Marcus L.
Michael M.
Worth every penny!
mathieu l.
Hans Peter N.
MUSES8832E-TE1 Dual OPA SOP8 (Unit) The MUSES8832E operational amplifier is a dual OPA in SOP8 format optimized for high-fidelity and professional audio applications. This rail-to-rail OPA features a high maximum...
Replaced an SGM358
Hey there,
I replaced an SGM358 in my FIIO DK03. I am very pleased with the sound now. Thanks Audiophonics for the great service.
Hocine H.
Qualité optimale.
C'est cher au premier abord, mais une fois en main, puis installées on comprend pourquoi on met le prix. Une qualité irréprochable, une installation agréable, un maintien efficace et un son très neutre. Je tenais à remercier audiophonics car avec toutes les commandes que j'aie passée, ils ne se sont jamais trompés sur un article. un grand bravo et merci pour ce que vous nous proposez.
Pavol B.
SMSL PS200 DAC ES9039Q2M USB SPDIF Bluetooth 5.0 32bit 768kHz DSD512 MQA-CD The PS200 from SMSL is a small, compact DAC featuring quality components. It features an ES9039Q2M DAC chip, an XMOS XU316 USB interface and no fewer than 4 OPAs. It supports...
New BEST DAC under 100€
A few words about this little plastic DAC. First of all - the delivery was quick, but unfortunately, even though the package included 10 meters of network cable, they did not fill it with foam, so the paper box arrived completely destroyed. Fortunately, nothing happened to the DAC.
Now to the DAC itself. It's really a single, cheap-looking plastic box with plastic buttons, taking it apart would probably mean destroying the box. It looks really cheap in that sense. The second thing is what's in there and how it plays. And here the game changes completely. Those who saw it disassembled claimed that this is a really seriously made DAC, with quality components and a good architecture. Sound - I compared it with my flagship DAC, built on top of the ESS 9018SE chips, as well as with the NOS DAC built on the Wolfson chip, and with the R2R DAC, although "only" DIY. What I heard got me. It's true that the sound didn't have as much layering and harmonic richness as the two ESS9018SE chips, but that DAC was 20 times the price. On the other hand - the smoothness on the SABER is incredible, the richness of details, the light naturalness, the strength in the bass and yet so deep, the dynamics did not lag behind... But what got me the most was that I could literally hear it playing silently. Silence around the instruments, around the singers, the empty space around them literally played. The space is the same - at first glance more stereo than in depth. But if you listen closely, it's there, it's just not added forcibly. I still have to come back to the price, how much it costs. SMSL probably really invested mainly in the interior, as in the packaging. Although a risky purchase for me, I didn't know what I was getting into. But I'm glad I did. I love the sound of it. He is amazing. And for €100!!!!! I RECOMMEND!!!!
Istvan M.
Weak mechanics...
...or I was just unlucky. I bought two for my monoblocks and while one socket works perfectly, the entire "inner workings" of the other one, i.e. the part with the contacts, pushes backwards when I try to plug in a cable , and of course there is no contact - for some reason the middle part of this socket is not attached correctly or not at all to the sockets frame. It's completely unusual from Furutech.
Génial !!
Simples, bien conçues et facilité de mise en oeuvre. Le signal est très bien respecté. Excellente fiche.
Excellent coax
Il fait jeu égal avec un coax. Diy polarisé équivalent a plusieurs centaines d' euros.
Belle surprise et pour le tarif, c' est une aubaine !
Monte avec des switckraft RCA, beau combo ! A essayer !
900M-T-0.8D Soldering Tip Ø0.8mm This soldering iron tip has a long service life thanks to its high quality of manufacture. It will allow you to carry out your welding for your DIY projects.
Gérard M.
WONDOM PS-BC12112 BCPB3 Battery Management System Module 5x Lithium 18650 The Wondom BCPB3 is a battery management and protection module, taking advantage of the performance and reliability of the previous models while offering more battery...
Très bien.
Fait parfaitement le job pour alimenter un préamplificateur phono. MAIS attention le set de câbles et leds n'est pas livré avec comme indiqué précédemment et il est quasi indispensable.
Renaldo V.
Elipson 1400
envoi très rapide Merci
pour une mise à jour sur des filtres ( Elipson 1400 )
amélioration garantie
Renaldo V.
JANTZEN AUDIO COMPACT MKT 001-8040 Axial MKT Capacitor 160V 3.3µF Jantzen Audio's Compact MKT capacitors are made from the highest quality metallized polyester film available. Jantzen Audio has succeeded in making these capacitors more compact...
Elipson 1400
Renaldo V.
Elipson 1400
Une pépite
Je rejoins complètement les avis précédents. Pourtant câble fait cheap... Le bleu un peu clinquant aussi. Mais une fois installé, c'est un remède miracle.
Mon choix désormais.
Validey après avoir essayé Mundorf 10% et dinavix 4%( qui s' en sort très bien).
Les soudures sont belles, et le prix reste correct.
Parfaite
Excellentes fiches RCA, simple efficace et agréable a travailler et au rendu sonore
AUDIOPHONICS MUSES8920A Dual OPA DIP8 (Unit) Audiophonics is proud to present its MUSES8920A AOP in DIP8 format. This dual AOP is based on a high quality JRC (Nisshinbo Micro Device Inc.) chip, features JFET inputs and is...
Mouais
J'ai voulu essayer, je préfère les JRC 1612.
Je n' enlève pas d' étoile car c' est une affaire de goût et ils sont très bien construit.
Brice D.
Rodage KT120
J'utilise ces tube sur un Jadis DA88S et je préfère vous prévenir que le rodage est très long.
Prévoyez minimum 100 heures avant d'avoir une idée et 500 heures pour un rodage total.
Très bon tube si vous avez la patience d'attendre.
Comparativement aux étiquettes link, elles se soudent facilement et sont super bien conçu. Très transparentes, elles laissent le message via le câble intégre !
Superbes fiches aux rqp excellent
Elom G.
Top avec une très bonne réputation.
Testé chez moi dans un fosi v3, le son était bon et bien équilibré; pas grand chose à lui reprocher.
Mais pour le prix je m'attendais à un effet vraiment wahoo !
Bref, bon app très clair et équilibré mais pour moi un peu cher pour le résultat obtenu.
Elom G.
Cet aop bénéficie d'une très Bonne réputation.
Mais, testé chez moi dans un fosi v3, je n'ai pas été convaincu. Le son est doux et musical, ça c'est sur ! Mais les graves manquais de netteté et étaient même un peu brouillons.
Pour le prix, je ne suis pas convaincu.
Elom G.
très bon rapport qualité prix
utilisé dans un fois v3, cet app est assez surprenant. Le son est très bon pour son prix. Les graves sont bien tenus, les aigus corrects sans trop piquer. Il y a surtout un dynamique de fou, à la fois très agréable et peut être parfois un peu fatiguant.
Bref, pour le prix, ça vaut vraiment le coup de les essayer. Je recommande.
Elom G.
Testé dans un Fosi V3, c'est op font un peu mieux qui ceux fournis d'origine avec l'ampli, mais sans être exceptionnels. Les graves sont correct mais les aigus un peu métalliques. Le tout est un peu fatiguant; en tout cas pas très doux ou musical. Je ne les retourne pas vu le prix, mais ils ne me servirons à rien.
Elom G.
AUDIOPHONICS WIRE Interconnect Cable Stereo RCA OFC Copper Gold Plated 75cm The Audiophonics Wire serie offers a selection of affordable yet high performance cables, hand assembled in our workshop in France. The Audiophonics Wire RCA cable consists of a...
Bon câble avec un bon équilibre. Je n'ai pas pu le comparer au canard star quad qui est actuellement en rupture.
En attendant le réapprovisionnement pour faire la comparaison, je suis plutôt satisfait de ce câble.
Elom G.
Moyen
Ce câble est un bon rapport qualité prix; mais vu l'incidence du câble de modulation sur une installation, il vaut mieux mettre un peu plus cher pour quelque chose de plus équilibré. Pour 40euro le Audiophoncis à base de Mogami Neglex W2549 a été pour moi un meilleur choix.
Elom G.
Je rejoins la multitude de commentaires élogieux sur ce câble. Après avoir essayé beaucoup de câbles enceintes (audioquest, elecaudio, triangle, real cable, oehlbach), j'ai trouvé mon bonheur avec ce câble que j'ai adopté pour toutes mes installations audio, en simple et en bicablage avec la version 4x4mm2
Elom G.
TANCHJIM ONE In-Ear Monitors IEM Dynamic Ø10mm 126dB 16Ω 7Hz-45kHz These affordable Tanchjim ONE in-ear monitors feature dynamic Ø10mm drivers and a low-frequency design.
Ecouteurs de bonne qualité, sans prétention. Le son est bien équilibré; graves médium et aigus sont bien restitué. Pas de fatigue sur la durée d'écoute.
Après, ce sont des intra-auriculaires donc pas de sessions d'écoute trop longues ou pas à volume élevé, si vous voulez préserver votre audition.
Les écouteurs tiennent bien dans les oreilles grâces aux embouts de différentes tailles fournis.
Très bons conseils de la part d'audiophoncis
Serge G.
Decu
Claquements a la mise sous tension. bruit de moteur pendant la lecture.pas de clavier numérique sur la télécommande . obligé de faire défiler les chansons . vraiment déçu
Sandy G.
MUSICALITE ET PRECISION
Une belle expérience, que l'écoute de ce magnifique amplificateur.
Raccordé à un préampli MUSICIAN Monoceros, le résultat est excellent. Le différents registres musicaux sont présents, et fouillés, sans tomber dans un coté "ultra". La musique est belle, douce mais punchy à la fois...Un ampli a tube (j'en ai un) se justifie t il encore, au vu de l'évolution des "transistors" ?
IBASSO DC06PRO Portable DAC / Headphone Amplifier 2x ES9219C 32bit 384kHz DSD256 MQA 16x Ibasso unveils a new version of its DC06 portable DAC/headphone amplifier, the DC06 Pro. Compact, it features 2 ES9219C DAC chips and volume control knobs, new advanced features...
Excellente qualité audio et finition du produit
Mon meilleur dongle DAC, et cerise sur le gâteau, il chauffe peu (à peine tiède).
Cyril J.
Node2021
Respire la qualité
Cyril J.
BEATECHNIK x LHY AUDIO Filter Power Supply Module Kit for Bluesound Node X / N130 This filtered power supply module kit has been designed by LHY Audio at Beatechnik's request, and is intended for use with the Bluesound Node X and N130 products.
Node 2021
Changement de l' alimentation en une demi heure enfantin
Restitution sonore transcendai tout est plus naturel équilibré aucun regret
Claude T.
IAN CANADA TRANSPORTPI DIGI II Ultra Low Jitter Digital Audio Interface Module With the TransportPi Digi II, Ian Canada has taken their high-performance all-in-one digital audio interface for the Raspberry Pi to the next level. This module delivers a...
grande évolution
Par rapport a la version précédente, il y a une nette évolution dans la qualité du son. De plus en mode coax les parasites emi ont disparu.
Waouhhhh !
Le câble est rigide mais ce n'est pas une barre de fer non plus.
Il est suffisamment souple pour relier mon transport CD HDG à mon convertisseur HDG qui se trouve à côté de lui.
Le diamètre du câble est conséquent, la finition est magnifique, les fiches sont de très haut niveau et serties de caoutchouc à l'extérieur.
Livré en plus dans une jolie housse, ça fait pro !
Le plus important, le son : waouhhhh ! essais comparatifs avec plusieurs câbles numériques 75 ohms, il se compare à l'unanimité (de mes copains d'abord et autres individus ensuite) avec les plus onéreux, les plus réputés, que rigoureusement " ma mère " m'a demandé de ne pas nommer ici...
Bravo à Audiophonics pour ce superbe montage Haut De Gamme à un prix démocratique, livré en 48 heures.
Excellentissime !
Voilà une paire de connecteurs RCA à faible coût et de très haute qualité. Isolant PTFE Téflon, ça ne fond pas quand on soude.
J'ai pu faire plusieurs câbles de longueurs différentes grâce à ces fiches cinch montées sur le fameux câble SOMMERCABLE EPILOGUE.
Diamètre et qualité, tout est ok.
Merci Audiophonics, livraison en 48 heures.
Impeccable.
Voilà la deuxième paire que j'achète pour une jolie finition de mes câbles STRAIGHT WIRE RHAPSODY en 2,5mm2 côté enceintes.
Parfait aussi sur câble Mogami 3103.
Merci Audiophonics.
Formidable !
Je voulais solidariser des bulbes de tubes en verre nos de puissance (6V6, EL34, KT88...) sur leurs culots en bakélite.
Certains tubes avaient un jeu et je craignais qu'ils deviennent inutilisables.
Ce ruban n'est pas élastique mais il est souple et autocollant.
La largeur de 5 mm est bien, la largeur de 10 mm aurait pu convenir aussi.
Après avoir bien entouré les tubes (plusieurs tours bien serrés) à moitié sur les culots et moitié sur le verre sur 1 cm environ, ça ne bouge plus du tout.
Formidable donc !
Sur la languette de départ du rouleau, il est indiqué Koptan, c'est-à-dire que c'est du Kapton totalement insensible aux hautes températures.
Merci Audiophonics.
michel s.
Le Graal ?
Après plusieurs essais décevants avec différents câbles au mètre de tarifs plus abordables, j’ai décidé de casser ma tirelire pour voir si la qualité avait un prix. La réponse (malheureusement pour ma tirelire) est oui.
J’ai fini par trouver le son qui convenait à mes vieilles oreilles et à mon installation car comme vous ne l’ignorez pas, tout est très subjectif.(Enceintes Cantilène, Pré ampli tube, ampli classe A)
Ce Furutech FA-aS22 est un enchantement pour moi sur beaucoup de registre, (pas tout à fait neutre mais est-ce que cela existe ?) La musique coule tel un ruisseau sous les feuillages au printemps avec ce petit clapotis...Pardon, je m’égare. Je n’ai plus cette sensation désagréable que le grave n’est pas tenu, que le médium est en avant, que l’aigu est tronqué ou trop agressif. Tout est là, devant vous, en live. Les voix sont charnelles et l’intonation me semble juste. Bref, vous l’aurez compris, ce Furutech qui m’accompagne depuis maintenant plusieurs mois me ravit. Je ne regrette absolument pas mon investissement.
Je l’ai associé à des connecteurs RCA Ramm Audio et câblé le fil rouge au point chaud et le fil blanc à la masse avec la tresse à la masse côté source uniquement.
Connecteurs RCA Ramm Audio à visser 30891-GT vendu sur ce site. (voir avis)
Qu’est-ce qu’on dit ? Merci Audiophonics.
michel s.
Merci Audiophonics
Après un certains nombre de déception rencontré avec des câbles soit disant exceptionnels du marché dont je tairais les noms et vendus parfois à des tarifs frôlant l’indécence, j’ai décidé de faire des essais avec des câbles au mètre.
Ces connecteurs Ramm Audio se sont révélés parfaits pour ce genre de manip et très simples à utiliser. (Quand on dispose de la bonne clé 6 pans vendue par Audiophonics)
Si le câblage est bien réalisé, le rendu sonore peut s’avérer tout à fait magique. Après plusieurs essais infructueux, j’ai même fini par trouver mon Graal. (voir avis câble Furutech FA-aS22 vendu sur ce site)
Leandros B.
BEATECHNIK x LHY AUDIO LPS-A6 220V MK1 Linear Power Supply Module for EverSolo DMP-A6 Gen 1 The LPS-A6 linear power supply module has been specially designed to enhance the power supply stage of EverSolo DMP-A6 and DMP-A6 Master Edition network players by replacing the...
A real upgrade!
I placed the LPS in my eversolo DMP a6 master edition which is already a very nice sounding streamer/DAC.
From the first time the sound become more vivid, but the real thing happened after 12 non stop burn in.
The sound is now more natural, vivid with greater dynamics, significantly bigger sound stage, depth, multiple layers of micro details, focus, greater bass and more tremble extension with a nice silky presentation.
Highly recommended.
I hooked it on a musical fidelity m6i via kondo ksl vii interconnect, kondo persimmon power cable, kondo sp-c 2, 5 speaker cable and triangle genese lyrr speakers.
Leandros B.
Fantastic!
Those RCA plugs are absolutely neutral sounding, very nicely constructed and finished, so in that price point are a bargain!
michel s.
Pas donné mais aucun regret
Cela fait maintenant quatre mois qu'il équipe mon pré-ampli qui attaque un ampli classe A à transistors. Je le trouve bien meilleur que mon ancien NOS miniwatt Philips. Impression que le spectre de fréquence est beaucoup plus étendu. Ce qui m'enchante le plus ce sont les aigus; ils sont cristallins sans être du tout agressifs. La musique parait plus ouverte. Aucun souffle, très silencieux et musical. Je suis ravi du résultat.
Mathieu W.
IBASSO DC ELITE Portable DAC Headphone Amplifier BD34301EKV 32bit 768kHz DSD512 The Ibasso DC-Elite is the miniature version of the DX320 Max. In fact, the components and architecture of this portable DAC/headphone amplifier are inspired...
QUALITE INATTENDUE
Je ne savais pas trop quelle qualité attendre et c'est donc une immense surprise. Restitution de tres haut niveau, douceur incroyable, dynamique et surtout quelle scene sonore !!! avec mon senheiser ie 900 c'est le fameux son "hors de tete" qui est surprenant. L'image et la séparation sont de tres haut niveau. supérieur à ma Cobalt (deux fois plus cher en même temps) mais aussi à mon DAP Astell kern SE 200. C'est tellement bon que j'utilise le DAP uniquement en streamer et je sors en usb bit pertect dans le DC ELITE. Une de mes plus belles surprises de ces 10 dernières années en hifi nomade.
Gérard P.
Le pur et l'impur
Ma première source musicale est constituée d'albums dématérialisés stockés sur NAS en un lieu distinct du local d'écoute. A ses côtés, j'ai installé un barebone exclusivement dévolu à la lecture audio via le Media Center de JRiver. Les deux appareils sont alimentés par leurs SMPS d'origine et l'on sait que ces alimentations à découpage sont susceptibles de polluer le signal audio sortant. Celui-ci transite ensuite par un réseau Ethernet local 100Mbps et donc par le routeur d'une Livebox alimentée elle-même par SMPS. Il était dès lors nécessaire de régénérer le signal audio entrant dans mon DAC avant d'attaquer les étages d'amplification. Le module iPurifier d'iFi Audio arrive sur le marché à point nommé pour s'acquitter de cette tâche. La différence à l'écoute est-elle aussi époustouflante qu'espérée? Sans aller jusque là, je dirais que le son produit me parait plus propre, plus précis, sans altération des timbres ni réduction de la dynamique, bien au contraire. Quoique subtile, cette amélioration de la restitution musicale n'en est pas moins précieuse pour qui désire optimiser son système.
Leonardo B.
Great Sensitivity, Loud and Clear sound.
Using this device in a 15L bass reflex enclosure, great response all the way down to ~45hz, with some extra tuning and a larger enclosure no problem going down to the low 30s.
Here is a test I recorded sending 75 W to the subwoofer, plays bass heavy music with no problem.
https://www.youtube.com/watch?v=eSRwga-a_tA
Julien O.
DOMMAGE, ne convient pas pour montage mural
Produit super qualitatif, plutôt solide, borniers a visses montage solide avec plaque alu, mais voilà :
le boitier ne rentre pas dans une boite d'encastrement mural standard (legrand orange ou autre).
Il vous faudra entailler ces boites en plastique très cassantes avant d'installer cette prise au mur. Ca vous évitera d'insister avant et de rayer votre façade.
Aussi, les visses proposées en option pour la plaque murale ne sont pas assez longues, celles fournies dans les boites d'encastrement standard sont mieux.
Sinon le reste est ok.
François H.
Tweeter à l'excellent rapport qualité / prix
A son prix, ce tweeter est imbattable ! Le son est propre et clair, la tenue en puissance est bonne, l'esthétique est sobre et fonctionnelle. Un modèle vraiment très recommandable !
Reçu ce jour en remplacement de 2 Fosi za3, ajout d' aop Muses 8920, contre JRC 1612 pour les za3.
Bonne maîtrise des basses, est ce meilleurs globalement, pas sur. A voir avec un peu d'usure .
Johan G.
Low...
" It is very useful for designing low-quality speaker cables" - how enticing... I don't think the product text says this actually :)
eric L.
ampli pathos tt
j'ai remplace les tubes sovtek que je trouvais dynamique mais un brun agressif avec ces tubes genalex c'est parfait apréq quelques heures d'ecoute je percois le grave tres profond et un joli médium non agressif belle neutralité. Je recommande
Robert L.
Tres bon ampli
Avec ses tubes d'origine, cet ampli casque est excellent. Il alimente sans soucis mon Hifiman Sundara de 36 Ohms, ou mon K702 AKG de 32 Ohms, pourtant l'un et l'autre gourmand en courant. La signature sonore est bien sur typée, mais bien équilibrée, avec des basses naturelles, articulées , d'une puissance suffisantes a mes oreilles, avec de l'impact et des mediums et aigus bien détourés, assez précis, et sans agressivité, mais avec de bonnes attaques, rapides et dynamiques. J'ai d'autres tubes a tester dessus (6N30Pi, et 6ZH1P-EV) en réserve, mais pour le moment, ceux d'origine me conviennent.
Très satisfait après une bonne expérience déjà avec un Little DOT MK2, retubé en NOS...dont les CV 131 commencent a lâcher.....
Nicolas B.
Joint stocké aplati
Le joint présenté enroulé en bobine sur la photo est arrivé en bobine, mais aplati, surement pendant un long temps. Créant ainsi un angle vif. Une fois collé, le joint ne fais plus son action de jointage, car aplati à certains endroits. Dommage.
