dominique w.
Qualité apparente des connecteurs. Câble trés souple. Permet avant tout de profiter des bénéfices d'une liaison symétrique...
Pedro P.
Merveilleux amplis
C'est mon second achat de cet ampli, c'est dire si j'en suis ravi. Ils remplacent mes anciens modèles...
Andrii V.
IAN CANADA FIFOPI Q7 III
I purchased the Ian Canada FifoPi Q7 III for my custom DAC project, and I am extremely pleased with the results.
The...
Customers reviews - There are 21103 reviews.
Exceptionnel !
Montées sur un pur argent coaxial en 0,8 mm, c'est extraordinaire, une merveille. Meilleures que les autres elecaudio, xangsane et même les klei... En analogique elles ne m'avaient pas impressionné outre mesure, après j'ai pas tout essayé avec mais la.... Grosse claque pour ces petites fiches qui paient pas de mine. Et pour moi aucun problème serrage, ca tient.
Arnoud H.
PANGEA PREMIER XL Phono RCA - RCA Cable + Ground Wire 1.25m Pangea Audio's RCA-RCA Premier XL phono cable is a top-of-the-range cable with multi-AWG conductors made of pure Cardas grade one copper. This phono cable also...
Well balanced phono cable
There is not a lot of information to find on internet for this cable. That triggered my curiosity.
On the manufacturers website I found that the cable are made with Cardas Grade One Copper conductors. Which I think is desirable.
The cable needs time to settle in the system. When settled, the cable gives a very good balance between timbre, spaciousness and clarity. It is difficult to describe. At first it does not appear that special of a cable. It does not have an overly holographic soundstage. It is not overly punchy but something much more natural. Like instruments are played in your room instead of an overly sharp projection where the instruments are outlined to accentuate their presence.
I do not think this cable is for everyone due to their size and stiffness. On an other turntable I have the VDH D-502 cable which is much easier to handle in tight spaces than this cable.
If you play a lot of music with acoustic instruments I think you will be pleasantly surprised with this cable. This cable will not add a aggresiveness to the music, which is sometimes needed for rock, punk, pop or electronic music.
bon cable
le câble onyx 2025 mkII, est très bien en rapport qualité prix ,il fait bien son job.je l'utilise pour un câble phono pour un ami, le câble de masse existant déjà. comme tous ces câble, il faut être soigneux pas le dénuder , il est facile a souder.
rca amphenol
malgré son nom de médicament ,j'utilise régulièrement ces connecteurs RCA pour le design ,leur conception de qualité, et leur prix correcte. la partie en bout en matériau souple ,peut être ajusté selon le diamètre du câble.
Jordan R.
Bien construit & robuste
Acheté pour mettre dans ma baie réseau, mise sur un départ en direct au tableau électrique.
De façon générale le bruit de fond a reculé significativement.
Elle me satisfait pour mon utilisation.
Claudio Marco C.
AP310, incredibile!
L’Audiophonics AP310 si conferma un pre pulito, neutro e silenzioso, capace di gestire il segnale senza aggiungere nulla e senza perdere controllo. Proprio per valorizzare questa impostazione ho scelto, pur non avendone un reale bisogno, di ordinare anche il finale AP300 S250ncx. Per fare un setup di riserva. Non è ancora arrivato, quindi non posso valutarne l’accoppiata, ma l’obiettivo è semplice: completare la catena con un finale coerente e all’altezza della trasparenza dell’AP310. Questo pre l'ho inserito in una catena hiend al posto di un blasonato pre da 2mila euro "moderno" e devo dire che sono davvero stupito!
Stra consigliato, da inserire in catene dove si vuole che la firma sonora arrivi dalla sorgente ed eventualmente ravvivare vecchi finali fin troppo "musicali".
Rolandas L.
FOSI AUDIO ZH3 DAC Preamplifier Balanced Headphone Amplifier AK4493SEQ 32bit 768kHz DSD512 The ZH3 from Fosi Audio is a preamp and headphone amplifier that also includes a DAC function. This versatile device is based on four OPA1612 chips to provide 2570 mW of...
Fosi ZH3 puikus
Excellent produit, son incroyable ! Je l'utilise avec un casque DT 770 PRO et j'en suis ravi. Sinon, je l'utilise sur PC ou avec un Arylik S10+ et un Icepower 1200 via XLR vers un Dynavoice DM6. C'est un son exceptionnel pour les performances scéniques et en live. Je le recommande vivement.
Eric P.
Après avoir testé plusieurs câbles sur des enceintes Dynaudio j'ai découvert cette marque lors d'échanges avec des audiophiles avec des configurations variées.. Le passage sur des Prima OCC a transformé mon ensemble par rapport à d'autres câbles bien plus onéreux et conseillé par le revendeur Dynaudio notamment des câbles allemands...ces câbles Nova sont destinés à un système secondaire je ne suis étonné par leur qualité intrinsèque du même acabit avec un système de verrouillage...J'espère que Audiophonics continuera à distribuer cette marque
tony r.
NEOTECH NEET-1008 Ethernet RJ45 CAT6E Cable UP-OCC Silver 1m Neotech offers with its NEET-1008 an excellent RJ45 Ethernet cable, benefiting from an exceptional design. It incorporates four pairs of silver UP-OCC conductors with a...
Excellent câble réseau
Mon expérience avec des câbles réseaux se limite à un Viablue + telegardner monté par mes soins, un Audioquest Vodka et un missing bond ultimate. J'ai pu tester le Neotech neet 3008 avant d'acheter celui ci. Le 3008 est excellent, vivant et avec une bande passante complète (ce qui n'était pas le cas du Missing ou des autres câbles réseaux que j'ai possédé). Le 1008 au branchement était extrêmement doux alors que l'on pourrait s'attendre à l'inverse. Après quelques heures, la vivacité est bien là, comme son petit frère mais il conserve plus de facilité, si bien qu'à fort volume, il n'y a plus aucune agressivité. C'est d'ailleurs la principale différence entre le 3008 et le 1008 sur mon système (Esoteric N05XD + Accuphase A48S) et une légère extension dans l'aigu.
Rolandas L.
Fosi ZH3 puikus
Puikus produktas, skamba nuostabiai, naudoju su ausinemis DT 770 PRO, negaliu atsidžiaugti. Kitu variantu klausau PC ar Arylik S10+ su Icepower 1200 per XLR į Dynavoice DM6, nuostabi scena ir gyvi atlikėjai, rekomenduoju.
Paulo N.
OPAMP roll-of on My OPAMP #2 on FOSI MONO AMP V3
More spatial and even faster transients than the LME I used.
Manuel S.
Fantastic!
I ordered this preAmp in for replacing my old pass clone. The warmth, but also velocity and transients are great. Furthermore there is NO noisefloor. It is black and quiet and so it shows perfect dynamics. The build quality is also great with a cnc metal housing. Great product and great service from audiophonics, as always!
Dominique B.
CLOUDYX CL-BOX PRO Audio Streamer WiFi DLNA AirPlay Bluetooth 5.2 Multiroom DAC ES9018K2M Transform your audio setup into a true high-fidelity wireless system with the CloudyX CL-BOX Pro. This compact audio streamer enables multiroom broadcasting via WiFi and...
CLBox Pro Cloudyx
Remarquable à ce prix. Fait tout ce qu'il annonce et le fait bien. Seul bémol, l'application android a des problèmes de compatibilité avec certains matériel. Ne fonctionne pas sur TAB A Samsung par exemple, se referme systém
Dominique B.
CLBox Pro Cloudyx
Remarquable à ce prix ! Fait ce qu'il annonce et bioen. L'a
Aleksy R.
Best choice for this money
This amplifier is simply a sensation compared to my Marantz PM5003! Paired with the WIIM Ultra and KEF C7X, it delivers a truly mind-blowing musical experience. The entire soundstage has opened up, everything is clearly separated, the bass is tight and punchy, and the clarity is incredible. I’m listening to lossless and FLAC formats from a USB drive. Highly recommended — great job, guys!
Jean-Marie M.
Pertinant
Il est pénible, sur le terrain, de devoir passer deux câbles symétriques alors qu’un seul suffit.
Ce câble correspond exactement à ce que je cherchais. Il faut en revanche confectionner soi-même les extrémités pour y installer les connecteurs souhaités.
Point délicat : la gaine extérieure est robuste, mais les petits câbles symétriques internes sont très fragiles. Il faut donc les renforcer avec de la gaine thermo épaisse et trouver une astuce propre au point de séparation.
Après un peu de travail méticuleux pour obtenir une solution robuste, le résultat final est TOP.
Dommage de ne pas pouvoir poster une photo
Jean François M.
LUDIC AESIR Power Cable Schuko IEC C15 UP-OCC Copper Gold Plated 1m The Ludic Aesir is a high quality power cable. It integrates patented UP-OCC Drawn® Copper conductors, allowing to obtain a high purity monocrystalline structure (higher...
Cable secteur Ludic
Câble secteur de grande qualité (câble haute teneur en cuivre, grosse section du cuivre et fiches Schuko de très bonne qualité). Attention à la rigidité du câble en cuivre. En tenir compte lors de la mise en place.
Jean François M.
LUDIC KRATOS Filtered Power Distributor 6 Filter Outlets + 2 Direct Outlets Schuko Black The Ludic Kratos is an extremely powerful filtered section power distributor, capable of standing comparison with the highest quality products. It provides your HiFi equipment...
Ludic Kratos
produit de très bonne qualité. Dommage que les 6 prises filtrées ne soient en placage or ou argent pour une meilleure conductibilité. Ecran en façade très utile. Très bon produit.
Jean François M.
fiche schuko viborg
Excellente fiche de très bonne qualité et très bien conçue.
Didier T.
OPA2210 Dual OPA DIP8 (Unit) This OPA2210 is a dual OPA mounted on DIP8. It is built on Texas Instrument's Super Beta precision complementary bipolar semiconductor...
Un réel délice
Très liquide et suave, il procure une grande ampleur et des timbres d'une rare élégance.
Sa profondeur harmonique est réelle.
Très transparent, il est néanmoins aux antipodes d'une esthétique qui veut faire absolument "du détail pour épater la galerie".
Le 2210 livre la musique sans aucun stress et avec une grande délicatesse : tout coule avec une remarquable aisance.
Il fait merveille dans un préampli phono MM Graham Slee Communicator Amp 2.
A réserver au mélomanes avertis qui utilisent leur matériel pour déguster la musique et non l'inverse.
Ps : lui laisser le temps d'être sous tension et de "travailler" quelques dizaines d'heures avant tout avis pertinent.
Didier T.
Très bien mais pas spectaculaire
Très "3D" et immersif, il est aussi très informatif avec beaucoup d'air qui circule.
Très droit et neutre, son rendu est de nature assez tendue.
Il restitue à l façon d'un 2134 amélioré.
Dans certains cas, il peut possiblement engendrer un manque d'émotion.
A mon sens, plus destiné aux audiophiles qu'aux mélomanes.
Claudio c.
EARACOUSTICS SPA PRO Dynamic In-Ear Monitors IEM 16 Ohm 113dB 5Hz-40kHz EarAcoustic's SPA-PRO are in-ear earphones based on a dynamic driver with a dual N52 magnetic circuit and an ultra-thin, rigid graphene membrane, enabling fast transient...
TOUT CE QUE J AIME DANS UNE BONNE PAIRE D ECOUTEUR
J e suis pas déçu de mon achat , très très bon rapport qualité .
Le son est complet dans tout les registre.
Mario d.
Toroidal Transformer 100VA 2x15V 3.3A This high quality toroidal transformer delivers a power of 100VA 2x15V 3.3A and will be an ideal choice especially for the realization of your DIY projects requiring these...
13% higher voltage.
I purchased this 100VA toroidal transformer with 2×15V secondary (3.3A) for a linear power supply in an audio project. Mechanically the transformer looks good: neatly wound, compact, and it operates silently without any audible mechanical hum. Installation is straightforward and the wiring is clearly identified.
However, what I noticed is that the output voltage is noticeably higher than specified. Instead of the rated 2×15V AC, I measure approximately 2×17V AC with no load. That is about 13% higher than the nominal voltage.
To be fair, this behavior is not completely unusual for transformers. Many transformers are specified at their nominal load, and when measured without load the voltage can be significantly higher. Still, 17V instead of 15V is quite a large deviation, especially if the transformer is intended for power supplies that rely on accurate secondary voltages.
After rectification and smoothing this results in roughly ±23–24V DC, which can increase heat dissipation in linear voltage regulators and may not be ideal for circuits designed around a typical ±15V supply.
Pros
✔ Solid build quality
✔ Compact size
✔ No mechanical hum or vibration
✔ Sufficient power capacity (100VA)
Cons
✖ Output voltage significantly higher than specified (≈17V instead of 15V)
✖ Can cause extra heat in linear regulator circuits
⭐ Conclusion
Overall the transformer appears well built and works fine electrically, but the higher-than-expected no-load voltage should be taken into account when designing a power supply. If your design requires tighter voltage margins, you might want to consider a 2×12V or 2×14V transformer instead.
Joseph C.
EARACOUSTIC STA-HI END Dynamic In-Ear Monitors IEM 32 Ohm 110dB 10Hz-30kHz The STA-HI END from EarAcoustic are in-ear earphones based on two dynamic drivers to offer excellent performance at an affordable price. The combination of a 6mm polymer...
Mon meilleur iem budget
J’ai eut ma période de tests d’iem budget à moins de 50€, des renommées tels que Conch, zéro, tangzu, chu ii avec lesquels la question est plutôt le quel sonne le moins pire de tous…
J’ai également l’Artti R1 , qui est pas mauvais mais avec lequel on s’endort car aucune vie…
Quand à celui ci, il est parfaitement équilibré entre rondeur et vie pétillante :), tout sonne très propre sans rien mis en avant, excellente définition, ouverture et largeur stéréo. Il est un peu long à roder car les premières heures il manque de basses et de punch le rendant un poil agressif. Mais oui, il s’agit du meilleur iem que j’ai possédé à ces tarifs là :)
Miles B.
Good value and quality
These are a solid alternative to the more expensive offerings from furutech. I can not speak in terms of metals used but the general construction and good connection grip make them a good buy. They also tamed some hum on my active speakers which was an unexpected benefit, I recommend them if available space behind unit is not an issue.
Frédéric B.
Bons résultats
Branché sur un ampli Rotel RB 1070, une amélioration des plans et de l'ouverture se fait entendre dés la première écoute. Le cable n'apporte pas de coloration particulière et peu donc être jugé neutre, ce qui est appréciable.Les graves sont tendus et les aigus filent avec douceurs et clartés ... La fabrication du câble respire la qualité, par contre son diamètre et son poids implique un dégagement important à l'arrière de l'appareil . Satisfait de cet achat et du rapport qualité prix.
Emmanuel A.
CANARE L-5CFB High performance Digital cable 75 Ohm shielded Ø7.7mm Designed and manufactured in Japan by the famous CANARE company, this 75 Ohm L-5CFB high quality coaxial cable was originally dedicated to the professional broadcast market.
Top pour caisson de basse
Je l’ai acheter pour remplacer un câble atlas pour une liaison lfe entre mon subwoofer svs4000 et mon ampli hc denon
Et bien le résulta est parfait
Les impact sont percutant à souhait les basses ne bave pas
Il est top et pour un prix raisonnable il remplacera largement des modèle de 10fois ce prix voir plus
Mugdim K.
TOPPING PROFESSIONAL E1X2 OTG Audio Interface USB 1 In 2 Out 24bit 192kHz White With the E1x2, Topping offers an excellent audio interface designed for musicians and audio professionals. This great interface offers a very high level of performance for...
Good sound for little money.
Very good sound card, I use it for various purposes. The inputs are quiet, the outputs are strong enough. The headphone output is a special story, I have a Hifiman he400se and I am very satisfied with the output amplification. Clear sound without delay. The software for Windows is simple but with measured information and options.
Mugdim K.
But
The headphones are good, if you don't use EQ, they are listenable, but they have too many highs and lack bass.
Since there are planar drivers inside, you can slightly raise the lows / lower the highs, with EQ, so they sound much better. All in all, for headphones under 100 euros, they are too good.
Frédéric B.
Belle amélioration !
Branché sur un ampli Rotel RB1070, on peut ressentir une belle amélioration de l'image sonore. La scène s'élargit en largeur et profondeur, les instruments et interprètes respirent mieux contribuant à une belle écoute ! Un très bon cable que je recommande.
Ron L.
Erg goed
Mijn coax uitgang van de Oppo UDP 203 Vanity welke DoP 64 uitstuurt is aanzienlijk verbeterd in helderheid diepte stilte en dynamiek.
Echt een aanrader.
Gevoed met een IFi 5v voeding
Rumen S.
Insulated Binding Posts Gold Plated Ø16x43mm (Pair) These affordable terminal blocks feature quality construction and a simple yet effective design. With gold-plated contacts, they ensure good conductivity and durability....
Nice!
For this price, there’s nothing more to wish for.
Except… maybe one more nut for easier installation. But even much more expensive connectors suffer from this drawback.
Rumen S.
Flexible Fitting for Potentiometer Shaft This potentiometer shaft connector accepts shafts with a maximum diameter of 6mm. Mounting is simple with 1.5mm hex screws.
Very good!
Exceptionally useful part! However, be careful when tightening the bolts. The material is still plastic, and the thread can be damaged.
Andis S.
Easy to build DAC
Easy to build great sounding converter. Going to swap opamps.
Vivien S.
DC 5V Jack Filter with Supercapacitor to Jack DC This DC 5V jack filter with supercapacitor allows you to obtain a clean power supply for your Hi-Fi equipment and appliances, thanks to 4 supercapacitors 20F - 3.0V and an...
Pratique sur Raspberry Pi
pour le son je ne suis pas sûr de percevoir une différence derrière mon allo usbridge.
Par contre c'est très pratique pour éteindre correctement son RPI :
1 lancer l'extinction du RPI via un mini clavier type sayo device
2 couper immédiatement l'alimentation du filtre
... le RPI a le temps de terminer sa procédure d'arrêt propre sur la charge des capacités du filtre, puis lorsqu'elle est épuisée l'alimentation est totalement coupée pour le RPI
cela m'évite de rester planté devant mon streamer pendant 1min pour qu'il s'éteigne.
à l'allumage, juste rélancer l'alimentation, le filtre monte en charge (1-2min) puis lance l'alimentation du RPi qui démarre.
bref très pratique
Vivien S.
transfigure mon caisson
mon caisson est parfait depuis que j'utilise cet Y sur les entrées rca plutôt que celle LFE.
La différence est plus qu'audible.
Ivan B.
BURSON AUDIO V7 CLASSIC PRO Single OPA (Pair) As an evolution of the V6 Classic, the V7 Classic Pro now achieves ultra-low noise levels while retaining the sparkling highs that are the strength of its predecessor. Overall,...
Significant improvement for Gustard DAC and KEF 105/3
I installed two Burson V7 Classic Single op-amps in my Gustard DAC, which is connected to a Sony TA-F870ES amplifier and KEF 105/3 speakers.
The upgrade is clearly audible. The soundstage opened up significantly, becoming deeper and more precise. What I like about the V7 Classic is the natural, organic tone—the mid-range is rich and the highs are detailed but never fatiguing. Even with my current cables, the transparency has improved. A very solid upgrade for anyone looking to get more musicality out of their system.
Luís A.
Dangereux
Ça a fonctionné pendant un mois, puis ça a commencé à faire du bruit et les appareils (téléviseur et chaîne hi-fi) ont commencé à clignoter.
Jonathan V.
Super qualité
Bon je me suis fais des cables instru pour guitares, particulièrement sensibles aux perturbations. Dans un premier temps j'ai utilisé ma soudure, j'avais un cable identique avec connectiques identiques acheté en magasin, j'ai comparé le son c'était la Cata. Seule la soudure était différente, j'ai commandée celle-ci, certes chère mais après installation c'est top! son parfaitement identique au cable magasin à 60e... parfait merci, bon matos et arrivé hyper vite en prime ;-)
Alain C.
Bon produit, mais attention à ne pas trop forcer sur la patte de masse, pour la détordre par exemple, elle se désolidarise facilement, et il faut être minutieux pour les soudures, sous la loupe, c'est mieux !
Raul P.
TINYSINE TSA7804B Class D Amplifier Module TPA3116D2 DSP Bluetooth 5.0 4x50W 4 Ohm The TinySine TSA7804B module is a four-channel Class D amplifier board with integrated DSP and Bluetooth receiver. Its TPA3116D2 chip is capable of developing 4x50W power at...
Great for simpel use
Great amp for stereo speaker or sound bar. Only part missing would be to have more gpio´s to control the DSP
Gérard B.
TONEWINNER AT-500 AV Processor / Home-Theater Preamplifier Dolby Atmos 16 Channels 9.3.4 / 7.3.6 The Tonewinner AT-500 is an 8K home cinema processor designed for immersive configurations up to 9.3.4 or 7.3.6. It provides full decoding of Dolby Atmos and DTS:X formats,...
Tonewinner AT-500
Correspond bien à mes attentes. Quelles sont les différences entre les modes "Pure" et "Direct"? Mais j'ai constaté un bug: sur certaines entrées, je n'ai pas le son. Je suis obligé de changer le mode (audio) de Direct jusqu'à "Dolby Upload" pour obtenir du son, puis je reviens au mode "Direct" que j'ai choisi. J'ai tenté de me connecter en WiFi pour réaliser une mise à jour (si elle existe), mais je n'ai pas pu rentrer ma clé WEP, le password WiFi ne permet pas de rentrer tous les caractères (et je ne sais pas si les majuscules sont prises en compte.....
laurent C.
mon ressenti: appareil aux finitions fragiles mais excellente sonorité
Trois Fosi v3 mono pour alimenter et soulager mon onkyo cinéma RZ 30 en face avant
(enceinte klipsch 500 rp) sonorité plutôt sympathique et détaillé de l'ensemble, un cran au-dessus de l'ampli l'onkyo. Finition visuelle apparente excellente mais les borniers enceintes sont médiocre et fragile a l'arrière de l'appareil, j'utilise des fiches bananes et les borniers bouge de partout ! combien de temps cela va tenir ? sur un des amplis le voyant de mise en route ne s'allume pas ! tous ça me semble bien fragile. Ampli minuscule mais profusion de câbles pas simple a organiser. tout de méme beaucoup d'inconvénients heureusement la qualité sonore est bien la
Maxime V.
TOPPING D50 III DAC 2x ES9039Q2M XMOS XU316 Bluetooth 5.1 LDAC 32bit 768kHz DSD512 Silver Topping's new D50 III desktop DAC has been updated to deliver even better performance than its predecessors. It now features two ES9039Q2M DAC chips and an XMOS XU-316 USB...
RQP au top
Une parfaite qualité de restitution (détails, dynamique, ...) dans un mini format et peu importe l'entrée choisie. Alimenté par une linéaire régulée de chez Audiophonics. J'exploite toutes ses entrées : coaxial, usb et toslink. Sub branché sur la sortie RCA et ampli de puissance sur xlr.
La télécommande en mode IR fonctionne très bien, alors qu'elle met un temps de réveil beaucoup trop long en BT (idem modèles plus haut de gamme de la marque).
Pourquoi payer plus cher.
François N.
GUSTARD U26 Digital Interface USB I2S SPDIF 32bit 1536kHz DSD2048 Black The Gustard U26 is a high-precision USB digital interface designed to deliver ultra-high-resolution audio quality to audiophiles and professionals. Developed in collaboration...
Gustard U 26.
Le Gustard U26 associé à mon A26. Il a métamorphosé ce dernier tant au niveau des basses, de l’aération. Plus de hauteur et de profondeur. Des petits détails qui étaient enfouis ressortent mieux. Très belle amélioration dans mon système.
jean-Luc R.
DAYTON AUDIO SPA100-D Class D Amplifier for Subwoofer 100W 20Hz-200Hz The Dayton Audio SPA100-D high-output subwoofer amplifier packs features normally found in larger amplifiers into a compact chassis, making it ideal for installation in...
bon produit pour un prix accessible
Bon produit, le pilotage automatique est très pratique, puissance largement suffisante pour piloter un hp de 38cm.
j'ai un très léger ronflement malgré le passage par une fibre optique mon cable de fin ne doit pas être assez blindé, ou le ronflement vient de mon berhinger FBQ. Mais à mi puissance c'est très supportable
La prise livrée en standard n'était pas faite pour la France , erreur rectifiée instantanément (au délais de livraison près) par le SAV
il manque quand même un gabarit pour faire la lumière dans le caisson
Henri c.
exelent
je l'ai utilisé pour lisser le haut medium d'un L12P110K RCF qui a un BL
de 23 ! ,ça n’a pas altéré la dynamique qui est très bonne.
le son est devenu plus fouillé ,plus vivant,mieux équilibré.
il faut soigner le câblage aussi, j'ai mis du 4mm2 Cu/Ag.
Frank D.
LHY AUDIO LPS25VA Linear Regulated Low Noise Power Supply USB 220V to 5V 2A 25VA Here's a stable, regulated linear power supply for any high-quality audiophile DIY project. All the necessary technical refinements are incorporated in this power supply...
Top Produkt & Top Shop
Hervorragendes LPS zum sehr guten Preis, zuverlässig verpackt und schnell geliefert.
Vielen, herzlichen Dank an das ganze AUDIOPHONICS Team, ihr seid die besten
Frédéric B.
LHY AUDIO EFI Optical Galvanic Network Isolator Black LHY Audio's EFI implements complete galvanic isolation through optical conversion, transforming the RJ45 Ethernet signal into fibre optic transmission before reconverting it to...
Top produit
Cet avis est bien sûr subjectif.
Amélioration de la clarté, de la dynamique et diminution du bruit.
Matériel sur lequel il est installé : streamer Auralic Aries G2.2, DAC Musician. Pré-ampli Parasound JC2, ampli Audiaflight FLS10 ( utiliser en bloc de puissance), enceintes EgglestonWorks Andra 3 SE.
Frédéric
michel s.
Bon rapport qualité/prix
Bon câble, bonne isolation, connecteurs corrects et bonne fabrication. (Bien que les élastiques rouges et blancs ne tiennent pas très bien)
Ce n’est pas le plus neutre ni le plus musical des câbles que je possède bien sûr mais pour l’emploi que j’en fait il me convient tout à fait.
