EVERSOLO AMP-F8 Amplifier
The Eversolo AMP-F8 is a stereo Class AB power amplifier, designed to drive demanding speakers with a stable and controlled reproduction. It delivers 2×180W into 8Ω and 2×280W into 4Ω in stereo mode, while its bridged mode reaches 500W into 8Ω, thanks to an 800W linear toroidal power supply.
By buying this product you get 179 loyalty points
Reference : 22473
1 799,00 €tax incl.
1 499,17 € tax excl.
EverSolo AMP-F8 Class AB Amplifier 2x280W 4Ω / 1x500W 8Ω
EVERSOLO AMP-F8: Front view
Intended for two-channel Hi-Fi systems as well as scalable installations, it combines balanced XLR and unbalanced RCA connectivity with a discrete amplification architecture, a damping factor greater than 400 and a signal-to-noise ratio of 115dB. This design promotes accurate reproduction, good speaker control and a stable output, including with high-power speakers or in open listening spaces.
Eversolo AMP-F8: Power reserve suited to demanding speakers
The Eversolo AMP-F8 is a stereo Class AB power amplifier, designed to drive high-demand speakers with a stable and controlled reproduction. It delivers 2 × 180W into 8Ω and 2 × 280W into 4Ω in stereo mode, while its bridged mode reaches 500W into 8 Ω, allowing it to drive floorstanding speakers or setups installed in more open listening spaces.
EVERSOLO AMP-F8: Rear view
Eversolo AMP-F8: A faithful and silent reproduction
With a THD+N rate of 0.003% and a signal-to-noise ratio of 115dB, the AMP-F8 limits signal coloration and maintains a clean sonic background. This low noise footprint promotes the perception of instrumental textures, vocal articulation, note decays and the different planes of the soundstage.
Eversolo AMP-F8: An 800W linear power supply
The AMP-F8 features an 800W toroidal linear power supply, combined with an independent design for the left and right channels. This separation limits interactions between channels and helps stabilize the stereo image, bass control as well as the reproduction of mids and highs. Beyond this energy reserve, a set of 24 audio filtering capacitors reduces residual ripple and allows a fast response during dynamic peaks.
EVERSOLO AMP-F8: Capacitors
EVERSOLO AMP-F8: Power Bass
Eversolo AMP-F8: Precise bass control
With a damping factor greater than 400, the AMP-F8 keeps the bass drivers under control, including with complex loads and large-diameter woofers. This control improves transient accuracy, promotes deeper extension and allows the bass to retain sharp definition during high-level listening.
Eversolo AMP-F8: Parallel Class AB amplification
Each channel uses three pairs of high-current power MOSFETs, selected for their consistency and mounted in a parallel architecture. This configuration distributes current more efficiently, reduces the risk of distortion and preserves linearity across different impedances, while maintaining a smooth and natural sonic texture.
EVERSOLO AMP-F8: MOSFET transistors
EVERSOLO AMP-F8: RCA and XLR input
Eversolo AMP-F8: Connectivity suited to Hi-Fi systems
The AMP-F8 offers balanced XLR and unbalanced RCA inputs, allowing it to be connected to a preamplifier, a DAC or a high-end source. This dual connectivity facilitates its integration into a two-channel stereo system as well as an existing installation intended to evolve gradually.
Eversolo AMP-F8: Integrated protection
A DC blocking circuit limits the influence of a DC component present on the mains at the toroidal transformer level. This protection reduces the mechanical vibrations that may appear in the transformer as well as the associated interference, providing the amplification stage with a more stable power base.
EVERSOLO AMP-F8: Transformer
Eversolo AMP-F8: A chassis designed for heat dissipation
Machined from premium-grade aluminum, the chassis combines a rigid structure, an anodized and sandblasted finish as well as thick walls. This construction helps limit mechanical resonances, promote heat evacuation and reinforce electromagnetic shielding, while the internal layout maintains a stable temperature during extended listening.
Eversolo AMP-F8: Analog VU meters
The analog VU meters on the front panel track the signal level variations in real time and add a direct visual reading of the musical activity. This function integrates into a clean front panel, while the reinforced speaker terminals and the optimized thermal design ensure a secure connection and consistent operation during daily use or high-power listening.
EVERSOLO AMP-F8: VU meters
Technical specifications
Product typePower amplifiers
Inputs1x stereo RCA
1x stereo XLR
OutputsSpeaker terminals
SNR≥ 115dB (A-weighted)
Frequency response10Hz–30kHz (±0.5dB, @ 1W/8Ω)
Output powerStereo: 2x 180W RMS @ 8Ω
Stereo: 2x 280W RMS @ 4Ω
Bridged: 500W RMS @ 8Ω
Amplification chip6x MOSFET / channel
Amplification typeClass AB
Input sensitivityXLR: 5.2V (23dB Gain) / 2.6V (29dB Gain)
RCA: 2.65V (23dB Gain) / 1.3V (29dB Gain)
Input impedance10kΩ
THD+N0.003% (@1kHz)
Crosstalk≤ -95dB (180W @8Ω / 1kHz)
Damping factor> 400 (@8Ω, 1kHz)
Supply voltage100V–120V 60Hz / 220V–240V 50Hz
Consumption1200W
Dimensions265 × 388 × 119mm
Weight15.9kg
Package1x Eversolo AMP-F8
1x Trigger cable
1x Power cable
InputXLR
OutputSpeaker terminal
Channel2 (Stereo)
ClassClass A / AB
Amplifier chipTransistors
Power (W)500.0
Power (W)280
EVERSOLO AMP-F8 Amplifier Class AB 2x280W 4Ω / 1x500W 8Ω
The Eversolo AMP-F8 is a stereo Class AB power amplifier, designed to drive demanding speakers with a stable and controlled reproduction. It...
