Matt H.
The AS6 is a beautifully constructed piece of equipment, inside and out.
I used to use 2 Cisco 2960 switches modified for...
Jelte D.
Smart little helper
Very well designed and built simple little tool to start all your equipment at once but in the order desired.
Too bad it does...
Ludovic F.
Valeur sûre en numérique
Excellente alternative aux câbles coaxiaux sur mesure : mêmes caractéristiques techniques (75 ohms réels), très belle qualité...
Customers reviews - There are 20225 reviews.
Good, but
These little shoes are great with a small but. The spike entry diameter is quite narrow and also deep. The shoe will contact with the cone of a spike rather than just the tip unless your spikes are very narrow
Pawel W.
AMANERO COMBO384 Digital latest version BK2304
The original product should be used with ASIO drivers for DSD DAC. The power supply requires 2 additional capacitors at 5V and 3.3V voltage, which results in super precise performance.
It s the latest version of amanero B2304, it needs new version of tool http://www.amanero.com/update118new.zip, old one doesnt work.
indispensable
ce DDC permet de passer de l'usb au I2s et vous permet d'obtenir un rendu sonore exceptionnel a partir d'un portable . les drivers asio fonctionne sans problème (W11) +Jriver32;
PANGEA PREMIER XL MKII Male USB-A to Male USB-B Cable Silver Plated Cardas Copper 1m With the Pangea Premier XL MKII, you get a high quality USB-A to USB-B cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas...
L'usb a son meilleur.
ce câble me donne un bon rendu en entée d'DDC singxer su 6 en sortie ver un DAC HOLO AUDIO SPRING 3 , j'utilise un cable PANGEA PREMIER SE MKII Câble HDMI 2.1 en format I2s Tout vient de chez Audiophonics . le rendu sonore est exeptionnel .
Thierry C.
MINIDSP FLEX HTx Audio DSP Processor 2x8 Balanced Channels SHARC ADSP21489 HDMI ARC eARC Big brother of the Flex HT, the Flex HTx from MiniDSP is a 2x8-channel multichannel audio processor perfect for integration into a home theater or multichannel sound system.
Remplace avantageusement les 2 DCX 24-96 pour gérer les 3 voies de mon système
Après avoir mis au point mon filtrage à l'aide de petit Behringer DCX, j'ai choisis de bénéficier du rapport signal/ bruit exceptionnel de ce DSP : 24dB de mieux (encore amélioré sans doute par le recours à un filtre à Supercondensateurs)
Les seuls bémols :
* Seulement 4 presets
* Pas de gestion de la convolution FIR contrairement à d'autres appareils de ce gamme moins ambitieux
Mohammed B.
Super Stecker spielt sehr neutral
Die Silver Steckern spielen sehr neutral detailreich flüssig sehr sauber musikalisch und der Bass kompakt trocken und sehr schnell.
Vorsicht!!
Im Vergleich zu Standardsteckern spielen die WBT viel zurückhaltend
und Neutral daher sind sie für Musikanlagen die zu dynamisch unsauber und zu offen spielen geeignet.
Alle neue WBT CU bzw AG Steckern spielen wie oben beschrieben ist
wer mehr Bass sehr offen bevorzugt , sollte was anderes kaufen Massivsteckern spielen mit mehr Druck im Bass und Dynamischer.
David T.
test sur Wilson Audio Watt Puppy 7
mes amplis actuels sont 2 Mark Levinson no.331 en configuration Monophonique . un son tres rapide , des superbes basses , microdetails fabuleux .
ce test sera fait sur plusieurs semaines .
excellent rqp
Ce distributeur secteur dispose d'une qualité de fabrication indéniable ; boitier en métal brossé de forte épaisseur et de bonne finition ; prise iec d'entrée en cuivre . Au niveau du son un gain très significatif en netteté et propreté d'image . j'ai rajouté mes filtres quiet line + des pieds antivibratoires sur roulement à bille ( en vente sur ce site) ( gain d'aération de la scène sonore ) . Ce distributeur est une excellente base pour un prix plus que raisonnable , certains plus chers ne feront pas forcément mieux .
Laurent C.
Fabuleux
Branché entre un Nuprime Ida-8 et sa boîte d'allumette le D-Sream Primo HD, enterre tous c concurrents... très musical, précis, dynamique sans fatigue comme certains hdg... un véritable régal.
Laurent C.
Le Must !!!
Ne cherchez pas plus loin... c le bon !!! Encore une excellente trouvaille chez Audiophonics, après le rca canare et le RJ45 audiophonics, une nouvelle très bonne surprise. Bravo
Laurent C.
Excellentes !!!!
Montées sur de l'elecaudio hp25OCC, j'ai pas trouvé mieux que les viborg... idem sur de l'atohm zef max. Je pense que c fiches bananes plaqués argent/or sont neutres comparé aux viborg tout cuivre qui amènent un brin de chaleur. Dans tous les cas, rapport qualité prix imbattable !!!
Jesse D.
AUDIOPHONICS OPA1656 Dual OPA DIP8 (Unit) Audiophonics is proud to present its OPA line-up with the OPA1656 based on a authentic Texas Instrument chip. This OPA offers excellent performance for audio applications. In...
Superbe !
Le meilleur OPamp a marier, selon moi, avec l'amplificateur FOSI AUDIO V3.
Linéaire et neutre sur toute la bande avec le circuit de cet amplificateur, il sera capable de retranscrire au mieux ce qu'il recevra à ses entrées.
Sinon pour AUDIOPHONICS, juste un petit message:
la forme particulière que vous avez donné au PCB de vos AOP est super sympa MAIS elle ne permet pas cependant de pouvoir l'intégrer dans tous les appareils, comme le FOSI AUDIO V3 ou j'ai du pour la peine intercaler des "Support Tulipe DIP8 Plaqué Or pour Circuit Imprimé" entre son PCB et l'AOP, ce qui éloigne le condensateur de découplage de sa proximité conseillée dans les datasheet de TEXAS INSTRUMENT...
Adam S.
this is brilliant
made a dac with 3 r2r bords and passive output without opamps ,tried with opamps it sounded dull and bad compared with my dddac, with passive output it beats ny dddac and my friends metrum pavane and a denafrips, they just got beated very bad, the psu used is a 3 stage psu with emi filters and lt3045 in the last stage, lm1084 in first stage and lf80 in second stage, and a lot af b4 15000uf caps in indput and before lt3045, this is the best dac i ever heard
Thierry C.
ATOHM WT-7992-G Isolated Built-in Terminal Block for Speakers Gold plated 92x79mm (Unit) The WT-7992-G terminal block, like all models offered by Atohm, is equipped with large terminals made of lead-free brass with 24k gold plating. It accepts cables with large...
La marque ATHOM n'apparaît pas mais inspire le sérieux aussi bien pour le plastique épais et pas cassant et le bornier proprement dit en métal massif bien plaqué.
Thierry C.
Reçus rapidement, bien emballés (2), tweeters de bonne facture, tout métal. J'ai pu remplacer des tweeters plus classiques (ferrite) dont l'impédance devait être légèrement supérieure. En portant de 4,7 à 7,5µF le condensateur série du filtre le raccordement avec le médium est impeccable à l'oreille et à la mesure. La courbe remonte vers les 20 kHz mais ça ne me gène pas et musicalement c'est très bien je trouve.
Jonathan K.
AUDIOPHONICS GREYHOUND Power Cable Schuko IEC C15 OCC / OFC Copper Shielded 3x2.5mm² 1.5m Hand-assembled in our workshops in France, the Audiophonics Greyhound Schuko to IEC C15 power cable offers an excellent solution for electrically connecting your HiFi equipment,...
Déroutant
dans les basses fréquences.
J'apporte une nouvelle fois mon avis sur ce câble mais cette fois-ci sur la version montée par audiophonics.
Dès la première écoute, on retrouve toutes les qualités du câble d'elecaudio, c'est à dire un éclaircissement de tout le spectre, un aigu beaucoup plus précis et plus riche, un médium remarquable et des basses tendues avec de la définition.
Ce câble me plaisant énormément, j'ai décidé d'harmoniser mon système, mon ampli ainsi que l'alim du pré-phono sont alimentés par ce câble secteur. Les câbles de modulation sont des sommercable Epilogue.
Après un petit rodage de quatre cinq après-midi/matinées, je suis assez stupéfait du résultat. C'est même d'ailleurs un peu déroutant. Sur la trompette de Jon Hassel, les montées dans les aigus sont enrichis d'énormément de matières et de détails ! Pareil, sur le disque de la planète sauvage (BO d'Alain Goraguer), j'ai jamais entendu autant de maîtrise et de définition dans les basses fréquences. La basse est d'une propretée et pourtant elle garde tout son côté organique. Bluffant. De même sur le disque d'illustration sonore Guy Pedersen - contrebasse, ce dernier instrument n'a jamais sonné aussi réaliste et vivant.
Ce qu'on peut retenir sur ce câble est qu'il apporte beaucoup de définition et de maîtrise sur tout le spectre audible et cela sans artifices !
Bravo à audiophonics, car pour le prix proposé, ce câble est stupéfiant.
Gorazd K.
XANGSANE XS-6002AU Banana plugs Gold-plated Ø7.5mm (Set x4) These Xangsane XS-6002AU banana plugs feature copper alloy contacts with gold plating for enhanced conductivity and resistance to corrosion and oxidation. Their...
Surprisingly quality bananas. I already have some very well-known audiophile brands, but these are not far behind them... or rather, they seem to me to be of the same quality, double screwing of the wire... in short, there is no point in paying for a well-known brand.
Et je remercie…
...tout d’abord, David et le site Audiophonics, pour le prix, la qualité de leurs produits et celle de leurs services, y compris le SAV, très réactif.
Ensuite les personnes qui ont donné leur avis sur ce câble ! En effet, ce sont eux, les « Audiophiles anonymes », qui m’ont grandement aidé à effectuer enfin LE bon choix.
Je vous expose mon problème d’origine : disposant d’un système audio me convenant PRESQUE (ampli TAGA HT 25, avec lampes chinoises d’origine remplacées par des russes, sur enceintes Focal Aria 906, reliés par du câble Viard HD de base (très bon au demeurant)) et ce après des années de recherche (quelques problèmes d’audition, ce qui fait que je ne supporte pas les aigus scintillants, même légèrement, les voix et médiums pas assez distincts et donc donnant de la « soupe » indigeste à l’écoute , et les basses trop envahissantes ou percutantes) ; or, le son était très bon, mais les aigus restaient encore un peu trop brillants…
(au passage, je m’étonne de ne jamais voir indiqué plus explicitement des mentions dans la présentation ou le test de produits audio du genre ‘déconseillé aux personnes ne supportant pas les aigus brillants’ ou ‘recommandé aux personnes cherchant des basses fermes mais pas des marteaux-piqueurs’ par exemple… ou alors je suis le seul ayant quelques problèmes auditifs ? )
Bref, j’ai beaucoup tâtonné puisque, comme pour le cognac, tout ceci est histoire d’assemblage, et ce entre : les enceintes, le câble, l’ampli, la pièce, le positionnement des enceintes dans la pièce, les caractéristiques auditives de l’auditeur, ses goûts… ce qui fait beaucoup de variables, pour finir par assembler correctement ce qui ressemble plus à un rubik’s cube qu’un puzzle !
Donc, je désespérais et puis en cherchant sur le site le câble qui pourrait enfin peut-être éventuellement à tout hasard me convenir avec un peu de chance, je tombe sur le MOGAMI W3103 2x4 mm2, sa très bonne note et ses 83 avis, et ce pour un prix très abordable.
J’examine la chose de plus près, et là quelques avis, se recoupant, m’interpellent ; il est fait mention de musicalité, neutralité, de scène sonore large, de précision des timbres… et enfin d’un défaut dont j’ignorais le nom : le côté SOMBRE donné au son… Sauf que ce défaut semble, pour moi, LA qualité que je cherchais !
Donc je commande, je reçois, je monte les fiches bananes, je branche et… ô miracle (ou presque!) : dès la première seconde LE son annoncé est là, propre, précis mais pas agressif, agréable, avec une scène sonore très large… et des aigus enfin domptés ! Je peux écouter mon ensemble plus de dix minutes sans avoir mal aux oreilles ! Un seul petit défaut : les basses sont un peu trop discrètes, mais je compte sur le rodage et, comme annoncé par certains, au bout d’une bonne dizaine d’heures elles sont remontées à la surface… pour mon plus grand plaisir : j’ai enfin LE son qui me convient !
Voilà, j’espère tout simplement que mon avis pourra à son tour être utile à d’autres lecteurs-auditeurs d’Audiophonics !
Mikael C.
Relié à mon DAC par câble toslink, fonctionne très bien. A voir la solidité sur la durée, mais c'est un transport cd qui fait très bien son travail. Je n'ai pas essayé la sorti son du lecteur, n'en ayant pas l'usage.
Juri L.
FOSI AUDIO V3 Mono Class D Amplifier TPA3255 240W 4 Ohm. Good!
Pablo P.
AUDALYTIC AH90 DAC AK4499EX XMOS XU316 LAN DLNA Roon 32bit 768kHz DSD512 MQA Black The Audalytic AH90 is a DAC offering excellent decoding performance and precise sound reproduction, thanks to a careful and intelligent design. And it's reasonably priced for...
Excellent dac streamer de Gustard
Dac et streaming en un seul appareil.
Qualité de son au rendez-vous.
Nombreuses connexions.
Possibilité d'alimentation externe, un vrai plus.
Télécommande.
Un maillon de la chaine de reproduction audio réussi.
À ce prix il n'ya pas mieux je pense.
Grande communauté des appareils Gustard.
Une valeure sûre dans le monde de l'audio
Geobert Q.
TOPPING DX3 PRO+ DAC ES9038Q2M NFCA Headphone Amplifier Bluetooth 5.0 aptX HD LDAC XMOS XU208 32bit 768kHz DSD512 Silver Topping unveils its DX3Pro+, a direct evolution of the excellent DX3Pro, an excellent compact DAC also offering headphone amplification and preamplification functions. Embarking...
Super !
Je l’adore ! On peut sortir sur line out ou casque ou les deux, et chaque mode garde son réglage
Geobert Q.
TOPPING MX5 Amplifier Merus Class D NFCA XMOS Bluetooth aptX HD 2x55W 4Ω 32bit 384kHz DSD256 Silver The Topping MX5 is a combo amplifier and headphone amplifier with integrated DAC ESS ES9018. Particularly versatile and powerful, it benefits from a Bluetooth reception thanks...
Juste un défaut
Pour ce prix, un combo DAC, préamp casque et amp, c’est génial. Mais un défaut dont il faut être conscient(e) : en mode casque seul, les enceintes sifflent :-/ Pas forcément gênant, mais faut le savoir.
Damien M.
Musique servie sur un plateau !
Possédant plusieurs cellules phonos et ne disposant pas de réglage de hauteur de bras sur ma platine , je compense en alternant des couvres plateau d'épaisseur différente qu'il m'arrive même de superposer. Une écoute subjective ( bien évidemment ) de l'album "White Hot & Blue" de Johnny Winter (du hard blues qui déménage) avec le Dynavox PM3 semble favoriser l'attaque ferme des lignes de basses et de ce fait met davantage en valeur les solis élastiques et virtuoses du fameux et regretté guitariste albinos dont les notes rebondissent de partout telles des balles de tennis. Les nuances de grain de son obtenu entre les différentes matières (caoutchouc , cuir, liège) sont très subtiles et pas forcément faciles à saisir , mais il est intéressant de faire l'expérience. Ce modèle me semble privilégier légèrement la dynamique et vu son excellent rapport qualité prix , il aurait était dommage de m'en passer.
Alexandre V.
J'ai été agréablement surpris par le look et les finitions de l'appareil. Il présente très bien !
J'utilisais avant un SMSL Q5 Pro branché sur des enceintes Dali Zensor 5. Eh bien, quelle différence !
L'Audiophonics est bien moins fatigant lors d'écoutes prolongées. Les basses sont bien plus présentes... Je vais devoir revoir les réglages de mon sub.
Par contre, j'ai l'impression que la scène sonore est un tout petit peu moins large.
Globalement, je suis très content de mon achat.
Gorazd K.
This amp exceeded my expectations. It is not too bright in my system as I was afraid for the d class. For the preamplifier I have atoll pr300 signature. It is neutral with excellent and controlled bass and with a huge reserve of power, the workmanship is impeccable, quality connectors... and as always safely packed by audiphoniccs
Mehdi O.
SMSL DL100 DAC 4x CS43131 Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD256 MQA-CD With the DL100, SMSL offers us a high-performance DAC incorporating quality components such as a combo of 4 Cirrus Logic CS43131 chips, an XMOS XU-316 USB interface and a...
Un tout en un pour un petit prix (HDMI Arc en bonus)
J'ai mis 5 étoiles non pas pour ses qualités sonores qui sont bonnes sans être extraordinaire, mais pour son côté couteau suisse à un prix vraiment abordable.
Voici ce qu'il inclut :
Sorties XLR (symétriques), RCA, casque 6,35mm et 4,4mm
Entrées : HDMI Arc, optique, coaxial, USB type C (1.0 et 2.0), Bluetooth (Aptx et LDAC)
Tout cela aux alentours de 200€, rien à redire.
Alors certes, pas de DAC ESS ni AKM, mais 4 puces Cirrus Logic CS43131 (2 par canal) qu'on retrouve dans des mini-DAC portables.
Des Op Amp de qualité, mais en quantité moindre, 3 OPA1612a qui permettent une amplification plus que correcte et puissante ( 2x 3W en 16Ω pour la sortie casque 4.4mm). Certes, il y a eu des économies, l'écran LCD a un effet "vintage" (comme nos anciens réveils), mais reste lisible. Certes le son n'est pas le meilleur du marché, mais n'est en aucune façon mauvais, bien au contraire et les mesures plus que correctes en attestent.
Je le conseille principalement à ceux qui désirent écouter au casque sur la TV (grâce au HDMI Arc meilleur que le câble optique (toslink)) et y brancher via les sorties XLR deux enceintes actives en stéréo, puis pourquoi pas un sub sur la sortie RCA.
S'il coûtait le double, il perdrait 2 étoiles, mais c'est justement sur le prix qu'il est imbattable. Une fois de plus, SMSL parvient à sortir un produit au rapport qualité/prix de folie.
PS : Le seul DAC tout en un qui propose les mêmes fonctionnalités dont le HDMI Arc est le FiiO K19 à 1400€, soit quasiment sept fois plus cher. Il y a également le SMS DO200 PRO, mais il n'y a pas de sorties casque.
Yves-G L.
Canare câble coaxial -1m.
Pour un prix vraiment raisonnable, une belle découverte. Niveau de définition supérieure, assise solide, scène sonore plus large. Fermeté et assurance. Merci car rarement distribué sauf erreur. Mon petit combo : Rotel A-14 mk2 et lecteur CD-14mk2 plus "vieilles" Mission M-71i - à changer un jour prochain - a gagné sur beaucoup de plans. Expé. et livraison rapide. Emballage pro.
Merci !
Anders C.
AUDIOPHONICS HPA-T400ET Power Amplifier Class D 3 Channels Purifi 1ET400A 3x400W 4 Ohm We are proud to offer you the AUDIOPHONICS HPA-T400ET, a 3 way class D power amplifier based on three PURIFI 1ET400A modules. This ready-to-use version is aimed at audiophiles...
Clean power. And a lot of it!
Sounds perfect with my Arendal 1723 speakers.
Mehdi O.
SMSL RAW-MDA1 DAC 2xES9039Q2M Headphone amplifier Bluetooth 5.1 32bit 768kHz DSD512 MQA The SMSL RAW-MDA1 is a balanced DAC featuring two ESS ES9039Q2M chips and a USB XMOS XU316 interface. These high-quality components enable it to support high-resolution streams...
Fait aussi bien (voire mieux) que des DAC avec ESS ES9038Pro
Excepté l'absence d'une Entrée HDMI Arc (que j'aurais souhaité, obligé de me rabattre sur le moins qualitatif SMSL DL100 pour le coin TV), le choix de mettre deux puces ESS ES9039Q2M (pour chaque canal) à la place d'une ESS ES9039Pro (le prix serait aisément doublé) et pas de PEQ intégré (une égalisation paramétrique), tout est parfait. Les mesures ne me contredisent pas.
J'avais peur que l'amplification casque (6,3 et 4,4mm) soient en retrait, que nenni, c'est excellent et puissant. Venant d'un Xonar Essence One amélioré avec des Opamp de qualité, j'entends des micro détails jusque là masqués. Un son précis, avec une bonne ouverture, détaillé sur l'ensemble du spectre, dynamique et de bonnes basses percutantes (juste ce qu'il faut). Je n'ai pas essayé de DAC à 1000€ ou plus, mais la différence doit être minime.
En toute honnêteté, ce DAC avec sortie casque vaut largement le SMSL M500 ou autre DAC tout intégré à base d'ESS ES9038Pro.
Un excellent rapport qualité/prix qui sera l'investissement idéal pour les mélomanes/audiophiles/homestudistes modestes et intelligents.
+ Un superbe son (sorties XLR, RCA et casque)
+ Tout est quasiment inclus (Bluetooth, MQA, MQA-CD)
+ Une taille modérée, s'insère partout
- Pas d'HDMI Arc
- Des puces DAC moins chères mais qui sont plus que suffisantes
- Pas de PEQ (égalisation paramétrique incluse) mais des filtres pour colorer le son.
Leonardo B.
Amazing response
Bought as a replacement driver for a 10l reflex subwoofer enclosure. Sound is spectacular, responsive all the way down 40-35hz. Not the cleanest sound but it is what i was looking for!
Très musical !
Montage fait avec des connecteurs Ramm vissants. On passe les problemes dus a la rigidité des gaines et la vis minuscule mal adaptée pour serrer 3 minuscules brins de 0,5 mm. Le résultat est tout bonnement stupefiant, précision, ciselé, avec des timbres magnifiques. Il devient mon meilleur câble actuel après en avoir testé beaucoup dans cette gamme de prix et même 3 a 4 fois plus cher.
Jean-Pierre D.
SMSL D1SE Balanced ES9038PRO DAC CPLD Altera XMOS 32bit 768kHz DSD512 Black The D1se from SMSL is an extremely powerful DAC, based on a symmetrical architecture using a high-end ESS ES9038Pro digital to analog conversion chip. Taking advantage of a...
Petit DAC musical et détaillé
Première Déclinaison du D1, promotion Audiophonics, prux intéressant, délivrant un son très ouvert, belle imagerie, bien, pour quelqu'un qui recherche un appareil musical avec un DAC de pointe ESS non gravé avec un encombrement minimal. Il existe un S2 avec davantage d'OP qui a remplacé celui-ci et le nouveau DAC ESS 9039. Ces modèles ESS ont une belle neutralité, mais ce n'est pas stérile, une alternative intéressante à AKM ou à des R2R d'entrée de gamme.
Lorenzo C.
AUDIOPHONICS HPC4 Speaker Cable OFC Copper 2x4mm² This Audiophonics HPC4 speaker cable has two conductors, both made of 511 strands of OFC copper to ensure optimum conductivity. The transparent PVC jacket makes the cable both...
Very good!
Got 10 mt. of this nice cable to replace a similar OFC cable, same section (4sq.mm) so no bells and whistles or sound miracles happens here.
Just measured it to find a R value waaaay lower than my previous one, and -this- is actually surprising!
Easy to plug with my full copper Viborg bananas, and very nice to see, this copper cable is worth every cent!
Thanks to Audiophonics Team for a faster than light delivery!
Happy listening!
Jean O.
rodage
Comme déjà signalé, cet ampli nécessite un rodage sérieux (plusieurs dizaines d'heures) avant d'en tirer la quintessence. Ne pas se fier aux premières impressions qui peuvent être un peu décevantes (bien à tort). Magnifique ensuite.
Eric z.
qualité - prix
Trés bon câble, bien construit, simple, rien de magique, avec lui on écoute la musique pas le câble, avec un rapport qualité -prix- résultat qui sort du lôt
eric m.
"Bling Bling"
Dans mon projet de mettre à niveau un Amplificateur PIONEER A-447. J’ai fait le choix de ces condensateurs ELNA.
Malheureusement à la réception de ma commande, je suis surpris par l’apparence « Bling Bling » de ces condensateurs ELNA LOA. Ils sont également bien loin de la valeur indiquée sur le composant. Bref…. Il n’y également aucune référence ELNA inscrite sur ces condensateurs. Je n’ai trouvé aucune valeur 15000µf/63V sur le site du fabricant Japonais ELNA.
Dans le doute, je préfère les utiliser pour un autre usage que HI-FI.
didier D.
YARBO RCA-019GB Gold 24k Plated RCA Connectors PTFE Ø7mm (Pair) The RCA Yarbo RCA-019GB connectors are models that benefit from a high quality manufacturing process. In a robust metal body are integrated 24k gold plated contacts, ensuring...
Très bonne fiches
Ces fiches sont parfaites. Montées sur un coax sommercable, le montage est très facile. La soudure du point chaud est facilite par la taille de la base du pin central . A cela s'ajoute le vissage de la masse... en tout 5 minutes de montage.
Rapport qualité/ prix top +++.
Eemeli T.
Crystal clear
Pretty well implemented cute basic DAC with a nice display and crystal clear sound. Jitter performance through spdif could be better though.
Eemeli T.
Best affordable BFA bananas
Nothing to complain of - great bananas with great fit to speaker terminals. Easy to work with and they look good aswell. 5 stars easily.
Eemeli T.
Very good stuff
This is a very competent cable. Durable, yet easy to work with.
Eemeli T.
CORNELL DUBLIER Aluminium Capacitor 80V 10000µF Cornell Dubilier's 380LX series capacitors offer excellent performance and will find their place in many applications, especially for switching power supply input and output...
Seems alright
Replaced main filter caps in my old sub with these.
Overall quality could be better, though - strip indicating minus lead was misaligned in one cap and I had to basically guess which one is minus and which one plus.
SERGE B.
Un excellent investissement !
J'ai une installation iFi de tout premier ordre (lecteur Cyrus, DAC Wattson avec switch EE8, préampli et ampli à lampes Yves Cochet, enceintes Ilumnia Magister Mk2) et bien que sceptique, j'ai essayé de changer les câbles d'alimentation pour voir si cela améliorait la qualité sonore.
J'ai d'abord utilisé de l'Olflex 110 CY 3 x 1.5 mm avec des prises Elecaudio PS24RA et des IEC Viborg en cuivre rouge . A ma très grande surprise le son a beaucoup gagné en détails, précision et ampleur. J'ai retesté en aveugle avec ma femme avec Ce câble-ci en alimentation de mes sources et le résultat est encore meilleur... Ma femme l'a tout de suite remarqué sans être au courant. Je ne suis pas ingénieur et je me l'explique pas mais le résultat est là et cela sans investir des sommes phénoménales...
Le câble est très gros (18 mm) mais assez souple et bien conçu si ce n'est au niveau des couleurs dont aucune ne correspond au neutre ! Dommage... Le fil de drain du blindage est très utile pour le raccorder à la masse ce qui est indispensable pour un blindage efficace.
Bref, un excellent investissement qui en vaut la peine
michel m.
Tres bien
J'avais un câble bas de gamme (grand surface) et depuis, je vous confirme la différence ...
Yuriy N.
Thanks to the Audiophonics team for quickly repairing my amplifier. Very responsive service. The quality of the device is unsurpassed for its price.
Joerg M.
Thank you Audiophonics for offering this product!
I'm really glad I bought the Allo DigiOne Signature!
Paired with a good DAC (I have the Topping E50), the sound is amazing.
Wonderful voices, generally excellent precision. - Fantastic!
I use a very good and very low-noise power supply (Allo Nirvana SMPS) for the streamer and the DAC. I assume the Allo Shanti, for example, could bring further improvements.
The speakers seem to exist even less to me, the spatial image has more depth. Everything seems more realistic. Fantastic even for live recordings.
I also have the predecessor (without signature, unfortunately no longer available). This already has amazing qualities. With signature it is actually even better.
The Allo DigiOne Signature is, in my opinion, a fantastic product and definitely worth every cent!
Joerg M.
Pierre-Marin L.
IAN CANADA UCCONDITIONER PRO Ultra Capacitor Conditioner Board 5V The Ian Canada UcConditioner Pro 5V is a ultra capacitor signal conditioner module for use with a 5V power supply. It will significantly improve the quality of your power supply...
Génial
Super upgrade pour mon RPI qui sert de Host Diretta...
Avant j'avais une alim Allo Shanti. Là c'est le jour et la nuit : je pense me faire un streamer complet en Ian canada...
C
Lucien v.
JANTZEN AUDIO ELECAP Electrolytic Capacitor 100V 5.6µF 5% Jantzen Audio EleCap electrolytic capacitors are non-polarized aluminum capacitors using etched or "raw" foil. With a tolerance of ±5%, they are more accurate than most...
condensateur JANTZEN
condensateur bien reçus ,après vérification son plus à 10% pas 5%
6.10 µf à 6.18µf
Pedro V.
Great audiophile headphone - with some caveats
These entry level Hifiman headphone sound excellent with acoustic music, jazz, classical provided you use them with a proper amplifier - smartphone or tablet will not cut it.
It sounds a bit "edgy" with an Adioqiuest DragonFly 1.5 but sound great with a Schiit Vali 2++ and Audiphonics RaspiDAC streamer, beating my Massdrop/Sennheiser HD 58x as the best "budget audiophile" headphone.
The cable could be a bit longer and would prefer it was terminated in a straight rather than an angled jack (in particular because it is much better suited for stationary listening).
