FLAGSHIP KIMBERS Speaker Terminals (Pair)
These Flagship Kimbers speaker terminal are designed using high-quality materials. Their contacts are made of pure copper, while the clamping nut is made of brass and their body is made of black steel. The result is a robust speaker terminal with high conductivity.
Reference : 21196
24,90 €tax incl.
20,75 € tax excl.
Shipping date: 24-11-2026.
Flagship Kimbers Speaker Terminals Pure Copper Ø15.4 x 64mm (Pair)
Photo of FLAGSHIP KIMBERS terminal blocks
These Flagship Kimbers binding posts are designed using high-quality materials. Their contacts are made of pure copper, while the clamping nut is made of brass and their body is made of black steel. The result is a robust speaker terminal with high conductivity. Furthermore, their aesthetic appeal offers a unique feature for anyone looking for original and distinctive terminals. They are compatible with banana plugs, bare wires, and 8mm spades.
Dimensions of FLAGSHIP KIMBERS speaker terminals
Product typeSpeaker terminal
Contact materialPure copper
Maximum internal conductor diameterØ4mm
Maximum panel thickness18mm
Drill diameterApprox. 8mm
MountingTo screw
Total dimensionsØ15.4 x 64mm
PackageSold by pair
Mounting typeTo screw
ConnecticFemale
Max panel thickness (mm)18.0
Accepts Banana PlugsYes
ConnectorSpeaker terminal
Des borniers solides.
Une mise en oeuvre aisée: serrage parfait sur les câbles internes de mes JMlab 706 Opale, serrage aisé sur mes câbles d'enceintes...du solide et surtout des contacts en cuivre. Pourquoi se ruiner en câbles d'enceintes coûteux pour les connecter sur de la vulgaire ferraille ?
This review has been posted for FLAGSHIP KIMBERS Speaker Terminals Pure Copper Ø15.4 x 64mm (Pair)
These Flagship Kimbers  speaker  terminal are designed using high-quality materials. Their contacts are made of pure copper,...
