Jochen M.
Tout n'est pas parfait
Richard M.
Bernard g.
Excellente Interface
Customers reviews - There are 19551 reviews.
Giovanni-Mattia P.
E1DA COSMOS SCALER Low Noise Variable Gain Balanced Preamplifier for COSMOS ADC The Cosmos Scaler is a low-noise, variable-gain preamplifier designed specifically for the brand's Cosmos ADCs. It incorporates quality components such as two OPA1612 and two...
A very useful accessory for E1DA Cosmos ADCiso
Accurately correspondent to specifications, perfectly fit for laboratory use, excellent support with ample explanations by the designer in Audiosciencereview's dedicated thread. Five stars.
Giovanni-Mattia P.
E1DA COSMOS APU Analog Processing Unit Preamplifier / Microphone Preamplifier The E1DA Cosmos APU is the first product of its kind available on the market. The name APU stands for Analog Processing Unit.
Well conceived and versatile device perfectly fit for lab usage
Giovanni-Mattia P.
Well conceived and versatile device perfectly fit for lab use
Giovanni-Mattia P.
E1DA COSMOS ADCiso GRADE A Balanced ADC ES9822Pro 32bit 768kHz E1DA offers an improved version of its high-end symmetrical ADC, the ADCiso. The analogue/digital conversion stage is still based on an ESS ES9822Pro chip, but the USB interface...
Perfectly fit for lab use
Benjamin R.
top
Excellent rendu sonore sur mon primaluna, très doux
Benjamin R.
SMSL DO300EX DAC AK4191+AK4499EX Headphone Amplifier XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 MQA-CD Black SMSL unveils, with the DO300EX, a powerful, high-quality DAC/headphone amplifier. It incorporates quality components such as the AK4499EX DAC chip...
vraiment top
Vraiment très efficace.
Facile d'utilisation, sans trop de fioritures.
Le son est vraiment sublimé, la puce AKM apporte douceur, volupté, et une spacialisation excellente.
Excellent rapport qualité-prix je ne peux que vous le conseiller
Charles B.
Appareil simple et qualitatif
J'utilise cet appareil en amont de mes enceintes actives pour switcher entre mon ensemble Home-cinéma et mon ensemble Hi-Fi : rien à redire, le bouton de sélection des sources est très agréable à manipuler et je n'ai pas noté de dégradation sur le son.
Charles B.
MINIDSP FLEX DIGITAL Audio Processor DSP SHARC ADSP21489 XMOS Bluetooth The Flex Digital miniDSP is the brand's 3rd generation 2-in/4-out audio processor. It keeps the powerful floating point processor previously used with a redesigned input/output...
Un très bon préampli/DSP numérique
Possédant le Flex TRS à sorties symétriques et des enceintes actives à DSP numérique, je souhaitais le remplacer par le Flex digital afin d'éviter les conversions AD/DA inutiles. Niveau son, rien à redire ni au niveau souplesse d'utilisation mais j'ai dû le renvoyer (merci Audiophonics !) car le signal d'horloge reste actif lorsque l'appareil est en Standby (MiniDSP me l'a confirmé). Or mes cela empêche mes enceintes de se mettre en veille. C'est bien dommage car c'est vraiment un bon appareil.
Charles B.
MINIDSP FLEX Audio Processor DSP Balanced SHARC ADSP21489 XMOS Bluetooth The miniDSP Flex is the brand's 3rd generation 2-in/4-out audio processor. It keeps the powerful floating point processor used previously with a redesigned input/output...
L'un de mes meilleurs achats en Hifi !
Je comptais mettre cet appareil entre mon préampli Accuphase et mon ampli mais je suis revenu en arrière rapidement car je trouvait que cela donnait une sonorité métallique au son.
Finalement je l'ai branché en tant que préampli-DAC et là c'est top : c'est le meilleur DAC que j'ai jamais eu et la partie préampli est très bonne, sans compter le fait qu'avec les 2 sorties j'ai pu enfin intégrer/filtrer mon caisson de graves. Bref je suis ravi de cet achat ! Et merci Audiophonics dont le service est toujours au top :-)
Claude R.
Enfoncer fermement les connecteurs Toslink jusqu'au "clic" !
Si comme beaucoup d'autres vous trouvez que "les connecteurs Toslink sont un peu lâches", n'hésitez pas à les enfoncer fermement jusqu'au "clic" !
Ce problème n'est pas spécifique à ce câble et ayant moi-même perdu énormément de temps à chercher d'où provenaient les micro coupures de mon casque par manque d'explication j'espère que ça sera utile à d'autres ;-)
Gerhard K.
Excellent Sound
On the output I run a 2.1 system (KEF LS50 Meta + DIY subs) with 3x500W class D plate amplifiers (Pascal). I came from a RPI3 + Hifiberry DAC HD2, running on Volumio, which sounded quite good to me.
But immediately, keeping Voilumio as OS, I heard quite a difference: cleaner sound, less fatiguing in the highs, more solid image, better dynamics. I can't say it way day and night, but there clearly was an improvement that justified the cost. Even my wife who is not very audiophile noticed the difference.
The RPI4 surely contributes to the responsiveness of the system (music library stored on a NAS over eth GBit), no waiting anymore, fluent switching between library, Spotifiy, Hiresaudio and Youtube. Bravo Audiophonics and thanks!
Yannick B.
SHANLING CD80 CD Player Philips Sanyo HD860 DAC ES9219MQ Bluetooth 5.0 LDAC Silver The Shanling CD80 is an efficient CD player with integrated DAC. It performs these functions brilliantly, thanks to its meticulous architecture and high-quality components,...
Définition et précision pour pas cher.
Je viens de m'offrir ce joli lecteur cd en remplacement de mon bon vieux Rega Planet.Le Shanling est moins encombrant et plus pratique (chargement du disque frontal un peu bruyant cependant....).
La musique qui en sort m'enchante.C'est précis et définit sans être froid. Je découvre de petits signaux musicaux que le Réga occultait.Bref,je suis heureux de mon joujou,Ma seule critique ira vers ces petits "clics" électrique que j'entends à chaque changement de piste du disc ,ainsi qu'au démarrage et fin de lecture.(en manuel ou avec la télécommande)
Le Bluetooth fonctionne aussi très bien.
Merci à Audiophonics qui a assuré pour le délai de livraison.C'est bon de pouvoir compter sur autant de sérieux.
Bertrand D.
Incroyable à ce niveau de prix !
Sur les conseils avisés d'Audiophonics, j'ai changé mon ampli Yamaha WXA 50 pour un SMSL AO200 MkII. Cet ampli symétrique est absolument incroyable de pureté, puissance et neutralité ... mais associé au Topping E50 c'est tout bonnement exceptionnel !!! C'est bien simple ... ce n'est plus la même musique que j'écoute ... On ne parle plus de pureté, de grave tendu etc - tout y est avec une neutralité exceptionnelle - mais d'une évidence sonore totale. Avec le Topping E50, vous écoutez le mixage tel que l'a prévu la production, un point c'est tout. Les accords sonnent plus fluides que jamais ... ils ont même une sonorité parfois légèrement différente de ce que je pouvais entendre avant. La scène sonore se déploie dans des direction qui m'étaient inconnues ... le Topping E50 apporte une présence et une proximité avec la musique (on est à 30 cm de la guitare par exemple) que j'espérais, depuis des années ... obtenir un jour ... !
ISOACOUSTICS ZAZEN I Vibrations Absorber Platform 432x381x30mm 11.3kg The IsoAcoustics zaZen, named after a method of sitting meditation, is a vibration-absorbing platform designed to be paired with vinyl turntables, tube amplifiers or other...
quel naturel!
Tous les détails sont là mais sans agressivité ni surdéfinition , un naturel excellent avec une scène sonore large , bravo ! Attention pourra mettre en valeur les défauts de votre installation ...
RQP imbattable
Ramm audio reste fidèle à ses habitudes : rigueur et qualité.
Facile à mettre en œuvre et associé aux fabuleuses nouvelles prises Rca de chez Xsangsam sans soudure, au prix dérisoire, le résultat final est bluffant.
J’ai monté les deux fils sur le point chaud et la tresse à la masse des deux côtés.
A l’écoute, il se dégage un mélange de dynamisme et de finesse avec des aiguës exceptionnels.
La magie opère au bout de 20/30 heures de chauffe avec des timbres justes et aérés.
A écouter d’urgence, vous n’en croirez pas vos oreilles.
En conclusion, ces deux nouveaux produits , Cable Ramm et prises Rca proposés par audiophonics remontent encore le niveau du RQP.
Alors un grand merci aux acheteurs de cette belle entreprise.
Bravo audiophonics
Patrick
Laisse passer la musique
Premier achat concluant fiches très bien faites avec une très bonne conductivité (précisée dans le description) c'était mon critère de choix en plus des 5* et commentaires litigieux
Une belle concurrence a ETI que je possède sur mon système en moins cher
Xavier V.
17,50 euros TTC en 2015
17,50 euros TTC en 2015, 35,90 euros TTC en 2023.
No comment !
David V.
convertisseur spdif/Toslink
Utile pour qui souhaite, par exemple, connecter un téléviseur sans sortie optique mais avec une sortie SPDIF que l'on peut, grâce à ce petit boitier, relier à une barre de son avec entrée Toslink. Evite aussi de racheter une télé quand on en a une sans sortie optique mais qui fonctionne encore.
Wilfrid L.
VIABLUE T6S SCREW RCA Connectors Gold Plated Ø8mm (Pair) These Viablue T6S RCA connectors benefit from an impeccable manufacturing quality. With their 24-carat gold-plated contacts, they offer very good audio signal conductivity while...
Belle qualité
Connecteurs de belle qualité
Cependant j'aurais aimé une notice car le montage du câble n'est pas aisé.
J'aurais également aimé qu'une clé allen soit fournie.
Prévoir une clé allen de 2 (tout petit) et attention au serrage!
J'ai ''foiré'' une tête de vis sans pour autant avoir trop forcé. Heureusement le câble est serré mais je ne pourrais plus démonter le connecteur.
Laurent r.
Tres bien
Il est très bien;il fonctionne avec mon dac et l'apairage avec mon téléphone s'est fait sans probleme.Sur la photo il a l'air plus grand que la réalité.Attention toutefois il possède une prise usa donc il faut un adaptateur non fourni.Point de vu livraison on ne peut faire mieux,commandé vers 12h30 et reçu le lendemain après midi au point relai dpd.
MOONDROP DAWN PRO Portable Balanced Headphone Amplifier DAC 2xCS43131 32bit 384kHz DSD256 With the Dawn Pro, Moondrop unveils a high-performance, affordable portable symmetrical DAC headphone amplifier. Two CS43131 DAC chips enable the...
Great amp
Fantastic little amp, especially for the price. Very happy with this purchase.
MOONDROP CHU In-Ear Monitors IEM Dynamic 10mm with Microphone 120dB 28 Ohm 20Hz-20kHz Moondrop unveils with the Chu in-ear earphones taking advantage of a very nice design quality and sound reproduction at an exceptionally affordable price. Each IEM features a...
Amazing value
Must say I have been surprised by the sound quality in these. Did not expect much with this price tag, but was positively surprised. You can't go wrong with these, if you are looking for a budget/entry level IEM.
Olivier S.
Pour recepteur SDR radioammateur
J'ai acquis deux alimentations dans le cadre d'un projet dit de websdr. Il s'agit de récepteur d'ondes radio en ligne.
Ces petits bijoux me permettent d'alimenter deux redpitaya 122-16 sur la sortie 3A et deux AIRSPY sur la sortie 1A.
La qualité est indéniable. Par contre ont aurait aimer voir des ailettes de refroidissement.
En effet, nos récepteurs tournent 24h/24. L'augmentation de la durée de vie par un meilleur refroidissement serait un réel plus.
Mais sinon, les niveaux de bruit annoncés et la stabilité sont bon.
LAURENT G.
Accessoire dispensable
Si le produit est bien construit et livré avec divers adaptateurs qui peuvent être utiles, son insertion à l'entrée USB de mon ancien DAC n'a pas apporté de modification clairement audible sur mon système que ce soit en bien ou en mal.
Je ne l'utilise plus avec mon nouveau DAC.
Je reste dubitatif sur son utilité réelle.
Laurent G.
LAURENT G.
Produit fragile à l'utilité incertaine
Inséré en sortie de PC, avant le cable usb alimentant un DAC, Cet accessoire n'a pas eu d'influence audible significative sur les performances audio de mon système. Au mieux un effet "placebo". En outre la connectique est fragile et cette clé usb s'est délitée au bout de quelques mois.
Je ne peux recommander un tel accessoire.
Laurent G.
Pierrick R.
1MII LAVAUDIO DS220 Bluetooth 5.1 Receiver QCC5125 DAC ES9018K2M aptX Adaptive LDAC This small, practical and compact 1Mii Lavaudio DS220 Bluetooth 5.1 receiver brings wireless connectivity to your HiFi system. Its high-quality design is based on the...
Qualité au rendez-vous
Excellente finition et connectique complete.
A 3 metres du recepteur la transmission Blutooth avec mon smartphone est établie en moins d'une seconde et en qualité Ldac. Avec des fichiers Flac qualité CD, sur mes enceintes de bibliothèque et mon ampli de classe A/B, je n'ai trouvé aucune différence 'qualitative' entre les CDs et ce petit transmetteur. Les bois, les cordes grattées frottés ou frappées, les cymbales, les grosses caisses... Tout est precis, net et bien positionné.
C'est bien bien mieux que mon précédent transmetteur aptx.
Sami S.
bonne alim.
une bonne réserve de puissance
Charles P.
Gaine tressée Viablue
Que dire tout le monde l’a connais, cette haine est différente des gaines tresses ordinaire, un mélange de deux matériaux sans doute , leurs couleur bien marqué en font des gaines pour câble de luxe, très bon rendue une fois installé.. je recommande .
Charles P.
Embout Viablue
Bien connus des audiophile, leurs qualité irréprochable en font leurs renommé, ils possède une partie protège câble, le prix est excessif, mais s’est pas nouveau, très satisfait de ces embouts..
Charles P.
Embout de câble plasué argent
Embout de câble en plusieurs diamètre disponible, bonne qualité générale , commande pour leur longueur que l’on peut ajuster en coupant biz sur, satisfait de ces embouts.
Sami S.
ampli pour la sono
sonorité pas de tout détaillé en haut de spectre ,si vous cherchez un ampli de qualité audiophile ce module n'est pas fait pour vous
Terence M.
NEUTRIK NTP3RC-B Jack 3.5mm Connector 3 Poles Stereo Angled Gold Plated Ø4.5mm (Unité) This 3.5mm NTP3RC-B jack connector from Neutrik has 3 poles with gold plated contacts, ensuring good conductivity but also excellent oxidation resistance. The connector body is...
LE connecteur mini-jack coudé.
Il existe aussi en version nickel, mais le noir est résolument plus chic. J'admets prendre en compte aussi l'aspect visuel. Ces connecteurs sont très solides et bien conçus. Il faut toutefois noter une compatibilité moyenne avec les connecteurs mini-jack des smartphones Samsung, qui semblent rejeter le connecteur comme une mauvaise greffe. Il reste mal enfiché. C'est le seul appareil sur lequel j'ai un soucis. J'utilise ces connecteurs depuis 15 ans, j'ai dû en souder une soixantaine, et c'est toujours un plaisir (à condition d'agrandir le caoutchouc lorsqu'on emploie des câbles de section importante).
Terence M.
Souple, facile à souder, suffisament résistant
J'utilise régulièrement ce câble pour assembler des micros à capsules électret. Étant relativement souple, il est assez peu microphonique, à condition de réaliser un bon découplage mécanique du câble juste avant la capsule.
Gadget
Bien léger et fait un peu dînette.
Pour le prix, ça passe.
Bon fer a souder. Chauffe rapidement avec une règle de température a mollette.
Bien pour le prix
Pas top qualité mais convenable
Pas facile ces demoiselles !
Certe, c' est mon premier diy, mais je déconseille aux débutants en soudure, ce qui est mon cas.
Il faut savoir souder vite au risque de voir les pattes de fixation se désolidariser du châssis en plastique.
Sinon, elles sont jolies et fonctionnelles.
Pas trop de référence à comparer, puisque c' est mon premier diy en xlr. Fait ce qu'il faut !!
Pas simple..
Mon premier câble monté en xlr .
Il faut être patient avec la tresse qui est difficile a détresse.
Quant aux conducteurs, torsader les bleus ensemble et de même pour les blancs.
Enfin, j' y suis arrivé, comme son homologue en RCA, ce câble est neutre transparent et laisse la place a la musique .
Difficile pour les débutants mais recommandable quand même.
Bonne qualité et fabrication massive. Contacts francs.
Juste une petite critique : On ne peut le fixer, il n'y a pas de pattes de fixation, ou simplement quatre trous filetés "Dia 4 ou 5", pour amener vis et équerres de fixation sur un support, meuble, mur, etc.
Peter D.
Taken by surprise
Got 6m pair to run under a newly laid wooden floor away from system into an adjacent room as a trial run. Was using 2M pair of Nordost Red Dawn (R. D.) into B&W 805s in old setup. A 6M pair of R.D. would have been €€€€. The bass response is so much better & wider soundstage from this ATAUDIO ribbon cable. Thicker conductors compared to R. D maybe help? Treble is very similar to R. D also. Using a Copeland CTA405 so the cables are a fraction of the total setup but really really surprised at detail level. Another 20-30 hrs of burn and these could be recommendable to my hifi buddies. Starting to wonder if spending €€€€ on cables is snake oil. Fast delivery to Ireland and we'll packaged. Will purchase again from audiophonics
Jeorge B.
DMP-A6
Great in all aspects no need to use my Ares 12th DAC they sound equally. The touchscreen is responsive. And no worries about shopping online with Audiophonics. Cheers!!!
gilbert Q.
Gilbert
Le placage or ne tient pas . Ceci étant constaté après une seule utilisation sur bornier Jantzen carbone .
gilbert Q.
Gilbert
Ce câble NES-5002 dégage une odeur désagréable typée pétrole qui
pour moi le rend impropre à une utilisation dans des pièces de vie .
Pour être totalement sincère , je vous suggère de renvoyer votre stock
à votre fournisseur car il est peu probable que vous puissiez satisfaire
un quelconque client avec un câble qui pue .
Malgré cette mauvaise surprise je conserve à votre société ma confiance et mon estime .
trés bien
je voulais essayer du tube Mullard sur un ampli guitare. Pour commencer livraison impeccable et colis soigné. Ensuite montage du tube et premier essai. Aux premiers accords basses présentes sans agressivités, mediums et aigus qui se tiennent sans débordements ..C'est pas donner mais c'est bon ..Adopter..
Laurent T.
Top qualité !
Vraiment très belle et bien faire cette iec Elecaudio châssis , les câbles tiennent parfaitement et le serrage est top bref que du positif
AUDIO-GD D-28.38 ES9038Pro DAC 32bit / 384kHz DSD512 Amanero Crystek Accusilicon Class A Discrete Headphone Amplifier The D28.38 by Audio-GD combines the function of DAC, disrete preamplifier / transistor (non-feedback balanced design).  It uses an ESS ES9038PRO DAC chip,which features the...
Tres bien
Appareil reçu le lendemain de la commande donc très satisfait.
Ayant déjà eu cet appareil mais sans le DAC intégré je suis en terrain connu.
Il faut quelques heures avant que cela délivre tout son potentiel.
Une simple remarque ; un manuel en Français aurait été le bienvenu pour paramétrer les filtres du DAC a ma convenance.
Je ne me sers que du preampli en XLR et donc très satisfait.
Merci Audiophonics.
Frederic S.
Power Adapter USB-PD QC3.0 5V / 9V / 12V 20W This power adapter delivers 20W of power and features dual USB-A and USB-C connectivity. It also benefits from QC3.0 (Quick Charge) and USB-PD fast charging technologies. It can...
RQP au top
Frederic S.
SMSL SANSKRIT 10TH MKIII DAC USB AK4493S XMOS XU316 32bit 768kHz DSD512 Gray SMSL comes back with an updated version of the Sanskrit, the Sanskrit 10Th MKIII, taking back the compact and practical design of the former model while improving its...
Équilibré
ISOACOUSTICS GAIA II Vibrations Absorbers Isolators 55kg Ø51x43mm (Set x4) IsoAcoustics Gaia II vibration absorbers improve clarity and soundstaging for speakers or subwoofers weighing 55kg or less. They feature a machined stainless steel body with an...
GAIA II
Franchement bluffant.
GB
