The AMP-F2, developed by EverSolo in collaboration with the Starke Sound team, is a Class D amplifier based on the integration of the latter's innovative NS600 module. As a result, it offers a high energy reserve, great dynamics and a highly accurate sound. The all-new SAPS switch-mode power supply provides the audio circuit with a clean electrical...
This professional stereo line transformer FGA-202 effectively reduces signal interference and hum, which can occur, for example, when connecting PC sound cards to HiFi systems or mixers.
FiiO unveils one of its most sophisticated devices with its K19. The K19 is an ultra-complete, high-performance DAC/headphone amplifier. It features two ES9039MSPRO DAC chips for balanced signal processing and support for high-resolution PCM 32bit 768kHz and DSD512 streams. Two THX AAA-788+ modules handle signal amplification, for maximum output power of...
With the LineFlux NCF, Furutech delivers a beautiful high-end RCA cable. This one ensures a perfect transmission of the signal, thanks to carefully selected materials, to a cryogenic treatment but also to the NCF material developed by the brand.
Gustard unveils with its DAC-R26 an absolutely exceptional digital to analog converter. This one uses an R2R architecture using discrete components of very high quality and perfectly optimized to offer exceptional sound performances. Practical, it benefits in addition to a complete connectivity, of a Bluetooth and network connectivity, allowing to control...
This 3m-long optical HDMI 2.0 cable supports high-definition video streams up to 4K 60Hz, with a maximum bandwidth of 18Gbps, and is compatible with CEC, 3D, HDR 10, eARC, DDC, EDID and DHCP 2.2 technologies.
This protective cover in brown imitation leather for DAP Hidizs AP200 will give your personal music player an elegant appearance while protecting it from possible shocks.
The S8 Pro Robin from Hidizs is a portable balanced DAC and headphone amplifier combo based on two Cirrus Logic CS43131 converter chips and capable of delivering 160mW + 160mW at 32 Ω. Furthermore, the device supports sampling rates up to PCM 32 bit 384kHz and DSD256. Moreover, this device has dual balanced and unbalanced outputs to suit all applications.
The Hidizs XO is the ideal companion to accompany a smartphone and enjoy a high quality sound reproduction. Combo DAC and portable headphone amplifier, it benefits from very good performances and a neat design, perfect to listen to your music in the best conditions, especially on the move. It even provides a double balanced / single-ended output to fit...
In 2012, HIFIMAN unveiled the legendary EF6 DAC and headphone amplifier, offering a substantial energy reserve and a particularly detailed sound stage. Ten years later, HIFIMAN is back with a brand new model, the EF400, using all the best of the latest technologies developed and more particularly the brand's R2R Himalaya DAC module. The EF400 is a modern...
The GA-10 is a HiFiMAN headphone amplifier developed in collaboration with GoldenWave. It uses ECC83/12AX7 tubes for its preamplification stage and EL84 tubes for its power stage. The use of these tubes results in a smooth, warm sound reproduction.
The iBasso AMP13 module was designed to provide an alternative amplification system for the iBasso DX320 and DX300 digital music players, allowing for a different sound signature to suit individual tastes. Here, the AMP13 adopts a Korg Nutube 6P1 tube amplifier stage, providing a smooth and round sound, complemented by a second amplifier section to boost...
iFi Audio's HDMI iSilencer is an HDMI filter designed to reduce noise and jitter in your signal and protect your equipment from surges that can be caused by electrostatic discharges.
The Ikko ITM05 is an ultra-portable balanced headphone amplifier and DAC combo, integrating high quality components in an extremely compact and lightweight format. It's the perfect companion for your smartphone to give you the best sound experience wherever you are. Practical, it slips easily into a pocket or bag.
This KAIBOER XLR interconnect cable is an XLR male to XLR female interconnect cable. It features pure 4N silver conductors and a 2x 8-strand litz wire structure for maximum conductivity. In addition, the XLR connector contacts are 3u gold-plated for corrosion and oxidation resistance.
The Keces P8 is a high quality regulated linear power supply that will provide your high-fidelity audio system with a clean electrical signal. The power supply features a neat design with a high quality toroidal transformer and separate ground.
With the Keces S3 you get an all-in-one device, covering the functions of DAC, preamplifier and headphone amplifier. Carefully designed with high-end components, it provides a high quality sound reproduction that is as rich and precise as it is dynamic.
This pair of male RCA to male XLR cables uses the balanced (3-pin) RCA connectors developed by Khadas for their Tone2 Pro / Tone2. These cables are therefore designed to carry a balanced audio signal.
The Khadas Tea is an ultra-compact, high-performance portable DAC headphone amplifier. Featuring an ES9281AC Pro DAC chip and a QCC5125 Bluetooth receiver chip, it is capable of supporting high-resolution PCM 32bit 384kHz, DSD256, Apple Lossless (ALAC) and MQA rendering via its USB-C input, as well as...
Meet the famous digital to analog conversion circuit (DAC) based on 32 bit ESS ES9038Q2M chip with PCM support up to 768kHz and native DSD512 and even MQA. New headphone buffer / amplification stage in 4 x OPA1612 for advanced headphone driver.
