100% Aluminum 260 x 170 x 70mm
This brushed aluminum case with silver front is ideal for integrating an amplifier or any other audio setup. With a professional quality design, this case is robust and durable, and will effectively protect your components. The case is pre-drilled: there is a space on the back panel to fix an IEC socket and 6 holes for RCA. The front panel allows the installation of a push button as well as a rotary switch.
| Specifications | |
| Product type | DIY Case |
| Material | Brushed Aluminum |
| External dimensions | 260 x 170 x 70mm |
| Internal dimensions | 250 x 153 x 59mm |
| Panels thickness | Front panel: 8mm Rear panel: 3mm Others panels: 4.7mm |
| Drillings | Rear panel: 6x RCA Ø11mm 1x IEC 27.8 x 32mm Front panel: 1x Ø13.5mm 1x Ø7mm |
| Color | Front panel: Silver Others panels: Black |
