By buying this product you get 549 loyalty points
The Gustard C26 Ultra is an external OCXO master clock designed to provide a 10MHz reference to compatible digital audio devices. Its oven-controlled crystal oscillator, combined with a low phase noise output circuit, aims to ensure stable distribution of the clock signal.
Intended for systems incorporating several components fitted with an external 10 MHz input, it offers four outputs with matching for 50Ω and 75Ω impedances. Its built-in linear power supply and vibration control features complete the design, making it possible to centralize the synchronization of compatible devices within a single setup.
The Gustard C26 Ultra is an external master clock designed to provide a 10MHz reference signal to compatible digital audio devices, such as DACs and digital-to-digital converters. Its OCXO crystal oscillator keeps the crystal at a controlled temperature to stabilize its operation, while the circuit design aims to limit phase noise. It can thus serve as a common reference for several components of a digital system, provided they feature a compatible 10 MHz clock input.
A dedicated driver circuit conditions and distributes the oscillator signal to the outputs, in order to preserve its characteristics during transmission to the connected devices. This architecture allows the C26 Ultra to provide four square wave clock outputs, with automatic matching for 50Ω and 75Ω impedances. It thus enables the simultaneous synchronization of several compatible components from a single reference.
The C26 Ultra incorporates a linear power supply designed specifically for its clock circuit. This architecture aims to provide a stable, low-noise supply to the sensitive stages, in order to support consistent operation of the oscillator and output circuit. As the power supply is built in, the device can be installed as a standalone reference clock in a digital system.
Beyond the OCXO's own thermal regulation, the C26 Ultra combines several layers of insulation around the oscillator and associated components, in order to limit thermal disturbances that may affect the signal. Its vibration dissipation system is based on a multilayer composite structure, while flexible internal connections reduce the transmission of vibrations to the oscillator. This design aims to preserve clock stability in its installation environment.
The outputs of the C26 Ultra rely on dedicated connectors and flexible internal cables, in order to limit the mechanical transfer of vibrations along the signal path. The four outputs allow several devices with an external 10MHz input to be connected, while support for 50Ω and 75Ω impedances facilitates integration with various equipment.
Technical specifications
| Specifications | |
| Product type | Audio clock |
| Outputs | 4x BNC |
| Oscillator | OCXO |
| Output frequency | 10MHz |
| Output waveform | Square wave |
| Output impedance | 50Ω / 75Ω (Automatic matching) |
| Phase noise | -123dB |
| Short-term frequency stability | 9×10⁻¹⁴ |
| General | |
| Supply voltage | 100-240V AC, 50/60Hz |
| Consumption | < 15W |
| Dimensions | 330 x 260 x 65mm |
| Weight | 6.5kg |
| Color | Black |
| Package | 1x Gustard C26 Ultra 1x Power cable |
