Renaud D.
Exceptionnel
Robert g.
Pascal H.
Dominique S.
Anodized Aluminium Push Button with Power Symbol Blue Light 1NO1NC 250V 5A Ø19mm Black This monostable (single position) 250V 5A anodized Aluminium button incorporates a blue LED and a Power symbol for the most beautiful effect. It is ideal for all your DIY...
Très joli.
Très joli, fait son petit effet. Manipulation très agréable, le mouvement est fluide et le bouton émet un petit clic lorsqu'il est enfoncé.
Frederic d.
Wall Plate Aluminum base plate Schuko for FURUTECH FI-E30 Black We designed this all-aluminium wall plate to cover the Furutech plugs FI-E-30 (G) and FI-E-30 (R) and thus transform it into a complete wall socket.
L'illustration ne correspond pas au produit recu. Sur la photo on voit la plaque murale en aluminium brossé, l'embase recue est en alu mais pas brossée, beaucoup moins joli...
Ely R.
SPEAKER SNAP Gold Plated Banana Plugs Ø4mm (Pair) These  Speaker Snap banana plugs  are gold-plated for optimum resistance to corrosion and erosion. They also feature an extremely practical mounting system that...
bon produit , bon site.
bonjour, produit reçu en bonne état, correspond a la description, efficace a l'usage. je suis satisfait de mon achat sur votre site.
Bogdan-Mihai M.
TOPPING PROFESSIONAL E2X2 Audio Interface USB 2 In 2 Out 24bit 192kHz Black With the E2x2, Topping offers an excellent audio interface designed for musicians and audio professionals. This excellent interface offers a very high level of performance for...
I really don't think you can find anything better at this price point
I got it because my focusrite interface (Solo 3rd gen) would keep disconnecting and wasn't working all that well for me.
Input & output sound quality exceeds expectations. Latency is very good too. Build quality is great, mostly metal.
I highly recommend this.
You can also find a detailed review of it here:
https://www.audiosciencereview.com/forum/index.php?threads/topping-e2x2-audio-interface-review.49127/
David M.
Excelente sonido, pero.....
Compré estos para compararlos con unos DEXA que tengo instalados en un DAC eastern eléctric minimax DAC plus mk2.....
Lo primero que tengo que advertir es que esta reseña u opinión está publicada después de realizar la comparación entre los DEXA que tenía instalados y ya rodados y los burson V7 vivid recién estrenados, es decir, sin rodar.
Este DAC monta un par de opamps dobles y un par simples, y la comparación ha sido cambiando los 4.
Bien, el sonido de los V7 es realmente excelente. Los graves son articulados y bastante profundos, medios bien definidos y nada estridentes, agudos refinados y transparentes. Tiene una buena escena, con bastante anchura y buena profundidad, es muy estable y los instrumentos están bien localizados.
Lo que menos me ha impresionado es la dinámica, aunque, como ya he dicho, la prueba la he realizado si que tuviesen ningún rodaje previo.
Tengo que decir que los V7 vivid dobles se calientan bastante.
Comparados con los DEXA, estos últimos consiguen una gama baja con más garra, muy profunda y exuberante. La zona media también me ha parecido mejor, sobretodo en las voces o instrumentos de viento, muy holográfica, y por arriba más transparente. En general me han gustado más los DEXA, además la escena es bastante más tridimensional y espectacular, y la colocación de los instrumentos más estable.
Como ya he dicho, los dexa están rodados y los V7 no, de manera que volveré a publicar la reseña una vez que puedan competir a igualdad de condiciones.
Lo importante es que, tanto los burson como los DEXA superan ampliamente a los operacionales de serie, y supongo que lo mismo valdrá para el resto de máquinas. Otra cosa importante es que los DEXA ya no se encuentran a la venta, o por lo menos yo no los he visto.
Dicho esto, es posible que para otros equipos de audio sean más apropiados los V7 vivid antes que los DEXA.
La prueba la realice con un preamp audio research ls16mk2, etapa ALEPH J (25w pura clase A SE), sonus Faber electa amator mk1. He usado un EVERSOLO dmp a6 con upgrade de fuente PSU lineal como streamer y un sencillo lector marantz CD 6006 UK edition como unidad de transporte para CD
A H.
Easy to use
Perfect fit and nothing breaks after resoldering and reclamping a Canare cable. High quality.
A H.
DIY Male USB-C 3.0 Connector Gold Plated This USB-C male connector will allow you to design your own cables. These take advantage of gold-plated contacts on the USB-C connector side and copper alloy solder pads.
Easier to use as it seems
I use this between my dc cable and the iFi iDefender, so only the dc is connected. Although this usb is very tiny, soldering the wires and putting the plug together was easier than I initially thought it would be. Use heat shrink tubes to finish it.
Désiré A.
A marié avec le câble secteur de votre choix, ce connecteur IEC va faire le travail avec perfection.
Je recommande vraiment un changement par rapport à des IEC no name.
Il y a mieux mais c'est déjà un minimum.
Je recommande ce produit à 100% par rapport à un connecteur basique.
YANNICK B.
très bon raport qualité prix
Cela fait maintenant 3 mois que je vis avec ces amplis je les utilisent en home cinéma avec mon préampli DENON et franchement ces amplis sont très musicaux et quel pêche en home cinéma!
Désiré A.
NICHICON KG GOLD TUNE HiFi Audio Capacitor 50V 10000µF The Nichicon capacitors of the KG range have been specially designed for audio. Thus, they allow to achieve a high fidelity sound reproduction and can be integrated in different...
Très bon produits
Condensateurs de très haut niveau, installé dans un ampli intégré sans soucis. Redonne vie à vos matériels.
A vérifié de prendre les même valeur préconisé par le constructeur de votre matériel électronique.
Désiré A.
ELECTRO-HARMONIX KT88EH Platinum Tubes (Matched Quad) These Electro-Harmonix tubes are world-renowned for their warm analog sound. The Electro-Harmonix KT88 EH is often referred to as the "Ultimate KT88".
Excellent tubes
Un gros changement de sonorité après un rodage, vraiment du bon produit et , un gros merci à toute l'équipe pour un retour de tube d'effectué.
Le SAV est très rapide te très professionnel.
A recommandé.
Pierre C.
Excellent filtrage
Donne une belle musique en sortie de PC, naturelle
et vivante.
Attention toutefois à ne pas lésiner sur les câbles d'entrée
et de sortie pour tirer le meilleur parti du Silkline.
Antonio C.
Highly recommended
I’m very happy with the Shanling ET3. The build quality is outstanding — solid, elegant, and clearly made with care. It offers plenty of connectivity options (USB, I²S, coaxial, optical, AES/EBU), making it easy to integrate into any setup.
I haven’t used the Bluetooth or streaming functions yet, so I can’t speak to those features. However, as a CD transport, it has already improved the sound in my system compared to my previous CD player — more detail, clarity, and presence.
I also really appreciate the top-loading design. It feels more reliable than traditional tray mechanisms and even reminds me a bit of the ritual of placing a vinyl record — a nice touch for music lovers.
If you’re looking for a reliable, great-sounding CD transport with modern features and excellent construction, I highly recommend the ET3.
doux et équilibré
.je me range a l avis général,excellent cable moins précis et détaillé que le neotech 1220.il a trouvé sa place entre le preampli musician monoceros et les filtres actifs.entre le dac holo spring et le preampli je préfère un câble argent. Prise xlr eizz sans soudures.
Gilles F.
Nous sommes plusieurs Audiophiles à avoir abandonné des câbles à plus de 2000€ la paire pour opter pour ce modèle. Pour 50 € je me suis offert du bi câblage de mes enceintes JBL K2 9500 et ça sonne magnifique
Gilles F.
EVERSOLO DMP-A10 Streamer ES9039PRO WiFi DLNA AirPlay Bluetooth aptX HD LDAC 32bit 768kHz DSD512 With the DMP-A10, Eversolo unveils its new high-performance network player and DAC. Compared with its predecessor, the DMP-A8, it...
Excellent son
J’ai 2 installations avec de très grosses enceintes (JBL Everest et k2) et j’ai aussi un DMP A8. Je peux témoigner que le DMP A10 sonne très différemment sur les 2 installations toutes choses égales par ailleurs : moins sec, plus charpenté et plus de graves…. J’attribue cela au DAC qui est différent. On pourrait probablement avoir encore mieux au niveau de la définition avec un DAC très haut de gamme (plus que 8000€)
Jacques E.
authentiques !
Oui, contrairement à ceux qui équipaient mon DAC chinois...
Jizhuang S.
Electroswitch C4D0206N-A
Excellent mais attention à deux points, l'axe de rotation ne mesure pas 6mm mais 6,37 mm ( mesure faite sur les quatre pièces commandé) donc il faut utiliser une mèche de 6,5 pour agrandir le trou du bouton aluminium. Surtout ne pas forcer ! La rotation est dure, donc à monter sur silentbloc si utilisation avec des amplis à tubes à chauffages directs. Rien d'autre à signaler.
Jizhuang S.
VIBORG VC303R RCA Female Connector Silver / Rhodium Plated Copper Ø8.5mm Viborg's VC303R RCA connector has a pure copper core for excellent signal transmission. The connector is also plated...
Viborg VC303R
Très bien fini toujours un peu compliqué pour les soudures du au revêtement rhodium. Une solution largement supérieur sera d'utiliser des embases RCA Klei Perfect Harmony plaqué argent. C'est ce que j'ai fais avec un petit bricolage en DIY
Jizhuang S.
HOLO AUDIO MAY LEVEL 2 Balanced R2R DAC and Independent Power Supply 32bit 1536kHz DSD1024 After 3 years of research and development to achieve a whole new level of performance and sound quality, HoloAudio introduces the MAY Level 2 discrete balanced R2R DAC! Flagship...
Holo Audio May 2
Excellent appareil, extrêmement musical, très détaillé mais sans excès, l'intégration des différentes voies ( médium aigu ) est remarquable, aucune mise en avant particulier ! Certains peuvent trouver que le grave est très légèrement en retrait. Très très sensibles aux différents câbles ! Un mauvais choix peut amener à un léger manque d'entrain. Sur mon système entièrement à pavillon quatre voies ( SANS filtre ) utilisant uniquement des amplis single ended pure classe A à tube 20A, je suis terriblement satisfait. Mon DAC précédent était un DDDAC de Douede Douma recommandé par J.Hiraga. Très musicale mais moins que le Holo Audio May 2 ! Très hautement recommandé pour de la musique acoustique ( ! ), mais a essayer avant pour de la musique électronique.
Bonne écoute !
Panikos K.
AUDIOPHONICS MOS-120 Amplifier
Excellent amplifier at or beyond its price point.
I combined it with the excellent AUDIOPHONICS RCA 4-1 input selector and set up a beautiful high quality second audio system.
I must mention the exceptional AUDIOPHONICS service !!!!!!!!!!
Panikos K.
In terms of build quality and sound transparency , selectors can't be done better than this. PERFECT and superb value for money.
THANKS AUDIOPHONICS *********************
Paul J.
Awesome!
Currently running a wiim pro plus into Klipsch 'The sevens'. The digirescue made an amazing difference to the clarity. My wife even asked what I had done to the stereo! Highly recommended
Alexandre C.
Très bien mais...
Excellente finition, materiaux de qualité, design et ergonomie bien pensés, la forme du tube permet de bien insérer et bien libérer la prise.
La force pour insérer et libérer est elle aussi bien calibrée : puissante pour un bon contact durable mais pas extreme pour ne pas s'agacer à tortiller le tube quand il est bien coincé au fond devant le mur.
Bémols : Le design qui laisse croire à un dévissage par l'arrière alors que le tube est monobloc, dévissage sur l'avant, et ça complique l'esthetique.
Techniquement le point de raccord à la masse n'est pas raccordé au corps tube en laiton mais au ras de celui ci, faire attention à l'épaisseur de la soudure à cet endroit, soit c'est trop épais et contact avec le tube ou pire, c'est invissable, soit c'est trop fin et le tube ne sera pas à la masse et ne complétera pas le blindage du câble.
Digital Interface SPDIF Coaxial / Optical Toslink Converter DAC Headphone Amplifier 24bit 192kHz This compact digital interface converts a SPDIF coaxial signal to Toslink optical and vice versa. What's more, it integrates an RCA output and a 3.5mm headphone output, capable...
Produit conforme au descriptif, délivrant un son de très bonne qualité, et des combinaisons d'entrée et de sortie multiples.
Conforme au descriptif, mais surprenant quand même !
Rapport qualité/ prix incroyable, très bien pour un petit ensemble secondaire.
Bon produit...
Très bon complément avec le kit pack enceinte stéréo BT
Bon produit, très bon service...
Produit conforme au descriptif, installé avec l'extension proposée (interrupteur/chargeur USB/ entrée jack). SAV disponible et rapide, heureusement car notice pas complètement claire pour un novice. Le son produit est de qualité, pour un prix un peu excessif, mais l'assistance technique étant efficace, je ne regrette pas mon achat...ainsi que le résultat obtenu !
Karl-Heinz E.
BURSON AUDIO EXT-2 Extension for DIP8 OPA Silver Plated Copper 35mm (Pair) The Burson Audio EXT-2 are DIP8 extenders to install your AOP in a practical way. They are flexible and allow you to orientate your AOPs according to the space available on a...
Passt perfekt
DIP 8 Extender passen exakt und lassen sich gut ausrichten.Wurden für den Hifiman EF5 genutzt.
Pierre C.
Excellent filtrage
Interface qui restitue une musique bien plus naturelle en sortie
de PC pour alimenter au mieux un convertisseur, à un tarif
très raisonnable.
Attention toutefois à l'accompagner d'un câblage à la hauteur,
aussi bien en entrée qu'en sortie, pour en profiter pleinement.
Floriana V.
fa il suo lavoro, un po di morbidezza in più.
Nel mio caso non ho riscontrato un gran miglioramento. Può darsi che avendo un alimentatore switching e una scheda pci purificatrice gli effetti siano minimi.
Jean P.
cable secteur FP-S032N
cable monté avec des fiches furutech fi48 rhodium et utilisé sur un lecteur réseau melco , après quelques heures de rodage je peux donner un avis très positif ; ce cable est neutre en comparaison du tcs 31 que j'utilise( plus lourd dans les basses !) , très bonne dynamique, des aigus très fins et des médiums fluides , bonne cohérence des registres et pas d’agressivité; comparé à un gigawatt lc3 évo il se comporte très bien , il faut dire que les fiches furutech utilisées participent au résultat . ceci est un avis personnel et dépend des appareils utilisés mais je recommande ce produit .
Michel B.
ELECAUDIO DCT-2.1G Male Jack DC 5.5/2.1mm Connector Tellurium Copper Gold Plated 3µ This DC 5.5/2.1mm Elecaudio DCT-2.1G connector will allow you to design high quality power cables, ensuring a clean transmission of the electrical signal to your HiFi device....
Trop mal conçue
Par rapport à fiche DC Elecaudio habituelle Réf. 9822, celle-ci est supposée plus haut de gamme, car en "alliage de cuivre".
Hélas en pratique elle est beaucoup moins bien conçue que la 9822 tout en étant 50% plus chère.
Corps trop court, bague de serrage trop courte ne servant quasiment à rien (et qu'on finit par devoir couper pour visser le corps plastique), trou mal positionné sur la partie Masse, ne permet pas de souder correctement des câbles à 4 fils comme le StarQuad par ex.
J'ai pris quelques photos: je donnerai le lien si je ne peux pas les rajouter à mon avis.
Bref, restez sur la 9822, bien mieux conçue et moins chère.
John Z.
Good solder
Good solder, a little bit harder to work with as it has no resin core, but only 100% solder. Recommended when you want a solder containing a substantial amount of silver.
Geoffroy T.
Super ampli
Ces amplis de puissance drivent parfaitement mes Revival Audio Atalante 5 dans toutes les situations d'écoute.
J'ai opté pour ces amplis car je peux les cacher dans un meuble.
Quim F.
Funcionament perfecte
Funcionament perfecte del producte i de tot el procediment de compra i lliurament. Felicitacions a l'empresa!
Quim F.
JANTZEN AUDIO ELECAP Electrolytic Capacitor 100V 5.6µF 5% Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most...
Quim F.
JANTZEN AUDIO SUPERES 002-0193 Resistor 10W 3.9 Ohm (Unit) Jantzen Audio Superes resistors offer high quality at a price that is always affordable. They offer excellent tolerance to high temperatures and very good shock resistance....
Quim F.
MUNDORF L071 Air Core Coil 0.71mm 0.82mH Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this...
Efficace et procéder à des essais .
Ces atténuateurs font parfaitement le job , dans ma configuration : lecteur cd à haut niveau de sortie + enceintes à rendement très élevé ( 99 db ) + intégré dont le bouton de volume envoie trop vite la puissance . En outre , beaucoup de cd sont lourdement compressés , avec un niveau d'enregistrement donc excessif ... Le réglage à - 20 db est peut-être excessif . Faut voir , selon les cas . Celui à - 10 db est sans doute un peu insuffisant . Comme souvent, le réglage intermédiaire , à -15 db , m'a semblé le meilleur . Ces atténuateurs sont branchés sur les sorties haut niveau de l'intégré . Je n'ai pas l'impression qu'ils dégradent la qualité du résultat final . Cependant , l'oreille humaine a toujours l'impression que plus c'est fort meilleur c'est : il faut donc tourner davantage le bouton de volume pour retrouver les sensations habituelles mais on a une meilleure souplesse de dosage ...
André G.
Bonne tenue dans le grave
J’ai branché ces câbles de modulation Furutech entre mon ampli Pass Lab XA 25 et mon lecteur de réseau et le résultat est exceptionnel ; bien sûr le prix de ces câbles flirte avec du haut de gamme. À recommander
André G.
Tweeter léger mais efficace
J’ai branché ces tweets Dayton en complément de mes tweeters à ruban afin d élargir la bande passante, résultat meilleure spatialité et cohérence. Pour un prix dérisoire ces tweeters font le boulot.
Paulius S.
Wiring Cable OCC Copper PTFE Sheath 1.5mm² Ø2.2mm Transparent This Ø2.2mm wiring cable is composed of an OCC 6N copper conductor with a cross-section of 1.5mm². This conductor itself is made up of 19 strands of 0.32mm each....
Very good wiring cable.
Paulius S.
There is no better binding posts for the money.
Gérard B.
Je l'avais acheté pour la compatibilité ASIO (rare sur ce type d'appareil). Mais il ne fonctionne pas à 192kHz en TOSLINK: il y a des coupures fréquentes du signal, qui rendent le son inaudible. J'ai donc conservé mon ancien interface USB qui fonctionne sans problème.
patrice f.
Soundcare standard
des basses fréquences mais aussi éclairci tout le spectre audio.
Dimitrios K.
Neotech usb cable
Pierre H.
Condo Mundorf 22000µF/63V
Mundorf, fait parfaitement le JOB et sympa le double face pour le maintenu du condensateur, facilite le montage mécanique et la soudure.
Pierre H.
MUNDORF MLYTIC AG Capacitor 40V 10000µF These capacitors have been specially developed for small power amplifiers or preamplifiers. This new product replaces the M-Lytic SI series. The "Glue-On" output pins made of...
Référence : 11175
Pierre H.
Référence : 11175
Bouton parfait, et bien fini.
