GUSTARD C26 Low Noise OCXO Clock 10MHz Silver
New
The Gustard C26 is an external OCXO master clock designed to provide a 10 MHz reference to compatible digital audio devices. Its oven-controlled crystal oscillator, combined with a low phase noise output circuit, aims to ensure stable distribution of the clock signal.
By buying this product you get 359 loyalty points
Reference : 22744
3 590,00 €tax incl.
2 991,67 € tax excl.
Gustard C26 Low Noise OCXO Clock 10MHz Silver
GUSTARD C26: Front view
The Gustard C26 is an external OCXO master clock designed to provide a 10MHz reference to compatible digital audio devices. Its oven-controlled crystal oscillator, combined with a low phase noise output circuit, aims to ensure stable distribution of the clock signal.
Intended for systems incorporating several components fitted with an external 10MHz input, it offers four outputs with matching for 50Ω and 75Ω impedances. Its built-in linear power supply and vibration control features complete the design, making it possible to centralize the synchronization of compatible devices within a single setup.
Gustard C26: 10 MHz OCXO Clock
The Gustard C26 is an external master clock designed to provide a 10MHz reference signal to compatible digital audio devices, such as DACs and digital-to-digital converters. Its OCXO crystal oscillator keeps the crystal at a controlled temperature to stabilize its operation, while the circuit design aims to limit phase noise. It can thus serve as a common reference for several components of a digital system, provided they feature a compatible 10MHz clock input.
GUSTARD C26: OCXO Clock
GUSTARD C26: Output stage
Gustard C26: Low phase noise output circuit
A dedicated driver circuit conditions and distributes the oscillator signal to the outputs, in order to preserve its characteristics during transmission to the connected devices. This architecture allows the C26 to provide four square wave clock outputs, with automatic matching for 50Ω and 75Ω impedances. It thus enables the simultaneous synchronization of several compatible components from a single reference.
Gustard C26: Built-in linear power supply
The C26 incorporates a linear power supply designed specifically for its clock circuit. This architecture aims to provide a stable, low-noise supply to the sensitive stages, in order to support consistent operation of the oscillator and output circuit. As the power supply is built in, the device can be installed as a standalone reference clock in a digital system.
GUSTARD C26: Linear power supply
GUSTARD C26: Insulation
Gustard C26: Thermal insulation and vibration control
Beyond the OCXO's own thermal regulation, the C26 combines several layers of insulation around the oscillator and associated components, in order to limit thermal disturbances that may affect the signal. Its vibration dissipation system is based on a multilayer composite structure, while flexible internal connections reduce the transmission of vibrations to the oscillator. This design aims to preserve clock stability in its installation environment.
Gustard C26: Dedicated output connectors
The outputs of the C26 rely on dedicated connectors and flexible internal cables, in order to limit the mechanical transfer of vibrations along the signal path. The four outputs allow several devices with an external 10MHz input to be connected, while support for 50Ω and 75Ω impedances facilitates integration with various equipment.
GUSTARD C26: Internal wiring
Technical specifications
Product typeAudio clock
Outputs4x BNC
OscillatorOCXO
Output frequency10MHz
Output waveformSquare wave
Output impedance50Ω / 75Ω (Automatic matching)
Phase noise-118dB
Short-term frequency stability4×10⁻¹³
Supply voltage100-240V AC, 50/60Hz
Consumption< 15W
Dimensions330 x 260 x 65mm
Weight6.5kg
ColorArgent
Package1x Gustard C26
1x Power cable
The Gustard C26 is an external OCXO master clock designed to provide a 10 MHz reference to compatible digital audio devices. Its oven-controlled...
