grande pièce de 75m².
- l’ampli Master 3 est très classique, chauffe peu, 450w très purs, pousse très fort et en silence entre les plages. Car j’ai connu un gros ampli intégré d’une marque prestigieuse qui vibrait si fort entre les plages…..
- le préampli est une merveille : des aigües fins et déliés jamais agressifs, des détails que je n’avais pas encore entendus comme la respiration de musiciens ou des pages de partition que l’on tourne.
La musique est ample c’est ce qui surprend le plus, les attaques sont très franches et les solos de batterie incroyables. La scène sonore est élargie et beaucoup plus profonde.
Les voix sont extraordinairement présentes, incarnées.
Les basses sont très profondes et parfaitement naturelles et les contrebasses ont enfin une largeur normale ! On entend, on voit, la corde et son grain, l’archet. Quel plaisir !
Mais il faut des enregistrements à la hauteur, la seule limite est là.
L’association de ces deux appareils est une réussite : la main de fer et le gant de velours.
Bref je ne regrette pas mon choix, je regrette de ne pas l’avoir fait plus tôt !
Je remercie Audiophonics d’aller dénicher au bout du monde des produits capables de sonner aussi bien mieux même que ceux que l’on nous présente partout mais cinq ou dix fois moins chers.
Gabriel F.
Pierre S.
Le SMSL AD18 V3 mérite une alimentation de qualité (rectificatif)
Ma recommandation précédente était inadéquate : une alimentation de 32 volts en 8 ampères envoie trop de courant dans l'AD18. C'est une alimentation de 24 volts en 6.5 (ali-express) à 6.67 (alimentation de l'AD18 V1) ampères qui donne les meilleurs résultats sans que l'AD18 dépasse jamais les 32-34 degrés alors même que l'un de mes V3 drive avec une facilité déconcertante (impossible de pousser à plus de 20/60 en appartement) une paire de Rogers L6a tandis qu'un second fait de même avec des Ls7t, C'était, en revanche, un peu juste, surtout pour les Ls6a, avec la nouvelle alimentation livrée en standard avec l'AD18 V3 (24 volts, 5.2 ampères).
Jean claude R.
IMPRESSIONNANT A CE PRIX LA
Ils ont allègrement remplacés mes Kubala Sosna Elation à un pris indécent
Jon N.
Fabulous Board--Thanks
This is an excellent power board. Made with great components and just right for DAC projects. Really fast turn around and well shipped. Very responsive to questions. Thanks again!
olivier l.
rien a dire
bon prix, bonne qualité, facile......
olivier l.
facile a mettre en place
le module est très simple a mettre en oeuvre, pour moi le projet était de remplacer les amplis sur des enceintes penta bang & olufsen 150W sous 8 ohm. bon ça marche mais un gros manque de profondeur et bass a la sortie, les 200w sous 8 ohm de l'ampli semble être non des percherons mais des poneys. cependant le kit reste sympa et simple et de bonne qualité sur les soudures et les composants.
Jerome L.
Branché sur un raspberry pi3, avec volumio et une alimentation ljneaire audiophonics, ce dac reste une solution terminale meme pour des oreilles tres aguerries. Alimenté avec une bonne alim, beacoup de profondeur, un son chaleureux et précis.
je trouve beaucoup de dac "plus analytique que la prise de son elle meme" qui en devient irréelle de précision, a se demander si c est possible, hors avec celui ci je trouve la precision alliée a un son global malgré tout.
Merci a l équipe irreprochable d audiophonics, et de leurs conseils toujours bien intentionnés et avisés.
Pierre M.
Bon d'accord, le titre mentionne "amplificateur" mais les photos de l'arrière ne permettent aucun doute : il s'agit d'un boitier préamplificateur et c'est ce que je voulais : donc opas de surprise pour moi !
Sinon, le produit est excellent : la façade est nickel et les plaques coté haut, bas et arrière sont de très bonnes finition et je ne vois pas non plus ce qu'il faut reprocher aux vis qui sont parfaites !
Bref, pour le prix, que du bonheur !
Quant
Etienne M.
Testé également à 250Hz dans la même configuration
Avec une fréquence de coupure à 250Hz dans un volume d'enceinte de 4 litres la distorsion reste en dessous des 0.5%.
A noter qu'avec 96dB maximum admissible à 1.00m, le son peut devenir brouillon sur de la musique orchestrale dans un fortissimo.
Pourtant, le calcul du déplacement de cône donnant 1.5mm maximum, on est qu'a 33% du Xmax. Avec un signal complexe, cela peut également provenir de l'ampli de 50W RMS utilisé.
Johan v.
Worth its price
After a long burn in I think this cable is worth its price.
Warm sounding perhaps a bit rolled off but very natural in its presentation.
Very good tonic for overly bright loudspeakers like some Klipsch with a tipped up mid high and top high response.
Not the last word in resolution but very pleasant! Merci Audiophonics
Jean-Michel D.
Qualités et légers défauts
Appareil très bien construit; mais très chaud à l'usage. La capot devrait être ajouré ( au moins au dessus des tubes. )
Sur mon exemplaire les leds du contrôleur de tonalité ne fonctionne pas; le contrôleur lui fonctionne normalement.
Le son est REELLEMENT meilleur avec le remplacement des 2 NE5532 par des OPA2604 ( BB ) montés sur support.
Didier G.
Bon rapport qualité
Construction solide, montage aisé, bonne restitution audio
Didier G.
Excellent cable
Après avoir équipé mon ampli, pourtant doté d'un câble nettement plus cher, et constaté une belle amélioration de la restitution, j'ai équipé les autres électroniques.
Ce câble a beaucoup de qualité : défini et énergique tout en restant équilibré ; matérialité et raffinement des timbres ; profondeur et détail de l'image.
Malgré une certaine rigidité, le montage des connecteur n'est pas trop difficile.
Marc-Olivier C.
Produit de qualité
Le Boss V1.2 est une solution DAC plug and play, au rapport qualité prix indiscutable !
Je l'utilise avec Volumio 2, et je suis entièrement satisfait de la qualité d'écoute.
Il manquerait une solution "Allo ADC + RIAA" pour RPI et ce serait un système modulaire au top !
En tout cas, c'est une chouette solution de streaming audio compacte et efficace.
Voir mes 2 avis sur le DAC : Après changement de l'AOP d'origine, ce 1622 sonne à merveille. Remplacement vivement conseillé pour monter en finesse de restitution !
Suite avis du 16 Février 2018. 2 DAC achetés depuis (un de secours). Le son métallique agressif du tout début a besoin d'un temps de chauffe et rodage, car le boîtier dégage une certaine chaleur après 2 heures de fonctionnement. Chaleur qui l'a rendu plus chaleureux ? En tout cas qui le fait "dégazer": Le vernis du circuit m'a fait éternuer en ouvrant le capot pour changer l'AOP comme conseillé par Audiophonics. Alors là je peux jouer des heures au casque avec le piano virtuel Pianoteq : pas de fatigue, de la nuance, de la finesse !!!! Sur casque Sennheiser que du plaisir ! Rapport «qualité-prix-boitier compact » Super ! Câble USB très faible jitter impératif.
Etienne M.
Très bon produit comme la plupart de large band une égalisation est nécessaire.
Utilisé avec un « DAYTON AUDIO RSS210HO-8 Reference » pour reproduire les basse fréquences, ce haut-parleur reproduit parfaitement le registre médium aigu avec une distorsion toujours inférieur 0.5%. Il faut noter par contre une bosse large de +3db au environ des 1800Hz suivie d’un creux large de 5dB autour de 6kHz avec un raccord en pente douce entre les deux soit 8dB d’écart global. Ce qui donne sans correction, des mediums très flatteur au détriment des aigus. L’accident est facilement corrigeable par une égalisation DSP en maintenant une distorsion toujours très faible et inférieur 0.5%. Le haut-parleur étant coupé à 600Hz (48db/octave), la répartition de puissance est très bien équilibrée avec le RSS210HO-8. La directivité important donne une excellente spatialisation stéréo au point d’écoute qui se trouve à 1.80m des l’enceintes actives.
A vérifier le cône semble en aluminium et non en papier.
Mikhail M.
J'ai remplacé mon hiface m2tech 2 par ce model.
Avec le cable PANGEA Premier XL 0.5m. Ce n'est que le début du rodage, mais deja TOP. Rien a voir avec hiface2.
Merci à Audiophonics pour le rapidité d'expédition.
Jean-marc B.
impressionnant
Tout ce que j'ai pu lire sur Audio-GD sur le net s'est révélé exacte.
Branché sur un Aries-mini de chez Auralic + alimentation Audiophonics,, dont le DAC m'avait déjà fortement impressionné pour le prix, tout est beaucoup mieux, mais pas que, les instruments se matérialisent sous nos oreilles.
- Scène sonore élargie
- Profondeur accrue
- Largeur de la bande passante étendue
- Donne de la matière et du poids aux notes
- Son analogique et très musicale
Bref pour comprendre il faut pouvoir l'écouter.
Du coup je deviens très désireux d'écouter son grand frère, le R2R 7He, car j'ai du mal à appréhender ce qu'il peut faire de mieux mais j'aimerais bien m'en rendre compte.
Je redécouvre ma musique et quelle plaisir.
Jm
Yvon C.
indispensable !
Audiophile de longue date, je me devais d'essayer cet appareil qui déclenche les passions et les polémiques. Au sortir de la boite, sans rodage, installé sur mon système et relié en coax. sur mon lecteur, il délivre un son que peuvent envier beaucoup d'ampli classique coûtant 20 fois son prix. Conclusions : Il peut faire le bonheur musical de beaucoup d'audiophiles en étant le coeur d'un système principal et être l'amplificateur rêvé d'un bon système secondaire. RECOMMANDATION ABSOLUE POUR CE PRODUIT AU R.P.Q. EXCEPTIONNEL.
PIERRE R.
capacités Mcap 250v
J'utilise depuis des années cette série remarquable par sa neutralité pour compenser les distorsions des chimiques dans les amplis et les lecteurs CD en les montant en parallèle . Par leur taille on peut aller de 10 à 47 microfarads en fonction de la place disponible .
