Tubes and lamps
mickael C.
Une des meilleures prises
mickael C.
Michel P.
Michel P
Tubes and lamps
  • 42,90 € 35,75 €Ex.
    In Stock
  • Ref : 18932
    In Stock
    The Mullard GZ34 tube is a high-end direct-heated rectifier diode. It is the re-edition of Mullard's most popular rectifier tube ever. Its purpose is to extend the life of other amplifier tubes by allowing them to heat up before voltage is applied.
    39,90 € 33,25 €Ex.
    In Stock
  • Ref : 18928
    The Mullard KT88 is a top-quality tetrode tube. It's an exact copy of the tube made by Marconi-Osram for Marshall in the late '60s and '70s. This tube will give you a powerful, balanced and detailed sound with full bass. The KT88 power tube can be used as a replacement for any 6550 tube, or can be integrated into the iconic Marshall Major to reproduce its...
    59,90 € 49,92 €Ex.
    In Stock
  • Ref : 20065
    In Stock
    The OB2 is a miniature cold cathode voltage regulator tube. It is ideal for amplification, voltage regulation and signal applications. It also offers excellent musical performance, with extended frequency response and low distortion. This OB2 tube can replace 108C1, CV1833, SR55, AG5210, STV108-30 or VR105MT tubes.
    7,90 € 6,58 €Ex.
    In Stock
  • Ref : 18077
    In Stock
    Psvane 12AT7-S tubes offer high plate current and low noise. They are therefore particularly recommended for use with a preamplifier or phono stage.
    75,00 € 62,50 €Ex.
    In Stock
  • Ref : 14787
    In Stock
    Psvane 12AU7-S tubes offer high plate current and low noise. They are therefore particularly recommended for use on a preamplifier or phono stage. This model has the same features as its predecessor, the 12AU7-TII, but with internal structural improvements for even better performance.
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 6717
    In Stock
    The PSVane 12AX7-S / ECC83 is a high-end S-Art preamp/amp tube with very good performance and musicality. It can be used as a DIY design or as a replacement for a defective 12AX7 or ECC83 tube.
    89,00 € 74,17 €Ex.
    In Stock
  • Ref : 16009
    In Stock
    189,00 € 157,50 €Ex.
    In Stock
  • Ref : 17015
    In Stock
    The PSVane 211-TII tube is a high quality direct heated thorium-tungsten triode that can be used in class A, B and C. The MKII series tubes use a PTFE base, ensuring high stability and very good insulation. The amber colored oxidized aluminum collar surrounding the PTFE base prevents corrosion and fingerprints while giving the tube a prestigious design.
    289,00 € 240,83 €Ex.
    In Stock
  • Ref : 19104
    In Stock
    PSVANE's 274B-Z rectifier offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than that of classic tubes, with voices more prominent than usual and an overall sound evocative of vinyl's own texture.
    109,00 € 90,83 €Ex.
    In Stock
  • Ref : 19108
    PSVANE's 2A3-Z power tube offers a warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than that of conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl's own texture.
    159,00 € 132,50 €Ex.
    In Stock
  • Ref : 19109
    In Stock
    PSVANE's 300B-Z power tube offers a warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than that of conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl's own texture.
    199,00 € 165,83 €Ex.
    In Stock
  • Ref : 15457
    Reduced price!
    In Stock
    The 5881 tube is the electrical equivalent of the 6L6 and 6L6G tubes, except that the dissipation plate and screen values are increased by about 20%. The design of this tube also provides better shock and vibration resistance.
    20,72 € 17,27 €Ex.
    25,90 € In Stock
  • Ref : 16522
    In Stock
    The PSVane 6CA7-TII MARK II is a high quality pentode tube that offers excellent sound performance for a rich and musical reproduction. This model will be able to replace advantageously a tube EL34.
    399,00 € 332,50 €Ex.
    In Stock
  • Ref : 17149
    The Acme Series high power tubes offer an exceptional design to provide high quality sound. This series takes advantage of a composite metal shield pole structure, skillfully combining graphite and wire mesh, promoting a warm and transparent sound reproduction.
    949,00 € 790,83 €Ex.
    In Stock
  • Ref : 16499
    In Stock
    999,00 € 832,50 €Ex.
    In Stock
  • Ref : 19010
    In Stock
    PSVANE Art KT150 is a high-end tetrode power tube with 70W plate dissipation. It is the most powerful tube in the 6550/KT88/KT90/KT120 family, developed to improve heat dissipation and ensure optimal sound performance. It is extremely reliable and guarantees a long life.
    479,00 € 399,17 €Ex.
    In Stock
  • Ref : 19012
    In Stock
    899,00 € 749,17 €Ex.
    In Stock
  • Ref : 17294
    In Stock
    The PSvane CV181-TII is a high quality dual triode tube used in voltage amplifier circuits. It can replace the 6N8P and 6SN7GT tubes, and offers excellent performance.
    In Stock
  • Ref : 16798
    In Stock
    In Stock
  • Ref : 19098
    PSVANE's CV181-Z power tube offers a warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl.
    129,00 € 107,50 €Ex.
    In Stock
  • Ref : 18086
    The PSVane ECC81 is a high-performance preamplifier/amplifier tube. These tubes are part of the brand's classic standard range, and provide excellent musicality. PSVane ECC81 tubes are 9-pin double triode tubes (Noval).
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 18085
    In Stock
    The PSVane ECC82 is a high-performance preamplifier/amplifier tube. These tubes are part of the brand's classic standard range, and provide excellent musicality. PSVane ECC82 tubes are 9-pin double triode tubes (Noval).
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 18081
    In Stock
    The PSVane ECC83 / 12AX7 is a preamplification / amplification tube that offers excellent performance and belongs to the Classic Series range of the brand. It can be used both for DIY projects or as a replacement for a faulty 12AX7 or ECC83 tube.
    29,90 € 24,92 €Ex.
    In Stock
  • Ref : 18323
    In Stock
    PSVane's EL34-PH tube is a replica of the well known Philips EL34, widely used in many tube amplifiers. The EL34-PH is characterized by a soft and musical sound signature. It is also capable of withstanding high voltages, up to 800V, to provide high power output.
    659,00 € 549,17 €Ex.
    In Stock
  • Ref : 14716
    In Stock
    329,00 € 274,17 €Ex.
    In Stock
  • Ref : 19094
    In Stock
    PSVANE's EL34-Z power tube offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl.
    99,00 € 82,50 €Ex.
    In Stock
  • Ref : 18087
    In Stock
    The PSVane EL84 is a high-performance preamplifier/amplifier tube. These tubes are part of the brand's classic standard range, and provide excellent musicality. PSVane EL84 tubes are 9-pin pentode tubes (Noval).
    32,90 € 27,42 €Ex.
    In Stock
  • Ref : 15691
    In Stock
    These EL84-S PSVane pentode tubes are improved versions of the EL84. They use longer plates, better materials and gold plated contacts, resulting in excellent sound performance. They are delivered matched.
    69,90 € 58,25 €Ex.
    In Stock
  • Ref : 15799
    In Stock
    These EL84-S PSVane pentode tubes are improved versions of the EL84. They use longer plates, better materials and gold plated contacts, resulting in excellent sound performance. They are delivered matched by four tubes..
    139,00 € 115,83 €Ex.
    In Stock
  • Ref : 19382
    In Stock
    PSVane KT150-J tubes are high-performance tubes mainly used for Hi-Fi amplification. They offer clear, detailed sound reproduction while maintaining pronounced dynamics.
    599,00 € 499,17 €Ex.
    In Stock
  • Ref : 19285
    In Stock
    PSVane KT150-PT tubes are high-performance tubes mainly used for Hi-Fi amplification. They offer clear, detailed sound reproduction while maintaining pronounced dynamics.
    299,00 € 249,17 €Ex.
    In Stock
  • Ref : 18288
    In Stock
    These PSVANE KT66GC tubes are power tetrodes from the PSVANE "Legend" series. They are ideal for DIY HiFi design, or as replacements for similar models such as the EL34, 6L6 or, KT77 or the original KT66 from GEC. Their baseplate has 7 pins. They are sold factory-paired in pairs.
    349,00 € 290,83 €Ex.
    In Stock
  • Ref : 18292
    In Stock
    These PSVANE KT66GE tubes are power tetrodes from the PSVANE "Legend" series. They are ideal for DIY HiFi design, or as replacements for similar models such as the EL34, 6L6 or, KT77 or the original KT66 from GEC. Their baseplate has 7 pins. They are sold factory-paired in pairs.
    279,00 € 232,50 €Ex.
    In Stock
  • Ref : 16347
    In Stock
    These high-end PSVane T-Series Mark II matched tubes offer exceptional performance. These tubes have a superb design quality and will easily find their place in your audio designs. The inside of the tubes is covered with a carbon layer for better heat dissipation and more stable performance.
    449,00 € 374,17 €Ex.
    In Stock
  • 229,00 € 190,83 €Ex.
    In Stock
  • Ref : 19099
    In Stock
    PSVANE's KT88-Z power tube offers a soft, warm sound, full and natural, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl.
    149,00 € 124,17 €Ex.
    In Stock
  • Ref : 20447
    PSVANE's KT88-Z power tube offers a full and natural sound, with good balance and no background noise. PSVANE offers us a tube with a more pronounced analog texture than conventional tubes, with voices more prominent than usual and an overall sound evocative of vinyl.
    In Stock
  • Ref : 19137
    Psvane's UK-EL34 penthode tube is musical, offering rich, detailed sound without sounding harsh. It's a solid investment for vintage gear, as well as guaranteed to improve the performance of newer equipment.
    89,00 € 74,17 €Ex.
    In Stock
