Vraiment bon, surtout pour ce prix Vraiment une très bonne surprise : -très bon son ! très ample dans les graves sans aucune exagération et sans devoir ajuster...
Very good preamplifier for the money It is pretty transparent even with the stock OPAs (in my case LM49720). Highly recommended (for the money). It is difficult to...
Discover our wide range of tubes and lamps, suitable for audio use, whether for the design of an amplifier or preamplifier, or to replace a defective model. To help in understanding electronic tubes, you can consult our detailed blog article: Understanding the different power tubes and their abbreviations.
The ECC802S / 12AU7 from JJ Electronics is a dual triode preamplifier tube. This hi-fi quality tube is perfect for replacing a 6189, 12AU7WA, E82CC or CV4003 tube or for integration into a DIY audiophile project.
The ECC803S /12AX7 tube from JJ ELectronics is a double triode preamplifier tube with a noval base (9 pins). This long-plate Hi-Fi quality tube is ideal for replacing a defective tube (ECC803S /12AX7 / 7025) or for integration in a DIY audiophile project.
JJ Electronic lamps are excellent value replacement products. The all-new JJ ECC83 MG vacuum tube is a completely different type from the JJ ECC83S. The new ECC83 MG has a slightly lower gain and is designed to accommodate extended clean tones and more headroom with guitar and HiFi audio amplification.
The Mullard GZ34 tube is a high-end direct-heated rectifier diode. It is the re-edition of Mullard's most popular rectifier tube ever. Its purpose is to extend the life of other amplifier tubes by allowing them to heat up before voltage is applied.
The Mullard KT88 is a top-quality tetrode tube. It's an exact copy of the tube made by Marconi-Osram for Marshall in the late '60s and '70s. This tube will give you a powerful, balanced and detailed sound with full bass. The KT88 power tube can be used as a replacement for any 6550 tube, or can be integrated into the iconic Marshall Major to reproduce its...
The OB2 is a miniature cold cathode voltage regulator tube. It is ideal for amplification, voltage regulation and signal applications. It also offers excellent musical performance, with extended frequency response and low distortion. This OB2 tube can replace 108C1, CV1833, SR55, AG5210, STV108-30 or VR105MT tubes.
Psvane 12AU7-S tubes offer high plate current and low noise. They are therefore particularly recommended for use on a preamplifier or phono stage. This model has the same features as its predecessor, the 12AU7-TII, but with internal structural improvements for even better performance.
The PSVane 12AX7-S / ECC83 is a high-end S-Art preamp/amp tube with very good performance and musicality. It can be used as a DIY design or as a replacement for a defective 12AX7 or ECC83 tube.
The PSVane 211-TII tube is a high quality direct heated thorium-tungsten triode that can be used in class A, B and C. The MKII series tubes use a PTFE base, ensuring high stability and very good insulation. The amber colored oxidized aluminum collar surrounding the PTFE base prevents corrosion and fingerprints while giving the tube a prestigious design.
PSVANE's 274B-Z rectifier offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than that of classic tubes, with voices more prominent than usual and an overall sound evocative of vinyl's own texture.
PSVANE's 2A3-Z power tube offers a warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than that of conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl's own texture.
PSVANE's 300B-Z power tube offers a warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than that of conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl's own texture.
The 5881 tube is the electrical equivalent of the 6L6 and 6L6G tubes, except that the dissipation plate and screen values are increased by about 20%. The design of this tube also provides better shock and vibration resistance.
The PSVane 6CA7-TII MARK II is a high quality pentode tube that offers excellent sound performance for a rich and musical reproduction. This model will be able to replace advantageously a tube EL34.
PSVane 845-T-MII/2 tubes are high-quality triode power tubes that can be used in class A, B and C. The MKII range of tubes uses a PTFE base, ensuring high stability and excellent insulation. The amber-coloured anodised aluminium collar surrounding the PTFE base prevents corrosion and fingerprints while giving this tube a prestigious design. The tube also...
The Acme Series high power tubes offer an exceptional design to provide high quality sound. This series takes advantage of a composite metal shield pole structure, skillfully combining graphite and wire mesh, promoting a warm and transparent sound reproduction.
PSVANE Art KT150 is a high-end tetrode power tube with 70W plate dissipation. It is the most powerful tube in the 6550/KT88/KT90/KT120 family, developed to improve heat dissipation and ensure optimal sound performance. It is extremely reliable and guarantees a long life.
The PSvane CV181-TII is a high quality dual triode tube used in voltage amplifier circuits. It can replace the 6N8P and 6SN7GT tubes, and offers excellent performance.
PSVANE's CV181-Z power tube offers a warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl.
The PSVane ECC81 is a high-performance preamplifier/amplifier tube. These tubes are part of the brand's classic standard range, and provide excellent musicality. PSVane ECC81 tubes are 9-pin double triode tubes (Noval).
The PSVane ECC82 is a high-performance preamplifier/amplifier tube. These tubes are part of the brand's classic standard range, and provide excellent musicality. PSVane ECC82 tubes are 9-pin double triode tubes (Noval).
The PSVane ECC83 / 12AX7 is a preamplification / amplification tube that offers excellent performance and belongs to the Classic Series range of the brand. It can be used both for DIY projects or as a replacement for a faulty 12AX7 or ECC83 tube.
PSVane's EL34-PH tube is a replica of the well known Philips EL34, widely used in many tube amplifiers. The EL34-PH is characterized by a soft and musical sound signature. It is also capable of withstanding high voltages, up to 800V, to provide high power output.
PSVANE's EL34-Z power tube offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl.
The PSVane EL84 is a high-performance preamplifier/amplifier tube. These tubes are part of the brand's classic standard range, and provide excellent musicality. PSVane EL84 tubes are 9-pin pentode tubes (Noval).
These EL84-S PSVane pentode tubes are improved versions of the EL84. They use longer plates, better materials and gold plated contacts, resulting in excellent sound performance. They are delivered matched.
These EL84-S PSVane pentode tubes are improved versions of the EL84. They use longer plates, better materials and gold plated contacts, resulting in excellent sound performance. They are delivered matched by four tubes..
PSVane KT150-J tubes are high-performance tubes mainly used for Hi-Fi amplification. They offer clear, detailed sound reproduction while maintaining pronounced dynamics.
PSVane KT150-PT tubes are high-performance tubes mainly used for Hi-Fi amplification. They offer clear, detailed sound reproduction while maintaining pronounced dynamics.
