VIABLUE T8 BINDING POST Speaker Terminals (Pair)
These Viablue T8 Binding Posts offer excellent design quality, maximising the contact surface with banana plugs and spades to minimise contact resistance. The pure copper contacts are gold-plated to provide flawless resistance to oxidation and corrosion. Finally, the Viablue T8 features polyoxymethylene (POM) insulation and a satin aluminium outer shell, combining technical excellence with refined aesthetics.
Reference : 21413
75,00 €tax incl.
62,50 € tax excl.
Shipping date: 24-11-2026.
Viablue T8 Binding Post Gold-Plated Copper Speaker Terminals (Pair)
Viablue T8 Binding Post : Front view
These Viablue T8 Binding Post offer excellent design quality, maximising the contact surface with banana plugs and spades to minimise contact resistance. The pure copper contacts are gold-plated to provide flawless resistance to oxidation and corrosion. Finally, the Viablue T8 features polyoxymethylene (POM) insulation and a satin aluminium outer shell, combining technical excellence with refined aesthetics.
Product typeSpeaker terminals
Contact materialPure copper
Contact platingGold
Insulation disc diameterØ18mm
Minimum thickness of mounting panel5mm
Mounting hole diameterØ11.8–12.2 mm
Internal cable mountingTo solder
Diameter of the welded joint4.9 mm
Overall dimensionsØ15.6 x 69mm
PackageSold in pairs (1x socket with red ring, 1x socket with black ring)
Mounting typeTo weld
ConnecticFemale
Max panel thickness (mm)N/A
Accepts Banana PlugsYes
ConnectorSpeaker terminal
VIABLUE T8 BINDING POST Speaker Terminals Gold Plated Copper (Pair)
These Viablue T8 Binding Posts offer excellent design quality, maximising the contact surface with banana plugs and spades to minimise contact...
