Giuseppe C.
Complicato
Kevin S.
Paulius S.
Very Useful
Nothing to complain.
Customers reviews - There are 19319 reviews.
Tero S.
Soundstage monster
This has one of the biggest soundstages iw heard. Also instrument separation is far superior to almost any THX AAA based AMP.
BLACK background, sounds just happen all around you.
BUT needs absolutely top notch DAC to get most out of this.
Vincent P.
DD TC44A DAC CS43131 Male USB-C to Female Jack 4.4mm 32bit 384kHz DSD256 This TC44A DD adapter for smartphone is composed of a male USB-C connector and a female 4.4mm jack. It also includes a CS43131 DAC for efficient conversion of the audio signal...
Très bon rapport encombrement / performances
Excellente qualité de fabrication, encombrement minuscule, son clair et détaillé, signature sonore neutre... Ce micro DAC/AMP fait très bien son boulot, il drive correctement des intras ou des casques à faible impédance.
Lubos S.
SMSL SU-8S Balanced DAC ES9068AS USB XMOS 32Bit 768kHz DSD512 MQA The SMSL SU-8s is a symmetrical DAC featuring the new ESS ES9068AS digital to analog conversion chip. This last one supports high sampling rates, up to PCM 32bit 768kHz and...
SMSL SU-8S
DAC suitable for high-quality active PC speakers.
It doesn't seem like a suitable adept for a large lineup, but absolutely ideal for a PC.
I run it with a Genelec 8330CP speaker via XLR and the sound is fine.
Lubos S.
SMSL D1SE Balanced ES9038PRO DAC CPLD Altera XMOS 32bit 768kHz DSD512 Black The D1se from SMSL is an extremely powerful DAC, based on a symmetrical architecture using a high-end ESS ES9038Pro digital to analog conversion chip. Taking advantage of a...
SMSL D1SE
Big surprise for little money.
I bought this DAC for my weaker setup that I run in my studio.
Minimac M1- HQPlayer- SMSLD1SE- Accuphase E210 - Wharfedale Linton Heritage.
The performance is excellent, the sound is more reminiscent of something between an AKM and R2R than a Sabre.
Surprisingly, it held its own even in my large home setup, but there it competed with the much more expensive Accuphase DP750 and yes - it lost.
But the difference was not abysmal.
It is a suitable DAC for a set (amplifier, cables, loudspeaker) with a total value of around 5,000 EUR.
Alain S.
Avis de Paul G totalement faux
Vous pouvez apprécier le produit pour ce qu'il est mais dans la réalité des faits il est parfaitement possible de faire beaucoup mieux pour beaucoup moins cher.
Ce produit n'est qu'un SOC à 50 € dans une boite sans avoir l'évolutivité logiciel et hardware des susnommés "system on a chip"
Sans parler du fait qu'il soit bloqué sur Volumio la seule solution out tout est payant ...
Excellent streamer dans un tarif contenu, gagne à y ajouter une alim linéaire. pour faire mieux il faut y mettre beaucoup plus cher.
Parmis la meilleure connectique RCA
Excellents connecteur neutres qui se font totalement oubliés sur le trajet du signal, 5 étoiles très méritées
Un must
Certainement un des meilleurs conducteurs électriques il le fait aussi bien en CS qu'en strapps HP.
Merci Néotech et Audiophonics de nous permettre de disposer d'un aussi bon conducteur
Mario V.
ELECTRO-HARMONIX GOLD 2A3 Power Tube Platinum Gold Plated Grid (Matched Pair) The high quality Electro-Harmonix 2A3 power tubes are tubes with direct triode heating by oxide cathode. They are ideal for a low frequency power amplifier in the amplifier...
Lampes fantastiques.
Bonjour, je viens de recevoir les tubes EH 2A3 et je les ai déjà montés sur mon ampli, le son est déjà fantastique, sans préchauffage, supérieur en richesse harmonique et en détail par rapport aux Golden Dragon en ma possession.
Je tiens à vous remercier pour le service rapide et courtois et j'ai hâte de faire d'autres achats dans votre boutique.
Joyeuses Pâques et salutations d'Italie!
Mario V.
Pascal P.
Génial
Petit objet très efficace : j'ai vraiment gagné en clarté du son, moins de dureté, un rendu plus analogique. De mes 4 connexions USB et/ou Xmos, c'est la meilleure. En plus il fonctionne sans alimentation et peut donc être nomade : super bon avec mon téléphone. A 75 € il ne faut surtout pas s'en priver.
Bon sélecteur de source.
Un bon sélecteur de source, assez massif, mais qui n'est pas donné. Pas d'effet sensible sur le signal, au sens positif: c'est propre, sans atténuation. Utilisé pour switcher le signal de mon DAC SU-6 (très bien, Audiophonics aussi) entre preamps à tubes ou en direct sur mon Pioneer A30-K
Bon et élégant petit préampli
Un bon et élégant petit préampli (c'est comme ça que je l'utilise). Le son est propre, clair, détaillé. Cependant il est moins "tuby" que d'autres preamp, comme le Tube 03 de FX Audio. Pour le "roulement de tube", les tubes installés dépassent peu, et sont un peu difficiles à retirer cependant (actuellement j'utilise des Sylvania des années 60).
Fabulous cable
For CD source, I decided to replace my Oyaide Tunami cable with this cable terminated with IeGO silver plated IEC/Schuko. My experiment has paid off.
The sound has developed even more detail than before while opening up slightly. As magnificent as the Oyaide was, the sound is a very heavy one, where the Noetech presentation is "lighter" without losing any coherency.
I cant wait to hear the result in a few months after burn in. The cable has less than 20hrs on it and the improvements are very noticeable. A very worthwhile investment.
Helmut M.
DYNAVOX Speaker Cables 2m
fast delivery
very solid cable !
good quality !
Elsa A.
Switching Power Supply Module 700W +/-60V This LLC switch mode power supply module has a main output delivering ±60V. The resonant circuitry uses a high frequency sine wave, ensuring excellent stability and a...
SMPS
Excellent rapport Q/P, tensions vérifiées : très propres . Encombrement réduit . parfait pour modules UCD 400.
J'aurais préféré des sorties principales sur faston plutôt que sur borniers à vis, à voir sur la durée.
Helmut M.
WIIM Pro
fast delivery
I'm using Android
Connection with Coax to my Amplifier with built-in DAC.
I tested successfull internet radio and DLNA streaming
from my server (minimserver) with a lot of flac-files (16 / 44.1)
gapless playback works very well.
browsing through my big flac-library works fast.
very good!
the WIIM Pro is also detected from other DLNA control-software
for example "Audionet Remote Control Point RCP" for windows 10
gapless playback works her as well.
I like the WIIM Pro device
Pierre N.
AUDIOPHONICS TPA-M50 Class D Mono AmplifierTPA3116 1x60W 4 Ohm Black The Audiophonics TPA-M50 is a compact amplifier with a low price but very good sound performance. The TPA-M50 is based on an amplification chip TI TPA3116D2 capable of...
Bruit résiduel.
Je nuance mon premier avis car comme cela a déjà été signalé il y a un bruit résiduel quand on pousse le volume. Mais comme l'ampli est très puissant ce n'est pas nécessaire.
Pierre N.
Génial
Je viens de le recevoir. L'alim commandée séparément est plus grosse que l'ampli. Il est connecté sur une enceinte pour TV mono. Grâce à la fonction sommateur G+D les voix sont plus lisibles que si il n'y avait que la voie gauche ou la voie droite. Auparavant j'utilisais un SMSL AD18 que sur une voie. Le son est bien plus précis dans tous les registres et me semble équilibré sans agressivité. Dans la limite de l'enceinte qui n'est pas une haut de gamme (100€). Le test a été fait avec la sortie Toslink de la TV, puis un DAC SMSL à 200 € avant l'ampli. L'amélioration vient donc de l'ampli mais aussi du convertisseur puisque avant le SMSL AD18 faisait les 2.
Daniel C.
La qualité de la prise RCA est indiscutable, cependant, il serait pratique que la rondelle en plastique corresponde à la couleur de la fiche en question (rouge ou noir) pour faciliter le branchement. Idem pour la couleur de la matière dans la prise
Mathieu J.
1MII LAVAUDIO DS200 PRO Bluetooth 5.0 Receiver aptX LDAC CSR8675 DAC ES9018 Black The 1Mii DS200Pro is a compact and powerful Bluetooth 5.0 receiver, using a Qualcomm CSR8675 Bluetooth chip. This one is compatible with the codecs of high resolution...
2eme en commande
Le son est excellent pour écouter les redifs arte concert sur youtube depuis le laptop ou le portable. Mes deux chaînes seront équipées
Patrice J.
Voltage Display Voltmeter with Green LED 60-500VAC Ø22mm This voltmeter will allow you to monitor the voltage of a device. Its green LED display is easy to read. The voltmeter accepts voltages from 60VAC to 500VAC. Its...
Comme à son habitude Audiophonics vend d'excellents produits.
En ce qui me concerne une erreur de la part d'Audiophonics a été commise sur cet article, son SAV s'est empressé de me le remplacer dans les plus brefs délais.
Merci encore à Audiophonics pour sa bienveillance au service de ses clients.
Daniel P.
Conception vraiment nulle
Le son est bon, mais pour le montage... Pour la phase et le neutre on peut mettre du 5mm, et pour la masse c'est tout petit, et ce n'est pas le même mode de fixation. C'est n'importe quoi, je ne comprends pas cette marque. Quand au serre câble, là aussi, il faut avoir l'esprit tordu. Pour moi, Neotech c'est terminé.
Helmut M.
WIIM Pro
fast delivery
Connection per Coax to my Amplifier with built-in DAC.
I'm using Android
I tested successfull internet radio and DLNA client
access to my server (minimserver) with a lot of flac-files (16 / 44.1)
gapless playback works very good.
browsing through my big flac library works fast.
very good!
the only missing thing is a windows client from WIIM Home.
therefore I use "Audionet Remote Control Point RCP" as player on win10.
it detects the WIIM Pro as DLNA client and plays my flac-files gapless.
Helmut M.
WIIM Pro
WIIM Pro
fast delivery
I'm using Android
very good!
Mathias S.
Parfait en sim racing
Parfait pour du simracing piloté par Simhub.
J'en ai 2, peut être un 3eme et c'est assez impactant comme résultat !
connexion facile et rapide.
Helmut M.
WIIM Pro
fast delivery. device works fine.
I testet Internet Radio + local music library (UpNP/ DLNA) per coax
I have have a large library with flac files 16 Bit 44.1 kHz
scrolling through the library is very fast
gapless playback works fine. PERFECT
Pedro P.
Indispensable !
Installés sur mes amplis AUDIOPHONICS LPA-S400ET, la symbiose est parfaite. Après avoir essayé des OPA1656 et 1612, j'ai voulu essayer ces petits joyaux sans trop en espérer, j'avoue... Grand bien m'en a pris, c'est juste le passage vers un autre monde, celui qui passe de la très très HiFi à la musique pure tout court ! Il a tout, le détail, la patate et la musicalité et mon sourire d'audiophile comblé :) Que la musique commence !
Pedro P.
Fabuleuse résolution, impressionnante dynamique et musicalité !
Autant ne pas tourner autour du pot, cet ampli est fabuleux ! D'ailleurs, ce n'est pas le premier que j'achète car ils sont destinés à mon système actif. D'abord, je tiens à dire qu'avec les OPA fournis, il est déjà excellent, je les ai remplacés par des OPA1656 (un peu mou) puis des OPA1612 plus dynamiques. Aucun n'a vraiment réussi à me convaincre à 100% aussi je me suis (en me pinçant un peu le nez) laissé tenter par les SPARKOS LABS SS3602 et là, comment dire, ça sonne comme aucun ampli que j'ai pu avoir ou écouter auparavant. Cela inclu des amplis à tubes, MosFet Class AB (Holton Precision Audio) et mes précédents Class D qui avaient chassé les anciennes technologies. Pour rester bref et ne pas tomber dans le lyrisme, cet ampli mérite les Sparkos pour en tirer la plus haute musicalité possible. Mes HP sont tenus comme jamais, on pousse le volume et le bonheur monte d'un cran, le son est pur, extrêment défini et pourtant jamais fatigant, c'est ni chaud ni froid, c'est tout simplement pur (non, je ne vais pas faire un jeu de mots là). Bravo à Audiophonics, cet ampli est une totale réussite, très bonne qualité de fabrication/finition à un prix raisonnable qui ravira les plus exigents d'entre nous.
Ivo C.
Tube 12AU7
Vient remplacer un ECC83 afin de réduire le gain d’un préampliphono MC, résultat difficile à apprécier.
Marc M.
Associée au cable hp Elecaudio 250 Cc, un son doux, neutre, avec un très beau médium, des aigus soyeux et une belle assise dans le grave. Des heures d écoute sans fatigue grâce à une belle spacialisation des différents plan sonores. à recommander sans hésitation !
Ovidiu P.
Great DAC for its size and price.
I can't judge the marketing speech in the product description but to my ears it sounds great. Sure you can get a different DAC for 5$ less but why would you do that when this one has the best specs I could find in an RPI zero compatible DAC?
Yves A.
Belle finition, bon rapport qualité/prix, livraison impeccable.
Michael N.
Stereo ADC Board WM8782 I2S 24bit 192kHz This small stereo ADC module converts an analog signal to digital. The output is thus done in I2S. Equipped with a Cirrus Logic WM8782 chip, the module supports PCM sample rates...
Documentation
Arrived in less than a week in a large cardboard box with paper packing, so no damage. However, the device was in a polythene bag with with no electrostatic protection and no documentation. For example, I would like to know the maximum peak-to-peak input put voltage before digital clipping. The web page just says 2 volt rms, which is pretty ambigous.
Alain M.
Problème de fonctionnement
J'ai posté hier un avis concernant le fonctionnement problématique de cet appareil sous Windows. Je n'avais jamais pu le faire fonctionner.
Perdu pour perdu, j'ai donc décidé d'ouvrir le boitier pour voir si éventuellement une soudure aurait posé problème. Et je dois dire que j'ai bien fait ! Du coté circuit imprimé/coté soudure, j'ai aperçu des taches blanchâtres semblables à du sel, principalement autour et sur les divers connecteurs présents sur le circuit. En grattant délicatement ces tâches avec un ongle j'ai réussi à enlever ce genre de sel séché. Pour être sûr de bien tout nettoyer j'ai passé un pinceau imbibé d'acétone. Le circuit fut alors impeccable.
Le circuit remonté dans sa boite à alors fonctionné correctement tout de suite.
J'en ai déduit un problème de production, mais suis étonné que ce produit n'ait pas été testé avant la mise en vente. D'autres appareils doivent certainement être dans ce cas.
Si il avait été possible d'insérer une photo ici, ça aurait été très parlant.
Philippe R.
Un excellent DAC!!
Appareil exceptionnel par son équilibre et l’ampleur de la scène sonore restituée.
Écoute juste, fine et détaillée, très analogique, beaucoup de présence, on en oublie que l’on écoute du numérique.
Utilisé sur un système très neutre, ce DAC fait des merveilles.
L’écoute devient addictive, du pur bonheur!
J’ai pu le comparer, dans les mêmes conditions, avec un Musician Pegasus dont l’écoute donne une sensation d’effet loudness (basses renforcées presque à l’excès sur certains enregistrements)
À la première mise en service, le R26 donnerait un peu la même sensation mais tout s’estompe au bout de 4h d’utilisation.
L’alimentation (transfos toriques) peut aussi se faire entendre pendant cette période de rodage avec une petite ronflette permanente, mais tout rentre vite dans l’ordre et l’appareil est par la suite très silencieux.
Je confirme les retours élogieux faits sur le R26.
Alain M.
Problème de fonctionnement avec Windows
J'ai acheté il y a quelques années un testeur DATS V2. Il fonctionnait très bien sous Windows 7. Puis, Windows est passé à la version 10 et là, le DATS V2 ne fonctionnait plus. Je l'ai donc revendu pour passer à la nouvelle version DATS V3 (la version actuelle). Ca ne fonctionne pas non plus. Depuis Windows est passé à la version 11 et le testeur DTS V3 en fonctionne toujours pas. En fait, une classique mesure d'impédance fait apparaitre une courbe déformée sans rapport avec une mesure d'impédance. Le fournisseur Dayton ne répond pas aux questions et je ne suis pas le seul à avoir ce genre de dysfonctionnement.
Est-ce qu'un acheteur de ce produit a les mêmes problèmes et si oui, y a t'il une solution ?
Terrific
I reluctantly swapped out the silver/rhodium version of these sockets and really glad I did.
I had struggled with glare from my system for quite some time, but these seem to have taken that glare away as well as making the speakers disappear. I hear music from "space" now rather than around each speaker.
Great little investment.
Zoltán K.
Excellent product
This is a high quality, good looking, well made power distributor that is well priced at around 160 EUR. It does not include an RF filter, which is the main reason why I chose this unit. The input and output connectors are of excellent quality, they provide a connection that is firm, neither loose nor too tight. One does not need to use excessive force to connect or disconnect high quality power cords. The four feet ensure stable positioning. In my Hifi system this unit supplies power only to a NAS, a switch and a media converter. Still, in comparison with an entry level HiFi power distributor equipped with RF noise filtering, to my ears the use of this unit provided a more alive and lively musical performance, through better spatial perception, better resolved details, better transients and dynamics. This unit is clearly well suited for use in HiFi applications.
Julien D.
Matériaux de qualité, Très Satisfaisant !
Ne sachant pas encore qu'il existait des versions améliorées VORTEX HIFI (informées énergétiquement) j'ai commandé ces versions standard d'excellente qualité, la matière est très souple mais ferme, se logeant ainsi de manière optimum dans les prises jack 6.35mm inutilisées de vos appareils et accessoires HIFI. Dans mon cas un lecteur MINIDISC SONY et des rallonges de casque de plusieurs métres faites en câble "GEB" de chez HIFI & Cie avec prises NEUTRIK et FURUTEC achetées ici chez AUDIOPHONICS.
Les prises de casque que je traite aux nettoyants Deoxit (vendus ici également) et à l'huile VORTEX HIFI NANO DIAMANT SIGMA sont ainsi protégées de la poussière et de l'oxydation quant inutilisées. Egalement très satisfaisant pour les maniaques comme moi qui prennent grand soin de leurs appareils ! :)
Julien D.
Nickel pour remplacement sur câble secteur ACTINOTE ARIA
En ayant voulu démonter le connecteur IEC d'origine de mon câble secteur ACTINOTE ARIA ancienne génération (avant le EVO avec prise schuko en bois), j'ai détérioré les visses plastique ; ça ne m'a pas trop dérangé car je comptait faire prisonnier le câble dans un lecteur MINIDISC SONY.
Cependant, après découverte de l'aspect et de la rigidité des conducteurs du câble ACTINOTE, j'ai abandonné et décidé de réhabiliter le câble secteur à ses fonctions premières.
Mon choix s'est donc porté sur cette version ELECAUDIO, identique aux fiches qu'utilisait Actinote avant de passer en 2023 à la marque Oyaide.
Son assemblage est bien conçu, attention tout de même à bien insérer les visses finales dans leur filetage, car une fois je suis passé à coté.
Il a fallu également abandonner une pièce plastique permettant de serrer le câble à l'entrée de la fiche, car une bague caoutchouc, propre à actinote et permettant le serrage de la gaine tissu avant la section, augmentait le diamètre total du câble.
Après quelques tests d'écoute, Le rendu sonore m'est apparu préservé par rapport à la version d'origine, l'aspect du câble parait plus robuste et moderne. On saluera tout de même les très bons conducteurs de l'ancienne fiche IEC Actinote (plaqués argent à l'époque) dans lesquels les conducteurs cuivre (phase/terre/neutre) étaient soudés à l'argent.
Au final, je recommande fortement ce connecteur IEC ELECAUDIO au rapport qualité prix exceptionnel ; pas étonnant qu'Actinote les avait choisis précédemment, avec un cahier des charges spécifique bien entendu (visses non métalliques, stickers et traitement/placage or des connecteurs peut être supérieur).
Leonas J.
XDUOO TA-22 Tube Headphone Amplifier 2x 12AU7 DAC 2x ES9038Q2M Bluetooth 5.0 aptX HD LDAC 32bit 384kHz DSD256 MQA xDuoo unveils with its TA-22 a beautiful headphone amplifier and DAC combo with a neat design. This one embeds quality components in order to provide a sound restitution both...
perfect xduoo ta-22
neutral sound with very good stock tubes, rolled nos RFT 12au7 from 1960 east germany made. more relaxed sound with more extended highs.
Bernard B.
Du plaisir
le velouté des lampes au prix chinois...FDA chef d'orchestre, une discothèque toute numérisée sur PC, avec une baguette libre nommée foobar améliorée par une courbe cible du génial Pétoin drivant de petits large bande en caissons bass reflex triple ( en DIY merci Pétoin !!!!) et me voilà auditeur d'un chaîne HI-FI cheap mais très agréable.....je recommande fortement même si une sortie casque serait la bienvenue...
C b.
parfait pour mon lecteur oppo.
parfait pour mon lecteur oppo maintenant piloté par mon ampli home cinéma.De plus il ne reste plus en veille quand je ne l'utilise pas. Je retire 1 étoile car léger flottement quand il est connecté dans la prise iec 13 de mon lecteur.J' ai corrigé avec quelques tours de ruban adhésif autour de la prise de ce boitier.
C b.
pilote mon lecteur oppo relié à l'ampli home cinéma
parfait pour mon installation.
Mon lecteur oppo est maintenant piloté par mon ampli home cinéma via 1 prise triigger et ne este plus constamment en veille quand je ne l'utilise pas.Néanmoins je retire 1 étoile car l
C b.
pilote parfaitement ma freebox revolution avec une télécommande logitech harmony one
Fais le job parfaitement avec ma télécommande logitech harmony one de plus de 10 ans.
vous mettez la clé usb en façade sur la freebox player-pour la télécommande HARMONY ONE dans le logiciel harmony vous chargez Alice L-H D03A et non pas freebox revolution et c'est parti...
Bruno F.
Eclairage sur un Marantz
Très bon rendu sur un éclairage de Marantz 4300, après essai l'idéal est de les incliner vers l'arrière on obtient un meilleur résultat comme à l'origine, incliner côté vitre le rendu est trop fort style bleu piscine !
Pierre M.
ISOACOUSTICS GAIA III Vibrations Absorbers Isolators 32kg Ø43x39mm (Set x4) IsoAcoustics Gaia III vibration absorbers improve clarity and soundstaging for speakers or subwoofers weighing 32kg or less. They feature a machined stainless steel body with an...
Incroyable
J'avais des soucis de "creux de basse" dans ma pièce impossible à régler, l'écoute était tres localisée. Selon l'endroit de l'écoute cela sonnait très différemment.
Les pieds ont permis dhomogeiniser la diffusion, l'écoute est agréable en tout point d'écoute. Utilisé sur un svs sb1000pro et enceintes paradigm founder80F
Pierre M.
LUDIC KRATOS Filtered Power Distributor 6 Filter Outlets + 2 Direct Outlets Schuko Black The Ludic Kratos is an extremely powerful filtered section power distributor, capable of standing comparison with the highest quality products. It provides your HiFi equipment...
Bel objet
Je ne saurais pas dire si le filtrage est efficace, je n'ai pas l'équipement et les connaissances précises en la matière pour le faire.
Mais la fabrication est de qualité. Et l'écran, et c'est rare pour ce genre d'objet, ne fait pas kitch. C'est sérieux et classe.
Pierre M.
KLEI PURE22 HARMONY Male RCA Connectors Silver Plated Copper Ø9.5mm (Set x4) These KLEI Pure22 Harmony RCA connectors represent the most advanced model of the brand. A proprietary mathematical model is used to define the relationship between the ground...
Une merveille
Une merveille à souder, les soudures argent se déposent sur les pâtes à merveille. On dirait qu du flux est déjà présent c'est bluffant. Plastique TRES résistant à la chaleur du fer.
Particulièrement adapté pour un cablage en masse flottante avec un câble symétrique (alpha S22 de chez furutech).
Les deux pâtes à souder se présentant de part et d'autre au même endroit.
Sonne merveilleusement bien, il a énormément aéré mon écoute.
