Peter Š.
Peter Š.
Tomislav N.
bertrand w.
Boîtiers HIFI 2000
Excellents produits (matière, définition, réalisation). Les commandes sont traitées avec rigueur et perfection.
Vifs...
Customers reviews - There are 19568 reviews.
Thomas B.
Upgrade for XDUOO XD05 Pro
While the configuration of XD05 Pro, featuring OPA1612 integrated OpAmps provides already a sonic experience of high quality, one can recognize shortcomings in instrument separation, soundstage and attack. This is most noticeable in symphonic music played by large orchestra. There are not many reviews covering XD05 Pro and Sparkos SS3602 OpAmps and, with respect to the price of SS3602, I felt quite hesitant placing an order. Eventually I did and I am not at all disappointed! In fact, I am happy to endorse the Sparkos SS3602 OpAmps improve the HiFi experience in all aspects but one: the relative volume is slightly less than with OPA1612.
Worth noting: the XD05 Pro opamp printboard just manages to accomodate the SS3602, critical due to closy-by capacitors. In my case the remedy was chopping off the protruding wire tips in the very corners (tiny elevator bars fixing the printboards on top of each other) making sure the tips do not touch the capacitors. Different printboard revisions may carry cap's of different size and make, so yours may look different.
Anyway, I am convinced the Sparkos SS3602 mark the high end of OpAmp rolling and recommend them wholeheartedly!
Digital Interface USB Amanero / Bluetooth 5.0 to AES / SPDIF / I2S 32bit 192kHz DoP128 This small, high-performance digital interface takes a Bluetooth 5.0 or USB signal as input and then outputs it in I2S (via HDMI), AES, Toslink Optics or Coaxial. The Bluetooth...
Transfigure un "ancien" DAC Audio GD NFB 12.1,dont l'entrée USB est trés moyenne.
Avec un bon câble numérique coaxiale (un Audiophonics commandé en même temps),c'est vraiment très bon : Quobuz+Audirvana,avec un PC (en attendant un streamer dédié)
LAURENT G.
Eviter les box internet à proximité....
je veux juste signaler que cet amplificateur est sensible au bruit que peut générer une box internet située à proximité. J'avais installé la mienne sur l'étagère située juste au dessus de celle de l'ampli. Conséquence un ronflement périodique très audible dans le canal droit, atténué dans l'autre.
Problème résolu en éloignant la box internet (1 mètre suffit), ce qui au passage laisse augurer une médiocrité de conception et/ou de construction de cette dernière.
Laurent G.
LAURENT G.
Premières impressions
Preampli transparent et suffisamment puissant pour l'utiliser avec l'HPA -S400ET que j'ai du régler sur 20 db de gain pour pouvoir garder un réglage fin du volume.
Utilisé en sortie XLR, la possibilité de rajouter du gain en sortie est bienvenue pour une source phono qui gagne un peu de relief.
Ce appareil ne semble avoir aucune signature sonore et n''apporte donc aucune coloration particulière au son. Belle qualité de construction apparente et plutôt lourd pour la taille.
L'ayant reçu très récemment, il est trop tôt pour lui donner une note, notamment sur la fiabilité.
Mode d'emploi en français téléchargeable appréciable, mais ce serait mieux s'il était systématiquement joint avec l'appareil.
L.G.
Excellent cable
J'ai encore acheté ce câble pour un autre système.
A ce jour je n'ai pas trouve mieux et surtout a ce prix pour alimenter mes trois systèmes.
Il est vraiment au top.
Merci à Audiophonics pour avoir reçu le colis en 24H
Eric A.
AC/DC Switching Power Adapter 100-240VAC to 42V DC 8.5A This power adapter takes in input a voltage of 100-240VAC and allows to have in output a voltage of 42V DC for a current of 8.5A. Its output connector is a DC 5.5/2.5mm jack,...
Tres bonnee alimentation
Tres bon produit, ne chauffe pas du tout sur des blocs aiyima A07max. Je regrette seulement que le cordon secteur ne soit pas fourni, c'est pourquoi je ne met que 4 etoiles.
Eric A.
Rapport qualité prix impressionant
J'utilise 2 amplis A07 max en mode mono et c'est produit qui bien associé, c'est à dire avec un bon preampli peut se révéler très impressionant, car d'une très grande transparence.
En effet la puissance n'est pas un problème, mes Kef 105 -2 sont parfaitement tenues, cela descend bas, plus bas même qu'avec un ampli yamaha AS-2100. Impressionant ce que ces petites boites arrivent à envoyer comme jus, même si on reste tout de même loin des 300 W annoncés. Attention au voltage car les premières versions avaient des condensateurs de 50v un peu juste pour utiliser du 48v, pour ma part j'utilise l'alimentation 42v 8,5A Audiophonic sans probleme, cela chauffe tres peu. Je voulais tester la classe D à moindre frais je suis convaincu.
Richard P.
Belle surprise
Pour essayer en remplacement d'autres câbles japonais commençant par Moga dans le médium/aigu, ils apparaissent de suite un peu moins précis mais musical à mon goût sur mon système.
Très satisfait.
MUNDORF F71 Varnished Wire Ferrite Core Self 0.71mm 1.5mH The F-Series combines small size and low price, making it an excellent value for money for filtering woofers, or any other application requiring high inductance and/or low...
Super.
Super pour mes filtres d'enceintes, je les utilise en parallèle. Livraison 24h !
MUNDORF L071 Air Core Coil 0.71mm 0.27mH Air coils, for physical reasons, are unbeatable in terms of precision on the restitution of the impulses, and are free of any distortion (contrary to ferrite coils). For this...
Super.
Utilisées en parallèle dans mes filtres d'enceintes. Livraison 24h !
MUNDORF MR10 non-inductive metal film Resistor 10W 18 Ohm Unlike conventional resistors,  film metal winding resistors have no residual inductance. Thus, in cases where impulse response is essential, in midrange frequencies for...
Elles sont longues.
Longues mais excellentes pour mettre en parallèle dans des filtres d'enceintes. Livraison 24h !
MUNDORF E-CAP ECAP100 (BR100) RAW Capacitor 100VDC 32VAC 10μF Mundorf E-Cap audio and signal coupling capacitors are bipolar electrolytic capacitors. They are used in applications where film capacitors are not suitable for space or cost...
Ils sont extras.
Très belle fabrication pour filtres en parallèle d'enceintes. Livraison 24h !
JANTZEN AUDIO CROSS-CAP Capacitor 400V 6.8µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
J'adore.
J'adore vraiment ces condensateurs, avis émis après utilisation d'une vingtaine de cette série. Livraison 24h !
JANTZEN AUDIO CROSS-CAP Capacitor 400V 4.7µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
J'adore.
J'adore vraiment ces condensateurs, avis après utilisation d'une vingtaine de cette série. Livraison 24h !
JANTZEN AUDIO CROSS-CAP Capacitor 400V 3.3µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
J'adore
J'adore vraiment ces excellents condensateurs, avis après une vingtaine achetés. Livraison 24h !
J'adore.
J'adore décidément ces condensateurs, j'en ai acheté une vingtaine, ils sont vraiment bons. Livraison 24h !
Excellent.
Excellente en série pour filtrer mes Cabasse Dom12 de mes Caravelle.
Livraison 24h !
JANTZEN AUDIO 000-0837 4N Copper Air Core Wire Coil 20AWG 0.92mH The Jantzen Audio Air Core Wire Coil is made of a very pure copper wire, offering distortion-free inductance. It will therefore be suitable for all audio applications. The coil...
Super en parallèle.
Super pour mes filtres en parallèle.
JANTZEN AUDIO 000-1673 4N Copper Air Core Wire Coil 17AWG 2.5mH 60x30mm High Purity Copper Wire. Distortion-clean induction. Suitable for all audio applications.  The coil benefits from a modern design, self-supporting and with a low tolerance...
Du costaud !
Excellente. Plus imposante en vrai qu'en photo. Pour mettre en série sur mes Cabasse 21NDB, je refais entièrement mes filtres de Caravelle. Elle fait 2.60 mH, j'ai déroulé jusqu'aux 2.47 mH nécessaire, j'ai un impédance-mètre. Livraison en 24 h, je m'habitue à force, bravo à Audiophonics.
Très bien.
Bien plus solides que mes cosses chinoises même si celles-ci sont made in China aussi.
Patrice D.
Super pour le prix
Câble légèrement rigide et assez volumineux pour un casque mais très bien fini. A l'écoute de la douceur. Je peux monter d'avantage le volume là ou avec ma rallonge standard ça saturait rapidement. Plus de matité. Ce qui n'est pas pour me déplaire.
Pour le prix un super produit.
robert g.
SHANLING CD-S100 (23) CD Player DAC AK4493 Sanyo HD850 USB 32bit 384kHz DSD512 Black The Shanling CD-S100 (23) is a high quality, high performance and versatile CD player. The core of the system is based on a  triple-core Junzheng X2000 processor...
Shanling cd s 100
exellent lecteur rapport qualite prix imbatable a recommander vivement performance et musicalite sont au rdv merci a l equipe Audiophonique pour le choix judicieux des appareils proposes
Gabriele F.
Excellent device
I ordered FLEX with RCA outputs, I must say that it is an excellent device, supported by excellent software, with which it is possible to model the response of the listening room.
Only negative note, the volume knob, too plasticky.
Carlo B.
Tutto ok.
Il prodotto si presenta bene, spedizione rapida. Lo sto testando, a breve aggiornerò recensione.
Ioannis P.
SHANLING M1S Compact HiFi Digital Audio Player DAP DAC ES3098Q2M Bluetooth 5.0 aptX LDAC 32bit 768kHz DSD MQA Black Shanling offers with the  M1S  a technical and aesthetic evolution of the M1  high fidelity digital player . This S version benefits from an improved ...
Perfect match for my DAP
Great quality product and Audiophonics are just the best!
Ioannis P.
Small size, BIG sound!!
I couldn't be happier with my purchase. This little DAP is a true wonder! It sounds amazing so I am just wondering if this is considered entry level then what more someone could expect from anything else costing double or triple the money!! Super happy with my choice and the shipping service provided by Audiophonics, can't recommend them highly enough.
Herbert N.
Un DAC fantastique de Topping
J'ai maintenant deux de ces appareils et je suis assez enthousiaste à propos de ce DAC. J'ai déjà testé de nombreux DAC différents, de Sabaj, SMSL, Eversolo, ainsi que d'autres modèles de Topping, le D70 Pro Sabre et le E70 Velvet. Le E70 est génial, le son est dynamique et clair, seul le D70 Pro Octo surpasse le E70V en termes de clarté et de transparence. Le D70 Pro Octo n'est pas le DAC le plus rapide, c'est clairement le D70 Pro Sabre qui a une longueur d'avance, il est vraiment extrêmement rapide et clair comme du cristal, par rapport à l'Octo, le son est quand même un peu plat et manque un peu de profondeur et de chaleur. Le son de l'Octo a un large spectre dynamique, les basses sont profondes et fermes, les médiums et les aigus sont clairs, le son semble "rangé", structuré, pas comme chez beaucoup d'autres où on est complètement dépassé par la transparence. Un super produit de Topping !
BOÏTE MAGIQUE...
Après quelques jours d'utilisation intensive du petit FX-AUDIO Tube 03 je me permets de donner un avis supplémentaire pour enrichir celui que j'ai déjà donné et reflétant les premières heures d'utilisation. Il faut reconnaître qu'une fois les tubes rodés ainsi que le petit buffer lui-même, la restitution devient bluffante de qualité. Les timbres sont extrêmement agréables avec une richesse harmonique rare, On ne note aucune acidité sur les violons, ce petit buffer sera à même de corriger beaucoup d'amplificateurs à transistors un peu trop brillants. La dynamique est également de premier ordre et l'image stéréo assez spacieuse selon les tubes choisis. Un petit buffer vraiment exceptionnel.
mike s.
Flawless transaction
I wanted to capture the audio out from my AppleTV and send it to my DAC via i2s. This device helped me to achieve that goal. It required one extra hdmi cable in the signal as well as a second hdmi cable to handle the i2s duties. I also needed a 5V power supply that wasn’t included. I was shocked at how quickly the unit was delivered.
Jean-François A.
CORNELL DUBILIER Audio Electrolytic Capacitor 50V 10µF This Aluminium Cornell Dubilier electrolytic capacitor has a rated voltage of 50V and a capacity of 10µF. Its tolerance is 20%. It offers...
Excellent Condensateur
Condensateur installé dans un Amplificateur NAD 3020A.Excellent, l'amplificateur a retrouvé une jeunesse et fonctionne musicalement mieux que jamais! Très bon condensateur Cornell Dubilier.Un grand merci à nos amis d'Audiophonics de nous fournir ces condensateurs
Jean-François A.
PANASONIC FC Low ESR Capacitor 25V 220μF Panasonic FC capacitors benefit from a high design quality and a low ESR. They will be suitable for most of your projects, whether for DIY creation or as a replacement for...
Excellent condensateur Panasonic
Condensateur installé dans un Amplificateur NAD 3020A.Excellent, l'amplificateur a retrouvé une jeunesse et fonctionne musicalement mieux que jamais! Très bonne série FC de chez Panasonic. Un grand merci à nos amis d'Audiophonics de nous fournir ces condensateurs
Jean-François A.
Condensateur installé dans un Amplificateur NAD 3020A.Excellent, l'amplificateur a retrouvé une jeunesse et fonctionne musicalement mieux que jamais! Très bonne série KW de chez Nichicon.Un grand merci à nos amis d'Audiophonics de nous fournir ces condensateurs
Jean-François A.
Condensateur installé dans l'alimentation principale d'un Amplificateur NAD 3020A.Excellent, l'amplificateur a retrouvé une jeunesse et fonctionne musicalement mieux que jamais! Très bonne série KW de chez Nichicon.Un grand merci à nos amis d'Audiophonics de nous fournir ces condensateurs
Jean-François A.
Condensateur installé dans le circuit d'ampli d'un Amplificateur NAD 3020A.Excellent, l'amplificateur a retrouvé une jeunesse et fonctionne musicalement mieux que jamais! Très bonne série KW de chez Nichicon.Un grand merci à nos amis d'Audiophonics de nous fournir ces condensateurs
Jean-François A.
Condensateur de grande qualité
Gilles M.
AUDIO-GD R-1 NOS R2R Discrete DAC DSP FPGA USB Amanero HDMI I2S32bit 384kHz DSD512 Black The NOS version of the Audio-GD R-1 benefits from new features and a number of improvements, with the aim of providing ever more precise and rich sound reproduction.
Naturel
Super service de la part d’Audiophonics, bravo pour votre rapidité de traitement et votre offre.
Concernant le dac R2R Nos : musical, naturel, les détails sont là sans être envahissants, rythme, bref du plaisir dans la matière à partir de musique dématérialisée. J’ai aussi un Chord Hugo 2 qui m’amuse beaucoup mais me fatigue parfois. Écoute casque uniquement. Construction solide avec les fonctions de base sans avoir besoin d’un écran 15 " qui brille comme un sapin de Noël. Je recommande.
JANTZEN AUDIO CROSS-CAP Capacitor 400V 39µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
J'adore !!
Je suis fan de ces condensateurs, plus moelleux que des SCR ou des Mundorf de base. Ils tiennent la comparaison avec des Mundorf Evo voir plus.
Pour avoir mieux, il faut passer au Mundorf Suprême.
Audiophonics toujours au top pour la livraison.
J'adore !!
JANTZEN AUDIO CROSS-CAP Capacitor 400V 15µF Jantzen Audio Cross Caps MKP 400V are considered the best value for money for the design of passive crossovers for loudspeakers. Made in Europe, this new competitor of the...
J'adore !!
Herbert N.
Fantastischer DAC
Ich habe inzwischen ja 2 dieser Geräte im Einsatz und bin schon ziemlich begeistert von diesem DAC. Ich habe wirklich viele probiert, bis ich mich für den D70 Pro Octo entschieden habe, wie Geräte von Sabaj, SMSL, Eversolo, auch andere Modelle von Topping, wie den D70 Pro Sabre und beim E70 Velvet bin ich erstmal hängengeblieben. Der E70 ist wirklich schon ein sehr guter DAC und dann kam der D70 Pro Octo in den Verkauf, der den E70 Velvet, in Bezug auf Klarheit und Transparenz, noch einmal übertrifft. Der schnellste DAC ist der Octo nicht, hier hat eindeutig der D70 Pro Sabre die Nase vorne, der ist wirklich extrem schnell und kristallklar, fast ein wenig zu klar, weil der Klang dann doch etwas flach ist, im Vergleich. Der Klang beim Octo hat ein großes dynamisches Spektrum, der Bass klingt tief und fest, Mitten und Höhen sind klar, der Klang wirkt „aufgeräumt“, strukturiert, nicht so wie bei manch anderen, wo einem die Transparenz erschlägt und komplett überfordert. Tolles Produkt von Topping!
Arnas K.
TOPPING DX9 DAC AK4499EQ Headphone Amplifier NFCA Bluetooth 5.1 AptX LDAC 32bit 768kHz DSD512 Silver To celebrate its 15th anniversary, Topping unveils a high-performance DAC / Headphone Amplifier: the DX9. In addition to its very high performance, Topping has given it a...
Topping's Masterpiece
Very beautiful, great build quality and heavier than predecessors
is first impressions when i received it.
Packaging is top notch! You can be assured than your Topping dx9 arrive in pristine shape.
Sound is Classic Topping aka very punchy and clean with some chocolate warmth flavoring.
Dont expect old and bad recording to sound impressive!
Great recordings, Games like Battlefield 4, far cry primal, Alien Isolation sound very powerful and dramatic with my HD800S and balanced cable.
Other contender was Element x2 with tiny bit better components with practically same features and also beautiful design, but that costs 4.4k euro!
This dac/amp is absolute is absolute bargain in comparison to dac/amps like Rme adi2 or chord hugo 2 and other contenters up to 3k.
I wish Topping continue Dx9 cause it have so much going on in their favor like Top tier dac, top tier amp, 1st class design and build and ton of feature and inputs.
Topping have absolute Winner in my book!
DIMOKRITOS D.
Truly natural sounding cable
I have tried numerous cables of any cost in my system. To my surprise, the sound of this cable is the most natural off all. It is fast, dynamic, full bodied, perfectly controled and very detailed but it never gets harsh, even at the cressendos of a symphonic orchestra. The timbre over the whole audio band is truly exceptional and, yes, the air and space of the stereo image is allmost spooky. The lack of harshnes makes bad recordings acceptable. Beware though. It needs at least 10 hours of break-in for the extreme frequencies to start to open-up. And it might not be everyone's cup of tea. I have heard cables with more energy in the treble but the balance of this cable, to my opinion is trully exceptional. To my system it simply was "the holy grail"
Stéphane V.
Sur Aune X8 XVIII Magic Dac, avec l'alimentation Aune XP2 indispensable, le résultat est d'une grande fidélité, d'un naturel qui ne force rien. La musique est libre et équilibrée dans toutes ses dimensions, y compris dans son art. Trois feutrines assez denses et doublées en guise de pieds ont été ajoutées après l'essai d'autres matières, pour libérer la place nécessaire au volume du Sparkos sous l’appareil. Le rodage est important. Le son est passé d'une grande douceur à une forme de petite dureté passagère. Cette dureté a disparu depuis laissant la place à l’évidence décrite.
Roberto G.
Beau distributeur et belles finitions. Il est plutôt grand et fait son poids. Aucune radiation autour du boîtier, ni sur les prises. Le filtrage est de qualité. Il n’en fait pas trop et apporte une belle sonorité naturelle. Belles basses, belle aération, aigus assez doux et détaillés. Bel équilibre. Quatre prises filtrées c’est déjà bien et c’est appréciable d’avoir deux prises non filtrées pour des amplificateurs sur un bon distributeur. Bouton power bien placé sur le devant, joli, discret et très utile. 5/5
Fabien T.
Prix/prestation de 1 er ordre !
Un tweeter à guide d onde dans cette gamme de prix et au regard de sa courbe entre 10 et 20khz je m'attendais probablement à des aigus anémiques et coupants assez tôt. Belle surprise pour une 20aine d'€. Croisés sur un ordre 3 ( peuvent se satisfaire d un ordre 2 dans bien des associations tweeter woofer différentes avec un crossover adéquat !! ) à 3200 hz, il se montrent qd même assez précis et rigoureux de façon générale. Leur faiblesse en haut de gamme ne pose finalement pas vraiment soucis à l'écoute. Peut être un peu "secs" et dans mon cas mériteraient sûrement une résistance de l'ordre d un ohm voir un peu moins en série juste en amont pour les atténuer et rendre l écoute plus "maîtrisée" lorsque le volume monte. J'ai hésité à mettre 5 étoiles car mm si ils n'offrent pas la douceur et le détail d un RST28 ,compte tenu de leur tarif on ne peut rien leur reprocher !! Le guide d onde est un avantage ici, tant pour l'écoute et la diffusion hors axe léger je trouve, et également par recul du ctre acoustique tweeter au woofer, améliorant la synchro temporelle et la rendant plus naturelle que d inclure un delay dans son crossover
Karl K.
changement de fréquence de coupure
très bon produit, sonorité excellente.
J'aimerais changer la fréquence de coupure et choisir une coupure entre 1800 et 2000 Hz, quelle valeur de condensateurs choisir, 6n8?
Filippo M.
DAYTON AUDIO PC68-4 Full-range speaker 20W 4 Ohm 86dB 120Hz - 17kHz Ø6.3 cm A compact wideband loudspeaker with beautiful finishes. Ideal for building/repairing a small audio system.
content
expédition rapide et j'ai placé ce haut parleur dans barre de son ....MERCI
RESTITUTION ASSEZ TYPEE...
Pour le prix d'une poignée de main dans une boutique Hifi High-End vous avez ici un petit préampli susceptible de procurer de réels plaisirs aux amateurs du son typé "tube". Je ne saurais trop conseiller d'effectuer un" tube rolling" afin de trouver ce qui conviendra à vos goûts car les tubes 6K4 fournis d'origine ont tendance à émousser l'aigu alors que les 5654W se révèlent nettement plus équilibrés. De même, bien que moins important, on peut changer les ampli ops. Les LM 4562 NA à très faible bruit ne conviennent pas, rendant l'aigu trop brillant voire acide, les JRC 5532 procurent un résultat très honorable et les TLE2142CP confèrent un peu plus d'aération, adoptés ! Il faut reconnaître tout de même que ce préampli favorise le médium, ce que les inconditionnels du tube apprécieront mais les puristes un peu moins, en effet les musiciens sont placés au premier plan ce qui génère beaucoup de présence mais défavorise la profondeur d'image, ce que personnellement je regrette. Comparé à l'ampli classe D Aiyima A07 MAX (seul), ce dernier possède une image plus spacieuse, c'est incontestable, et un grave d'une meilleure tenue. Ceci dit ce petit FX-AUDIO Tube 03 ne démérite pas; je suis étonné par sa très bonne transparence et sa fidélité de timbre, chose d'autant plus étonnante que l'alim fournie (12V, 1A) n'est pas de type faible bruit. Faut-il y voir une conception du répartiteur interne d'alimentation particulièrement soignée ou bien l'effet des lampes elles-mêmes, tout simplement ? Autre élément à porter au crédit du FX-Audio: sa dynamique, sa spontanéité qui rend la musique particulièrement vivante. En conclusion : un préampli au son assez typé qui réjouira ceux qui aiment ce genre de sonorité, personnellement je reste fidèle aux bons amplis classe D directement attaqués par un DAC pour leur restitution proche du signal et leur réalisme affirmé.
P.S. Mention spéciale "tableau d'honneur" pour le S.A.V. d'Audiophonics qui m'a remplacé un tube défaillant avec une réactivité exemplaire, aussi je recommande chaudement l'enseigne Audiophonics, certes vous pourrez trouver très légèrement moins cher sur un certain site marchand basé en Chine, mais soyez bien conscient qu'Audiophonics vous procure écoute, conseils, garantie et service après vente "first rate", choses que vous ne trouverez pas ailleurs.
Xangsane XT-T1061
Pourquoi ne pas prévenir lors de la commande que le produit n'est disponible. J'aurais choisi un autre connecteur RCA.
Salutations
Panagiotis B.
Great so far
That's my first DAC, but I can tell when the sound quality is nice.
Checked with coax/optical and Bluetooth (LDAC)
The volume via optical is a bit lower than coax.
I tested the usb input with my win11 laptop. I used the issued cable from the box, and the display went to "384" as I plugged it in. No drivers needed.
I set it to 24/96 and played a few flacs of the same quality. Sounded nice. System sounds, Youtube videos were ok.
It's early, but as far as I can taste, the sound is well balanced.
Treble is not sibilant, though my speakers feature titanium domes and can be fatiquing with low quality music.
Bass is there, too.
Sound is overall transparent, without strange colorations.
The remote control is very handy.
I use D-6s as a center of all my digital sources (Bluray, win11 PC), Sony MD Deck, Cellphone)
So the remote acts like a universal volume control of my humble system.
Let's hope D-6s proves reliable...
Service from Audiophonics was great so far. I chose the faster shipping option and the parcel came in 2 days from France to Greece.
