KECES EPHONO+ Phono Preamplifier MM/MC/Optical
The Keces Ephono+ is a phono amplifier with a separate power supply, designed to provide precise amplification of analogue cartridges whilst isolating sensitive circuits from electrical interference. It utilises a remote power supply architecture incorporating an in-house developed H-Sonic toroidal transformer, whose design minimises noise and stabilises the voltage to ensure consistent operation of the gain stages.
By buying this product you get 119 loyalty points
Reference : 21700
1 199,00 €tax incl.
999,17 € tax excl.
Keces Ephono+ Phono Preamplifier MM/MC/Optical
Keces Ephono+ : Front view
This approach is complemented by extensive compatibility, incorporating MM/MC inputs as well as dedicated support for DS Audio optical cartridges, allowing the amplification to be adapted to different playback technologies. Impedance and gain adjustment, up to 72 dB in MC mode, allows for precise adjustment of level and load, whilst the balanced XLR outputs (lockable Neutrik connectors) and gold-plated single-ended RCA outputs ensure flexible integration into various systems. In line with this, the switchable high-pass filter limits unwanted low-frequency noise from the vinyl record, whilst the low-noise linear power supply incorporates thermal protection (OTP) to ensure stable, long-term operation.
Product typePhono preamplifier
Inputs2x Stereo RCA
Output1x Stereo RCA
1x Stereo XLR
Total harmonic distortion (THD)MM: 0.02%
MC: 0.05%
Optique: 0.04%
Signal-to-noise ratio (SNR)MM: 78dB
MC: 70dB
Optique: 75dB
Frequency response20Hz-20kHz
Input impedanceMM: 47kΩ
MC: 56Ω / 100Ω / 220Ω
Input capacitance100pF
GainMM: 46dB / 52dB
MC: 66dB / 72dB
Optique: 30dB
Power supplyPhono amplifier: 24V DC
Power supply stage: 110V-120V AC, 60Hz / 220V-240V AC, 50Hz (Switchable)
DimensionsPhono amplifier: 220 x 220 x 66mm
Power supply stage: 220 x 220 x 66mm
WeightPhono amplifier: 2kg
Power supply stage: 3kg
Package1x Keces Ephono+ phono amplifier
1x Keces Ephono+ power supply stage
ClassN/A
The Keces Ephono+ is a phono amplifier with a separate power supply, designed to provide precise amplification of analogue cartridges whilst...
