VIABLUE ROTATION PROTECTOR Anti-Rotation Protection for T8 Binding Post (Pair)
The VIABLUE Rotation Protector is an anti-rotation protection and mechanical locking device designed for speaker binding posts and connection terminals, particularly suited to VIABLUE T8 binding posts.
Reference : 22337
29,90 €tax incl.
24,92 € tax excl.
VIABLUE ROTATION PROTECTOR Anti-Rotation Protection for T8 Speaker Binding Posts (Pair)
Sold in pairs, this accessory securely holds the binding posts in place and prevents them from rotating when tightening spade connectors, a common issue with traditional binding posts mounted in circular openings. VIABLUE T8 binding posts feature a specific design with flattened threads on their upper and lower sides, allowing them to fit perfectly into the oblong openings of the Rotation Protector for optimal stabilization. Made of polyamide (PA), this device combines excellent mechanical strength, a break-resistant matte satin finish, and very good vibration absorption properties. For discreet and efficient integration, it is installed inside the loudspeaker cabinet or connection panel by sliding it onto the threaded section of the binding posts before securing it with the toothed washer and nut. Measuring 67 x 20 x 3.2 mm, it is compatible with center-to-center spacing between 17 mm and 45 mm, providing excellent versatility for a wide range of speaker binding post configurations.
Technical Specifications
Product TypeAnti-Rotation Protection for Speaker Binding Posts
MaterialPolyamide (PA)
Dimensions67 x 20 x 3.2mm / 2.6 x 0.8 x 0.1“
Minimum Distance Between Connection Terminals (Center-to-Center)17mm / 0.7"
Maximum Distance Between Connection Terminals (Center-to-Center)45mm / 1.8"
CompatibilityVIABLUE T8 Speaker Binding Posts
PackagingSold in Pairs
Mounting typeN/A
ConnecticN/A
Max panel thickness (mm)N/A
Accepts Banana PlugsN/A
ConnectorN/A
Contacts Plating (Connector)N/A
The VIABLUE Rotation Protector is an anti-rotation protection and mechanical locking device designed for speaker binding posts and connection...
