OYAIDE TUNAMI TERZO V2 Interconnect Cable
The Oyaide TUNAMI TERZO V2 is a premium interconnect cable designed to ensure very-low-loss analogue transmission with high immunity to interference. It relies on a 102SSC copper conductor with a 1.25mm² cross-section combined with a dense-geometry 3E structure, while integrating a triple shield and low-dielectric-constant polyolefin insulation to stabilise electrical parameters and limit parasitic interactions across the full spectrum.
Reference : 22198
74,91 €tax incl.
62,42 € tax excl.
Shipping date: 24-11-2026.
Cable sold per metre
Oyaide TUNAMI TERZO V2 Shielded Balanced Interconnect Cable Copper 2x1mm² Ø8.0mm
Oyaide TUNAMI TERZO V2 : Front view
Intended for demanding high-fidelity systems, it combines high conduction capacity, advanced interference management and control of mechanical phenomena, preserving signal integrity even in complex electromagnetic environments. This approach enables it to serve as a critical link within an audio chain, while maintaining electrical consistency and reproduction stability suited to the most sensitive configurations.
Oyaide TUNAMI TERZO V2 : Internal structure
Oyaide TUNAMI TERZO V2: 102SSC Conductor and 3E Structure
The TUNAMI TERZO V2 relies on the 102SSC conductor in primary copper conforming to JIS C1011, whose treatment via full pickling and diamond drawing refines the strand surface to facilitate signal propagation across its active layer. This approach is extended by a double annealing operation eliminating internal mechanical stress, while manufacturing precision of ±1µm ensures structural homogeneity directly correlated to a conductivity of 102.3% IACS.
Beyond material purity, the "3E Stranded" technology organises three strand diameters according to a dense concentric geometry, allowing the reduction of internal gaps and achievement of a perfectly circular cross-section. This structural regularity ensures uniform adhesion with the insulation, limiting dielectric variations and ensuring constant electrical stability in high-level analogue links.
Oyaide TUNAMI TERZO V2: Enhanced cross-section and polyolefin insulation
The cable adopts a conductor cross-section of 1.25mm², the largest among the brand's signal cables, thus reducing transmission losses by lowering linear resistance. This increased conduction capacity results in better signal integrity over longer distances or in low-level configurations, while maintaining stable dynamics.
This approach is extended through the use of a polyolefin polymer insulation, whose dielectric constant — approximately four times lower than PVC — limits energy storage and signal lag effects.
Oyaide TUNAMI TERZO V2: Triple shield
The TUNAMI TERZO V2 integrates a three-layer complementary shield architecture, effectively isolating the signal from external and internal electromagnetic interference. The first layer uses an electromagnetic wave absorber that converts magnetic flux-related disturbances into thermal energy, thus reducing their impact on transmission.
This approach is reinforced by a second copper foil layer providing continuous screening against external interference, while the third layer — a horizontally wound 102SSC shield composed of 160 strands of 0.12mm — acts against both external noise and internal noise generated by micro-vibrations or discharge phenomena. This hierarchical combination maintains a stable electromagnetic environment around the conductor, a necessary condition for precise analogue transmission in complex high-fidelity systems.
Oyaide TUNAMI TERZO V2 : PU outer jacket
The assembly is protected by a pearl-white polyurethane outer jacket, selected for its mechanical strength and stability over time, while ensuring effective protection against external stresses. This jacket contributes to maintaining the structural integrity of the cable, thus extending the benefits of internal design choices in terms of electrical stability and vibration management.
This coherence between conductor, insulation and shield enables the TUNAMI TERZO V2 to maintain constant parameters in real-world conditions, facilitating its integration into systems where control of losses, interference and mechanical phenomena directly influences the quality of sound reproduction.
Product typeSignal cable
Number of conductors2
Conductor cross-section2x1mm²
Conductor material102SSC copper
Insulation materialPolyolefin polymer
Shield1st layer: polyolefin EMI-absorbing material
2nd layer: copper foil
3rd layer: 102SSC copper braided sleeve (160 / 0.12mm)
Outer jacket materialPolyurethane
Cable diameter (nominal)Ø8mm
ColorWhite
PackageSold per metre
Diameter (mm)8.0
ShieldingYes
Section (mm²)1.00
Ground / ShieldingYes
OYAIDE TUNAMI TERZO V2 Shielded Balanced Interconnect Cable Copper 2x1mm² Ø8.0mm
The Oyaide TUNAMI TERZO V2 is a premium interconnect cable designed to ensure very-low-loss analogue transmission with high immunity to...
