DDHIFI MD19S USB-C Cable Fast Charging 8cm
The DD HiFi MD19S is an ultra-compact USB-C cable designed for fast charging and data transmission in portable applications.
Reference : 22189
16,90 €tax incl.
14,08 € tax excl.
Shipping date: 25-11-2026.
ddHIFI MD19S USB-C 100W Fast Charging Cable OCC Copper / Silver-Plated OFC DATA 8cm
DD HIFI MD19S
The DD HiFi MD19S is an ultra-compact USB-C cable designed for fast charging and data transmission in portable applications. Measuring just 8cm in length and weighing only 8g, it is the ideal solution for connecting a smartphone, portable DAC, digital audio player, or power bank without creating excess cable clutter.
Its construction is based on a flat parallel 3-conductor architecture using high-purity OCC copper conductors for the power lines, combined with a silver-plated OFC copper-shielded data section to minimize interference and preserve signal integrity.
The MD19S supports up to 100W charging power, enabling fast charging of USB Power Delivery compatible devices. Its 21.3 AWG power conductors provide low resistance, while the 22.3 AWG data lines ensure reliable signal transmission.
SoftFlex PVC insulation provides excellent flexibility and durability for everyday use, complemented by premium FEP insulation on the main conductors for both high- and low-temperature resistance. Compact, durable, and discreet, the DD HiFi MD19S is perfectly suited to portable setups where minimizing cable bulk is essential.
Please note that the cable's DATA section is not OTG compatible. This means it is only compatible with DAC/AMPs featuring a built-in OTG USB Audio circuit, or with devices that use a separate USB Audio interface and USB power input for charging.
Technical Specifications
Product TypeUSB-C Cable
Connectors2x USB-C
OTG DATA
Cable ConstructionFlat Parallel 3-Wire Design
InsulationSoftFlex PVC
Conductor Gauge (DATA)22.3 AWG (D+), 22.3 AWG (D-)
Conductor Material (DATA)High-Purity OCC
Shielding Material21.5 AWG Silver-Plated OFC
Conductor Gauge (POWER)21.3 AWG (V+), 21.3 AWG (G)
Conductor Material (POWER)High-Purity OCC Copper
Conductor Cross-Section0.382mm² ×2
Conductor InsulationPremium FEP Insulation Resistant to High and Low Temperatures
Maximum Charging Power100W
Length8cm
Weight8g
Package Contents1x DD HIFI MD19S
Length (m)0.08
ShieldingYes
Section (mm²)0.326
Section (mm²)0.410
ConnectorUSB-C
DDHIFI MD19S USB-C Cable Fast Charging 100W OCC Copper / Silver-Plated OFC Data 8cm
