AUNE AR5000 MKII Open-Back Dynamic Headphone
New
Aune unveils here the MKII version of its AR5000 headphones. It is also an open-back headphone featuring a dynamic MLD ("Multi-Layer Distributed") driver measuring no less than Ø50mm. However, Aune has decided to improve certain aspects such as the dynamic driver and the overall acoustic architecture of the headphones for a better frequency response with extended and detailed highs as well as deeper bass.
By buying this product you get 36 loyalty points
Reference : 21930
369,00 €tax incl.
307,50 € tax excl.
Shipping date: 12-06-2026.
Aune AR5000 MKII Open-Back Dynamic Headphones 28 Ohms 112dB 5Hz-43500Hz
Photo of the AUNE AR5000 MKII
Aune unveils here the MKII version of its AR5000 headphones. It is also an open-back headphone featuring a dynamic MLD ("Multi-Layer Distributed") driver measuring no less than Ø50mm. However, Aune has decided to improve certain aspects such as the dynamic driver and the overall acoustic architecture of the headphones for a better frequency response with extended and detailed highs as well as deeper bass. The MKII version retains a high-angle acoustic structure for clear and detailed sound reproduction. Its 28-ohm impedance and 112dB sensitivity make it easy to drive. In addition, it benefits from a detachable cable with interchangeable termination, allowing a high level of compatibility with various headphone amplifiers.
Frequency response of the AUNE AR5000 MKII
Aune AR5000 MKII: Dynamic Driver with MLD Diaphragm
The Ø50mm dynamic driver with MLD diaphragm of the Aune AR5000 MKII offers a balance between rigidity and damping, significantly reducing distortion across the entire frequency response range. The result is transparency and a high level of detail. Its optimization through new materials and surface treatments enables extended high-frequency performance.
AUNE AR5000 MKII: Dynamic Driver with MLD Diaphragm
AUNE AR5000 MKII: More Bass and Dynamics
Aune AR5000 MKII: More Bass and Dynamics
A new airflow management system and a new magnetic circuit structure provide better linearity and deeper bass.
Aune AR5000 MKII: Interchangeable Connectivity
The Aune AR5000 MKII features a high-end detachable cable with OFC copper conductors and a Litz wire structure. In addition, its interchangeable 6.35mm jack, 3.5mm jack, and balanced 4.4mm jack terminations provide a high level of compatibility.
AUNE AR5000 MKII: Interchangeable Connectivity
Technical Specifications
Product TypeHeadphones
Headphone TypeOpen-Back
DriverDynamic with MLD technology
Frequency Response28 ohms
Nominal Impedance28 ohms
Sensitivity112dB SPL @ 1kHz/1Vrms
THD<0.03% @ 1kHz
Detachable Cable
Headphone Connectors2x 3.5mm Jack
Interchangeable Termination1x 3.5mm Jack
1x 6.35mm Jack
1x Balanced 4.4mm Jack
Cable Length1.5m
Dimensions224 x 238 x 122mm
Weight365g
Package Contents1x Aune AR5000 MKII
1x 2x 3.5mm Jack Cable with Interchangeable Termination
1x 3.5mm Jack Termination
1x 6.35mm Jack Termination
1x Balanced 4.4mm Jack Termination
ColorChampagne
Impedance (Ω)28
Efficiency / Sensitivity (dB)112.0
Lowest frequency (Hz)5
Highest frequency (Hz)43500
WirelessNo
Cable terminationJack 4.4mm
Cable terminationJack 3.5mm
Cable terminationJack 6.35mm
Headphone / Earphone connectorJack 3.5mm
AUNE AR5000 MKII Open-Back Dynamic Headphone 28 Ohms 112dB 5Hz–43500Hz
Aune unveils here the MKII version of its AR5000 headphones. It is also an open-back headphone featuring a dynamic MLD ("Multi-Layer...
